Corky Posted July 16, 2024 Posted July 16, 2024 Great to see this new release. I'm in for sure. I was wondering since they had change alieron sizes, retracteble tail wheel and new instrument panel would this make the original IX kit done? Or they just do new a new mould for the MkVIII pieces? Thanks for any insights. cheers
VMA131Marine Posted July 16, 2024 Posted July 16, 2024 1 hour ago, Corky said: Great to see this new release. I'm in for sure. I was wondering since they had change alieron sizes, retracteble tail wheel and new instrument panel would this make the original IX kit done? Or they just do new a new mould for the MkVIII pieces? Thanks for any insights. cheers Most likely they have used replaceable mould inserts to make changes where needed but there are clearly some new parts. We’ll have to compare sprues to the Mk.IX when the kit is released. The next obvious thing to do would be an ‘e’ wing for the Mk.IX and a cut down fuselage for the bubble canopy Mk.IX and Mk.XVI. The XVIs also had the more bulged top cowling to cater for additional bulges on the Packard Merlin engine and I’m not sure Airfix would want to make such changes, although Tamiya did in their 1/32 kits. The Mk.VII with its pressurised cockpit is probably a non-starter. 1
Julien Posted July 16, 2024 Posted July 16, 2024 20 hours ago, TheKinksFan said: Funny that they make a big deal about the collector's coin, "once they are gone, they are gone forever" 😄.I'm pretty sure 99% couldn't care less about pins, badges or coins. What is exciting is the new mk VIII kit and that iconic scheme. You would be surprised how many do care, if they did not im sure Airfix would not market it.
TheKinksFan Posted July 16, 2024 Posted July 16, 2024 1 hour ago, Julien said: You would be surprised how many do care, if they did not im sure Airfix would not market it. I stand corrected.
Giorgio N Posted July 16, 2024 Posted July 16, 2024 11 hours ago, Paul J said: Quite interested in this. Perhaps I can do one of the 67 Squadron ones in Burma that my late father in law worked on as an armourer courtesy of being in the RAF Servicing Commandos following his time in Normandy. Could Airfix be persuaded to re tool their retool of the Mk9of just a few years ago and do a Mk.8 too??? Which retool do you mean ? 5 hours ago, Corky said: Great to see this new release. I'm in for sure. I was wondering since they had change alieron sizes, retracteble tail wheel and new instrument panel would this make the original IX kit done? Or they just do new a new mould for the MkVIII pieces? Thanks for any insights. cheers It was clear when the IX was issued that the kit was designed from the start to allow further variants in the future. In particular the way the fuselage was moulded pointed at the possibility of adding the retractable tailwheel of the Mk.VIII. The wings on separate sprues also make adding a new set very easy without any need for permanent changes to the original moulds. The lower wing part would also include the new position for the downward fuselage light. We'll sure see both the IX and the VIII in production in the future and of course a XVI may easily follow 1
Bedders Posted July 16, 2024 Posted July 16, 2024 This looks very nice indeed. And with an VIII one is not far away from a VII or PR X/XI. Justin 1
Giorgio N Posted July 16, 2024 Posted July 16, 2024 7 minutes ago, Bedders said: This looks very nice indeed. And with an VIII one is not far away from a VII or PR X/XI. Justin As some song said, so close but far away.... A Mk.VII would require a new fuselage for the different canopy configuration. Would Airfix do one for a variant built in a relatively small number ? Personally I doubt it The PR variants would be even father away as would require a new fuselage for the different windscreen and then new wings. Again, would Airfix do this ? I have my doubts because the PR variants don't seem to have as much following amongst the wider modelling community, being generally something that only Spitfire fanboys like me search for. Of course each modeller will be able to add the desired modifications and I don't doubt that conversions will be issued by a number of companies, I'm just not sure Airfix would offer such variants from the box. Of course should they do it I'll be happy to be proven wrong. Happy for you folks, personally I'm not into this scale at all... although the idea of a very large Spitfire VIII in my collection is indeed something quite tempting 1
stever219 Posted July 16, 2024 Posted July 16, 2024 On 7/15/2024 at 11:00 AM, Karearea said: Best looking cover since the Eduard Weekend Ed. VIII There are hints of the old FROG Mk. VII/IX box arr too. 1
VMA131Marine Posted July 16, 2024 Posted July 16, 2024 2 hours ago, Bedders said: This looks very nice indeed. And with an VIII one is not far away from a VII or PR X/XI. Justin A VII would require new fuselage halves. The pressurisation of the cockpit meant doing away with the sliding canopy and the fuselage deletes the canopy rails as a result. Then there is a pressure bulkhead at the back of the cockpit along with other changes. I don’t think a VII is likely but would be happy to be proved wrong.
Rabbit Leader Posted July 16, 2024 Posted July 16, 2024 1 hour ago, stever219 said: There are hints of the old FROG Mk. VII/IX box arr too. yes… I totally agree! 6 2
Paul J Posted July 17, 2024 Posted July 17, 2024 On 16/07/2024 at 09:19, Giorgio N said: Which retool do you mean ? The one that came out just a few years ago. The new tool one.
