U-2R ‘Dragon Lady’ Senior Span (81740) 1:48
Mike
1:48 Hobby Boss via Creative Models Ltd
Back in the 1950s, extreme high-altitude anti-aircraft missiles weren’t yet available, and aircraft could over-fly foreign nations with a degree of impunity, as long as they could stay high enough to keep out of range of enemy fighters and less capable missile batteries.  Lockheed’s Skunk Works were tasked with creating a new aircraft on reasonably short notice that could fly higher than any previous aircraft or missile, virtually on the edge of space, to accomplish the task of gathering intelligence on America’s Cold War enemies, predominantly over-flying the Soviet Union.  They took the fuselage of the new F-104 Starfighter that was then in development, adding massively extended wings more suitable to a glider, and shortening the fuselage, leaving sufficient space to carry high-definition optics and/or electronic intelligence gathering equipment.  Developed in secret using black project money from the CIA, the airframes were developed in close proximity to the engineering staff, embedding them in the factory to quickly resolve any issues that came up, which resulted in the initial order coming in on time and under budget.  New high-altitude fuel had to be developed, and the custom optics were designed specifically for use in the aircraft, which garnered the designation U-2, the U standing for Utility, to confuse anyone hearing about it, thus delaying its discovery a little longer.
Once flights over the USSR had begun, it was discovered that the Soviets were regularly tracking the aircraft, which led to a project to reduce the type’s radar return, which was initially unsuccessful, but later was revisited by covering the skin in a Radar Absorbent Material (RAM) that was a matt black colour on application.  There have been many upgrades and alterations to the type since it was initially fielded, leading to an aircraft that looks somewhat like the original, but is hugely different in terms of capabilities, especially when it comes to intelligence gathering.  They still jettison their wing-mounted stabiliser legs on take-off however, and are stalked on landing by a muscle car to improve the pilot’s situational awareness from his cramped cockpit, which is worsened by the pilots having to wear a space suit due to the altitudes involved that would have a fatal effect on anyone flying whilst wearing a standard flight suit.  The largest change other than building two-seat airframes for complex tasks and training of the elite pilots was the U-2R in 1967, which increased the size of the airframe by around 30% and introduced the wing ‘Superpod canoes’ that could be filled with intelligence gathering equipment and gave the aircraft a greater range by the enlargement of the fuel tanks.  Despite the age of the basic premise and the march of technology, the U-2 has persisted attempts to retire it, even surviving the introduction of the un-manned Global Hawk, which is capable of many of the same tasks with extended loiter times due to the pilots being ground-based.  NASA use a few U-2s, redesignated as ER-2s, which are used for high-altitude civilian research, painted white with the blue NASA cheatline as no-one is likely to want to shoot them down.
The Kit
This is a new tooling from Hobby Boss that was released late in 2023 and has only recently arrived this far from China, with another boxing depicting the U-2S expected soon(ish).  The kit arrives in a top-opening box with a painting of the aircraft flying high, which is what it does best, with the stars visible in an inky black sky.  Inside the box are seven sprues in grey styrene, a clear sprue, Photo-Etch (PE) sheet, decal sheet, instruction booklet, plus a colour profile sheet in A4, printed on both sides.  Detail is excellent throughout, and incorporates some intelligent use of slide-moulding, particularly to create double-wall, single part intake trunks with detail on the interior and exterior.  There are also a ton of aerials, antennae, a dorsal pod, and optional flat-spotted forward areas to the Superpod canoes under the wings.  There is also plenty of detail in the cockpit, gear bays, and even a pair of detachable wing support wheels on their banana-shaped struts, plus air-brakes that can be fitted in the deployed position with a suitably well-detailed bay behind each of them.
