I'll be doing the following, newish Miniart kit. It has a full interior so I am going to come up with a way of displaying it so the interior won't go to waste.. Maybe a garage scene.....
p?i=9e4125bef56b093ec3f6b0691ef5414c
Edited by Stef N.
Scene not seen. With not woth too.
  • Like 18
Yes, I really want to see how this turns out. At some point, I'll probably pick up one of these, though without an interior.
John.
Cheers Paul, Craig and John. It's going to be a puzzle to see how to show off the interior, especially the great looking engine, but something I'll figure out as I go along.👍
Nice one Stef, I’ll be doing the exact same model, but can’t start until I get back from a short break. Mine will be just a straight build, hopefully will finish in time and I’ll do different markings to you….
all the best
Ed
Ooh a full interior build!  Let me grab a chair, brew and snacks! :popcorn:
As for how to display, may I refer you to my Sherman build and the use of brass rods?
Keith ☺️
Keith ☺️
Thanks Keith and welcome along. I had thought of your Sherman as good way of doing it. Definitely on the shortlist. 👍👍
Hi Stef. It's great to have you taking part in this GB with what is an excellent choice of kit. I haven't seen this MiniArt kit before, so I'm looking forward to following your progress.
Kind regards,
Stix
Now back off my holiday so I can get this started or looked at to be precise.
Here are the box contents for starters. Once unwrapped there are more than I thought. There was a bit of broken plastic in the bag but I won't find out where it came from for a while.
p?i=0e8f0b41d91438c8253dfe4a30a5fcdf
The instructions look very nicely printed.
p?i=cd32daeace6cadead20d4b5d7914d17a
And I will be keeping the markings very simple, so a British trainer with basic codes will do.
p?i=f30927cc5275cafc7520460fa20e438a
It says US Olive Drab as the overall colour. Any help if this would be an appropriate colour would be appreciated.
Cheers all.👍
  • Like 10
You're trying to open that can of worms again. I did the same thing with a question here;
I'll definitely be following this one, as I've not built one of these before. Good luck with the build Stef.
John.
Yes, that is a big can of worms. 😬🤣
A shame that Tamiya OD is way off, I've got pots of that. I will look for the Mr Hobby ones suggested.
Cheers and thanks for the info. 👍👍
As in XF-62?
I don't know that it's 'way off'   @Casey   maybe able to help here,  it's maybe greener than you would want,  but OD did vary.
As do Tamiya paints, IIRC there was wailing and gnashing of teeth when they changed the formula.
If you are really bothered about colour,  you need to get some actual samples,  @Mike Starmer  books on British armour colours do have actual paint chips in them, including OD.No9
see also
https://mafva.co.uk/?p=2607
U.S. ARMY CORPS OF ENGINEERS COLOUR.
No.319/ No 9 Olive Drab
Mix:  7 x Humbrol 46 + 3 x Humbrol 33 + 1 x Humbrol 155.
Alternative;  5 x Revell 46 + 7 x Revell 310 3 x Revell 361
In use: 1942-45 on Lend Lease vehicles on its own or, in Italy with Light Mud or rarely Black.
Description:  Varies with application and fading.  Nearest WW2 match is FS595b 33070.  A very dark drab when new with a green hint, fading brown or grey in use.  When fresh, this is very similar to S.C.C.15 in British colours.  Despite being widely cited as a match, FS595a 34087 is the 1950-70s colour which is too brown and light
If you find XF-62 too green, maybe add some XF-10 to brown it a bit.     Just make sure you mix enough for the the entire model !
I'd suggest  4 parts xf-62 to 1 part XF-10  may get you in the area,  from a look at the FS 33070 chip, and memory of the paint colour....   though my plans for paint this afternoon are large amounts of white for some DIY
HTH
HTH
4 minutes ago, Troy Smith said:
As in XF-62?
see also
HTH
HTH
Thanks for that info and the mix. I'm a complete novice when it comes to British/US armour colours so this all helps.👍
Would be much easier if I had a good real OD.9 paint sample :) And as you said, there's plenty of OD's.
But the one thing is, - those colors are difficult to make without real earth pigments, and this makes a lot of modeler paints inaccurate, which compounds on the problem that those colors are in the most color sensitive spectrum of human vision - we are much more able to see color difference between two OD's than between two Insignia Yellows.
Also, I noticed that Tamiya's differ in time. I have bottles across years that have very different colors :(
@Mike Starmer  says
"Nearest WW2 match is FS595b 33070"
Which is at least a starting point,  I had a look in daylight when I posted,  hence my mental guesstimate of 4 part XF62 to 1 part of XF10...
 I had no time to try this out so may give you a laugh to see how far out I am...
22 minutes ago, modelling minion said:
Thats a very large amount of parts Stef, quite daunting!
It looked sensible when it was wrapped in plastic. I get the feeling it's going to be fiddly. 😂
It looks like a carpet monster next meal! :D
Edited by Casey
  • Haha 5
WOW! I think you may have more parts there than the rest of us combined!! :hypnotised:
I'm looking forward to seeing it all go together.
Kind regards,
Stix
  • Haha 4
Kind regards,
Stix
Cheers Stix. I may have bitten off more than I can chew. Hopefully 3 months is enough. 🤣👍
Rather you than me, Stef!
I shall enjoy following your build from a safe distance.. 😄
Ear protectors on. 😂
Cheers Ian, I should be cracking on with this by next week. Just finishing up another project which is nearly there. 👍
Yes, you are right. I have two pots of Tamiya, one new, one over ten years old and they are different colours. I'll try one straight up and one with the mix Troy suggested. 👍👍
Anyway I have started the kit. First step nearly done, 128 to go. I'll get some photos up to show you the lovely details. 😲😁
