Mike Posted February 16, 2024 Posted February 16, 2024 Aston Martin DB5 007 Goldfinger (05653) Easy-Click System 1:24 Carrera Revell Aston Martin’s Grand Tourer, the DB5 rose to prominence above almost anything they had produced to that date or since, when it won a starring role in the James Bond film Goldfinger, driven by Sean Connery as the eponymous hero, fitted with guns, oil-slick dispensers, bullet-screen and an ejector seat to name but a few of the gadgets used. Like all of Jimmy’s cars, it ended up in a tangled heap, crashed into a building, and JB in the hands of the bad guys, which is a surprisingly common outcome for such a supposedly accomplished spy, although he always manages to escape. Developed from its predecessor the DB4, the DB5 was so named after the owner of the company David Brown. The engine was a light-weight aluminium straight-six block with three carburettors that propelled it to over 140mph thanks to its 280bhp output that was sent to the rear wheels via a 5-speed gearbox that was bought in from a third-party to solve previous problems that their home-grown box had encountered, although a four-speed box was used in early editions. It was also available with a 3-speed automatic box, but who’d want that unless they had leg issues? Like modern Astons, it was lavishly appointed, with leather trim, thick luxurious carpeting, and traditional chrome wire-wheels with knock-on/off nuts. The magnesium alloy body had two doors, and could seat two comfortably, with additional space for children or adults with no legs, and luggage in the boot. It was initially launched in 1963, and the production run included a small number of custom-built cabriolets, some of which had more powerful Vantage engines, and at the very end of production some were kitted out with the upcoming DB6’s engine. During its last year of production in 1965 they released the Vantage option with an extra 40+bhp of power squeezed out of the engine thanks to improved carburettors and more aggressively profiled camshafts, with only 65 being made before the DB6 replaced it in their line-up. The DB6 was an evolution of its forerunner, with improved aerodynamics and luxury, developing into a closer representation of the later DB series cars that we’re probably familiar with from our childhood and beyond. The Kit This is a new tool Easy-Click System kit from Revell, designed to be built by novices or experts alike, requiring no glue unless you feel the urge, and including a set of five thumb-pots of acrylic paint and a two-ended paint brush. You also receive a folded A3 poster of the box art without the trappings required for the packaging, which you can hang on the wall if you wish. Inside the end-opening box are four sprues in black styrene, three sprues and the bodyshell in muted silver, one in dark grey, two chromed sprues, a clear sprue, four flexible black tyres, decal sheet, sticker sheet, and instruction booklet that is printed in colour, and has the painting and markings guide on the rear pages. Though this is a snap-together kit and comes with both decals or stickers for the younger audience, detail is good for a kerbside model, and it includes some of the gadgets that Mr Connery used in the movie, such as the bullet-screen, ejection seat opening in the roof, and the extendible axles that tore the side out of the baddie’s car during a frenetic chase. Construction begins with the floor pan, which has a silver insert that depicts the underside of the engine and transmission using two parts, over which the suspension struts are added, pivoting the front axles with moulded-in brake disks and their connecting arm, then layering a sub-frame over it before moving on to the rear axle. The back axle is bulked out with an insert in the centre that creates the differential housing, fitting suspension struts and dampers into the rear of the floor pan. The twin down-pipes from the engine are placed side-by-side along the centre of the floor pan, then attention turns to the interior. The front seats are each made from an L-shaped part with pencil quilting that has a rear panel inserted, while the dashboard has the steering column and wheel inserted into the right side, adding eight decals or stickers to the dials, and another to the centre of the steering wheel and centre console. The interior floor is a grey part that receives the rest of the internal assemblies, starting with the gear stick, which has a choice of standard or 007 variants with the cap open displaying the red button. A choice of centre armrest with alternative open rest that has gadget buttons in it is made next, then the driver’s foot pedals are snapped into the right footwell, popping the front and rear seats in behind. The door cards are both fitted with inner handle, while the driver’s side has another secret pocket that can be fitted open to display more gadgets. They