demiles Posted February 26, 2024 Posted February 26, 2024 I'm an armour modeller but need help with what I believe is an aircraft colour. Can anyone advise me on a manufacture of BS 217 Sea Green, a good substitute or provide a mix ratio for this colour. Thanks
Dave Fleming Posted February 26, 2024 Posted February 26, 2024 (edited) I'm not aware of one - it's not a common aircraft colour (if it'; an aircraft colour at all - BS381C has a range of colours used for 'official' purposes.) What's the armour use? It might be known by it's name or another name Equivalents in other specifications are: https://www.e-paint.co.uk/colour-alternatives.asp?cRange=BS+381C&cRef=BS381C+217&cDescription=Sea+green If mixing I'd start with Sky and add some dark grey to it Edited February 26, 2024 by Dave Fleming
demiles Posted February 26, 2024 Author Posted February 26, 2024 (edited) Thanks for the reply, using it as part of the unusual cam on a Taiwanese CM-34 Clouded Leopard, it is the light green below. Edited February 26, 2024 by demiles 1
rossm Posted February 26, 2024 Posted February 26, 2024 According to the old IPMS colour cross reference guide FS34227 is close. Humbrol 120 claims to be the same.
rossm Posted February 26, 2024 Posted February 26, 2024 3 minutes ago, rossm said: According to the old IPMS colour cross reference guide FS34227 is close. Humbrol 120 claims to be the same. Having found my FS595 I'd say it's not yellow enough to match your photo which is almost a lime green - Humbrol 38???
JackG Posted February 26, 2024 Posted February 26, 2024 Should try posting in the modern armour section, we may even have some members from the country of Taiwan that may help. Scalemates does not list any paints with that BSC code and Sea Green results are mostly dark examples.
303sqn Posted February 26, 2024 Posted February 26, 2024 https://www.ebay.co.uk/itm/165128517323?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338757644&toolid=20006&customid=b3825e6ce3685ffbaa51dd4362893325&_trkparms=ispr%3D1&amdata=enc%3A1vSVhwV7eR7W29RGj8FWttA38 It is car touch up paint but you should be able to thin it and use it on a model.
Troy Smith Posted February 26, 2024 Posted February 26, 2024 (edited) 5 hours ago, demiles said: Can anyone advise me on a manufacture of BS 217 Sea Green, a good substitute or provide a mix ratio for this colour. BS381C 217 - Sea green look it up on epaint https://www.e-paint.co.uk/colour-alternatives.asp 5 hours ago, demiles said: what I believe is an aircraft colou it's not specifically an aircraft colour, but part of the BSC381C range of colours. BS 381 C is NOT the WW2 standard, and it's not colour I have ever run across in the context of WW2 paint schemes. Question - why is Taiwan using a British Standard colour? Answer is likely someone has said this is similar in colour when asked. Similar is the crucial bit, epaint only shows up four similar colours. This kind of question comes up a lot, and the use of other colour standards for 'matches' is useful as long as you know the limitations, and who has provided the 'match' So, where/how did the idea that this is "BS 217 Sea Green" arise from, and what are the other colours shown? I would suspect in Taiwan an FS595 color, the US government color range, is more likely, but it may just be a local color. If it's local then you may as well eyeball a mix from the photo. As has been suggested, this should be in modern armour, not WW2 aircraft, as the real question is does anyone know what paint this is, or what paint standard does Taiwan use? The latter is much more of a rabbit hole, and this may even be classified information given tensions between China and Taiwan. Apologies if sounds like a lecture, just I have read and participated in many paint discussions on here and issues that arise. And, as always @Casey would be a good person to ask. HTH PS I put in a thread report suggesting moving it to modern armour Note, three dots top left, you can edit your post, as what you are really asking Taiwanese CM-34 Clouded Leopard, light green colour match which as a thread heading shows exactly what you are asking Edited February 26, 2024 by Troy Smith add PS
demiles Posted February 27, 2024 Author Posted February 27, 2024 Thanks for all the great information. AFV Club list the paint as Russian Green(1) but what is this colour? It turns out to be a very sickly pale green. This isn't an Federal Standard colour but the closet I could get to was 34524 but it is to light and not green enough. The reason I have placed it on the aircraft forum listed as Sea Green is that I have been looking into this colour for well over 12 months and the closet match I got was BSC381C 216 Eau de Nil however this was to light and somehow I bumped into some discussion on cockpit colours for Spitfires which seem to be either Apple Green or Sea Green, the later look like a better match for my colour and as I'm not and aircraft guy I thought I would asks the Boffins here, as I am somewhat stumped. Troy, thanks, not a lecture but good info, the other three colours are the standard NATO cam colours and have for sometime suspected that the colour is something the Taiwanese just use. 1
rossm Posted February 27, 2024 Posted February 27, 2024 Putting your photo into Photoshop the colur comes out as roughly #7da766 in RGB terms or 125,167,102 There are, or were last time I looked, various model paint matching websites that may be able to take these figures and return a suitable model paint match. I've scanned my bookmarks and found https://www.paint4models.com/Paint Conversion Chart 2010-2021.pdf and FS34258 is the closest I can see which is available in Testors as FS34258, Lifecolour Mimetic Green 1 or Pollyscale WarPac grey green. I'd probably add a touch of pure green to lift it a bit.
Graham Boak Posted February 27, 2024 Posted February 27, 2024 34 minutes ago, demiles said: Thanks for all the great information. AFV Club list the paint as Russian Green(1) but what is this colour? It turns out to be a very sickly pale green. This isn't an Federal Standard colour but the closet I could get to was 34524 but it is to light and not green enough. The reason I have placed it on the aircraft forum listed as Sea Green is that I have been looking into this colour for well over 12 months and the closet match I got was BSC381C 216 Eau de Nil however this was to light and somehow I bumped into some discussion on cockpit colours for Spitfires which seem to be either Apple Green or Sea Green, the later look like a better match for my colour and as I'm not and aircraft guy I thought I would asks the Boffins here, as I am somewhat stumped. Russian Green is what the early model producers called the colour for Russian tanks, before we knew anything better. I don't think that it was anything more than an expression of ignorance. I don't know which aircraft sites you've been visiting, but early Spitfire cockpits were indeed in apple green (whatever colour that might mean - it seems to have been a light green of some kind, but the actual colour is unidentified). Later ones were a standard colour called Grey Green. I've not seen any Sea Green mentioned before.
Troy Smith Posted February 27, 2024 Posted February 27, 2024 (edited) 17 hours ago, demiles said: the other three colours are the standard NATO cam colours and have for sometime suspected that the colour is something the Taiwanese just use. NATO camo colours are likely to be in RAL, German colour standard. https://www.e-paint.co.uk/RAL-classic-colour-chart.asp I'd be looking at RAL 6018 Yellow green or RAL 6039 Fibrous green as possibles? ------------------------------------------ EDIT - pulled out K-7 deck, does not have 6039. The nearest to the photo is 6021, but I'd also be tempted to try adding white to the NATO 6031 and see what that look like --------------------------------------------- I have a RAK K-7 deck but it'd dark here, so only artificial light so what you can see on the screen is not very representative. If the other colours are standard NATO, RAL 6031 Green, RAL 8027 Brown and RAL 9021 Black (via google) then it maybe possible to get some kind of answer as you have those as colour references, @Casey or is that twaddle? @Steben any thoughts? Edited February 28, 2024 by Troy Smith add PS
Casey Posted February 28, 2024 Posted February 28, 2024 5 hours ago, Troy Smith said: standard NATO Wasnt it just FS 34094/30051/37030 as per AR-750-1 regulation? 1
Casey Posted February 28, 2024 Posted February 28, 2024 But the photo above does not show CARC color scheme. Dark green/brown/black could be but the light green is not
Troy Smith Posted February 28, 2024 Posted February 28, 2024 2 minutes ago, Casey said: Wasnt it just FS 34094/30051/37030 as per AR-750-1 regulation? No Idea, the further you get from WW2 the less I know..... I assume that the RAL colours I mention are their FS 595 'equivalents' of these? I just googled NATO RAL and got the above. They look like the 3 colours used on a Leopard, which I assume use RAL and not FS 595, something I got cheap years ago as practice armour kit, which is the only reason I had a vague idea about the colours in the pic. Just now, Casey said: Dark green/brown/black could be but the light green is not The OP said this, which is why I went down the NATO RAL route. 18 hours ago, demiles said: the other three colours are the standard NATO cam colours and have for sometime suspected that the colour is something the Taiwanese just use. @Casey got a call to see IF the 3 were standard, could the picture be used to identify the mystery light green? Just another random paint thread which dragged me in I'm afraid.
