M1A2 SEP Abrams Tusk II US Main Battle Tank (72-003) 1:72
Mike
Meng via Creative Models Ltd
The Abrams Main Battle Tank is the direct replacement to the M60, when it was realised that the venerable design was ill-suited to further modification to cope with emerging threats that were entering the battlespace. The new design entered limited service in 1980 and went on to become the main heavy tank in the Army and Marines branches of the American armed forces. It saw extensive action in the two Gulf Wars, where it fared extremely well against older Soviet designs with minimal damage inflicted in a tank-on-tank fight due to its composite armour and accuracy at extended range. It was developed further with the AIM programme, which upgraded the battle management systems and returned the vehicles to factory fresh condition. The A2 was improved again, giving the commander his own sighting system as well as other system changes. The SEP received additional changes to its armour and systems, with a remote weapons station added later.
With the involvement of the Abrams in urban combat during the Afghanistan campaign, it became clear that the tank was vulnerable in close-quarters combat, where the top of the tank was open to attack from small arms fire, and RPGs could be used with relative safety of the firing team, who could pop up and disappear in between shots, giving the tank crews little indication of where the shot originated. The problems of IEDs buried under roads or in buildings also disabled several tanks in action, all of which led to the TUSK and improved TUSK II upgrade packages, which stands for Tank Urban Survival Kit. To counter IEDs a shallow V-shaped keel was added to the underside to deflect blast away from the hull, reactive armour blocks were added to the side skirts and turret, and bullet-resistant glass and metal cages were mounted around the crew hatches on the turret to provide protection for the crew during urban operations, or if they were called upon to use their weapons in combat. A combat telephone was also installed on the rear of the tank to allow better communication between accompanying troops and the tanks, as well as slat armour at the rear to protect the exhaust grilles of the gas turbine engine, the blast from which was directed upwards by a deflector panel that could be attached to the grille to avoid cooking the troops behind.
The TUSK II kit improved on the original TUSK with shaped charges incorporated into the ERA blocks on the sides of the tank, and additional shields for the crew when exposed. Both kits were field-installable, which reduced the cost and time the vehicles spent out of commission. The A3 variant is intended to incorporate many weight-saving changes, such as internal fibre-optic data transmission, lightness of armour and gun, amongst many other improvements. This is still distant and far from guaranteed, given the changes already seen in planning that have included a totally new platform, so it looks like the A2 will be around for some time yet, possibly until 2050 while the politicians make up their minds.
The Kit
This is a brand-new tooling from Meng from their new 1:72 scale AFV range, and it arrives in a sturdy end-opening box that should be as hard to crush as any top-opener.  Attractive box art is found on top, while painting details are on the back of the box, and inside are six sprues of light grey styrene, a clear sprue, a small decal sheet, and a black and white instruction booklet in portrait A5, with a sprue diagram on the rear page.  Detail is good, with link-and-length tracks, separate ERA blocks, raised weld-lines, and detailed road wheels that are moulded individually, rather than in a long run as with earlier kits from other manufacturers.  In terms of detail, this could well become the de facto standard in this scale, based on what we have seen.
Construction begins with sixteen paired road wheels and two drive sprockets, all of which are made from two halves, and are set to one side while the lower hull is made up from floor and two side panels that slot into the back of the suspension mounts moulded into the floor for a strong bond.  The swing arms are moulded into the floor, save for the two forward wheel stations, which are linked together by a damper, and are formed from a separate part that is slotted into holes in the side walls along with two return rollers per side.  The TUSK keel, front idler wheel and rear drive sprocket are then installed so that the tracks can be made up, built from two long runs top and bottom, two diagonal lengths under the ends, and a curved section of three links to fit around the ends of the road wheels.  The Abrams doesn’t have much in the way of sag in the top track run, but these won’t be seen, so it’s a little accuracy hidden away, and it’s possible the top run could be omitted to save modelling time if you feel the urge.  The upper hull has headlight clusters and the driver’s hatch fitted before the lower hull it given a rear bulkhead, which also has light clusters moulded into the rear in cylindrical projections, adding a field telephone box, towing hook and eye, plus the afore mentioned blast deflector for the hot exhaust.  The two hull halves can then be mated, and the side-skirts installed, followed by the curved ERA panels over the top, locating them on four lugs in the surface of the skirts.
The majority of the turret is moulded as a single part, with just the rear bulkhead a separate part with the crosswind sensor pole moulded-in, adding the gunner’s hatch, the binocular FLIR box on top with optional open doors to display the clear lenses, a spare ammo box for the pintle-mounted crew weapons, and the drum-shaped gunner’s primary sight to the roof.  The gun is moulded as one part with the fume extractor hump and a separate muzzle with velocity sensor, after which it is plugged into the mantlet, with coax machine gun moulded-in, held in position by gluing the top and bottom turret halves together, taking care to keep the glue away from the pivots.  Each side of the turret has a set of stowage boxes with IFF placards moulded-in, topped with a lid and separate ammo can, fitted in place with the smoke discharger packages at the front on their mounts.  Armour plates and ERA blocks are applied over the front portions on both sides, leaving the IFF boards exposed, and installing the top of the mantlet on a tab, again being careful with the glue.  The aircon unit is fixed to the floor of the stowage area at the rear of the turret, mounting the tubular frame, IED disruptor aerials, another tubular rack for more storage that includes a couple of jerry cans, and a separate IFF board hung on the rear.
Crew protection is begun by installing a protective shroud around the left of the gunner’s hatch, creating the machine gun emplacement on a ring around which the heavily modified LMG is rotated, protected at the sides by two window panels that have clear panes in the centre, and for once the thickness of the glazing is suitable for the scale.  A third glass panel is fitted to the right, with another without a window on the left, which usually faces the commander’s more complex cupola.  An eight-block vision-block ring is inserted from under the cupola, which has a two-part hatch inserted into the centre, then the M2 .50cal with ammo box is slipped through the front splinter guard, which has two clear panes installed, adding a three-facet fixed set with individual windows on the right, and another two-part pair of windowed panels on the left, all of which fit into the top of the cupola on slots.  As if there weren’t enough guns available, the remote .50cal mount over the mantlet is attached with an ammo box on a separate bracket.  To finish the build, the turret is lowered onto the hull and twisted into position, locking on a pair of bayonet lugs moulded into the turret ring that correspond with notches in the hull ring.
Markings
There is only one decal option supplied in this boxing, the details of which are found on the rear of the box.  It’s a desert vehicle from Iraq, painted a desert tan.  From the box you can build the following:
The decals are printed in China, and beyond that we don’t have any more information.  Under magnification they are a little hazy, but once applied they should look fine to the Mk.1 eyeball, especially after a little weathering to the finished model.  Don’t let it put you off, as everything looks worse under 3x magnification.
Conclusion
A well-detailed new tooling of the almost ubiquitous Abrams in smaller scale, which should put some of the older tools out to grass, and allow modellers to build a more detailed, modern US MBT out of the box, and at a pretty reasonable price in our inflation-soaked world.
Highly recommended.
Review sample courtesy of