have a decal applied, and are clipped into the sides of the floor, held vertically by the dash that is installed at the same time. The completed interior is inserted into the bodyshell after adding a rear-view mirror above the windscreen, and if you’re going for realism, there are quite a few ejection-pin marks around the perimeter of the roof liner that you may wish to hide with filler. A black inner wheel well insert is added forward of the interior while the body is inverted, and at the rear, three clear lenses are clipped into the corners to create the light clusters, painting the lenses the appropriate clear colour. Naturally, there are alternate bottom lenses depicted flipped open to display the barrels of the rear machine guns. The front and rear number plate holders are built with a rotating prism held inside a frame, adding the bumper and boot handle at the rear, plus slide-out over-riders that are held in place by a pair of washers inside. The front bumper is installed after the bodyshell and floor pan are mated, fitting a front valance to the rear of the bumper, and adding the same kind of slide-out over-riders either side of the rotating number plate holder before fixing them under the front of the vehicle, and slotting the distinctive chromed Aston Martin grille into the centre. Side lights or machine guns are fitted into the front wings, and the headlight lenses are too, once the inner lens and chromed reflector are fixed into the recess. The wheel hubs are built from three layers, the rear of the hub in black, and the wire wheels in chrome, trapping a top-hat washer in the centre that friction-fits on the axles. The flexible tyres are slipped over the hubs and attached to the model, one per corner as you’d expect. The windscreen is carefully inserted from outside, helping it along by inserting your index finger (other fingers are available) through the ejection seat hatch to ensure it doesn’t fall inside. The rear screen can be inserted similarly, adding the side windows from the outside. It’s worth noting that the side windows are supplied as a single part, including both the door window and the quarter-light, and locating on a pair of tabs that clip into the sills of the bodyshell. External chromed door handles and the wing detail inserts are applied to the exterior side, and you have a choice of installing standard knock-off wheel nuts, or the 007 weaponised versions that project from the centre of the wheel on a tubular support, by using different chromed parts. More chromed parts follow, including the aerial base, a pair of windscreen wipers, and wing mirrors, not forgetting the hatch through which your unfortunate front seat passenger would be ejected should the need arise. You can pose it closed by using the part, or leave it off to show off the interior better. The last standard parts are the twin exhausts that have the back box moulded in, clipping to the end of the down-pipes under the body. The 007 specific gear is finalised by sliding the bullet screen behind the rear window, which slots into the rear bodywork, and can be fitted with a decal or sticker that portrays some bullet damage for a little movie frivolity. Next to the exhausts, a black tube is inserted into a hole in the valance, and if memory serves, this is the oil dispenser. It’s a while since I’ve seen Goldfinger. Markings This is a special edition, so there is only one option on the decal sheet, although there are alternative number plate options for those rotating plate holders. From the box you can build the following: Decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas. It’s not clear who printed the stickers, but they seem well-done and fit for purpose. Conclusion Sean Connery played a colder and cooler Bond (controversial!) than his replacement, and the DB5 cemented its place in motoring and movie history by appearing in Goldfinger. It’s a good-looking model of the car, and should provide some fun for the novice and expert alike, choosing which of the gadgets to deploy on your model. Highly recommended. Carrera Revell model kits are available from all good toy and model retailers. For further information visit or 6
Basosz Posted March 12, 2024 Posted March 12, 2024 I'm not gonna buy or build it but my brain *will* be mulling over how I would make a re-usable ejector system for this 2
johnlambert Posted June 30 Posted June 30 On 12/03/2024 at 17:11, Basosz said: I'm not gonna buy or build it but my brain *will* be mulling over how I would make a re-usable ejector system for this Ejector seat? You're joking! (somebody had to say it) 2
kapam Posted July 6 Posted July 6 Nice looking kit. I would love to see an advanced modeller challenged to build it OOB and use only the paints & brushes provided. I say that without cynicism, as I’m confident that someone with the right skills could do a fine job of it.
