Confused and Bemused by "Azure blue" - can anyone help please
5huggy
I have a 1/48 tropical (Mk5) spitfire from Malta and a trop tomahawk (1/72) on the side benches, progressing nicely.
I use Humbrol "ENAMELS"  - and have done for over 45 years!
Both  these models are newish - spit from 1/48 double (with me 109) and Tomahawk last Christmas from Aldi - BOTH are Airfix.
Confused by the fact that both designate 157  Azure blue for the underside. - YEP -Humbrol do 157 in "Acrylic"but not in "Enamel".
There is no info anywhere as to an alternative in enamel!
I have trawled through BM website and not found any real answer -maybe ive missed somewhere
PLEASE pretty please - can anyone tell me either a mix of humbrol enamels or a very close enamel to use
Bemused by the fact that Airfix'/Humbrol (one and the same) - do not warn /advise that the only paints that can be used are "Acrylics".
BUT they they make the Azure 157 in Acrylic - Why? not enamel?
I do not wish to go to acrylics as i have an absolute fortune worth of enamels and all associated venting /breathing equipment (to remove pong!)
I've also learnt over many years how these work .
Humbrol used tro do it as an enamel as well, I have a tin. It was too dark though\
In any case here is discussion right here on Britmodeller about it
Azure Blue discussion
  • Agree 1
1 hour ago, FatFlyHalf said:
If the paint is the same as the can lid then Xtracolour have used the wrong reference.
Wartime Azure Blue is not the same colour as the postwar BS381c colour of the same name.
It is a light purple blue,  I have made a mix for it in acrylic so I spent a long time looking at the MAP chip.
@Mike Starmer is a good chap for Humbrol mixes, he may have one.
HTH
May be worth checking Phoenix Precision Paints for enamel RAF colours.
Not all "acrylic" paints are the same.  I suspect you are thinking of the water-based ones: the lacquer-based ones are similar to enamels but smell strongly.  Enamel paints smell is largely due to using turps substitute: naphtha thinner are much less noticeable.  Do not use Lacquer paints on top of enamel unless very well cured.
Summary of enamel matches out of the tin:
Humbrol 157 in the newer style of tin, shouldn't be that hard to track down.
Phoenix Precision M114 Azure Blue Smooth, 14ml (phoenix-paints.co.uk)
Sovereign ACRN34
Of these Phoenix is probably the easiest to buy. I can't vouch for any mixes published here or elsewhere.
FWIW current Humbrol acrylic 157 is very good.
John
Humbrol 157 was withdrawn years ago.  According to my samples, the original colour in 2002 was quite dark and not accurate at all.  This might have been intended to be the BS. shade but was not dark enough.  The replacement colour in 2015 was very different and almost exactly right.  Naturally this being the correct colour that modellers need, they withdraw it.
  • Sad 1
And yet Airfix still selling models that they specify require 157 Azure????
IMG_5274[1]
IMG_5273[1]
A lovely pile of bits and pieces arrived from Hannants this afternoon in the post. 😁
I had taken a punt on a suggestion by @FatFlyHalf for Xtracolour from Hannants (X026).
The paint has duly been tested out, and first thing to note is its a "Gloss" so will need to be "matted"
but here's a quick view on my FW mule and plastic spoon.When the paint has had 24hrs to harden a bit more , I,ll matt coat and post pics to see what the resultant looks like.
IMG_5276[1]
IMG_5278[1]
Lighting is not the best and does make painted parts "appear" far darker - but in real life ! its not too bad - It may well be better when a matt coat is applied and natural daylight - (tune in tomorrow 😉)
3 minutes ago, Ed Russell said:
It does not signify much to match the colour to a printed instruction sheet.
Some of the threads quoted above matched various paints to the MAP colour charts.
Quite right @Ed Russell
I have to admit it's pretty close for my liking , and at the end of the day its a "representation" for a model - and since its undersides - its only got to be somewhat near for my purposes 😉
wartime colour from film
45791221395_bdda178668_b.jpgHurrican HW189 B front by losethekibble, on Flickr
the best representation is between the 2 cannon on the right.
It's an light, intense purple blue.
It varies in appearance with the light, which is what good camouflage colours do
More period colour
5563260675_8270a31b7f_b.jpgSpitfire in Malta 15 May 1943. by Etienne du Plessis, on Flickr
3558942015_c80e1fcd9c_b.jpgAvro York by Etienne du Plessis, on Flickr
5046398921_2a58808962_b.jpgBristol Beaufort,    Malta by Etienne du Plessis, on Flickr
49755554013_f91a666e88_b.jpgHurricane IIc,   1943 by Etienne du Plessis, on Flickr
49991141187_c36b6429e8_b.jpgClose up of Hurricane Mk II d . by Etienne du Plessis, on Flickr
49755564378_54ef94cb85_b.jpgBaltimore Mk.IIIA  , 1942. by Etienne du Plessis, on Flickr
6897888105_457d54f2eb_b.jpgDouglas Boston in North Africa. by Etienne du Plessis, on Flickr
2525592762_bab91961c1_b.jpgBoston III..........SAAF by Etienne du Plessis, on Flickr
3032770598_0e1d350c70_b.jpgSAAF Boston by Etienne du Plessis, on Flickr
15074951115_dbd4361253_b.jpgRCAF Spitfire V     1943. by Etienne du Plessis, on Flickr
This is Light Mediterranean Blue, also used, same unit and time as pic above
40081280613_bf5a14854b_b.jpgRCAF Spitfire Mk. V, 1943. by Etienne du Plessis, on Flickr
and Dark Mediterranean Blue
41403206570_49acd07d1f_b.jpgKittyhawk nose art, 1942. by Etienne du Plessis, on Flickr
8 minutes ago, Ed Russell said:
From @John 's post quoted above
which look more like Light Mediterranean Blue to me.   In the pic above, note the light, intense purple blue the colour has.
You could just say it's finished in LMB, and not worry.....  Malta Spitfire colours are a matter of intense debate.....
HTH
  • Thanks 3
  • Love 1
IMG_5276[1]
IMG_5278[1]
Xtracolour and Xtracrylix are all gloss as they are intended to be suitable for decal application straight onto the paint, which reduces the chance of silvering. It does therefore mean for many finishes a coat or two of matt or semigloss varnish will be required. Decals also come in a variety of finishes and even for a gloss finish varnishing may be required.
No idea why I'm mentioning this as you can get neither any more but years ago before colour TV was invented I used to use Humbrol MC12 instead of 157, which always looked too dark. Still not quite there but closer than 157.
s!AulkVcvqXjiciDDN6eWWy3uLg-sL?embed=1&w
Hmm,  that long ago H157 had not been invented either..... You are perhaps thinking of the Azure Bluein the Humbrol Authetics range, which in the lengthy linked thread the idea is that Humbrol Authentic Azure Blue was matched to Light Mediterranean Blue in error.
Humbrol MC12 was another in the Authentic range, military blue for use on Napoleonic's, a google brings up it was Prussian Dragoon Blue
https://www.scalemates.com/colors/humbrol-authentic-colours--811/mc12-prussian-dragoon-blue-enamel-matt--7393
And from memory it was a medium purple hued blue,  which is more in the ball park....
ooh, I love the stuff you can search up..... :giggle:
the lovely nurse has just ironed my straight jacket and has my pills ready so.......
  • Haha 5
