1926 Mack Bulldog
4 hours ago, dnl42 said:
I continue to be amazed at how you can effectively paint such intricate assemblies. :worthy:
Just go "low and slow" with the airbrush, eventually paint will end up everywhere 🙂
Hi Jeroen,
Just stumbled across your Mack AC build.
Nice progress, especially the real wood trunks.
Good luck !
Greetings
JohnHaa
I did some painting, these past couple of days. First, switched colours on the chassis and cab.
That's semi gloss black on the chassis, I always like that. The engine got the same colour, I may do something with it but I don't intend to show it.
And grey primer on the cab.
I wasn't thinking and sprayed the cab's underside grey as well... I didn't have to do that as I was planning on having it black. Anyway, it's now black again.
While the cab itself is nice and red. The cab floor will be black which will be a little bit of a struggle probably, but I'll get a brush in there.
Wheels are red too. This can all be clear coated tomorrow.
I gave the wooden parts a quick coat of something over the black primer, I think it was khaki because that's what I had. It's just meant as a base coat, I'm not particulary good at painting wood but I think I can make this work with some more paints.
  • Like 10
I shot a clear coat this afternoon and went ahead with the decals this evening. I must say, these decals were very well behaved. I don't really like decalling because I always manage to damage one or something, but these were really nice. I've got them all on without a hitch.
The other side is the same, except for the curly one at the bottom which only this side has, because there's a toolbox on the driver side.
I did the signs as well, and cleaned up the front tyres and put them on.
  • Like 10
Terribly smooth - I never managed to get such a slick surface. Looks fantastic with the decals.
  • 3 weeks later...
I've finally done some more work on the Mack. Last time, I did the decals and I started out today by sealing them in with gloss varnish. Then I dulled the whole thing down with a matt varnish, I mean for sure this truck isn't shiny, hauling logs in the woods.
I painted and installed the seat, glued the cab onto the chassis which was a bit of a chore but it worked in the end.
Exhaust was weathered and glued on.
The next job will be the rest of the weathering, going for a muddy look.
I managed to paint the wooden deck as well.
I configured my logs, I think I have enough length on the chains. I have burnishing fluid for metal tracks and tried it on the chain but it did absolutely nothing. So I soaked them for a bit in thin Vallejo Red Leather paint and dried them with the hairdryer. I think this will do.
  • Like 12
Well, just like that, it's done! I muddied the thing, hot glued the logs on and that was it. This was a fun little build.
I'll take better pics for the gallery, need to charge some batteries for my camera first 🙂
Thanks for watching and tagging along!
  • Like 14
Very well done. :clap2:
It would be right at home on some logging road, deep in the forest. Quite a few of those in Northern Cal.
It's certainly very characterful indeed and makes a nice change from the modern 'box on wheels' trucks.
A great nostalgic piece of work, Jeroen. The finish is striking - you do have an eye for this!
Thanks, that's very kind 😊
You've produced another stunning model Jeroen :goodjob:
The subtle weathering is a particular highlight for me.
