Building the the interior of a 1/72 Armourfast Achilles tank destroyer (great basis for some scratch building) but unsure how large the rounds need to be. Hoping to make a number of them from old sprue, sharpened at each end. I have a load of photos from builds found online so have an idea of sizing from them at least.
17pdr APCBC round was 859mm overall.  Cartridge was 583mm and projectile 276mm (APDS only about half that).   Projectile was obviously 76mm diameter.  Cartridge base diameter was 135mm.  I can't find measurements for the diameter and taper of the cartridge case body.  About 125mm at  the base at a guess.  In that scale a few mm makes little difference.
That gives the same basic dimensions but doesn't help with the case taper, shoulder length and angle etc.
Have you looked at whether 1/48 50mm (is there any?) or 1/35 37mm ammo might work? Diameters will be about right but there is length and shape to consider.