Casey Posted February 28, 2024 Posted February 28, 2024 If it is of any help, BS217 is NOT amongst those paints: Spoiler Sample set: Humbrol (170 samples) A1701 | No 157 | Azure Blue - Matt | GU 1.3 A6238 | No 187 | Dark Stone - Matt | GU 1.5 AA0037 | No 37 | Bright Green - Matt | GU 1.4 | Opacity 75.83% AA0046 | No 46 | Orange - Matt | GU 8.5 AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8 AA0076 | No 7 | Light Buff - Gloss| GU 95.2 AA0173 | No 173 | Track Colour - Matt | GU 1.3 AA0234 | No 234 | Dark Flesh - Matt | GU 4.4 AA0343 | No 31 | Slate Grey - Matt | GU 7.5 AA0549 | No 50 | Green Mist - Metallic | GU 94.3 | Metallic AA0552 | No 51 | Sunset Red - Metallic | GU 95.3 | Metallic AA0770 | No 66 | Olive Drab - Matt | GU 5.9 AA0775 | No 70 | Brick Red - Matt | GU 3.1 AA0802 | No 73 | Wine - Matt | GU 1.3 AA0816 | No 74 | Linen - Matt | GU 7.9 AA0833 | No 75 | Bronze Green - Matt | GU 2.0 AA0847 | No 76 | Uniform Green - Matt | GU 2.1 AA0850 | No 77 | Navy Blue - Matt | GU 1.7 AA0878 | No 79 | Blue Grey - Matt | GU 4.3 AA0905 | No 82 | Orange Lining - Matt | GU 4.1 AA0919 | No 83 | Ochre - Matt | GU 5.3 AA0922 | No 84 | Mid Stone - Matt | GU 4.1 AA0967 | No 87 | Steel Grey - Matt | GU 6.9 AA0970 | No 88 | Deck Green - Matt | GU 2.0 AA1105 | No 100 | Red Brown - Matt | GU 3.8 AA1119 | No 101 | Mid Green - Matt | GU 2.9 AA1167 | No 105 | Marine Green - Matt | GU 7.1 AA1287 | No 116 | US Dark Green - Matt | GU 2.1 AA1314 | No 119 | Light Earth - Matt | GU 4.5 AA1328 | No 120 | Light Green - Matt | GU 3.1 AA1331 | No 121 | Pale Stone - Matt | GU 7.0 AA1376 | No 125 | US Dark Grey - Satin | GU 11.4 AA1393 | No 126 | US Medium Grey - Satin | GU 37.9 AA1417 | No 128 | US Compass Grey - Satin | GU 31.6 AA1420 | No 129 | US Gull Grey - Satin | GU 21.6 AA1448 | No 131 | Mid Green - Satin | GU 21.1 AA1451 | No 132 | Red - Satin | GU 11.0 AA1465 | No 133 | Brown - Satin | GU 33.0 AA1496 | No 28 | Camouflage Grey - Matt | GU 17.2 AA1523 | No 140 | Gull Grey - Matt | GU 5.4 AA1568 | No 144 | Intermediate Blue - Matt | GU 4.8 AA1599 | No 147 | Light Grey - Matt | GU 6.1 AA1609 | No 148 | Radome Tan - Matt | GU 19.1 AA1612 | No 149 | Dark Green - Matt | GU 2.9 AA1626 | No 150 | Forest Green - Matt | GU 1.4 AA1729 | No 159 | Khaki Drab - Matt | GU 2.0 AA1780 | No 164 | Dark Sea Grey - Satin | GU 25.9 AA1804 | No 166 | Light Aircraft Grey - Satin | GU 54.6 AA2248 | No 248 | RLM 78 Himmelblau - Matt | GU 3.0 AA6330 | No 195 | Dark Green - Satin | GU 31.5 AA6344 | No 196 | Light Grey - Satin | GU 29.9 AA6389 | No 200 | Pink - Gloss | GU 91.8 AA6392 | No 201 | Black - Metallic | GU 91.3 | Metallic AA6608 | No 220 | Racing Red - Gloss | GU 100.0 AA7222 | No 222 | Moonlight Blue - Metallic | GU 95.0 | Metallic AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0 AA7225 | No 225 | Middle Stone - Matt | GU 2.6 AB0047 | No 47 | Sea Blue - Gloss | GU 65.0 AB0052 | No 52 | Baltic Blue - Metallic | GU 78.7 | Metallic AB0065 | No 65 | Aircraft Blue - Matt | GU 6.3 AB0078 | No 78 | Cockpit Green - Matt | GU 4.1 AB0090 | No 90 | Beige Green - Matt | GU 9.5 AB0091 | No 91 | Black Green - Matt | GU 1.6 AB0094 | No 94 | Brown Yellow - Matt | GU 2.2 AB0104 | No 104 | Oxford Blue - Matt | GU 1.4 AB0145 | No 145 | Medium Grey - Matt | GU 2.4 AB0165 | No 165 | Medium Sea Grey - Satin | GU 17.2 AB0167 | No 167 | RAF Barley Grey - Satin | GU 9.2 AB0168 | No 168 | Hemp - Satin | GU 33.8 AB0226 | No 226 | Interior Green - Matt | GU 2.3 AB0230 | No 230 | Pru Blue - Matt | GU 1.3 AB0237 | No 237 | Desert Tan - Matt | GU 1.3 AB0238 | No 238 | Arrow Red - Gloss | GU 65.7 AB0239 | No 239 | British Racing Green - Gloss | GU 56.0 AB0240 | No 240 | RLM 02 Grau - Matt | GU 1.3 AB0241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 4.0 AB0242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.5 AB0243 | No 243 | RLM 72 Grun - Matt | GU 1.5 AB0244 | No 244 | RLM 73 Grun - Matt | GU 1.4 AB0245 | No 245 | RLM 74 Graugrun - Matt | GU 0.9 AB0246 | No 246 | RLM 75 Grauviolett - Matt | GU 1.3 AB0247 | No 247 | RLM 76 Lichtblau - Matt | GU 12.9 AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5 AB0251 | No 251 | RLM 81 Dunkelbraun - Matt | GU 0.7 AB0252 | No 252 | RLM 82 Olivgrun - Matt | GU 0.7 AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8 DB0001 | No 1 | Primer | GU 5.6 DB0002 | No 2 | Emerald Green - Gloss | GU 79.8 DB0003 | No 3 | Brunswick Green - Gloss | GU 63.0 DB0009 | No 9 | Tan - Gloss | GU 76.9 DB0010 | No 10 | Service Brown - Gloss | GU 78.0 DB0011 | No 11 | Silver - Metallic | GU 6.7 | Metallic DB0012 | No 12 | Copper - Metallic | GU 48.2 | Metallic DB0014 | No 14 | French Blue - Gloss | GU 80.5 DB0015 | No 15 | Midnight Blue - Gloss | GU 79.7 DB0016 | No 16 | Gold - Metallic | GU 6.4 | Metallic DB0018 | No 18 | Orange - Gloss | GU 78.0 DB0019 | No 19 | Red - Gloss | GU 90.2 DB0020 | No 20 | Crimson - Gloss | GU 84.2 DB0021 | No 21 | Black - Gloss | GU 45.3 DB0022 | No 22 | White - Gloss | GU 65.9 DB0023 | No 23 | Duck Egg Blue - Matt | GU 4.3 DB0024 | No 24 | Trainer Yellow - Matt | GU 3.6 DB0025 | No 25 | Blue - Matt | GU 5.1 