Yugoslavian RAF 352Sq 1944 camo colour question
zotz
352 Sq operating with the Balkan AF were in green and grey.  They may have had desert-camouflaged Spitfires when working up elsewhere in the Middle East, but the data of 1944 seems early for operations.  I do have a book on the subject, I'll try to look it up tonight to check the early use.
1 hour ago, zotz said:
rather than route through farcebook,,,
https://www.asisbiz.com/il2/Spitfire/RAF-352Sqn.html
Most of the images show a Sky fuselage band and spinner, which was factory applied for the Day Fighter Scheme.
Spitfire-MkVcTrop-RAF-352Sqn-C-JK608-JK8
the one exception I spotted
Spitfire-MkVcTrop-RAF-352Sqn-G-MH592-Hin
Given this has MH592 has an Aboukir filter, and the serial is on a light patch, this maybe a desert scheme which has had the Middle Stone overpainted in Dark Green.
This did happen. This is a Hurricane in this scheme
45791221395_bdda178668_b.jpgHurrican HW189 B front by losethekibble, on Flickr
This image, taken on film which makes the yellow look black, and the red dark, has darkish underside,  Azure Blue is a purple blue
http://www.airhistory.org.uk/spitfire/p064.html
MH592 VcT CBAF M55 6MU 14-8-43 47MU 5-9-43 'Ocean Rider' 23-9-43 Casablanca 10-10-43 NAfricanASC 31-10-43 352Sq Yugoslav AF as '9487' 'G' 18-5-45 (Belgrade Museum initially confused with JK808)
Apparently this still exits
I'll @dragonlanceHR  @Supercuber  who maybe able to add more on this,  I presume these photos are mostly from a book?
Perhaps this is the book @Graham Boak mentions?
HTH
12 minutes ago, zotz said:
Thanks so much. They were taken from the web while looking for rare schemes while producing a Vc decal sheet.
HTH
Troy:
Would the bottoms be finished in Azure blue?
1 minute ago, zotz said:
Troy:
the only 352 Sq Spitfire Vc in the link which may have Azure Blue is MH592.
Repainting the upper surface into Temperate Land Scheme (Dark Green/Dark Earth) has been documented in Tunisia, and Italy,  but was far more common in SEAC when they received Desert Scheme finished aircraft.
All the others in the linked Asisbiz page look to be Day Fighter Scheme, Dark Green/Ocean Grey over Medium  Sea Grey, with Sky spinners and fuselage bands.  (note capitalisation, these are the actual paint names)
If you have not seen this
Supermarine%20Spitfire%20Camo%20&%20Mark
scanned here
https://boxartden.com/reference/gallery/index.php/Camouflage-Markings/Supermarine-Spitfire
this is still one of the best introductory guides, while it only cover North West Europe, the markings were factory applied, and the camouflage pattern is the same for any colour scheme, as well as the roundel and fin flash sizes.
You may find this of use as well
British%20aircraft%20USAAF%20service%202
https://boxartden.com/reference/gallery/index.php/Camouflage-Markings/British-Aircraft-in-USAAF-Service
the whole series are in the link.
They also have the old profile series and Aircam books, which will show what photos have been around for a long time, the actual profiles vary in usefulness/accuracy
HTH
  • Love 1
scanned here
HTH
How would you finish MH592?
Sorry, I can't find the Yugoslavian-published booklet.  I think it was simply called 352 (Yugoslavian) Squadron, or similar.  It isn't in either of the two places it could legitimately have been, so must have been misfiled.
Hello,
it is excepted as fact that Hinko Sojic's Spitfire had been painted in desert colours. This is not correct, though. There is a colour (not colourised) footage in IWM, collection, taken on Vis in 1944/45, which includes 352(Y) Sq. mission briefing and take-off of aircraft. It clearly shows MH592 in Dark Green/Ocean Grey/Sea Gray Medium camouflage. The footage was debated two or three years ago on this forum, but I could not find the topic at the moment. The video also shows, that MH592 had clipped wings. Cheers
Jure
  • 100% 1
25 minutes ago, Jure Miljevic said:
Hello,
Jure
Thanking you for this information!
Thanks Jure
I was having a recollection of some film....
