M55 203mm Self-Propelled Howitzer (63548) 1:35
Mike
1:35 I Love Kit via Creative Models Ltd
Based upon the chassis and some of the lower hull of a P47 Patton, but with the running gear and hull reversed, it travelled engine-deck first, with a huge turret that had limited traverse overhanging the rear that necessitated changes to the rear of the track run, and had a self-entrenching tool attached to the rear.  It was developed from the earlier M53 that carried a 155mm gun, which it replaced in 1956 with the US Army, serving in Vietnam until the end of the 60s, when it was replaced in turn by the open-topped M110 howitzer after serving with it side-by-side for several years.  The type also served in small numbers with a few NATO states, the last of whom kept it a little longer before it faded into history, scrapyards and museum storage.
It was operated by a crew by six, consisting of a commander, driver and gunner, plus three more crew members to feed the gun with massive shells, of which it could carry just ten in internal storage, and as it was essential that it was required to continue firing for more than twenty minutes (1 round per 2 minutes), it would be accompanied by support vehicles that carried more rounds to feed the beast.  The type was built by Pacific Car & Foundry, and was protected by 25mm/1” of armour, as although it wasn’t expected to be on the frontline, the nature of combat couldn’t always guarantee that it wouldn’t occasionally see limited action, even if it was only sporadic gunfire as a target of opportunity by the Vietcong, as the North Vietnamese army was sometimes known.  Its top speed was a surprising 30mph, but that would reduce markedly on unmade roads or tracks, as 44 tonnes of metal and armour will stress any suspension system.
The Kit
This is a new boxing from another of Trumpeter’s brands, although it’s a strange name for a brand by any usual standards, even if it is descriptive of how we sometimes feel about our stashes.  The kit shares many of the hallmarks of a Hobby Boss kit, which is another of their brands, and arrives in a top-opening box with a painting of the subject on the front.  Inside the box are five sprues and two major parts in sand-coloured styrene, two identical sprues in brown styrene, a blast bag part on its own sprue for the gun in light grey flexible plastic, a tree of sixteen translucent poly-caps, a small clear sprue, two substantial frets of Photo-Etch (PE), a small decal sheet, instruction booklet in black and white, plus a glossy colour painting and decaling guide printed on both sides.  This is an exterior kit, and the detail is good, extending to the link-and-length tracks, and the PE adds more fine detail to the kit, remembering that you’ll need to glue the PE parts in with Super Glue (CA).
Construction begins with the road wheels, making eight pairs of one type, four more of another, and two of a third type, each made from hubs and separate tyres, with a poly-cap trapped between the two wheels for easy installation and removal.  Six pairs of return-rollers are made up, then the hull is prepared with suspension details, four on each side, plus a more complex arrangement at the front, building one for each side from five parts.  A pair of hatches with separate latches are fitted into holes in the rear bulkhead, mounting several small parts around them, including a towing hook and lugs for various eyes, breaking it down into two separate stages.  The suspension arms and stub axles are inserted into each of the axle ports, fitting two suspension struts per side, adding the return-rollers to their sockets, and a single small wheel to the front suspension arm alongside a pair of road wheels, using up the rest of them in specific order on both sides of the hull.  The front bulkhead has two small hatches and eyes installed, building up the drive sprockets from three parts, plus a two-part final drive housing that is glued to the sides of the hull.
The tracks are link-and-length, using a long length on the lower run, plus three shorter sections for the upper run, adding a diagonal section under the drive sprocket, and creating the rounded ends from seven individual links at the front and ten at the rear, plus another two between the diagonal and lower run at the front.  The upper hull is a large part with the turret base in a stepped down area at the rear, and this is detailed with louvred grates that have separate lifting lugs, stowage boxes with separate hatches and handles, two tapering assemblies with PE grilles on the open wider end, and many small parts around the deck and sides.  Two more boxes are built with PE inserts glued into slots within, and their open rear ends house the front light clusters with clear lenses that are fitted on a PE support, adding a PE strip along the sides of the hull so that the PE side skirts can be fixed in place along with several PE fixings per side.  More lifting handles are dotted around the deck, then it is mated to the lower hull, and the travel lock is built from five parts, some without glue, and mounted on slots in the front bulkhead.
The turret is a large moulding, as is the floor, which has two supports that trap the mantlet between it and the upper when they are mated.  A rack with several shelves is attached to the left of the turret before it is closed, covering the projecting edges of the floor at the sides with PE that has tread-plate texture etched into it, bending the edges over to hide the styrene underneath.  A lower door is mounted in the cut-out in the rear, building the upper door with its locking mechanism from seven parts, adding vertical parts with PE sections to the sides, and festooning the turret sides with individual pioneer tools, and more on racks, along with several small parts, which have their shapes magnified in the instruction steps for a better view.  A side hatch is added, and jerry cans are made for either side of the rear door, with a vent on the right side, creating the commander’s cupola from three parts reminiscent of a Patton’s cupola, making the gunner’s hatch from three parts, gluing it in place with another side door beneath it.  More detail parts in styrene and PE are used, and two pairs of track links are fixed to the sides of the mantlet, sliding the two-part gun barrel through the flexible blast-bag after dealing with the seam, which will be eased by ensuring proper alignment of the two halves whilst gluing.  The barrel assembly is slotted into a keyed hole in the mantlet, adding a small searchlight nearby, and completing the detailing of the turret with PE racks on the left side, grab handles and styrene protective cages around parts at the front of the roof.
The self-entrenching blade has two pivots made and linked with a flimsy panel, which is probably best done after locating the pivots on the blade to ensure they are glued at the correct angles.  The blade has several stiffening ribs moulded-in, with three more inserted in slots, joining the blade to the hull using two pegs that slide into the projecting trunnions at the back of the vehicle, passing through holes at the ends of the pivots.  The turret then slots into position on the rear of the deck, but as there aren’t any bayonet lugs, it will be held in place by gravity and will fall out if you invert the model.  The barrel is locked in position with a C-shaped clamp that glues it to the travel lock assembly at the front of the vehicle.
Markings
Two decal options are provided on the sheet, and the only clues to their use and location is given by the serials and the names painted on the barrel.  From the box you can build one of the following:
  • US Marines 233244 ‘Eve of Destruction’
  • US Army 40228648 ‘Tiny Tim’
The decals are printed with good density and sharpness, and only one has two colours, so register isn’t a problem.
Conclusion
The M55 is a bit of a monster, and quite appealing as such.  It served in active combat zones, so can be built in a state of heavy use, and the detail should be enough for most modellers to make the most of.
Highly recommended.
Review sample courtesy of