DB0026 | No 26 | Khaki - Matt | GU 3.4 DB0027 | No 27 | Sea Grey - Matt | GU 10.5 DB0029 | No 29 | Dark Earth - Matt | GU 3.6 DB0030 | No 30 | Dark Green - Matt | GU 3.2 DB0032 | No 32 | Dark Grey - Matt | GU 11.2 DB0033 | No 33 | Black - Matt | GU 3.9 DB0034 | No 34 | White - Matt | GU 6.5 DB0036 | No 36 | Pastel Green - Matt | GU 6.9 DB0038 | No 38 | Lime - Gloss | GU 82.8 DB0040 | No 40 | Pale Grey - Gloss | GU 65.2 DB0041 | No 41 | Ivory - Gloss | GU 58.2 DB0042 | No 42 | Pastel Violet - Matt | GU 4.8 DB0044 | No 44 | Pastel Blue - Matt | GU 7.0 DB0048 | No 48 | Mediterranean Blue - Gloss | GU 71.1 DB0053 | No 53 | Gunmetal - Metallic | GU 6.1 | Metallic DB0054 | No 54 | Brass - Metallic | GU 8.0 | Metallic DB0055 | No 55 | Bronze - Metallic | GU 6.7 | Metallic DB0056 | No 56 | Aluminium - Metallic | GU 14.6 | Metallic DB0057 | No 57 | Pink - Matt | GU 5.2 DB0058 | No 58 | Magenta - Matt | GU 6.4 DB0060 | No 60 | Scarlett - Matt | GU 3.5 DB0061 | No 61 | Flesh - Matt | GU 5.9 DB0062 | No 62 | Leather - Matt | GU 3.5 DB0063 | No 63 | Sand - Matt | GU 7.1 DB0064 | No 64 | Light Grey - Matt | GU 5.9 DB0067 | No 67 | Matt Tank Grey - Matt | GU 5.2 DB0068 | No 68 | Purple - Gloss | GU 79.1 DB0069 | No 69 | Yellow - Gloss | GU 93.5 DB0071 | No 71 | Oak - Satin | GU 19.7 DB0072 | No 72 | Khaki Drill - Matt | GU 6.8 DB0080 | No 80 | Grass Green - Matt | GU 3.6 DB0081 | No 81 | Pale Yellow - Matt | GU 1.9 DB0085 | No 85 | Black - Satin | GU 19.5 DB0086 | No 86 | Light Olive - Matt | GU 9.2 DB0089 | No 89 | Middle Blue - Matt | GU 5.4 DB0093 | No 93 | Desert Yellow - Matt | GU 4.5 DB0096 | No 96 | RAF Blue - Matt | GU 6.6 DB0098 | No 98 | Chocolate - Matt | GU 3.0 DB0099 | No 99 | Lemon - Matt | GU 8.5 DB0102 | No 102 | Army Green - Matt | GU 4.6 DB0103 | No 103 | Cream - Matt | GU 6.1 DB0106 | No 106 | Ocean Grey - Matt | GU 4.4 DB0109 | No 109 | WWI Blue - Matt | GU 4.7 DB0110 | No 110 | Natural Wood - Matt | GU 6.4 DB0113 | No 113 | Rust - Matt | GU 4.9 DB0117 | No 117 | US Light Green - Matt | GU 3.5 DB0118 | No 118 | US Tan - Matt | GU 5.6 DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4 DB0127 | No 127 | US Ghost Grey - Satin | GU 19.7 DB0130 | No 130 | White - Satin | GU 27.3 DB0153 | No 153 | Insignia Red - Matt | GU 4.1 DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6 DB0155 | No 155 | Olive Drab - Matt | GU 6.2 DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3 DB0160 | No 160 | German Camouflage Red - Matt | GU 4.9 DB0163 | No 163 | Dark Green - Satin | GU 21.8 DB0171 | No 171 | Antique Bronze - Metallic | GU 7.1 | Metallic DB0174 | No 174 | Signal Red - Satin | GU 25.2 DB0186 | No 186 | Brown - Matt | GU 4.5 DB0189 | No 189 | Chrome Silver - Metallic | GU 89.6 | Metallic | Opacity 88.33% DB0208 | No 208 | Fluorescent Signal Green - Gloss | GU 11.3 | Fluorescent | Opacity 42.64% DB0209 | No 209 | Fire Orange - Gloss | GU 20.2 | Fluorescent | Opacity 34.55% MET27001 | No 27001 | Aluminium - Metalcote | GU 5.2 | Metallic MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic MET27003 | No 27003 | Polished Steel - Metalcote | GU 47.4 | Metallic MET27004 | No 27004 | Gunmetal - Metalcote | GU 5.2 | Metallic Sample set: Revell (86 samples) 36104 | White | RAL 9010 | GU 72.8 36105 | White | RAL 9001 | GU 5.7 36106 | Tar black | RAL 9021 | GU 2.3 36107 | Black | RAL 9005 | GU 79.8 36108 | Black | RAL 9011 | GU 1.4 36109 | Anthracite | RAL 7021 | GU 4.7 36112 | Yellow | RAL 1018 | GU 79.5 36115 | Yellow | RAL 1017 | GU 6.5 36116 | Sandy yellow | RAL 1024 | GU 2.6 36117 | Africa brown | GU 3.1 36125 | Luminous orange | GU 3.5 | Fluorescent 36130 | Orange | RAL 2004 | GU 87.7 36131 | Fiery red | RAL 3000 | GU 90.5 36134 | Italian Red | GU 88.5 36135 | Flesh | GU 5.9 36136 | Carmine red | RAL 3002 | GU 3.0 36137 | Reddish brown | RAL 3009 | GU 1.8 36139 | Dark green | GU 2.2 36140 | Black green | GU 2.1 36142 | Yellowish olive | GU 1.8 36143 | Medium grey USAF | GU 2.9 36145 | Light olive | RAL 7003 | GU 2.2 36146 | Nato olive | RAL 7013 | GU 1.6 36147 | Mouse grey | RAL 7005 | GU 2.4 36148 | Sea green | RAL 6028 | GU 2.1 36149 | Light blue | GU 3.1 36150 | Light blue | RAL 5012 | GU 72.9 36151 | Ultramarine | RAL 5002 | GU 85.4 36152 | Blue | RAL 5005 | GU 82.7 36154 | Night blue | RAL 5022 | GU 85.3 36155 | Light green | RAL 6027 | GU 3.3 36156 | Blue | RAL 5000 | GU 2.2 36157 | Grey | RAL 7000 | GU 3.5 36159 | Sky RAF | GU 3.4 36161 | Emerald green | RAL 6029 | GU 82.3 36162 | Sea green | RAL 6005 | GU 88.5 36165 | Bronze green | RAL 6031 | GU 2.9 36166 | Olive grey | RAL 7010 | GU 2.2 36167 | Greenish grey | RAL 7009 | GU 2.3 36168 | Dark green RAF | GU 2.1 36169 | Granite grey | RAL 7026 | GU 1.6 36174 | Gunship grey | GU 3.1 36175 | Stone grey | RAL 7030 | GU 3.5 36176 | Light grey USAF | GU 4.1 36177 | Dust grey | RAL 7012 | GU 3.8 36178 | Tank grey | RAL 7024 | GU 2.9 36179 | Greyish blue | RAL 7031 | GU 1.9 36180 | Mud brown | RAL 8003 | GU 82.2 36182 | Dark earth RAF | GU 2.1 36183 | Rust | GU 1.9 36184 | Leather brown | RAL 8027 | GU 1.9 36185 | Brown | RAL 8023 | GU 2.5 36186 | Olive brown | RAL 7008 | GU 2.2 36187 | Earth brown | RAL 7006 | GU 4.8 36188 | Ochre brown | RAL 1011 | GU 2.4 36189 | Beige | RAL 1019 | GU 2.9 36190 | Silver | GU 76.6 | Metallic 36191 | Steel | GU 4.9 | Metallic 36192 | Brass | GU 54.8 | Metallic 36193 | Copper | GU 60.8 | Metallic 36194 | Gold | GU 53.0 | Metallic 36195 | Bronze | GU 61.5 | Metallic 36199 | Aluminium | GU 9.6 | Metallic 36301 | White | RAL 9010 | GU 20.9 36302 | Black | RAL 9005 | GU 11.1 36310 | Lufthansa Yellow | RAL 1028 | GU 25.6 36312 | Luminous yellow | RAL 1026 | GU 4.9 | Fluorescent 36314 | Beige | RAL 1001 | GU 18.8 36330 | Fiery red | RAL 3000 | GU 16.2 36331 | Purple red | RAL 3004 | GU 17.8 36332 | Luminous red | RAL 3026 | GU 3.7 | Fluorescent 36350 | Lufthansa blue | RAL 5013 | GU 19.6 36360 | Fern green | RAL 6025 | GU 22.2 36361 | Olive green | RAL 6003 | GU 24.5 36362 | Greyish green | RAL 6013 | GU 12.4 36363 | Dark green | RAL 6020 | GU 21.6 36364 | Leaf green | RAL 6001 | GU 20.4 36365 | Patina green | RAL 6000 | GU 38.1 36371 | Light grey | RAL 7035 | GU 17.8 36374 | Grey | RAL 7001 | GU 20.7 36378 | Dark grey | RAL 7012 | GU 28.0 36381 | Brown | RAL 8025 | GU 42.5 36382 | Wood brown | RAL 8001 | GU 24.0 36730 | Orange | GU 87.2 | Opacity 34.45% | Transparent 36731 | Red | GU 93.0 | Opacity 42.21% | Transparent 36752 | Blue | GU 88.5 | Opacity 48.3 | Transparent Sample set: Vallejo Air (254 samples) 71.001 | White | Blanco | FS37925 | RAL9016 | RLM21 | GU 3.5 71.002 | Medium Yellow | Amarillo Medio | GU 3.0 | Opacity 59.78% 71.003 | Red RLM 23 | RLM23 Rot | RLM23 | GU 1.6 | Opacity 92.19% 71.004 | Blue | Azul | GU 1.4 71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5 71.006 | Light Green Chromate | Verde Claro Chromo | GU 1.3 71.007 | Olive Green | Verde Oliva | GU 1.2 71.008 | Pale Blue | Azul Claro | FS35414 | GU 2.0 71.009 | Eau De Nil "D.E. Green" | Verde Huevo Pato | BS216 | GU 1.8 71.010 | Interior Green | Verde Interior | FS34098 | GU 3.5 71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2 71.012 | Dark Green | Verde Oscuro | GU 2.6 71.013 | Yellow Olive | Oliva Amarillo | FS34062 | RAL6016 | GU 3.7 71.014 | Gunship Green | Verde Acorazado | GU 2.7 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.6 71.016 | USAF Olive Drab | USAF Verde Oliva | FS34088 | ANA613 | GU 2.6 71.017 | Russian Green 4BO | Verde Ruso 4BO | FS34082 | GU 2.6 71.018 | Black Green | Verde Negro | GU 3.2 71.019 | Cam. Dark Green | RAL6007 Grün | FS34083 | RAL6007 | GU 3.5 71.020 | Green Brown | Verde Pardo | GU 2.0 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 0.6 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 1.3 71.023 | Hemp | Tan Green | FS34201 | GU 2.8 71.024 | Khaki Brown | Marron Caqui | GU 2.4 71.025 | Dark Yellow | RAL7028 Dunkelgelb | RAL7028 | GU 3.0 71.026 | US Flat Brown | Marron US | FS30215 | GU 2.5 71.027 | Light Brown | Marron Claro | GU 5.2 71.028 | Sand Yellow | Amarillo Arena | GU 4.2 71.029 | Dark Earth | Tierra Oscura | GU 1.0 71.030 | Brown Green | Marron Verdoso | GU 1.7 71.031 | Middlestone | Piedra Medio | GU 1.5 71.032 | Golden Brown | Marron Dorado | GU 1.2 71.033 | Yellow Ochre | RAL1006 Gelb | RAL1006 | GU 1.7 71.034 | Sand Brown | Marron Arena | GU 1.6 71.035 | Cam. Pale Brown | Cam. Pardo Claro | FS30140 | RAL8025 | GU 2.1 71.036 | Mahogany | Caoba | GU 1.9 71.037 | Mud Brown | Marron Lodo | GU 2.0 71.038 | Cam. Medium Brown | Cam Pardo Medio | FS30097 | GU 1.3 71.039 | Hull Red | Marron Rojizo | GU 2.6 71.040 | Burnt Umber | Sombra Tostada | RAL8014 | GU 1.6 71.041 | Armour Brown | RAL8017 Rotbraun | RAL8017 | GU 1.1 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.6 71.043 | US Olive Drab | US Verde Oliva | FS34087 | GU 3.0 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.9 71.045 | Cement Grey | Gris Cemento | RAL7033 | GU 2.8 71.046 | Pale Blue Grey | Azul Gris Claro | GU 3.6 71.047 | Grey | Gris | GU 2.0 71.048 | Engine Grey | Gris Motor | FS36076 | GU 2.2 71.049 | Sea Grey | Gris Mar | GU 3.2 71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1 71.051 | Neutral Gray | Gris Neutral | FS36173 | GU 3.4 71.052 | Anthracite Grey | Gris Antracita | GU 2.2 71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9 71.054 | Dark Grey Blue | Gris Azul Oscuro | RAL7024 | GU 2.2 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 1.7 71.056 | Panzer Dk. Grey | RAL7021 Dunkelgrau | RAL7021 | GU 1.6 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 71.062 | Aluminium | Aluminio | GU 45.5 | Metallic 71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic 71.064 | Chrome | Cromo | FS17178 | GU 41.7 | Metallic 71.065 | Steel | Acero | GU 29.0 | Metallic 71.066 | Gold | Oro | FS17043 | GU 19.8 | Metallic 71.067 | Bright Brass | Laton | GU 32.1 | Metallic 71.068 | Copper | Cobre | GU 11.1 | Metallic 71.069 | Rust | Oxido | GU 7.1 | Metallic 71.070 | Signal Red | Rojo Señal | GU 6.2 | Metallic | Opacity 82.48% 71.071 | Arctic Blue | Azul Artico | GU 6.3 | Metallic 71.072 | Gunmetal | Fusil | FS37200 | GU 17.3 | Metallic 71.073 | Black | Negro | GU 14.6 | Metallic 71.074 | Beige | Beige | FS33695 | GU 2.7 71.075 | Ivory | RAL1001 Elfenbein | RAL1001 | GU 3.9 71.076 | Skin Tone | Color Piel | GU 5.1 71.077 | Wood | Madera | GU 1.7 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7 71.079 | Tan Earth | Tierra | GU 2.4 71.080 | Rust | Oxido | FS30111 | BS435 | GU 2.7 71.081 | Ochre | Ocre | GU 2.1 71.082 | Fluorescent Red | Rojo Fluorescente | FS38903 | RAL2005 | GU 2.5 | Fluorescent | Opacity 32.63% 71.083 | Orange | Naranja | GU 2.5 | Opacity 64.68% 71.084 | Fire Red | Rojo Fuego | GU 3.1 71.085 | Ferrari Red | Rojo Ferrari | GU 2.9 | Opacity 95.6% 71.086 | Light Red | Rojo Claro | GU 3.2 | Opacity 68.56% 71.087 | Steel Blue | Azul Acero | RAL5013 | GU 2.3 71.088 | French Blue | Azul Francés | GU 3.0 71.089 | Light Sea Blue | Azul Mar Claro | GU 3.5 71.090 | Deep Sky | Azul Oscuro | FS35056 | GU 1.9 71.091 | Signal Blue | Azul Señal | FS35044 | RAL5004 | ANA605 | BS106 | GU 1.7 71.092 | Medium Olive | RAL6003 Olivgrün | RAL6003 | GU 1.9 71.093 | Nato Green | Verde Otan | FS34094 | GU 2.0 71.094 | Green Zinc Chromate | Verde Zinc | GU 2.0 71.095 | Pale Green | Verde Pálido | RAL6011 | GU 2.4 71.096 | Olive Grey | Verde Oliva Grisáceo | GU 4.6 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1 71.101 | Light Blue RLM78 | RLM78 Hellblau | RLM78 | GU 5.3 71.102 | Red | Rojo | GU 3.6 | Opacity 91.71% 71.103 | Grey Blue RLM84 | RLM84 Graublau | FS36559 | RLM84 | GU 1.7 71.104 | Green RLM62 | RLM62 Grün | RLM62 | GU 3.4 71.105 | Brown RLM26 | RLM26 Braun | RLM26 | GU 2.6 71.106 | Ivory RLM05 | RLM05 Elfenbein | GU 6.3 71.107 | US Interior Yellow | US Amarillo Inter. | GU 3.0 71.108 | Uk Azure Blue | Uk Azul Azure | FS35231 | ANA609 | GU 3.1 71.109 | Faded P.R.U. Blue | M485 Blue Gray | FS35189 | BS636 | GU 1.6 71.110 | Dark Grey | Gris Oscuro | BS640 | GU 3.7 71.111 | USAF Light Blue | USAF Azul Claro | FS35109 | GU 2.1 71.112 | Sand | Arena | GU 3.5 71.113 | IDF Blue | Azul IDF | FS35177 | GU 2.4 71.114 | Medium Gray | Gris Medio | FS35237 | GU 4.2 71.115 | Blue Grey | RAL7016 Blaugrau | RAL7016 | GU 2.0 71.116 | Camouflage Grey Green | RAL7008 Graugrün | RAL7008 | GU 2.3 71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0 71.118 | Camouflage Grey | RAL7027 Grau | RAL7027 | GU 2.7 71.119 | White Grey | RAL9002 Grauweiss | RAL9002 | GU 5.2 71.120 | Dark Ghost Gray | Gris Oscuro USAF | FS36320 | GU 5.9 71.121 | Light Gull Gray | Gris Gaviota USN | FS36440 | ANA620 | GU 2.6 71.122 | US Desert Armour 686 | US Camuflaje Moderno 686 | FS33446 | ANA620 | GU 8.0 71.123 | Dark Grey RLM42 | RLM42 Dunkelgrau | RLM42 | GU 3.2 71.124 | USAF Green | Verde USAF | FS34092-ANA612 | GU 2.7 71.125 | USAF Brown | Marrón USAF | FS30219 | ANA628 | GU 2.6 71.126 | IDF/IAF Green | Verde IDF/IAF | FS34227 | BS283 | GU 4.1 71.128 | Gris Violeta | Gray Violet | FS36134 | GU 4.0 71.130 | Orange Rust | Óxido Aanaranjado | RAL2010 | GU 4.5 71.131 | Concrete | Cemento | GU 3.4 71.132 | Aged White | Blanco Envejecido | FS37769 | RAL1015 | GU 4.9 71.133 | Suciedad | Dirt | GU 6.0 71.134 | IJA Midouri Green | IJA Verde Midouri | GU 5.3 71.135 | IJA Chrome Yellow | IJA Amarillo Cromado | FS33655 | RAL1003 | GU 3.4 | Opacity 67.5% 71.136 | IJA Earth Brown | IJA Marrón Tierra | GU 1.9 71.137 | US Light Green | US Verde Claro | FS34151 | ANA611 | GU 3.1 71.138 | US Sand | US Arena | FS30277 | GU 3.2 71.139 | US Field Drab | US Marrón Verdoso | FS30118 | ANA617 | GU 3.9 71.140 | US Desert Sand | US Arena Desierto | FS30279 | ANA616 | GU 3.1 71.141 | IDF Sand Grey 73 | IDF Gris Arena 73 | GU 4.0 71.142 | IDF Sinai Grey 82 | IDF Gris Sinai 82 | GU 3.6 71.143 | UK Light Stone | UK Piedra Clara | BS361 | GU 3.9 71.244 | Sand Beige | Sandbeige | RAL1039 | GU 1.8 71.245 | Loam Beige | Lehmbeige | RAL1040 | GU 3.9 71.246 | Yellow Brown | Sandbraun | RAL8031 | GU 4.3 71.247 | Light Olive | Helloliv | RAL6040 | GU 4.2 71.248 | Brown Grey | Gris Marrón | RAL7050 | GU 5.6 71.249 | Nato Brown | Lederbraun | FS30051 | RAL8027 | GU 1.9 71.250 | Bronze Green | Bronzegrün | RAL6031 | GU 2.3 71.251 | Nato Black | Teerschwarz | FS37030 | RAL9021 | GU 0.4 71.255 | Light Blue RLM65 | RLM65 Hellblau | RLM65 | GU 1.7 71.256 | Green RLM73 | RLM73 Grün | RLM73 | GU 3.2 71.257 | Light Blue RLM76 | RLM76 Lichtblau | RLM76 | GU 1.7 71.258 | Grey Green RLM74 | RLM74 Graugrün | RLM74 | GU 1.4 71.259 | Grey Violet RLM75 | RLM75 Grauviolett | RLM75 | GU 1.5 71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5 71.263 | Green RLM72 | RLM72 Grün | RLM72 | GU 2.6 71.264 | Brown Violet RLM81 | RLM81 Braunviolett | RLM81 | GU 1.2 71.265 | Olive Green RLM80 | RLM80 Olivgrün | RLM80 | GU 2.9 71.266 | Dark Blue RLM24 | RLM24 Dunkelblau | RLM24 | GU 4.9 71.267 | Light Green RLM25 | RLM25 Hellgrün | RLM25 | GU 4.7 71.268 | German Grey | RAL6006 Feldgrau | RAL6006 | GU 2.2 71.269 | Red | RAL3000 Rot | RAL3000 | GU 5.3 71.270 | Off-White | RAL9001 Weiss | RAL9001 | GU 4.9 71.271 | German Red Brown | RAL8012 Rotbraun | RAL8012 | GU 3.2 71.272 | German Yellow Brown | RAL8000 Gelbbraun | RAL8000 | GU 2.3 71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629 | GU 3.9 