Whitewolf Posted July 17, 2024 Posted July 17, 2024 (edited) In all honesty a MKVIII was expected as a spin off from the IXc, bit like Tamiya did in 1/32. trying to make the maximum amount of money out of the investment in the IXc moulds. This is a great kit, I already have the IXc to build as a IXe, but once again a further focus on a Merlin engined variant, would rather see a 1/24 Griffon engined Spit like a PRXIX.for example, but most manufacturers seem oblivious to the fact Griffon engined Spits existed in the 1/32 and 1/24 ranges. Edited July 17, 2024 by Whitewolf 1 1
fightersweep Posted July 17, 2024 Posted July 17, 2024 I think we all expected a Mk VIII eventually, but this is very welcome. Also a better starting point for the forthcoming Laminar Flow 1/24 Mk XIVe conversion I suppose what with the short span ailerons, retractable tail wheel etc. My wallet won't like this one bit. 1
Admiral Puff Posted July 17, 2024 Posted July 17, 2024 Ordered - to do a non-sharkmouthed RAAF aircraft! Having spend several golden splonders on Laminar Flow 1:32 conversion sets for the Tamiya Mk VIII/Mk IX, I won't be going down the same path in 1:24, though! 1
Giorgio N Posted July 18, 2024 Posted July 18, 2024 13 hours ago, Paul J said: The one that came out just a few years ago. The new tool one. You mean the 1/72 one ? If so, IMHO Airfix would do a good thing to replace it as I find it a poor kit, Not that it bothers me though as with the very good Eduard kit around ar similar prices there already is a proper Mk.VIII in that scale (actually the only proper VIII, all others are just IXs with a retractable tailwheel) 1
At Sea Posted July 18, 2024 Posted July 18, 2024 11 hours ago, Admiral Puff said: Ordered - to do a non-sharkmouthed RAAF aircraft! Having spend several golden splonders on Laminar Flow 1:32 conversion sets for the Tamiya Mk VIII/Mk IX, I won't be going down the same path in 1:24, though! How did they go together? i am very tempted by the LFD conversion kit so would be interested in hearing how challenging it is.
jenko Posted July 18, 2024 Posted July 18, 2024 The obvious next possible incarnation would be a high back 16. There is an excellent example just a couple of miles away from Hornby at the Spitfire and hurricane Memorial at the old RAF Manston. (This is the one Eduard did but made several mistakes) https://www.spitfiremuseum.org.uk/ Dick 2
Admiral Puff Posted July 18, 2024 Posted July 18, 2024 11 hours ago, At Sea said: How did they go together? i am very tempted by the LFD conversion kit so would be interested in hearing how challenging it is. The ones I've got (the low-back and high back Mk XIVs and the Mk XII) are going together beautifully - I can thoroughly recommend them. 1
PeterR Posted July 19, 2024 Posted July 19, 2024 Lot's of great subjects for this version, but hopefully we get decals for Clive Caldwell's Mk VIII. 1 1 1
AeroNautique Posted July 20, 2024 Posted July 20, 2024 (edited) I'd considered doing Bruce Ingram's 152 Sqn VIII, so this kit with the 156 Sqn markings is great news, I'll be picking up at least 1 of these. On 7/17/2024 at 10:02 PM, Whitewolf said: would rather see a 1/24 Griffon engined Spit Amen brother. I do sympathize a little (just a bit) with those who are tired of Spitfires...but a decent Griffon Spit in 1/24, is a hole in the market that needs plugged....c'mon Airfix 🙏 Edited July 20, 2024 by AeroNautique typo 1
Karearea Posted July 21, 2024 Posted July 21, 2024 15 hours ago, AeroNautique said: I'd considered doing Bruce Ingram's 152 Sqn VIII, so this kit with the 156 Sqn markings is great news, I'll be picking up at least 1 of these. Exactly what I’m considering- not hard to substitute the ‘L’ code and serial numbers, even if each Panther was slightly different. 1
MrB17 Posted July 21, 2024 Posted July 21, 2024 Never fails. I started mine on February 8, 2023! I guess I should get back to it and finish it off. Cheers Jeff 1
New Tool Posted July 21, 2024 Posted July 21, 2024 On 7/15/2024 at 4:01 PM, keithjs said: Schemes here. https://www.hannants.co.uk/product/AX17002?result-token=PTTAi It is priced there at £75 at time of writing. Isn't that unusually low for an Airfix 1/24 Spitfire?
352nd Fighter Group Posted July 21, 2024 Posted July 21, 2024 There is no point me getting this Because I have the Eduard 1/72 MK.VIII 1 1 1
Work In Progress Posted July 23, 2024 Posted July 23, 2024 On 7/21/2024 at 9:16 PM, New Tool said: It is priced there at £75 at time of writing. Isn't that unusually low for an Airfix 1/24 Spitfire? Must have been a data entry error, now showing as £89.99 on pre-order, which is about what one would expect at Hannants
