DominikS Posted February 20 Share Posted February 20 Hi! I have already asked the Uncle G. search engine for this and found some answers but they are not clear enough for me. So, what I know is that the voltage regulator was not installed on the back of the frame where it can be found on Mk. IX or V, for example but was moved to the portside. But where exacly? I found a drawing which shows it installed above (?) air bottles. On the other hand Eduard made Mk.VIII brassin cockpit and gave the vr below the "door". Which is correct? And the other thing is the shape. Was it tha same as in Spitfire Mk.IX but relocated or was it a box similar to the one used on early Mk.Is? Thank you for any help. Dominik 1 Link to comment Share on other sites More sharing options...
Dave Swindell Posted February 20 Share Posted February 20 2 hours ago, DominikS said: Hi! I have already asked the Uncle G. search engine for this and found some answers but they are not clear enough for me. So, what I know is that the voltage regulator was not installed on the back of the frame where it can be found on Mk. IX or V, for example but was moved to the portside. But where exacly? I found a drawing which shows it installed above (?) air bottles. On the other hand Eduard made Mk.VIII brassin cockpit and gave the vr below the "door". Which is correct? And the other thing is the shape. Was it tha same as in Spitfire Mk.IX but relocated or was it a box similar to the one used on early Mk.Is? Thank you for any help. Dominik From the AP, the Mk VIII had a type F voltage regulator mounted low down on the port side between frames 11 & 12 (numbered from the front, frame 11 has the seat mounted on it) 3 Link to comment Share on other sites More sharing options...
Biggles87 Posted September 18 Share Posted September 18 I always assumed that the voltage regulator was moved to the port sidewall on low backed marks only because of the changed shape of frame 11, but I could be wrong and often am. John Link to comment Share on other sites More sharing options...
Work In Progress Posted September 18 Share Posted September 18 Once you've moved it, you may as well standardise on a single solution that works for all variants Link to comment Share on other sites More sharing options...
BS_w Posted September 18 Share Posted September 18 read in Spitfire Mk VIII manual " a carbon pile voltage regulator, type F, is mounted on the port side of the fuselage aft of the electrical panel." Link to comment Share on other sites More sharing options...
Alex Gordon Posted September 20 Share Posted September 20 (edited) I don't recall where I found this image but it is a crop from the Pilots Notes for the VII/VIII. It is in the same location on the XVIII. Edited September 20 by Alex Gordon Adding a bit. 1 Link to comment Share on other sites More sharing options...