71.274 | Aggressor Gray | Gris Aggressor | FS36251 | GU 4.7 71.275 | USAF Medium Gray | USAF Gris Medio | FS36270 | GU 5.5 71.276 | USAF Light Gray | Gris Claro | FS36495 | GU 6.2 71.277 | Dark Gull Gray | Gris Gaviota Oscuro | FS36231 | ANA621 | GU 1.7 71.278 | Sand Yellow RLM79 | RLM79 Sandgelb | RLM79 | GU 3.7 71.279 | Insignia White | Blanco Insignia | FS37875 | ANA601 | GU 5.2 71.280 | Camouflage Gray | Gris Camuflaje | FS36170 | GU 5.0 71.281 | 3B Russian Green | 3B Verde Ruso | GU 6.7 71.282 | 6K Russian Brown | 6K Marrón Ruso | GU 5.5 71.283 | 7K Russian Tan | 7K Tierra Rusa | GU 8.6 71.284 | Uk Light Mud | Uk Marrón Claro | GU 9.3 71.285 | IJA Dark Green | IJA Verde Oscuro | GU 10.3 71.286 | IJA Olive Green | IJA Verde Oliva | GU 6.9 71.287 | IJA Khaki Brown | IJA Marrón Caqui | GU 4.7 71.288 | UK BSC 64 Portland Stone | UK BSC 64 Piedra Portland | GU 9.9 71.289 | US Dark Green | US Verde Oscuro | FS34102 | GU 4.4 71.290 | US Earth Brown | US Tierra Marrón | FS30099 | GU 5.1 71.291 | US Earth Yellow | US Tierra Amarilla | FS30257 | GU 4.6 71.292 | US Loam | US Marrón Barro | FS34086 | GU 7.6 71.293 | US Earth Red | US Tierra Roja | FS30117 | GU 6.8 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 71.295 | USN Sea Blue | USN Azul Marino | FS35042 | ANA607 | GU 2.2 71.296 | USAAF Light Gray | Curtiss Grey | FS36622 | GU 5.1 71.297 | JGSD Brown 3606 | JGSD Marrón 3606 | GU 6.4 71.298 | M495 Light Gray | M495 Gris Claro | FS36357 | GU 1.8 71.299 | Intermediate Blue | Azul Intermedio | FS35164 | ANA608 | GU 2.5 71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6 71.301 | Amt-4 Camouflage Green | Amt-4 Camuflaje Verde | GU 5.8 71.302 | Sky Type S | Verde Cielo | BS210 | GU 2.5 71.303 | A-24M Camouflage Green | A-24M Verde Camuflaje | GU 7.1 71.304 | Amt-11 Blue Grey | Amt-11 Azul Grisáceo | GU 6.7 71.305 | Interior Grey Green | Interior Gris Verde | FS34373 | GU 3.7 71.306 | Sky Blue | Azul Cielo | FS35550 | GU 3.5 71.307 | BS Medium Sea Grey | BS Gris Mar Medio | BS637 | GU 5.3 71.308 | Amt-12 Dark Grey | Amt-12 Gris Oscuro | GU 6.0 71.309 | Dark Slate Grey | Gris Pizarra Oscuro | FS34096 | BS634 | GU 1.9 71.310 | IJN Deep Dark Green | IJN Verde Oscuro Intenso | GU 2.0 71.311 | IJN Ash Grey | IJN Gris Ceniza | GU 2.4 71.312 | IJN Medium Grey | IJN Gris Medio | GU 2.2 71.313 | Dark Mediterranean Blue | Azul Mediterraneo Oscuro | GU 1.3 71.314 | Seaplane Gray | Gris Hidroavión | FS36081 | ANA625 | GU 3.8 71.315 | Tire Black | Negro Caucho | GU 1.2 71.316 | N. 41 Dark Olive Drab | N. 41 Verde Oliva Oscuro | GU 2.9 71.317 | AII SV. Gol Light Blue | AII SV. Gol Azul Claro | GU 3.2 71.318 | Amt-7 Greyish Blue | Amt-7 Azul Grisáceo | GU 1.7 71.319 | A-28M Greyish Blue | A-28M Azul Grisáceo | GU 2.8 71.320 | Amt-1 Light Greyish Brown | Amt-1 Marrón Grisác. Claro | GU 1.6 71.321 | Sky Green | IJA Light Grey Green | FS34424 | ANA610 | GU 2.4 71.322 | IJN Black Green | IJN Verde Negro | GU 1.3 71.323 | BS Dark Earth | BS Tierra Oscura | BS450 | GU 1.6 71.324 | BS Dark Green | BS Verde Oscuro | BS241 | GU 1.7 71.325 | IJN Dark Black Green | IJN Verde Negro Oscuro | GU 2.4 71.326 | IJA Grey Green | IJA Gris Verdoso | GU 7.2 71.327 | IAF Sand | Arena IAF | FS33531 | GU 1.7 71.328 | Light Blue | Azul Claro | FS35622 | GU 2.6 71.329 | Green | Verde | FS34159 | GU 5.0 71.330 | Khaki Green Num. 3 | Verde Caqui Nº3 | GU 2.1 71.331 | Cockpit Eme. Green “Faded” | Verde Interior Cabina | GU 1.6 71.332 | Underside Blue “Faded” | Azul Desgastado | FS35450 | GU 2.3 71.333 | Russian AF Blue | Azul AF Ruso | GU 2.0 71.334 | Flanker Light Blue | Azul Claro Flanker | GU 2.9 71.335 | Flanker Light Gray | Gris Claro Flanker | GU 3.8 71.336 | A-14 Steel Grey | A-14 Gris Acero | GU 1.7 71.337 | Flanker Blue | Azul Flanker | GU 3.0 71.338 | Russian AF Grey Blue | Gris Azul AF Ruso | GU 2.7 71.339 | Russian AF Grey N.3 | Gris N.3 AF Ruso | FS36373 | GU 2.3 71.340 | Grey Green | Gris Verdoso | GU 1.8 71.341 | Green Grey | Verde Grisáceo | GU 1.8 71.342 | Russian AF Light Blue | Azul Claro AF Ruso | GU 2.6 71.343 | Russian AF Grey N.7 | Gris N.7 AF Ruso | GU 1.9 71.344 | Russian AF Grey Prot. Coat | Gris AF Ruso | GU 2.8 71.345 | Russian AF Grey N.8 | Gris N.8 AF Ruso | GU 2.3 71.346 | Russian AF Grey N.4 | Gris N.4 AF Ruso | GU 2.5 71.347 | Russian AF Dark Green | Verde Oscuro AF Ruso | GU 1.4 71.348 | USAF Tan | USAF Marrón Arena | FS20400 | GU 2.0 71.400 | Uk Desert Pink | Uk Rosa Desierto | GU 2.1 71.401 | Uk Bsc 28 Sil. Grey | Uk Bsc28 Gris Plata | GU 1.8 71.402 | Uk Bsc 49 L. Purple Br. | Uj Bsc49 Mr. Purpura | GU 2.5 71.403 | Light Green | Verde Claro | GU 2.0 71.404 | No. 1 "Duck Egg Blue" | Azul Huevo De Pato | GU 1.8 71.405 | BS Dark Sea Grey | BS Gris Mar Osc. | GU 1.3 71.406 | Light Slate Grey | Gris Pizarra Claro | GU 1.5 71.407 | Sky Grey | Gris Cielo | FS36463 | GU 3.8 71.408 | PRU Pink | PRU Rosa | GU 3.7 71.409 | Zaschchitnyi Khaki | Verde Zaschcitnyi | GU 1.3 71.410 | AII Zashchitnyi Cam. Green | AII Verde Zaschitnyi | GU 1.2 71.411 | A-19F Grass Green | A-19F Verde Hierba | GU 1.5 71.412 | VVS Grey Blue | VVS Gris Azulado | GU 7.4 71.413 | A-18F Light Blue | A-18F Azul Claro | GU 8.8 71.414 | AEH-9 Light Grey | AEH-9 Gris Claro | GU 2.7 71.415 | A-21 Light Greyish Br. | A-21 Mr. Gris. Claro | GU 1.7 71.416 | IJA Dark Beige | IJA Beige Oscuro | GU 1.3 71.417 | "Aotake" Trans. Green | "Aotake" Verde Trans | GU 31.2 | Opacity 56.37% 71.418 | IJN Medium Brown | IJN Maroon Medio | GU 1.3 71.419 | "Aotake" Trans. Blue | "Aotake" Azul Trans. | GU 17.3 | Opacity 87.81% Sample set: Hataka (10 samples) HTK-A009 | Dark Earth | GU 9.1 HTK-A015 | Black-Green (RLM70) | GU 7.9 HTK-A016 | Dark Green | GU 9.6 HTK-A017 | Dark Green (RLM71) | GU 10.5 HTK-A023 | Grey (RLM02) | GU 14.1 HTK-A025 | Interior Grey-Green | GU 17.4 HTK-A026 | Sky "Type S" | GU 13.1 HTK-A029 | Light Blue (RLM65/78) | GU 13.2 HTK-A032 | Ocean Grey | GU 13.3 HTK-A034 | Medium Sea Grey | GU 14.2 Sample set: Lifecolor (12 samples) UA 501 | RLM 70 - Schwarzgrün | GU 9.2 UA 502 | RLM 71 - Dunkelgrün | GU 11.3 UA 503 | RLM 65 - Hellblau | GU 9.1 UA 504 | RLM 02 Grau | GU 6.5 UA 505 | RLM 79 - Sandgelb II | GU 8.7 UA 506 | RLM 80 Olivgrün | GU 8.1 UA 546 | Dark Green | *FS 34079 | GU 7.0 UA 547 | Dark Earth | *FS 30118 | GU 6.3 UA 548 | Light Green | FS 34102 | GU 6.4 UA 549 | Light Earth | FS 30257 | GU 6.8 UA 550 | Sky | FS 34424 | GU 6.4 UA 551 | Grey Green | FS 34226 | GU 9.0 Sample set: Army Painter Warpaints (104 samples) WP1101 | Matt Black | GU 0.7 WP1102 | Matt White | GU 3.6 WP1104 | Pure Red | GU 2.5 WP1105 | Dragon Red | GU 2.7 WP1106 | Lava Orange | GU 2 WP1107 | Daemonic Yellow | GU 3.6 WP1108 | Necrotic Flesh | GU 2.1 WP1109 | Goblin Green | GU 0.9 WP1110 | Army Green | GU 2.1 WP1111 | Greenskin | GU 1.2 WP1112 | Angel Green | GU 1.6 WP1113 | Electric Blue | GU 2.2 WP1114 | Crystal Blue | GU 1.7 WP1115 | Ultramarine Blue | GU 2.4 WP1116 | Deep Blue | GU 4.3 WP1117 | Ash Grey | GU 1.4 WP1118 | Uniform Grey | GU 1.6 WP1119 | Wolf Grey | GU 2 WP1120 | Monster Brown | GU 1.7 WP1121 | Desert Yellow | GU 2.1 WP1122 | Fur Brown | GU 3.1 WP1123 | Leather Brown | GU 3.3 WP1124 | Oak Brown | GU 1.9 WP1125 | Skeleton Bone | GU 2.5 WP1126 | Barbarian Flesh | GU 1.5 WP1127 | Tanned Flesh | GU 1.3 WP1128 | Alien Purple | GU 1.7 WP1129 | Shining Silver | GU 28.6 | Metallic WP1130 | Plate Mail Metal | GU 33.8 | Metallic WP1131 | Gun Metal | GU 28.2 | Metallic WP1132 | Greedy Gold | GU 32.6 | Metallic WP1133 | Weapon Bronze | GU 39.2 | Metallic WP1141 | Hydra Turquoise | GU 2 WP1142 | Chaotic Red | GU 1.3 WP1144 | Bright Gold | GU 24.7 | Metallic WP1401 | Abomination Gore | GU 2.8 WP1402 | Arid Earth | GU 2.4 WP1403 | Babe Blonde | GU 4.8 WP1404 | Banshee Brown | GU 1.5 WP1405 | Basilisk Brown | GU 2.7 WP1406 | Brainmatter Beige | GU 3.9 WP1407 | Castle Grey | GU 1.6 WP1408 | Centaur Skin | GU 2.2 WP1409 | Combat Fatigues | GU 3.2 WP1410 | Commando Green | GU 3.1 WP1411 | Corpse Pale | GU 3.3 WP1412 | Crusted Sore | GU 1.3 WP1413 | Crypt Wraith | GU 1.9 WP1414 | Cultist Robe | GU 1.3 WP1415 | Dark Sky | GU 8.4 WP1416 | Dirt Spatter | GU 1.7 WP1417 | Drake Tooth | GU 2 WP1418 | Dungeon Grey | GU 1.1 WP1419 | Elemental Bolt | GU 2.5 WP1420 | Elf Green | GU 2.7 WP1421 | Elven Flesh | GU 2.6 WP1422 | Orc Blood | GU 2.3 WP1424 | Filthy Cape | GU 2.4 WP1425 | Dark Stone | GU 2.6 WP1426 | Fire Lizard | GU 4.2 WP1427 | Fog Grey | GU 1.4 WP1428 | Gorgon Hide | GU 2.3 WP1429 | Griffon Blue | GU 1.9 WP1430 | Hardened Carpace | GU 1.8 WP1431 | Hemp Rope | GU 3 WP1432 | Ice Storm | GU 1.7 WP1433 | Jungle Green | GU 2.9 WP1434 | Kobold Skin | GU 2.4 WP1435 | Kraken Skin | GU 4.2 WP1436 | Mars Red | GU 3.1 WP1437 | Toxic Mist | GU 1.8 WP1438 | Moon Dust | GU 3.8 WP1439 | Mouldy Clothes | GU 1.4 WP1440 | Mummy Robes | GU 4.1 WP1441 | Mutant Hue | GU 1.9 WP1442 | Mythical Orange | GU 4.4 WP1443 | Necromancer Cloak | GU 1.3 WP1444 | Grimoire Purple | GU 1.7 WP1445 | Oozing Purple | GU 1.6 WP1446 | Phoenix Flames | GU 3.5 WP1447 | Pixie Pink | GU 1.3 WP1448 | Poisonous Cloud | GU 4.4 WP1449 | Royal Cloak | GU 3.5 WP1450 | Scaly Hide | GU 3.2 WP1451 | Warlock Purple | GU 2.4 WP1452 | Voidshield Blue | GU 1.9 WP1453 | Snake Scales | GU 2.5 WP1454 | Spaceship Exterior | GU 2.4 WP1455 | Stone Golem | GU 2 WP1456 | Sulfide Ochre | GU 2.6 WP1457 | Toxic Boils | GU 1.8 WP1458 | Troglodyte Blue | GU 1.5 WP1459 | Troll Claws | GU 3.7 WP1460 | Vampire Red | GU 2.7 WP1461 | Venom Wyrm | GU 3.5 WP1462 | Viking Blue | GU 3 WP1463 | Wasteland Soil | GU 2 WP1464 | Werewolf Fur | GU 2.6 WP1465 | Witch Brew | GU 3.6 WP1466 | Wizards Orb | GU 0.9 WP1467 | True Copper | GU 28.3 | Metallic WP1468 | Rough Iron | GU 16.3 | Metallic WP1480 | Scar Tissue | GU 1.9 WP1481 | Field Grey | GU 2.3 Sample set: Tamiya (40 samples) XF-1 | Flat Black | GU 3.5 XF-10 | Flat Brown | GU 4.1 XF-11 | J.N. Green | GU 3.9 XF-12 | J.N. Gray | GU 1.9 XF-13 | J.A. Green | GU 8.2 XF-14 | J.A. Grey | GU 8.8 XF-15 | Flat Flesh | GU 15.2 XF-16 | Flat Aluminum | GU 6.7 | Metallic XF-17 | Sea Blue | GU 4.6 XF-18 | Medium Blue | GU 6.5 XF-19 | Sky Grey | GU 7.1 XF-2 | Flat White | GU 7.3 XF-20 | Medium Grey | GU 3.8 XF-21 | Sky | GU 6.7 XF-22 | RLM Grey | GU 4.3 XF-23 | Light Blue | GU 4.5 XF-24 | Dark Grey | GU 5.8 XF-25 | Light Sea Grey | GU 4.5 XF-26 | Deep Green | GU 5.3 XF-27 | Black Green | GU 2.1 XF-28 | Dark Copper | GU 5.3 | Metallic XF-3 | Flat Yellow | GU 3.8 XF-4 | Yellow Green | GU 5.1 XF-49 | Khaki | GU 5.5 XF-5 | Flat Green | GU 2.8 XF-50 | Field Blue | 7.1 XF-51 | Khaki Drab | GU 4.9 XF-52 | Flat Earth | GU 5.3 XF-53 | Neutral Grey | GU 6.6 XF-54 | Dark Sea Grey | GU 6.5 XF-55 | Deck Tan | GU 19.1 XF-56 | Metallic Grey | GU 6.3 | Metallic XF-57 | Buff | GU 18.2 XF-58 | Olive Green | GU 6.1 XF-59 | Desert Yellow | GU GU 20.7 XF-6 | Copper | GU 4.5 | Metallic XF-60 | Dark Yellow | GU 13.0 XF-7 | Flat Red | GU 0.9 XF-8 | Flat Blue | GU 3.4 XF-9 | Hull Red | GU 4.2 Sample set: Heller (3 samples) 002 | Emerald Green | Gloss | GU 28.8, 65.3, 84.3 | Opacity 71.69% 003 | Brunswick Green | Gloss | GU 3.3, 23.4, 52,3 | Opacity 98.95% 005 | Dark Admiralty Grey | Gloss | GU 9.6, 41.7, 70.7 | Opacity 100% Sample set: AK Interactive - 3G Acrylics (30 samples) AK11801 - WWI German Fokker Grey | GU 0.1, 0.8, 3.2 AK11802 - WWI German Light Green | GU 0.3, 1.2, 3.9 AK11803 - WWI German Dark Green | GU 0.0, 0.6, 3.3 AK11804 - WWI German Mauve | GU 0.1, 1.0, 3.6 AK11805 - WWI German Red Brown | GU 0.0, 0.4, 3.0 AK11806 - WWI German Light Blue | GU 1.1, 7.4, 30.9 AK11807 - WWI German Lilac | GU 0.2, 0.8, 3.1 AK11808 - WWI German Grey-Green Primer | GU 0.6, 2.1, 4.6 AK11809 - PC10 Late | GU 0.1, 1.2, 4.3 AK11810 - PC12 | GU 0.1, 0.8, 3.7 AK11811 - RLM 02 - RLM Grau (1938) | GU 0.4, 1.4, 3.8 AK11812 - RLM 02 - RLM Grau (1941) | GU 0.2, 0.9, 3.8 AK11813 - RLM 04 | GU 1.4, 2.6, 5.0 | Opacity 81.54% AK11814 - RLM 61 | GU 0.0, 0.6, 3.0 AK11815 - RLM 62 | GU 0.1, 0.7, 4.2 AK11816 - RLM 63 | GU 0.3, 1.2, 4.0 AK11817 - RLM 65 (1938) | GU 1.1, 7.8, 32.6 AK11818 - RLM 65 (1941) | GU 0.9, 5.9, 29.2 AK11819 - RLM 66 (1938) | GU 0.1, 1.1, 4.0 AK11820 - RLM 66 (1941) | GU 0.1, 0.8, 3.9 AK11821 - RLM 70 | GU 0.1, 0.8, 4.0 AK11822 - RLM 71 | GU 0.1, 0.6, 4.0 AK11823 - RLM 72 | GU 0.0, 1.0, 4.2 AK11824 - RLM 73 | GU 0.0, 0.8, 4.0 AK11825 - RLM 74 | GU 0.1, 0.7, 3.2 AK11826 - RLM 75 | GU 0.1, 0.9, 3.4 AK11827 - RLM 76 Version 1 | GU 1.2, 6.7, 23.4 AK11828 - RLM 76 Version 2 | GU 1.3, 6.6, 25.1 AK11829 - RLM 76 Late War Variation | GU 1.2, 4.9, 29.0 AK11830 - RLM 78 (1941) | GU 0.8, 8.2, 38.6 I suspect you need mixes.
JackG Posted February 28, 2024 Posted February 28, 2024 Except for the main gun which is made by Northrop Grumman, the vehicle was designed and manufactured in Taiwan. A model kit of the subject that is also made in Taiwan, does not have a direct hobby paint match but suggest a 2 to 1 mix of C64 and C39 from GSI Creos Mr Color brand. The sample profile artwork is washed out as found at HobbySearch but have seen a video review on youtube and it looks more closely like the photo at the beginning of this thread. 2
demiles Posted February 28, 2024 Author Posted February 28, 2024 Thanks again to all, I think I may have found something it is modo NEO Military Arms Color Lacquer Paint M-522 Emerald Green, made in Taiwan and it seems to come close to what I am after. Cheers 5 hours ago, Troy Smith said: Just another random paint thread which dragged me in I'm afraid. Sorry 1
rossm Posted February 28, 2024 Posted February 28, 2024 On 2/27/2024 at 10:17 AM, rossm said: Putting your photo into Photoshop the colur comes out as roughly #7da766 in RGB terms or 125,167,102 1 hour ago, demiles said: NEO Military Arms Color Lacquer Paint M-522 Emerald Green, That comes out at #73a81a in Photoshop so not quite as blue but doesn't look too much different on screen - good enough for government work I'd say 😉 1
JackG Posted February 28, 2024 Posted February 28, 2024 That NEO paint shade was suggested here almost two years ago . . . Note too in that older thread a set of colour instructions from AFV Club brand were also posted, and in that example the Russian Green from Creos is advised to match the required light green. There is something odd why the paint jar does not match the painted spoons Another advertisment for the same paint colour 1
Casey Posted February 28, 2024 Posted February 28, 2024 @JackG thats a good catch! I should add creos to list of paints to measure one day. I wish the person doing the spoonwork had a spectrophotometer
Mr_Sworld Posted February 28, 2024 Posted February 28, 2024 3 hours ago, Casey said: @JackG I should add creos to list of paints to measure one day. Oh please do. I'm thinking of jumping to lacquer for more modern-day colours. MRP and Mr Color seem to be the go-to choice at the moment.
demiles Posted February 29, 2024 Author Posted February 29, 2024 Have tried C135 but it doesn't contrast with NATO Green in a similar fashion to the photo, but thanks.
Casey Posted February 29, 2024 Posted February 29, 2024 41 minutes ago, demiles said: Have tried C135 but it doesn't contrast with NATO Green in a similar fashion to the photo, but thanks. I'll get you some mixes for BS 217 in a couple of hours. It could be good enough of a match, if there is no better information.
