StuH.42 Ausf.G Mid Prod. Jul-Oct 1943 (35385)
1:35 MiniArt via Creative Models Ltd
Following WWI the German military had identified a weakness in their forces, in that their advancing troops often left behind the support of their artillery as they moved forward, leading to a call for the creation of Sturmartillerie, which was effectively a mobile artillery piece that could travel alongside their forces, providing valuable protection.  By the time the Nazis were gearing up their economy and military for war more openly, a requirement for just such a vehicle was made official, mating the chassis of the then current Panzer III with a short-barrelled 75mm gun in a fixed armoured casemate with limited traverse, which gave the type a distinctive howitzer-style look.  In the later variants a longer high-velocity gun, the 7.5 cm StuK 40 L/48 replaced the shorter gun to give it an improved penetrating power that was more in alignment with the Tank Killer job that it had become used for.  These vehicles were designated Ausf.F or G, and were amongst the most produced version of this almost ubiquitous WWII tank.
A project to up-gun the StuG was instigated using an Ausf.F chassis and a 10.5cm leFH 18 howitzer, taking the name Sturmhaubitze 42 or StuH 42 for short.  The rounds were electrically fired, and it was to be fitted with a muzzle-brake to bleed off some of the recoil, and a dozen of this type were made from repaired Ausf.F examples, then almost 1,300 built as infantry support that were based on the Ausf.G, some without their muzzle-brakes due to the limited availability of certain metals as the war continued to turn against the Nazis, thanks to the Allied bomber force bombing their industrial base into rubble on a 24/7 schedule.
The Kit
MiniArt have now released several toolings of the late StuG III and this minor retool to depict the howitzer equipped sub-variant is a continuation of the Ausf.G series, which had changes layered on changes during the final batches as the war ground to its ultimate conclusion.  This boxing depicts a mid-production vehicle, and arrives in a standard top-opening box in the MiniArt style, with attractive artwork and decal profiles on one side.  Inside the box are forty-three sprues in mid-grey styrene, one in clear, two large Photo-Etch (PE) frets of brass parts, decal sheet, and glossy-covered instruction booklet with colour profiles in the front and rear.  Detail is excellent throughout, which is just what we’ve come to expect from modern toolings by MiniArt, with so much detail crammed into every part of the model, including individual track links that are different from the earlier pre-series kit we reviewed some time ago.
Construction begins with the floor, which receives the torsion suspension bars with their fittings, a pair of runners to support the engine that isn’t part of this boxing, and the support structure for the gun, which is made up from substantial beams that have a traverse shoe placed on top to give the gun its limited 15° travel for fine-tuning lateral aim.  The rear bulkhead is set against the engine mounts with its exhausts and towing eyes applied to the exterior later, and the hull sides are mated to the floor, with the bases for the final drive housing glued either side of a choice of three styles of front bulkhead, installing the engine firewall in the centre of the floor for structural strength.  The glacis plate with transmission inspection hatches are given a similar treatment, plus another appliqué panel, and the usual exhaust covers, towing lugs that have pins with PE chain-retainers and idler protection are added to the rear, and a radiator exhaust assembly with PE grille is made up and applied above it, adding some heat deflecting tinwork to the hull.  Narrow bolted panels are added to the sides of the hull in preparation for the upper hull parts that are added next.
Before the gun can be fitted, the walls of the casemate must be made up, and these are well-detailed externally, including vision slots and lifting eyes.  The shape of the casemate is completed with the addition of the front wall, which has a large cut-out to receive the gun in due course.  The front of the casemate is built out forward with a sloped front and some bolted appliqué armour, dropped over the front of the lower hull and joined by the breech assembly, which is covered by an armoured panel after armoured protectors to the mounting bolts have been glued over them.  The commander’s cupola is built on a circular base into which seven clear periscopes are slipped, completing the task later with several protectors, PE details and a set of V-shaped binocular sighting glasses in the separate front section of the cupola that can be open or closed independently of the main hatch.
