rafalbert Posted September 5 Posted September 5 Hi guys, I may regret this but I am in with the Mikromir Valiant. I know there is a bit of work to do with this kit and I have a lot of others in progress at the moment so it should be fun trying to fit it in. It may be a couple of weeks before I start but we will see how it goes. Dave 11
Adam Poultney Posted September 6 Posted September 6 Should be a good thread! Once it's over, perhaps you should reward yourself with a much nicer GWH Valiant
JOCKNEY Posted September 6 Posted September 6 Great stuff Dave I've never built a Mikromir kit before so look forward to seeing how this one turns out Cheers Pat
rafalbert Posted September 30 Author Posted September 30 As there are two of us building this kit, hopefully between us we will beat it into submission! As @exdraken said, the fit of the intakes is less than stellar and has taken a bit of fettling to get them to fit to a reasonable standard. More fettling is needed to sort out the join profile but I guess I knew this one wasn't going to be that straight forward. Reading @robvulcan's build, I definitely could do with a set of those wonderful intakes he created! Sadly, I do not have the skills or the patience to achieve anything close to that so out with the filler and sanding stick again. 5 1
rafalbert Posted October 20 Author Posted October 20 Now the Defiant has been completed I can devote more time to this project. The fuselage is now closed up with the seams still needing some attention. As @exdraken has mentioned, the canopy seems to fit surprisingly well, but it will still hide the cockpit detail nonetheless. Looking at the pitot tubes provided in the kit, I think I will also follow his lead and order some aftermarket replacements. 6
rafalbert Posted November 5 Author Posted November 5 I am at a similar stage to @exdraken, the overall shape is now there with liberal amounts of filler required to blend it all in. I need to do a bit more polishing of the surfaces and give the whole thing a coat of primer to see how the joins look. I too will be using the KV masks, it would be way too much hassle to try doing it on my own. I have also ordered the Master brass pitot tubes as they look to be far better than those provided in the kit. Transparancies, underwing tanks and undercarriage to follow. 9
JOCKNEY Posted Friday at 10:44 PM Posted Friday at 10:44 PM Hi Have you had a chance to make any more progress on this one ? Cheers Pat
