Refugees Musician Family (38084) 1:35
1:35 MiniArt via Creative Models Ltd
During WWII there were millions of displaced populations created by the advances of the Nazis across Europe, escaping from combat or persecution, resulting in huge streams of humanity making their way to a perceived safer part of their own or a neighbouring country.  People took only what they could carry, unless they were lucky enough to possess a motor car or some kind of cart, whether hand-pulled or horse-drawn.  People would take their most important belongings, loading up with their most valuable goods, whether monetarily or otherwise, often comprising items that might be of use in their profession or as currency to trade when they arrived at their destination.
The Kit
This figure set supplies two figures, plus their possessions that they are carrying and pushing in a pram, although they don’t appear to have a baby with them, so perhaps they picked it up earlier in their journey or they had one in storage at home. The set arrives in an end-opening figure-sized box, and inside are six sprues in grey styrene, plus a sheet of paper that has several pieces of art printed on it to use with the picture frames that are included on the sprues.
The parts for each figure are found in separate sprues for ease of identification, and parts breakdown is sensibly placed along clothing seams or natural breaks to minimise clean-up of the figures once they are built up.  The sculpting is typically excellent, as we’ve come to expect from MiniArt’s artists and tool-makers, with natural poses, drape of clothing and textures appropriate to the parts of the model.
The accessories are contained on four sprues, two of which are quite large, and contain several instruments that can be carried by the figures in line with the theme of this boxing.  Instructions for the perambulator are found on the back of the box along with the painting guide for the figures, with additional diagrams showing the building of the three cases that are also found on the sprues.
The instruments sprue includes the following:
  • Accordion – open (Piano Accordion)
  • Accordion – in case (Piano Accordion)
  • Harmonic – closed (Button Accordion)
  • Harmonic – open (Button Accordion)
  • Marching bass drum with sticks
  • Trumpet
  • Guitar
  • Violin in open case
  • Violin & bow with closed case
  • Mandolin
  • Banjo
There are no instructions included for the instruments, which would have been useful, but it wasn’t a stretch to guess that this sprue had been seen before, even with my memory, and it turns out we have reviewed the set when it was first released separately in 2020, which you can find here along with the instructions, just in case you pick this set up and can’t quite figure out how to put some parts together.
The smallest sprue has three picture frames moulded into it, with six paintings supplied on the accompanying piece of glossy colour-printed paper, including some very famous paintings that are most likely reproductions, given their provenance.  You simply cut them from the backing paper and fix them in place on the narrow rim around the inside of the frame in much the same manner as a real picture frame.  If you want to add glass to the frame, some acetate sheet would be much easier to cut to shape than trying to adjust the size and shape of a glass slide cover that is often used to depict broken glass in dioramas.
Conclusion
The figures are expertly sculpted, and they have a care-worn look to them that would be typical of anyone that has been displaced by war, indicating their profession by their luggage, and adding the possibility of a bereavement in the near past by the presence of the pram.
Highly recommended.
Review sample courtesy of