@zotz
Link to time of G
https://youtu.be/jzxa9KcoSUo?t=495
Interestingly they appear to have light blue spinners,
this is D, passing camera, and the Sky band looks near white, while spinner is light blue
https://youtu.be/jzxa9KcoSUo?t=497
Spitfire-MkVcTrop-RAF-352Sqn-D-BR130-Yug
HTH
8 hours ago, Jure Miljevic said:
Hello,
Jure
What he said. :D That colour footage is priceless.
The KP kit has  late look of roundels on the top of the wings. Initially the red stars were taking whole diameter of B roundel without any white left
images?q=tbn:ANd9GcSea5_Ym19X8O7pj-_fOT7
yugoslav-squadron-flying-spitfires-tacti
Later the insignia on the top of wing became with white indeed, but I  am not when it was.
Here https://www.asisbiz.com/il2/Spitfire/RAF-352Sqn/pages/Spitfire-MkVcTrop-RAF-352Sqn-D-BR130-Yugoslavia-Oct-1944-02.html it is seen on a take dated for October 1944 and also on other said to origin in March 1945, but initially they  looked differently. Also the fin flash sometimes is revered (blue-white-red).
Does anybody know the rules here?
Regards
J-W
Edited by JWM
@dragonlanceHR, this is also the danger of old age.  Old publication?  Surely not!  I bought the book when it appeared in the UK, which was only a few years back... it seems.   Of course this may not have been the first appearance of the information at home.  However I don't think any more modern information has appeared in the UK - this is the value of an international board such as this one.
Hello!
Amen to that, dragonlanceHR!
J-W, photos you posted were publicity material and had been taken at Canne airbase in time of the squadron's first combat mission on 18th August 1944. (Interestingly, in Цпитфајер booklet Aleksandar Kolo and Bojan Dimitrijevic suggest that one of the participating aircraft (EP439, K) had lower surfaces repainted in Azure Blue.) It seems that initially white was indeed omitted from roundels on wing's top surface, but reappeared later. However, there is no firm rule about it as roundels varied in size. The same goes for the red stars, which more often than not also got a bit "chunky". Colours of Yugoslav flag on tailfin had been occasionally reversed, and two of the photos from Vis shows one of the Spitfires (MH5xx, P) still with RAF fin flash. Also, in March 1945 at least one replacement aircraft (JL168, P) arrived with dark, probably black spinner. As usually, the best practice is to find as many photos as possible of one's modelling subject. Cheers
Jure
Tino Jelavic book is from 2003.
Some photos also suggest that machine were overpainted from previous brighter scheme (desert one). Look here on ) in serial
And the whole background of serial here:
This photo is done most likely on ortho film (or using filter):
the yellow outline and star red star are very dark but not the camo, what confirms a lack of yellow or red pigments in camo paints
The "chunk" stars are when (as on above on right and top)) the arms of two sided does not form a straight line...
Regards
J-W
You should check Avions magazine # 219-220  for latest  PARTISAN RAF PT1 & 2 articles, photos .profiles, schemes ,listings and stories , explain a lot about both Spitfires and Hurricanes in Yugoslav AF  service.
Also, Lift Here allready covered almost all  Spitfires in all scales  in various decals set , still available .
RGDS
Nenad/Supercuber
22 hours ago, Jure Miljevic said:
Hello,
Jure
I think it might have been this thread: https://www.britmodeller.com/forums/index.php?/topic/235084659-raf-day-fighter-use-of-yellow-leading-edge-in-the-mediterranean-352-sqdn-spitfire/#comment-3916704
Hello
Nice model, modelldoc. Smer, however, repacked the old Heller Spitfire Vb kit, but with Vc markings. I built several of those Heller kits as a teenager, but even then there were better kits available. I much prefered the old Airfix Spitfire Vb with Zumbach's RF-D and USAAF Lima Challenger decals, which appeared at about the same time. Cheers
Jure
Hello jovapad
In Tino Jelavic's book there is a colour profile of JL235 in Dark Earth/Mid Stone however the caption says she was probably painted in faded daylight fighter scheme. In first few post-war decades (and in some cases, much longer) when photos for publications had been sourced from official archives one got photo of the photo. When the same photos were reproduced from the books their quality declined with even further. Cheers
Jure