Noel Smith Posted July 7 Posted July 7 (edited) I reckon that there is no chance that an advanced modeller would ever build it out of the box with the paints and brush supplied considering the cost of the kit, even as a challenge ! More likely would spend a bit more and upgrade it with those Ukranian 3D printed detailing parts, grille, engine and wire wheels, after sourcing some AM Silver Birch to air brush it. Edited July 7 by Noel Smith
Circloy Posted July 7 Posted July 7 On 30/06/2025 at 07:09, johnlambert said: Ejector seat? You're joking! If I recall correctly the Airfix kit of the early/mid 60's came with springs to do just that & fire missiles just like the Corgi model of the same era. Not sure of the Doyusha kit of the ame era though. Scalemates show them as different tools.
cmatthewbacon Posted July 7 Posted July 7 On 6/30/2025 at 7:09 AM, johnlambert said: Ejector seat? You're joking! I never joke about my work.. 😜 best, M. 1 1
kapam Posted July 17 Posted July 17 On 7/7/2025 at 7:07 PM, Noel Smith said: I reckon that there is no chance that an advanced modeller would ever build it out of the box with the paints and brush supplied I guess you're right. I only brought it up knowing I would make a complete hash of it if I tried. 😬 My next thought is, would the formulation of those paints be suitable for thinning and airbrushing? Again, I must emphasise it would be beyond my talents to try it and succeed. 🤪
Noel Smith Posted July 17 Posted July 17 Now pay attention 007 ! Airfix I believe brought out a model of an Aston Martin DB6 shortly after the Bond DB5. Could be they modified or retooled the body for it and utilised some of the original DB5 tooling for the DB6 where compatible. Perhaps someone might be able to confirm this or not? If Airfix did utilise some of the DB5 tooling, then the Doyusha kit is probably from different tooling altogether.I Revell are to be congratulated for making a 1/24th scale kit of the Bond DB5 considering the number of years since the 1960's Airfix kit was made.
cmatthewbacon Posted July 17 Posted July 17 2 minutes ago, Noel Smith said: Airfix I believe brought out a model of an Aston Martin DB6 shortly after the Bond DB5 They did. They modified the DB5 body into a “DB6”… not very accurately. They gave the body a Kamm tail, but didn’t give it tbe extra 4” in length (4mm ish in 1/24), and more importantly fudged the roof line. The DB6 has a higher roof over the rear seats than the DB5 to make it more of a 2+2 for adults, but Airfix didn’t address this, just tapering down from the same height. The most noticeable upshot of which on the Airfix body is that the rear windows are pinched looking triangles rather than the trapezoids of the real thing. There’s a fair bit of cutting and reshaping needed to turn the Airfix “DB6” into an accurate, or even nice-looking model. The Doyushs kit is completely different tooling, available in a 007 box with Bomd and Oddjob figures and gadgets, or as a regular DB5. The latter is the one Airfix later reboxed to have a DB5 in their 1/24 car range when they were releasing a lot of Japanese origin car kits, many of which were older formerly-motorised kits that were quite compromised in detail. (The Doyusha DB5 is not an ex-motorised kit, but it is still pretty simple, and the shape is way too slab-sided….) best, M. 2
Noel Smith Posted July 17 Posted July 17 Thanks for the feedback Matt as that has answered a number of things that I suspected. Looks like those old kits weren't up to spec in a number of areas. How accurate is the new Revell kit? Have you got hold of one to have a look at or built one? They got the roofline a bit low where it meets the windscreen on their Jaguar E type Coupe unfortunately.
hendie Posted July 17 Posted July 17 For those interested I did a comparison between the new Revell release and the old Airfix release from the 60's. It did show up a number of rather significant differences although to be honest, I have no real idea of which is correct in most cases. Also to be noted is that I threw away lots of kit parts - from both kits 2
cmatthewbacon Posted September 3 Posted September 3 @hendie's walked the walk, but looking at the kit in my stash @Noel Smith, I think you can make the Revell kit look a lot better just by sanding to make the transition between the roof "sides" above the door and the "top" less sudden and slab-sided looking. best, M.
Noel Smith Posted September 3 Posted September 3 Funny thing that you put this post up Matt. Coincidence as only last night I pulled out my book about James Bond's DB5 and had a couple of hours looking at all the pics, studio sketches and info in it. 1
