PLA ZTQ15 Light Tank (72-001) 1:72
Mike
1:72 MENG via Creative Models Ltd
The Type 15 light tank was designed as a replacement to the previous generation of tanks that Chinese Army, Navy and Air Force used in high altitude areas where oxygen is limited, on soft ground where heavier vehicles would bog down, and in tight areas such as forests where the lack of mobility of larger, heavier vehicles would be an impediment.  It was under development some time early in the new millennium, with prototypes seen during the 2010s, and final acknowledgement by the PLA of it entering service in 2018, by which time it had been in service in growing numbers for two years.  It carries a 105mm rifled gun that can fire the usual range of munitions (including NATO rounds), plus Anti-Tank Guided Missiles that can be used to take out enemy tanks at ranges of three to five miles away under the right circumstances.  It is armoured with a combined steel and composite hull, with Explosive Reactive Armour (ERA) blocks fitted to the front, sides and turret, and the option of adding slat armour where shaped-charge rockets such as RPGs are expected.  It can also carry heavier ERA blocks for greater protection, but as with all things, more protection brings more weight, lower speed and a greater likelihood of bogging down.
Unusually for an AFV, the Type 15 has an onboard oxygen generator that feeds additional air to both the crew and the engine to compensate for the reduced power output by the 1,000hp diesel engine at higher altitudes, the oxygen permitting the crew to keep their wits about them in circumstances that could otherwise leave them confused and listless due to lack of oxygen in their bloodstreams.  The coaxial machine gun in the mantlet is a relatively lightweight 5.8mm, but there is a 12.7mm remote controlled gun station on the turret roof that is mounted side-by-side with a 35mm automatic grenade launcher.  On the similar but different overseas variant, the VT-5, there are significant differences to the shape of the forward hull, and the driver’s hatch is mounted centrally, whereas the Type 15 has the driver on the left side of the glacis plate.  The systems of the tank are modern, offering full stabilisation of the main gun, which is fed from the bustle-mounted ammo store by an auto-loader that permitted the crew to be reduced to three, and in the event of a direct hit, the ammunition storage is designed to blow outward to protect the crew, and increase the survivability of the vehicle, something the Russian tank designers could take note of.  Its drivetrain is similarly modern, using hydro-mechanical transmission, and hydropneumatic suspension to smooth the ride, while the sensor package allows the gunner and commander to share the aiming and firing of the main gun, as well as detecting incoming infrared signals, triggering the launch of smoke grenades to disperse the signal and warn the crew to move their vehicle.  Because of its comparatively light-weight, it can be air-transported in pairs, and can be delivered to its intended destination by palletised air-drop, although the crew would probably need a change of underwear once they landed.  It is likely to be in service with the Chinese military for some considerable time, increasing its capabilities with in-service updates as time goes by.
The Kit
This is the first tooling from MENG’s new 1:72 armour line, and it arrives in a figure-sized end-opening box in MENG’s usual satin finish, with an attractive painting of the subject matter on the front, and painting instructions on the rear.  Inside the box are four sprues plus the upper hull and turret in light grey styrene, and a concertina-fold instruction booklet in black and white.  There are no decals, so you will need to mask or hand-paint the digital camouflage patches that are dotted around the hull and turret, but if you paint the green first and mask it, that shouldn't be an onerous task.  Detail is good throughout, with fine raised and recessed detail across all exterior surfaces, extending to the underside, with deeply recessed link-and-length track links, and a well-represented blast-bag on the main gun.
Construction begins with the running gear, building twelve pairs of road wheels, two pairs each of drive sprockets and idler wheels, the former made from four parts each.  The lower hull is assembled around the floor, adding the sides and the lower glacis plate to the front, then installing the drive sprockets at the rear, and a line of three return rollers to each side of the hull.  Six pairs of road wheels and the idler wheels are slid over the stub axles, adding towing shackles to the glacis, which then leads to installing the tracks.  A straight length is fitted to the return run, gluing the lower run with diagonal ends, then completing the band with curved sets of three links per end, one for each side of the vehicle.  The rear bulkhead with a pair of exhausts and towing shackles is fixed to the back of the hull, after which the upper hull can be mated to the lower, adding the driver’s hatch at the front on the shallow slope of the glacis plate.  At the rear, two fuel drums are made up from halves, and are fitted to the bulkhead along with an unditching beam that has wooden bark texture moulded into it along with the two straps that hold it to the vehicle.  Side skirts are fitted to both sides as single parts, covering the top track run, which could probably be left off to save yourself some work.
The turret assembly is built from top and bottom halves, inserting a sensor into the front, and adding the commander’s cupola over his hatch cut-out, plus a pair of sensors to the forward corners.  The rear panel to the bustle is separate, and is fitted along with the two sighting boxes, rear sensors on the corners, the mantlet with sensor box on top, and the two crew hatches. Grenade launchers are fitted as three pairs on the sides of the bustle, and the single-part main gun is inserted into the hole in the mantlet, fixing a pair of sensor masts, aerial bases, additional detail parts to the roof, then building up the co-mounted 12.7mm machine gun and grenade launcher into the remote station from three parts, inserting its mounting peg into a hole in the centre of the roof, and adding a tubular part across the rear of the bustle.  The completed turret can then be mated with the hull, twisting the bayonet fitting to lock it into place.
Markings
There is just one option detailed on the rear of the box, which is all-over sand with green or brown digital camouflage scattered over the surface.  There are no decals, so none of the usual concerns over registration, sharpness etc.
Conclusion
1:72 AFV modellers should welcome this new range with open arms, as they are well-detailed and yet still relatively simple to build, and what’s more, they don’t stress the purse-strings unduly.
Highly recommended.
Review sample courtesy of
