P-47D-25RE Thunderbolt Advanced Kit (48001) 1:48
Mike
1:48 MiniArt via Creative Models Ltd
The Thunderbolt developed from a series of less-than-successful earlier designs that saw Seversky aviation change to Republic, and the project designation from P-35, to P-43 and P-44, each with its own aggressive sounding name. After a realisation that their work so far wasn't going to cut it in the skies over war-torn Europe, they went back to the drawing board and produced the P-47A that was larger, heavier and sported the new Pratt & Whitney R-2800 18-cylinder radial that would also power the B-26 Marauder, P-61 Black Widow and F4U Corsair. With it they added eight .50cal Browning machine guns aligned along the axis of flight in the wing leading edge.
The P-47A was still a small aircraft, and was initially ordered without military equipment to allow faster completion, but it was considered inferior to the competition then available, so an extensive re-design was ordered that resulted in the much larger P-47B, firing up to 100 rounds per second from the eight .50cal wing guns, and with a maximum speed of over 400mph, leaving just the fuel load slightly short of requirements.  It first flew mid-1941, and despite being a heavy-weight, its performance was still excellent, and the crash of the prototype didn’t affect the order for over 700 airframes, which were fitted with a more powerful version of the R-2800 and a sliding canopy that made ingress and egress more streamlined, particularly when bailing out of a doomed aircraft.  Minor re-designs to early production airframes resulted in a change to the P-47C, which meant that fewer than 200 Bs were made, the C benefitting from improved radio, oxygen systems, and a metal rudder to prevent flutter that had been affecting control at certain points in the performance envelope.  A quick way to spot a B is the forward raked aerial mast behind the cockpit, as this was changed to vertical on the C and beyond.  The production from a new factory that had been opened to keep up with demand led to the use of the D suffix, although they were initially identical to the C, but the cowling flaps were amended later, making it easier to differentiate.  Of course, the later bubble-canopy P-47s were far easier to tell apart from earlier marks, and constant improvement in reliability, performance and fuel load was added along the way.  The P-47D-25 carried more fuel for extended range, including piping for jettisonable tanks on the bomb racks for even more fuel. Taking a cue from the British designers, the bubble-top was developed and that improved all-round visibility markedly, although like the bubble-top Spitfires, later models incorporated a fin extension to counter the yaw issues that resulted.  Its weight, firepower and seemingly unstoppable character led to the nickname ‘Juggernaut’, which was inevitably shortened to ‘Jug’ and led to many, many off-colour jokes during and after the war.  Jokes that are still soldiering on to this day, despite being eligible for a pensioner’s bus pass.
The Jug was used extensively in the European theatre as an escort fighter, where it performed well in its ideal high-altitude environment. Later in the war when the Luftwaffe was a spent force, it also went on to become a highly successful ground attack fighter, strafing and bombing targets of opportunity, and eschewing camouflaged paintwork to add some extra speed with a smooth (and shiny) bare metal finish.  As well as flying with the US forces, many P-47s were flown by the other Allies, including the British, Russians, and after the war many other countries as the remainder were sold off as war surplus.
The Kit
This is a reboxing of a brand-new tooling from MiniArt, and is branded an Advanced Kit because it includes an additional sprue of plastic parts, and a fret of Photo-Etch (PE) brass to increase the level of detail of the kit, including the gun bays, and the ability to open the engine cowlings to display the excellent detail that is hidden away on the Basic Kit.  The kit arrives in one of MiniArt’s sturdy top-opening boxes with a dramatic painting of the subject on the front, and profiles of the decal options on one side, reserving the other side for practical details and text.  Inside the box are twenty-two sprues in grey styrene, although in our sample many of the sprues were handily still connected by their runners, which simplified photography.  There is also a clear sprue, a sheet of PE in a cardboard envelope, two sheets of decals, and the instruction booklet, which is printed on glossy paper in colour, with profiles for the decal options on the front pages, plus detailed painting and decaling information for the weapons and tanks on the back page.  Detail is beyond excellent, as we’ve come to expect from MiniArt in the last several years, with fine engraved panel lines, recessed rivets, plus raised and recessed features where appropriate, as well as fine detail in the cockpit, wheel bays, plus gun bays in the wings and engine.  If you’ve seen their AFV kits you’ll know what to expect, but this is special in this reviewer’s humble opinion.
