TROJAN AVRE (Newland Models)
5 hours ago, Hamden said:
Looking very business like now Ivan the fascine and blade are bringing this to life!
    Stay safe            Roger
Thanks Roger I’ve got the Full Width Mine Plough to go on as well but I’ll do that as a separate build I reckon😀
10 hours ago, PeteH1969 said:
Thanks Pete I have seen those videos,beasts aren’t they? If you haven’t found War Machine TV on YouTube it’s well worth it for British kit roaming Salisbury plain👍
Ivan
Hi guys,this is going slowly now,all the rams are on and despite thinking I could have them moveable I have failed🙁ithe arms were far to loose and flopping all over the place and just crying out to break! As I’ve said before it is VERY brittle and I’ve broken a set of pipes cleaning them up so out with the card and wire! Half done,time for a break😀
IMG_0311
the kit part is by the cupola so you can see the problem ,cheers
Ivan
  • Like 13
This is turning into an impressive model and I'm sure you will sort the plumbing problem, the light at the end of the tunnel is gradually getting brighter!
          Stay safe           Roger
Hi, a update😉 paint is on although it will need another wash,top hoses done I’ve made my own couplings as the kit ones are brilliant it’s just I couldn’t see them properly when they come off the block😳
IMG_0316
bottom ones to go now and then just finishing the odds and ends.
cheers
Ivan
  • Like 9
Todays efforts here chaps😀bottom hoses on just some smaller ones and a power lead for the camera to go,then some minor repairs and clean up so should be close to done.
IMG_0317
cheers
Ivan
  • Like 11
55 minutes ago, viper-30 said:
Coming together now mate ..well done
Thanks mate I hope you have a very big magnifying glass when you start yours😂
Stunning absolutely stunning Ivan as always with your work great workmanship topped off with outstanding attention to the smallest details and superb paintwork.
Will look good displayed next to your Chieftain AVRE.
    Stay safe           Roger
    Stay safe           Roger
Kind words indeed thank you👍 however the quality of this kit is outstanding (albeit expensive).as I’ve said the only issue I’ve had is it is probably a bit over engineered with some of the small parts.
Ivan
At last was able to do a bit of hose porn today that’s it done just needs touched up when it all dries😀
IMG_0319
IMG_0320
IMG_0321
and just for something different some netting on the side of the fascine,
IMG_0322
it’s been a bit of a slog today but all the hose work is done😀🍺
Ivan
  • Like 10
12 minutes ago, robgizlu said:
It's a Beast - Lovely work
Ivan - out of curiosity what green paint are you using?
Rob
Thanks Rob just some more fiddly bits now👍
Hataka IRR green is the colour although I’m not that satisfied with it it seems a bit too dark and then in another light it’s ok🙄😂
Ivan
Ivan
Thanks - Ivan - I think it looks perfect
Rob
