AModel 1/72nd scale Kalinin K-5, yet another 'Оловянный гусь' (Tin Goose)
16 hours ago, Old Man said:
I've only done their I-16
Me too.  I am grateful that this kit has larger parts.  The I-16 was maddening.
So basically the aircraft is finished.  I have only to paint it and add the decals.  This is the thing...the instructions say to paint it white, but there are so few photographs of the aircraft and most of those are inconclusive...it veers towards the NMF.  Other modellers have painted it white or silver.  I kind of like the tin NMF finish myself.
So that's the question I put before you...NMF or white?
The landing gear was soft/brittle and snapped.  I used CA and a splint.  Then actual glue.  I think it will hold.
Just a test fit of the motor...the control horns (upper and lower) are attached as are the running lights.
--John
  • Like 10
Good save of the wing parts John. As for the colour-scheme; all I can say is a natural metal seems more in keeping with the era :shrug:
21 hours ago, Corsairfoxfouruncle said:
Hopefully the painting wont be a headache.
I hope so too.  As of now, no problem.  I gave the whole thing a covering of white primer from AK.  I can go in either direction at this point, although I am still veering off into the NMF range.
Thanks to you both...I was lucky with the wings.
--John
That was a quick build. Great work nevertheless, particularly the wing adjustment and repairs.
Hi John,
During 1930's silver dope was also used quite much as overall colour in non-camouflaged aircraft in the Soviet Union.
AaCee
2 hours ago, AaCee26 said:
Hi John,
AaCee
I was going to say metallic dope... it gets interpreted as white or NMF and is probably somewhere in between. I'll be doing it on my Goeland.
Thank you.  Aside from the interior bits, there aren't a lot of pieces to this kit.
That sounds about right.  Thank you.
Excellent.  I will have to check in on your WiP...thanks!
The white primer was a good choice.  It kept the aluminum NMF from being too dark.  Ok, it's not quite so grey as aluminum dope, but then again, It's not finished either.
I am off-island tomorrow until Saturday so I figured I'd get some NMF work done before I head out.
--John
  • Like 11
--John
John do you use straight aluminum or a mix for Dope ? I use a mix of Aluminum and grey to get my dope.
I just used straight aluminum.
I can always soften it with another thin layer of your recipe. 😄
I'd not come across this plane either, so very interested. A not insignificant type too. Not sure if you've seen the photo on this page John. I thought it might help with your finish. Seems they issued passengers with parachutes too. How's that for confidence. ;) :D
Steve.
  • Haha 4
I mixed up a variation of the @Corsairfoxfouruncle 'Aluminum Dope', i.e. 50/50 grey primer and aluminum.  It went on well and looks more the part than the straight NMF.
I let that dry for a few hours and then went into the decals, which, as per any Amodel decal set I have ever used, all but shattered.  I was able to piece them together with some patience, lots of water and some colourful language.  I will spray them with satin varnish later tonight after they are dry.  They are too delicate/thin for a hairy brush.
I let them unroll themselves, btw...no sense making them worse!
Port and starboard are the same configuration...
Time to let that dry.  Other things to do.  I am back on the mainland tomorrow for a couple of nights so I want to get some of this off the bench before I go.
--John
  • Like 9
45 minutes ago, Corsairfoxfouruncle said:
To be honest I cant see anything wrong with the decals. And I agree I think the paint looks good. It gives that duller look over NMF
Thanks Dennis.  I was really careful with the decals.  Not nearly a jigsaw puzzle but the did split a bit. It worked out.
Oooof!  Feels like years since I sat at the bench.  I need to wrap some things up, for sure.  This is one. I'm almost there.  I have painted the struts and gear black; I have added control lines to the control horns; and I have added what I think are part of some sort of air filter/radiator/carburator unit that I saw on another build...Here's a picture of that build, not by me and I fished the image from the Interweb...
It's obviously a kit piece that did not come with my rendition of the K-5.
Yet I had a space moulded on mine that looks like it needs a part...
So I added some bits of plastic.
I'm ok with it.  What's left, you say?  Attaching the wheels, maybe a little exhaust stains...not much.  Some painting touch ups here and there.
--John
  • Like 10
Being in Russia I wonder if that is a heat exchanger for the oil ? Possibly a cockpit heater ? Fluid circulates around the engines hot oil and then enters a cabin radiator for heating. Reminds me of my school buses, they had a similar feature on the floor boards. The liquid was heated by the engine/radiator and would flow along the outer edges of the floor boards. Always had to reach down just to warm my hands up.
Yes...that is a good guess.  Something along those lines.
Looking good. Not familiar with the type at all.
Corrugated metal was certainly a popular inter-war skin choice - Hugo Junkers had a lot to answer for!
Regards,
Adrian