New Sprue & Photo-Etch
Construction begins with the highly detailed cockpit, starting with a choice of seat style.  One option has the seat put together from base, back and two side parts, which have elements of the seatbelts moulded-in, and are finished off by putting the remainder of the lap belts on the seat pan.  The other option uses new parts to build the seat without belts, adding the belts from the PE sheet separately.  A pair of support are inserted into recesses in the back of the seat, then it is installed on the ribbed floor, which has control column, plus seat-adjuster, and two other levers inserted, after which the rear bulkhead, one of the cockpit sidewalls and the front bulkhead are fitted, trapping the rudder bar with moulded-in pedals between them.  The starboard sidewall has an oxygen hose added, and a scrap diagram shows the detail painting as well as the location of the decals that need to be applied.  The head cushion is applied to the head armour, then the other sidewall is detailed with four controls and a PE wiring loom, numerous decals and more detail painting, so that it can be inserted along with the instrument panel and auxiliary panel, both of which have decals for the dials, with a choice of two for the main panel.  The tail wheel is made up in preparation for closing the fuselage, building a four-part strut that holds the wheel on a one-sided yoke, then adding a small curved bulkhead with sprung bumper at the front.  The fuselage halves are further prepared by adding two extra detail parts to the short sill panels that have ribbing moulded-in, and should be painted to match the cockpit.  At the rear on the underside, the supercharger fairing is slotted into the starboard fuselage along with the tail gear bay, and at the front, a cooling vent and an insert are added to the underside, fitting another vent to the port fuselage half in the same place.  The fuselage can then be closed around the cockpit, adding the aerial mast into a slot in the starboard spine, although whether that will remain there until the end of the building and painting is a moot point, and I’d be tempted to nip it off at the base, gluing the base in to act as a socket for the aerial after the heavy work is over.
The engine is created by joining the two highly-detailed banks of pistons together by a keyed peg, adding the push-rod assembly to the front, the ends of which mate with a circular support that is the frame onto which the cowling panels are added later.  The reduction-housing bell is detailed with magnetos and other parts, plus a collet at the centre where the prop-shaft would be.  This is joined to the front of the engine as it is mounted to a bulkhead at the rear, again on a keyed ring.  The convex firewall at the front of the fuselage is detailed with a ring of fasteners, the cylindrical intakes with PE mesh grilles, or you can utilise the similar less detailed part from the Basic Kit if you plan on leaving the engine covered.  There is a fuselage insert in front of the cockpit, and that has the two-part gunsight with clear lens and PE backup sight and link-plate added to the middle, and it is inserted under the coaming and joined by your choice of firewall that closes the front of the fuselage.
The intake trunking at the bottom of the nose cowling is made from five parts and installed in the lower panel, and you have a choice of open or closed top cowling panels by using additional parts.  To leave the cowling open, the engine is fitted to the detailed firewall along with the lower cowling and the three sections of cooling gills.  the closed option is surrounded by all four cowling segments, and at the rear you have a choice of installing open or closed cooling gills, using different parts to achieve the look you want, sliding the assembly over the completed engine, to which you can add the wiring loom if you are feeling adventurous, using the helpful diagrams near the back of the booklet, which also includes diagrams for wiring the gear bays.  The rudder is completed by adding an insert at its widest point (the bottom) to avoid sink marks, and it is mated to the fin on three hinges, allowing deflection if you wish.  Under the tail, your choice of bare or canvas-covered wheel assembly is inserted in the bay, with doors on each side, or if you are building your model in flight, a closed pair of doors is supplied as a single part, adding a small outlet further forward under the fuselage.
The upper wing halves have well-defined ribbing detail for the gear bays moulded-in, which is augmented by fitting two rib sections, front and rear walls, and an additional structure that has a retraction jack pushed through a hole in one of the wall segments.  The gun bays and their extensive ammunition stores are supplied in this boxing, using different upper wing panels with the bays opened.  The gun bays themselves are built from a mixture of styrene and PE surfaces, making up a four-compartment box into which the gun breeches are inserted, linking them to the outer wall with ammo feed chutes, and placing the ammunition boxes with open tops into the upper wing from within.  The closed bay option is shown with just the barrel stubs projecting from the leading edge, while both options install the wingtip lights and a pitot probe in the starboard wing.  A scrap diagram of the lower wing shows the location of the flashed-over holes that you can drill out for rocket tubes or pylons, then the flaps are made from two sides, plus a pair of hinges, and these are glued into the trailing edge of the wing with the ailerons, then the lower wing can be glued to the upper, along with two inserts at the tip and to the rear of the gear bay, which includes a flush landing light.  Three PE bay edge strips are inserted over the open gun bays, adding a PE indicator and PE bay prop to hold the styrene panels at the correct angle, the gun bay hinging forward, the ammo bay hinging aft.  The same process is then carried out in mirror-image for the other wing, omitting the pitot probe and landing light, after which the wheels and their struts are made up, each wheel made from two halves plus a choice of three hub types, and two styles of tyres are also provided, one without a flat-spot, the other under load on the ground, leaving it to your taste.  The struts are detailed with separate compressed or relaxed oleo scissor-links plus stencil decals, and they are mated with their wheels, plus the captive gear bay doors, the lower door made from two layers, again to avoid sink-marks.
