Street Workers (38081) 1:35
Mike
1:35 MiniArt via Creative Models Ltd
This set depicts a trio of street workers, not to be confused with a similar group of people, often referred to as the oldest profession.  These are people whose work is done on the street, and it includes a street-sweeper, a newspaper seller, and a lamp-lighter, from the days when street lamps were gas-powered, a power source that lingered longer into the 20th century around Europe than you’d possibly think.  Inside the figure-sized box are five sprues in grey styrene, the longest of which is nipped into two parts at the factory to allow it to fit inside the box, plus a pair of clear sprues, with a glossy sheet of instructions for the accessories that are included with the set.
The parts for each figure are found on separate sprues for ease of identification, and parts breakdown is sensibly placed along clothing seams or natural breaks to minimise clean-up of the figures once they are built up.  The sculpting is typically excellent, as we’ve come to expect from MiniArt’s artists and tool-makers, with natural poses, drape of clothing and textures appropriate to the parts of the model.  The street-sweeper is holding a long-handled Besom broom with a traditional bundled stick head, akin to a witches’ broom, made from two parts.  For a good join, a small hole could be drilled in the head of the broom to accept the shaft, cutting it to the desired length.  The lamp-lighter has one leg either side of the ladder (not health & safety approved), and has his arms above his head opening or closing the lamp head, while the paper seller is wearing a bibbed skirt and jacket, with her hair flowing over her shoulders in a 30-40s style, and a three-part stack of papers in her arms.
The accessory sprues provide parts to create a step ladder for the lamp-lighter to reach the street lamp, which is also included.  The ladder is made from the two sides plus a top step, while the lamp is built from a two-part bottom section and a fluted upper with perpendicular cross-rail ‘lollipops’ across the top that were commonly used by lamp-lighters if they were using a straight ladder.  The lamp itself is made from two faceted clear parts for the glazing, and a styrene top-cap with ferrule on top, fitting a clear bulb to a hexagonal base that is linked to the post by a four-legged bracket underneath.  There are more parts on the sprue, including an ornate suspension bracket for a lamp or a large clock, the parts for the latter also found on the long sprue.  There are no clock-face decals as it’s not an official part of the set, but you could try printing your own if you have the skills.
Conclusion
Another realistic, life-like figure set with plenty of accessories from MiniArt that will be perfect for a diorama setting.
Highly recommended.
Review sample courtesy of
