WIP Hasegawa 1/48 Spitfire Mk IXc to Mk XII
Fingers are crossed someone here can help. I am working on a Hasegawa Mk IXc and have the 1/48 Aries/Eduard aftermarket Merlin, engine mount, Mk XII cowling, cockpit and canons however does anyone know if there are any 1/48 resin Griffons with mounts out there? Else looks like I may have to proceed as a IXc. ūüėē
Thanks in advance!
Album: https://www.flickr.com/photos/194245204@N04/albums/72177720315076164/with/53551758831/
Cockpit 3
Gun Bay
Cockpit 3
Scratch Built Older Version Oil Cooler
Erm, several points here.
I do not know of a exposed Griffon for the single stage Griffon models.
The single stage Griffon are only in Spitfire XII, Seafire XV and XVII. All the others are two stage supercharger and are longer at the rear of engine.
Have you searched Scalemates?
Also you would need a new prop and spinner.
You want a Mk.XII, start with  Mk
XII kit to be honest, the Special Hobby is better than the Airfix kit, despite what you might read.
Re the build, you have already added the smaller oil cooler, correct for  Mk.XII or Mk.V,  not any of the Merlin 60 variants.
Detail points
The external wheel well, the circular tyre bit is underside colour, not internal colour.
The small tear drop bulges on upper wing over wheel Wells are post war only for use with the 3 spoke wheel.
The circular hole on the fuel tank in front of cockpit is a filler cap, you appear to have filled this.
Flaps are normally retracted on the ground, only dropped for maintenance.
The Hasegawa kit is noted for having an undersized rear fuselage, the Eduard Merlin 60 kits basically have made all the others obsolete.
The Hase kit looks fine on its own, but can look odd next to a correctly proportioned model.
What you have done so far look great,  I'd just fix the radiator and make  Mk.IX.
HTH
Hi Troy, much appreciated on all the good intel!
I'll start that search for the kit. I found one yesterday but it was mostly/all metal kit. Do know of any good references and photos for the Mk. XII? Info on the internet at the time when I started researching was very sparse, photos even sparser and walk arounds pretty much non existent. The fuel filler cap was filled in based on some of the photos I did manage to find. Time to un-fill, clean, put cap back on time and easy enough to restore the other radiator with some good old fashioned card stock. I will say I love Eduard, Squadron and other aftermarket add-ons. Wish they had them when I was a kid!
OK, to give you an idea, try this
https://www.britmodeller.com/forums/index.php?/topic/235067463-so-whats-actually-wrong-with-special-hobbys-spitfire-xii/
so you can see various peoples views on the kit.  Bear in mind my comment on some of the cross kitting.
Why bother, it's easier to fix the kits issues if you can see them.
Again, easiest way to do Spitfire XII in 1/48th is the Special Hobby kit, fixed if you need.   The Airfis kit is likely an easier build, but has a load of issues.
or
https://www.britmodeller.com/forums/index.php?/topic/234995521-building-a-better-spitfire-xii/
Which if nothing else deal with many of the questions and details of the airframe.
There are more threads, dealing with doing this in 1/72nd.
There are plenty online, this is a useful selection.
https://www.raf-in-combat.com/downloads/spitfire-mk-xii/
I assume these are all in this
https://www.raf-in-combat.com/downloads/squadrons-no-5-the-supermarine-spitfire-mk-xii/
They were only 100 built, and the only combat use was by 41 and 91 Squadrons, and later with an AA co-operation unit, 595 Sq, of which I know of 1 photo
Spitfire F. XII MB837 of 595 Squadron during the summer 1945.
also
https://www.destinationsjourney.com/historical-military-photographs/supermarine-spitfire-mk-xii/
Spitfire-F-Mk-XII-MB882-%C2%91EB-B%C2%92
this got discussed on here, as the Griffon was powerful, and also the prop rotates in the opposite direction to the Merlin, ground crew tended to use different pressures in the oleo legs to counter act this, hence the lopsided angle above.
The photos in the links cover the subject very well, actually I can only think of a few more not in the links, these cover most angles well.
Casidio Spitfire XIV I presume?
Aires did a set for the Airfix Spitfire 22/24
this is two stage Griffon,  but the main engine block is the same, as are the front parts of the engine bearers, as is the front section of the cowling.
  Grand Phoenix did a boxing of the Airfix kit, well, the Seafire, as a special edition with a resin engine
https://www.cybermodeler.com/hobby/kits/gp/kit_gp_seafire.shtml
which maybe findable in the USA on the used market.
while you are unlikely to find images of Spitfire XII uncolwed there are warbird Spitfire XV and XVII
http://www.venturapublications.com/news/publish/Seafire-engine-detail.shtml
You can get the SH XII kit in the USA easily
eg
https://spruebrothers.com/sph48107-1-48-special-hobby-supermarine-spitfire-mk-xii/
Have a read, and if you would like clarifications ask away.
HTH
As my old chief of smoke used to say "fantabulious". I believe you have me back on the right heading, straight and level and with engine leaned just right. Very much appreciate all of the info and references. Looks like it is going to be Sprue Brothers and Aires to the rescue and the Mk. IXc going back to a Mk/ IXc. Btw, love the avatar, been a long long long while since I've watched Clockwork Orange. Found and am following you on Flickr. I'm the one called "Gruntpa" there. May see if I can change my handle here to match.
I did that when I first joined...  I did the colour shift as I like blue.  I'd have to think why I picked it, it was a long time ago.
The B-52 looks like box art?  From the user name possibly ex USAF?
it's an awful lot easier to find information when you know what too look for and what to filter out.
You can change your user name, you just need to ask @Mike  nicely, though I don't know if 'Gruntpa' is that flattering.
45 minutes ago, SgtMac7 said:
Aires to the rescue
If you want the single stage Griffon you need to so some surgery and research.  It near heresy one here but I'm not that interested in Spitfires, but it's hard to get away from the damn things on  here..
Not sure where in the frozen north east USA,  one of members @gingerbob who does know an awful lot about Spitfire is Maine.
Re Griffon
this in the caption (to right) is listed as Griffon Mk.II - Spitfire XII
52739772641_4c5d468f35_b.jpgRolls Royce Griffon II / 88 by Thomas Vogt, on Flickr
this is Griffon 65, note the two sets of impellers at the rear for the two stage supercharger, which is why it's longer,
as you can see the main engine block is basically the same, it the stuff at the back that's different.
There will be images of Seafire XV/XVII warbirds with the cowls off so you can see how the engine bearers look, though I the the rear parts are just shorter.
Be worth asking in the WW II section.
HTH
Roger that and true, Spitfires everywhere, same for the Mustang D variants and understood the avatar. Box art is the first kit I ever built, was a Christmas present. Monogram 1/72 B-52D kit (with jet engine whistle noise maker inside) from 1968, dad bought it for me and it did NOT fit under the tree. I'll email Mike on the name change thanks! Gruntpa, in case anyone is curious, is American military slang for someone who is old in a profession where most die young. Did my time, did pretty decently and then was lucky enough to retire back in '05 after a couple of deployments.