The wings are glued to the fuselage with a stepped joint making for a stronger bond, and the elevator panels are each slotted into the tail, and have separate flying surfaces that can be posed deflected, each one a single part.  If you are building your model with the gear down, the inner gear bay doors are fitted to the fuselage, which contains the inner edge of the main gear bays, so remember to paint that while you are doing the bays.  If you plan on making an in-flight model, there are two single parts that depict the closed main bays, or you can insert the two struts with their wheels for the grounded aircraft.  The four centreline supports are fitted between the main bays for some decal options, then the model can be flipped over to stand on its own wheels so that the canopy can be installed, gluing the windscreen at the front, and deciding whether to pose the blown canopy open or closed.  The prop is also fitted, and this is made up from two parts glued perpendicular to each other, each holding two blades in opposition, and the spinner moulded into the front section.
The Jug could carry quite a load, whether it was extra fuel, rockets or bombs, and all these are included in the box, starting with the two-part pylons, which can be depicted as empty by inserting a cover over the business end.  You have a choice of four styles of tank, a 108gal compressed paper tank with a ribbed nose and tail, a 200gal wide and flat tank, the third 150gal streamlined tank with flat mating surface, and the last one slightly smaller at 75gal.  All but the third option has a pair of sway-braces between them and the pylon, which fit into slots in the pylons.  They are built in pairs to fit under the wings, but the first two options can also be used solo on the centreline support.  The bombs use the same pylons, and can be built in 1,000lb, 500lb or 250lb variants, each one made from two halves for the body and two parts for the square tails or thinner PE fins if you prefer, and mated to the pylon by a pair of sway-braces that varies depending on size.  There is also a smoke generator that looks like a drop-tank with a spout on the rear, which would be used to lay smoke for the Allied troops below to cover their actions, at least temporarily.  The final option is a pair of three-tubed rocket pods, which are made from two halves, plus inserts front and rear, which have their mounts moulded-in, and attach directly to holes drilled earlier under the wings.  A large diagram shows the correct location for all the pylons and their loads, and you are advised that drop-tanks weren’t carried under the wings with the rocket packs, which seems sensible.  No-one likes to fly home with their wings blown off, after all.
Markings
There are three decal options on the sheet, and a page near the rear of the booklet shows the location of all the many stencils on a set of grey-scale profiles to avoid cluttering the main profiles.  From the box you can build one of the following:
  • 62nd Fighter Sqn., 56th Fighter Group, 8th Air Force, July 1944 – Pilot Capt. Frederick Joseph Christensen Jr.
  • 61st Fighter Sqn., 56th Fighter Group, 8th Air Force, June 1944 – Pilot Lt. Col. Francis Stanley ‘Gabby’ Gabreski
  • 82nd Fighter Sqn., 78th Fighter Group ‘The Duxford Eagles’, 8th Air Force, Duxford, September 1944 – Pilot Capt. Ben Mayo
Decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin matt carrier film cut close to the printed areas.
Conclusion
There are a few other kits of this fighter on the market in this scale of course, but I have a feeling that this will soon become the de facto standard in due course as the selection widens.  The detail is exceptional and better still than the alleged ‘Basic Kit’ that preceded it.
VERY highly recommended.
Review sample courtesy of
Thanks again for a great review.  Alas, it looks like another candidate for the stash.  Can never have enough kits it seems, but finding the time to make them, that is another problem.  I need to really retire.
Thanks Mike,
Useful review, as always.
I'll wait for the block 30 and above, to expend my small collection of South American Jugs, but I needed to know what was exaclty the difference between Advanced and Basic kit.
Got to make a decision now on the box I'll buy... or buy both!