Construction begins with the two long fuselage halves, drilling out several holes in the top and bottom, and inserting the air-brake bay parts toward the aft end of the parts.  Attention then turns to the cockpit, starting with the ejection seat, which is made from seven styrene parts plus four-point PE belts, which is installed in the detailed cockpit tub along with a two-part control yoke, fitting a bulkhead to the rear, and the instrument panel in front of the pilot, with a decal to depict the dials.  Two side wall inserts are then fixed to the top of the consoles to finish the tub, moving on to the rear gear bay, building it from individual wall and roof parts, locating the gear strut between the side walls, and adding small diameter wide tyres to each end of the cross-axles.  The exhaust is a simple tube made from two halves, and it is capped by a representation of the rear face of the engine after painting everything a suitable shade of burned metal.  The front gear bay is moulded in excellent detail, showing the shape of the merging intake trunks within, to which the front strut and its retraction jacks are fitted, adding another pair of larger wheels to the stub-axle ends, painting both bays a grubby white.  The merging intake trunks are made in two stages that are joined together to create a Y-shape, which is blocked at the rear by a part that represents the front of the engine, gluing it to the roof of the front gear bay, then fitting the cockpit, both wheel bays and the exhaust between the two fuselage halves and gluing them together.  A forest of antennas is dotted around the underside, adding sideways opening front gear bay doors, a tail-bumper, and the actuators for the air-brakes into the bays near the rear.  Yet more antennae are fitted along the belly, a sensor dome is mounted in front of the front gear bay, and the rear bay doors along with the air-brake panels are installed, flipping the model over onto its wheels to fit the instrument coaming to the cockpit, plus another antenna and light to the spine.  The canopy is moulded in two parts, fitting a small exterior rear-view mirror on the port side of the windscreen, and PE interior rear-view mirrors to the canopy, gluing both into position, the canopy hinging to the port side if you plan to pose it open.  The two intakes are an impressive piece of slide-moulding, having inner and outer surfaces provided as one part, with a hollow interior that reduces the likelihood of sink marks, whilst providing plenty of detail, each one gluing into the openings behind the cockpit.  There is a slight seam around the intake lips that is easily removed, but the detail is well worth those few seconds of effort.  The dorsal pod is made from two halves with a small raised blister on the pylon added to both sides, fixing it to the spine over the wing roots on pins, while the tail fin is built from two halves plus a single part for the rudder, which has a corrugated surface that is a little too deeply defined.  Check your references and either fill the depressions, or sand back the raised portions as you see fit, although several coats of primer and some light sanding of the high spots might be better to retain the original thickness of the part.  This also applies to the ailerons and other flying surfaces, so you might as well do them all at once, unless you’re upset by this minor issue.
Each wing is made from top and bottom half, adding the majority of the Superpod body to the underside, with the top half of the tail cone a separate part, and the forward section that uses either two halves to create a cylindrical section with tapering nose cone, or by using different parts to create the nose cones with a flat-spot on the outer face, both styles having an optional L-shaped antenna installed on the top.  The flying surfaces along the trailing edge are all separate, and are glued to the rear of the wing, with the possibility of deflecting them if you wish.  Note that the black RAM isn’t painted under the extended flaps, so take care to check your references to help you paint this area correctly.  A spoiler is also fixed to the upper wing around mid-span, near the jettisonable stabilising gear legs that are made from curved struts with a wheel glued to each side of the bottom end.  These locate in a socket under the trailing edge of the wings, and of course the same process is carried out in mirror-image for the other wing.  The wings are glued to the fuselage sides on three separate slots, and here it will become obvious that they have been moulded with a slight sag, which is correct for wings of this aircraft, so don’t be tempted to correct this.  The two-part elevator fins have separate flying surfaces, and these fit to the fairing under the fin using a relatively small tab and slot, taking care to achieve the correct dihedral by checking your references.  There are several nose modules used in U-2 missions, and this boxing includes a simple more aerodynamic nose that is made from two halves, plus a single cone tip, with two PE probes fitted to small depressions in the rear edge of the nose.  It is glued in place to complete the build phase of the model.
Markings
Any U-2 after the early days is painted in black RAM, with very few markings, unless it’s one of the civilian airframes.  There are three options included on the sheet, predominantly stencilled in red, and most of the decals are applied to the tail fin.  From the box you can build one of the following:
Hobby Boss decals and the decaling instructions can be a weak point of their products at times, and they are generally printed anonymously in China.  This sheet is printed in this manner, but is suitable for purpose, particularly as the majority of decals are printed in red.  Registration where it occurs is good, as is colour density and sharpness, with a clear backed decal depicting the dials and switch-gear for the instrument panel.
Conclusion
The moulding and detail included in the kit is excellent, and other than the excessive corrugated texture on some of the control surfaces, there is little immediately visible to grouch about, although some are still trying.  Other than making sure you have enough space in your cabinet to accommodate the enormous wingspan of the Dragon Lady, there’s no reason not to have one.
Very highly recommended.
Review sample courtesy of
  • Thanks 2
