I stepped outside to breathe the air - Zvezda 1/48 MI-24V/VP - Finished
13 hours ago, Spookytooth said:
She is coming together very nicely Alistair.
Really colourful office.
Simon.
Thanks very much Simon,
A bit more glue.
If I can i'll get moving on the engines today.
Thanks for looking,
Alistair
45 minutes ago, Keeff said:
Nice work .... that cockpit is very busy!
Keith 😁
Thanks Keith,
How much will be visible is still to be determined.
Alistair
27 minutes ago, bigbadbadge said:
Ooooooo very nice progress Alistair,  looking good fella. Cracking work.
Chris
Thanks Chris.
Most kind of you.
Alistair
A start was made on the engines last Wednesday.
Parts cut prior to clean up.
They were built and primed on one of the nights after I got home on the early shift.
Today I got on with the paint and glue.
Not before time.
I didn't bother dealing with the seams on the engine halves as they won't be seen but used them as practice for the metal paint effects.
So, here they are after a base coat of steel followed by some pale burnt metal, burnt metal, jet exhaust, some engine blueing and some Nuln Oil on the compressor blades and such.
Fairly pleased with the result and they did fit perfectly into their assigned positions much to my surprise.
Now I need to bend, paint and fit the rudder pedals, then dirty things up a little and after that get on with the fuselage halves, doors and stuff.
Thanks for looking,
Alistair
  • Like 9
2 hours ago, bigbadbadge said:
Nice metal effects Alistair,  progressing well.  Great work
Chris
Thanks Chris,
It should start looking like a whirly thing soon.
Alistair
Before I started work on bits of this today I thought that a dry fit might be a good idea to see where I stand.
That all looks to be pretty good at the moment it may change when glue is involved.
A bit more PE added to the side doors.
Rudder pedals built up.
Then when I took things apart to start on the fuselage internals I realised there was a little work to be done before I go much further.
Thanks for looking,
Alistair
  • Like 9
Feel like I’m arriving late to the show, but mind if I pull up a chair too?
I’ve got a couple of these in the stash, so will be following this with interest.
Nice work- your progress is a lot more rapid than mine!
Thanks very much and welcome aboard.
If this thread helps in any way then that makes me happy.
Alistair
26 minutes ago, bigbadbadge said:
Dry fitting is looking good Alistair,  but wait, not more ejector pin marks, deja vu 🙄this will soon be buttoned up.
Cracking work
Chris
Thanks Chris,
It's going well enough and to be honest as this will all be buttoned up I don't think you'd see the ejector pins marks but I'm not taking the chance.
Alistair
More PE glued on along with the doors and the last sort of internal bit built.
The cockpit and cabin got dirtied up a bit with a smoke oil wash.
And before I head out for work a final dry fit before there's more paint involved.
Based on this dry fit I'm going to need to be really careful with the placement when glues is involved to get this sort of fit.
Thanks for looking,
Alistair
  • Like 9
Alistair,
I have somehow missed significant progress on this - lovely and rapid work! I do like your treatment of the engines,
Roger
19 hours ago, mark.au said:
Some typically superb work on display here, Alistair.
Thanks very much Mark,
Most kind.
15 hours ago, bigbadbadge said:
Great job on the interior Alistair,  looking good fella.
Chris
Thanks Chris,
Not that any of it will be seen.
15 hours ago, Dunny said:
Alistair,
Roger
Thanks very much Roger,
I was using them as an experiment in paint and I think they look all right.
7 hours ago, Jose Miguel said:
looking good, looking good
Many Thanks,
Most kind.
Bits and pieces have been attended to over the course of the day.
Firstly some paint, decals, windows and a bit of dirtiness to the fuselage half interiors.
Then a start with the glue and a last pic of the interior as it will never be seen again.
I then started to button everything up in stages until I got this result.
That's where it stands tonight. I'll have a good look in the morning and see where I can go.
Thanks for looking,
Alistair
2 hours ago, Vultures1 said:
Looks great all stitched up!
Thanks very much.
1 hour ago, bigbadbadge said:
It does look good all together Alistair
Great work
Chris
Thanks Chris,
Just working on the seams and thinking about getting more bits stuck on the outside.
Alistair
15 hours ago, Jose Miguel said:
You are doing an amazing work!!!!
I will follow your progress
Thanks so much.
Most kind and welcome aboard.
Alistair
