Something very out of my comfort zone: Mercedes G4
Climbing out of our comfort zone is the best way to advance :thumbsup:
On 5/10/2024 at 8:18 PM, Corsairfoxfouruncle said:
Welcome, it’s a long build so you have sone time to do other things.
Thank you @Corsairfoxfouruncle!
The start is not so brilliant.... would you believe this is three evening's work of cutting, cleaning and glueing a gazillion little pieces just for that??
20240522_235518
Hope to gain some pace or it will need at least two years to complete!
On 5/23/2024 at 9:34 PM, Corsairfoxfouruncle said:
Well take your time, builds are always more about the fun and relaxation than finishing.
Agree on that, I'm doing some assembly here and there between other builds.
Overall I find this kit quite boring and unnecessarily complicated though. See for example the wheels: there is a joint in the inner face of the tire which will need some filler and it is a very awkard place to fill and sand, then multiply that for eight times...
I understand the need to split the wheels in two parts to avoid the risk of sink marks, however a joint in the tread is a better solution in my mind: in any case you have to remove a mold line and a joint wouldn't be much worse.
20240602_164311
  • 3 weeks later...
More progress over the last few days:
20240613_083903
Then I started looking at the body parts and found a bad surprise:
20240612_220945
The fenders are short shot in two points.
Unfortunately I bought this kit a long time ago, so there is no point in contacting the retailer. I tried instead writing to ICM for a replacement, but I'm not holding my breath. Anyone can report their experience on this matter?
  • Sad 4
Oh no, that looks pretty serious.  I hope ICM can help you out.
If not, the parts may be repairable by backing the gaps with thin plastic card and then building up the surface using a two-part epoxy putty (like Milliput)?
Good luck.