Much of the gun breech detail is represented, and a large trunnion is fitted onto the two pins on the sides of the assembly.  Elevation, traverse, and sighting gear is installed on the breech, although it’s unlikely to be seen as anything other than a dim shadow within, especially once the roof is in place.  The roof-mounted MG34 has a separate breech cover and a drum mag, fitting on the roof in the ready-for-action post with the gunner’s hatch open behind it, and the gun slipped through the slot in the splinter shield.  It can also be posed pushed down flat with the gun absent and the hatch closed for travel.  The engine deck is built up with tapered sides and armoured intake louvres added outside them, drilling two holes for three of the decal options, which are covered with PE meshes as the deck is glued down onto the engine bay.  A length of spare track links is fixed across the rear of the casemate with the fume extraction armour in the centre with the barrel cleaning rods underneath, lashed to the deck with PE and styrene parts, then the four hatches are made with armoured vents.  two pairs of road wheels are carried on the deck on six pins welded to the rearmost pair of hatches, with a flat stowage box mounted between them on PE brackets.  In reverse of many AFV kits, the hull sides are decorated with suspension parts, the idler wheels and final drive housings, adding three turrets on each side that carry the return-rollers later.  A group of pioneer tools are dotted around the sides of the engine deck, including a fire extinguisher with PE frame, after which the paired wheels are fixed to the axles, with drive-sprockets at the front and idler wheels with PE rings at the rear, plus a trio of paired return rollers near the top of the hull sides.
https://www.britmodeller.com/reviews/creative/miniart/kits35/35385-stuh.42.ausf.g.mid/sprue10.jpg
https://www.britmodeller.com/reviews/creative/miniart/kits35/35385-stuh.42.ausf.g.mid/tracks.jpg
The tracks are individual links that are friction-fitted, using 94 links per side, and each link has three sprue gates to clean up, plus an occasional wisp of flash on the highly detailed sides, which will need scraping away with a sharp blade.  I created a length in short order, and the result is a very well-detailed track with flexibility to adjust them around the running gear of your model, and as they are a tight fit, they shouldn’t need glue, but I’d probably set them in position with liquid glue once I had them how I wanted them on the vehicle. Once they’re in place, one of two types of fenders are attached to the hull sides on small brackets, with mudguards and tiny PE fittings added once the glue has dried.  More pioneer tools and stowage are added to these, as space was a premium on these vehicles, and every flat surface ended up with equipment on it.  This includes a convoy light mounted in the centre of the glacis, and either the highly detailed PE fire extinguisher or a simplified styrene alternative if you prefer on the rear left fender.  Shovels, pry bars, track-tools, jack blocks and the jack are also found on the fenders, as are the two towing cables, which have styrene eyes and you’ll need to supply the 107mm cable material yourself, with a set of PE tie-downs holding them and the tools in place on each side.  The short howitzer barrel is a single part with hollow muzzle and two-part brake insert, sliding into the short sleeve via an end-cap, the sleeve moulded into the front of the inverted saukopf mantlet that is made from an additional two parts before it is slid over the recoil tubes and breech.
A pair of aerials are installed on the corners of the casemate rear wall, and variations of additional track lengths as appliqué armour at the rear, under the glacis or on the armoured sides of the mantlet.  Some decal options add the brackets for the Schürzen along the sides of the hull and fenders with a few small added outriggers, although two decal options don’t have them fitted.  The four PE schürzen panels per side are detailed with additional rectangular panels on their upper surface, and once the glue between the two layers of PE has cured, you simply hang them on the hooks, gluing them in place if you wish.
Markings
There are six markings options included on the decal sheet, all of them with varying camouflage based upon dunkelgelb with splotches or patterns of other colours to a greater or lesser extent.  From the box you can build one of the following:
  • 5.Komp. II. Abt. Pz.Reg. Hermann Göring, Italy, 1943
  • Unidentified Unit, Eastern Front, Autumn, 1943
  • 3. Pz.Gren.Div. ‘Totenkopf’, Eastern Front, Autumn, 1943
  • StuG. Abt. 237., Eastern Front, Elnya, Autumn, 1943
  • StuG. Abt. 276., Eastern Front, Autumn, 1943
Decals are by Cartograf, which is a guarantee of good registration, sharpness, and colour density, with a thin matt carrier film cut close to the printed areas.
Conclusion
Whilst it might easily be mistaken for a StuG if you don’t notice the barrel, the StuH is just a little different from the usual, with its stubby barrel, the muzzle brake giving it a more aggressive look.  The detail in the kit is excellent, and it will keep you busy for many a happy hour.
Highly recommended.
Review sample courtesy of
