Magna Models 1/72 Polikarpov ITP (M-1)
Resin.
Why does that word fill me - and I suspect others - with unease?
Probably for the same reason the Vacform in  "Multimedia kit: vacform, resin and white metal" does.
Is it because I think resin is outside my box?  Except .... I sometimes use resin aftermarket items, and don't appear to have had many problems with them.
Nor, apart from from some wobbly cutting, did I approach the vacform sails in boat kits like HMS Victory or Cutty Sark (the airfix ones) that I built as an early teenager with any trepidation..
Perhaps it's a natural thing when mainly dealing with injection moulded plastic to view the guys who do things in resin and/or vacform as somehow more advanced modellers than you, just  a weedy, injection moulded man..
But  yes, I have just made a resin kit. My first one.
To whit, the Magna Models Polikarpov ITP (M-1).  Nope, I'd never heard of it before I bought the kit at the Gloucester IPMS show way back in 2019.
Apparently it was a design for a heavily armed fighter, but it never got over a problem with the engine which wasn't able to give it the speed required.
But for £6, surely the kit couldn't go wrong?  Hmmmm    ....    Deafening silence.
Before I go on to the finished model, here's a couple of photos of the box, and the resin, vacform  canopy and white metal parts - the resin parts have been separated from the casting blocks.
SAM_4060
SAM_4061
SAM_4062
Now I'm not going to lie, making this kit was a touch problematical. That's because I failed to read the instructions properly.  yeas, I know, but in all honesty, how many Britmodellers have done the same?
What I would have seen in the instructions was a command not to cut the locating lugs off the wings as well as the casting blocks. Yes, you guessed, I cut the wing locating lugs off.
So I got around that problem by using a brass rod pin going through the fuselage to pin the wings to the fuselage. Surprisingly, for me, that worked!
SAM_4067
Was there a next problem?
Cutting the vacform canopy to size, perhaps? was there a reason why 2 vacform canopies were provided?
Nope, the first canopy cut and sanded out of the excess quite easily.
Anything else? Well, painting wasn't too bad; I gussied up the cockpit, painted some seat belts (not easily seen) and some attempt at an i/p, and used used Mr Masking compound around the wing root air intakes and wheel wells to give a pretty clean paint job there.
There was minimal paint bleed under the masking tape on wings and fuselage, easily cleaned up. The canopy masking went fine.
SAM_4078 SAM_4081 SAM_4082 SAM_4083 SAM_4086
My word, this is sounding easy, isn't it? Actually, given there are only 21 parts altogether - 9 resin, 1 vacform and 11 metal, I think I can be excused thinking that I shouldn't have found it difficult.
The minimal decals came from an old, long abandoned Mig 15 kit - Magna didn't supply any decals. Paints by Tamiya and Mr Color, varnishes by Windsor & Newton Galleria.
Would I do another resin kit? I don't know. I know that there are some resin kits around (I do read reviews) which are more akin to injection moulded kits, but what I'm thinking of are the type of resin/vacform/white metal kits err .... like the whirlybirds Sikorsky S 51 dragonfly that's in my stash.
Hmm .. maybe I'll give it a go, after I've retreated into my injection moulding comfort zone for a while!
  • Like 12
  • Sad 1
4 hours ago, MACALAIN said:
I had made mine yearsss ago.
Alain
Alain,
Did you mean the polikarpov or the dragonfly?
The Whirlykits S51 Dragonfly is quote a nice kit. The instructions are clear, and the vacform clear fuselage seemed to be a plastic that was plastic glue friendly. Mine is here
https://www.britmodeller.com/forums/index.php?/topic/235075958-westland-dragonfly-hr3-whirlybirds-kits-172nd-scale/
15 hours ago, Whofan said:
Alain,
The Polikarpov. If you whant, I can post my model.
Alain
Nicely done on the resin kit.  I, like you, am somewhat leary of full resin kits, even though I have a couple in my stash.  I use it in normal builds, but the idea of a full build is intimidating.  Congratulations on finishing this kit and doing so well on it.  Look forward to the helicopter.
Alain
Oh yes please, I’d like to see how it should have been done!
thanks for the kind words, George.
I confess when I took it out of the box I did think for a moment “this’ll be ok” because of the low parts count, but I still had a few moments or two.
The helicopter? I might put it off for a while!
It's post mate. But I have certainely made a mistake, it is possible that it is the Omega resin kit and not the Magna.
Alain
