Mike Posted February 2, 2024 Posted February 2, 2024 Tool Set (49013) 1:48 MiniArt via Creative Models Ltd It's a constant in war or peace that equipment breaks and the mechanics/fitters must repair them, whether it's wear-and-tear, accidental damage, clumsiness, misuse or due to enemy action, it all ends up in the same place if it's deemed suitable for repair, providing it's not behind enemy lines or under heavy bombardment. From WWII onwards, fighting tended to be fast-moving, so transporting anything back to a bricks and mortar workshop well behind the lines is time-consuming, and sometimes impossible, not to mention highly impractical once the lines of communication stretch far enough, so a field workshop is used instead, bringing their tools with them. This can be anything from a literal field to a large empty building that is commandeered by the "grease monkeys" so they can ply their trade. The Kit This set arrives in an end-opening figure-sized box with a detailed painting of the contents on the front, a painting guide on the rear. Inside are six sprues of grey styrene that included many tools, two small frets of Photo-Etch (PE) in a card envelope, and a double-sided sheet of instructions that guide you through building the more complex assemblies. There is a compressor with received and transport trolley; a two-part anvil; two styles of bucket/pales with PE handles; a wood saw made from two laminations of PE parts; a bench grinder with two wheels; a bench vice with separate mounting plate; a clamp-on vice with PE winder; two wooden tool boxes with tubular handles and a complement of tools; two wooden step ladders built from three parts each; a bench press drill with belt-drive; a two-man saw made from three PE parts and styrene handles; a hack saw with PE blade; two oxy-acetylene gas bottles with regulators and six spares with caps; a tubular trolley with space for two bottles and cast-iron wheels; an expanding metal tool box in the closed position with PE handle, plus another with the trays swung out that has tools moulded into the trays, the same PE handle and two PE open lid parts. Other parts that need less information or gluing are various hand tools such as various sized hammers, a pick-axe, two different axes, box plane, shovel & spade, pry bar, a pump, a welder’s torch and mask, blow-torch, G-clamp, belly-brace & bit, oil can and two spanners. You are provided with guidance on the colours of everything in the box on the rear, using swatches, colour names and paint codes from Vallejo, Mr.Color, AMMO, AK RealColor, Mission Models, and Tamiya, but other than the metal tool surfaces, most parts can be any colour you wish, within reason. Conclusion Detail is excellent, and is a perfect backdrop of a 1:48 diorama, providing items that have previously been unavailable separately or hard to find in styrene at this scale before. Highly recommended. Review sample courtesy of 3
