RAN WESSEX HAS31B
8 hours ago, Spookytooth said:
Yep, that is exceptional work there Chris.
Eye strain of the major league .
Simon.
5 hours ago, Pete in Lincs said:
I'll second that.
Thanks Simon & Pete - I've tried a couple of magnifying jobbies to help with fine work but I'm not 100% any of them as aids - some nice bright morning sunlight seems to be the best.
Chris
Edited by CJP
text
10 minutes ago, bigbadbadge said:
A fantastic update Chris, phenomenal work on the hinges, they are awesome.  The gearbox representation too, wow.
Great work
Chris
Thanks Chris, I'm a bit relieved it all seems to be working out!
Chris
Hi all - I decided to pay some attention to the cockpit area in preparation to install Hendies cockpit upgrades - consoles seats etc.
I started by adding some framing to the cockpit side walls from strip. I also added some detail to the rudder pedals referring to photos - the results are basic but will add to the cockpit clutter.
IMG_5971.avifIMG_5968.avifIMG_5969.avifIMG-5970.avifIMG_5967.avif
I sprayed the cockpit area Tamiya flat black and the quilting Mr Hobby H50 Lime Green - Hendies cockpit consoles & seats were also sprayed flat black & dry brushed with silver with some additional parts picked out in red and grey.
IMG-5975.avif
I am a bit unsure on the RAN Wessex seat colours so if anyone has a in service photo of the seats, I would appreciate seeing it or a link.
Do the preserved Wessex have genuine original cushions/survival packs etc or replacements? -  I have not been able to find a clear photo of the seats.
Thanks
Chris
  • Like 10
Chris if they were anything like the UK versions, the emergency pack - the big curvy part of the seat base - that was yellow, with a sheepskin bum comforter laid on top.
That might be completely useless information for you, I'm not sure.
Thanks Alan - I will see if anyone provides any info on the RAN seat colours otherwise I will run with what you advised
Chris
I couldn't resist gluing in Hendies centre & rear bulkhead consoles & I think they really bring the cockpit to life - the windscreen wiper motor & cyclic sticks still need to be fitted between the rudder/yaw pedals & to the left of the seat respectively - happy with that.
IMG_5977.avifIMG_5978.avifIMG_5979.avifIMG_5980.avifIMG_5981.avifIMG_5987.avif
I also experimented with painting the seats & modelling the sheepskin covers which looked ok until I took the close up photo above - it looks a little bit like a sheepskin cover but it looks a bit too messy & coarse I think - I will look at it again tomorrow & may strip it all off & try another method.
EDIT method#2 (wife's suggestion) - I glued a piece of thin felt over the second seats survival pack with PVA & I think it gives a slightly better effect than my previous effort so I will redo the other seat with felt - using felt worked out well.
In the last photo I have coloured the felt with Tamiya buff acrylic & this has helped to restrain the fibres that stick out.
IMG-5998.avifIMG_5990.avifIMG_5996.avifIMG_5997.avif
I think that once I add seat belts it will look ok.
bye for now,
Chris
Edited by CJP
text
1 hour ago, hendie said:
ooooh very nice, Chris
The sheepskin looks fine - those covers always looked really tatty and dirty
Thanks Alan, that's encouraging to hear - my wife gave me a piece of felt to try out to represent a sheepskin cover so I might see how that looks too and then decide.
I decided on painting the seat back in olive drab & placed the sheepskin cover (the fibres are scenic static grass) over the yellow survival pack.
Chris
The seat covers look good to me from where I'm sitting, even if it is 140,000000 miles away! I sometimes make the cover out of Miliput, wet the surface and then pat at it with Mrs Martian's tooth brush,  :oops:,  I mean an old tooth brush. That gives quite a nice effect. The downside of course is the wait for wet Miliput to dry, not to mention the aggravation I get from Mrs Martian if I get caught! :dalek1:
Battered and Bruised of Mars 👽
  • Haha 3
Thanks Martian that is a good tip & is noted for future use! - maybe you could placate Mrs Martian with a tube of tooth whitener?
Chris
  • Haha 4
That cockpit is astounding, well done you and Alan.
The buff felt looks exactly the way I'll want mine to appear as a seat cover, nailed it.
Hi all
I Continued working on the Wessex cockpit area - scratch built seat belts were made from Tamiya tape stuck to adhesive alumium tape & cut into strips.
I added an assortment of buckles I had from the spares box, unfortunately I have had not much luck finding suppliers of etched sheets of seat belt buckles other than L'Arsenal way over in France & postage is a disincentive on sending for them. The seat colours are a bit of a mystery so I took a guess and painted the seat back khaki & belts olive drab although I might paint the belts a darker grey. The cyclic sticks have been added but still to be painted matt black. The red fire extinguisher is from one of  Hendies boxes of bits & pieces & a coiled wire lead added to the back console copying from @hendies HC2 build.
IMG_6018.avifIMG_6019.avifIMG_6020.avifIMG_6030.avifIMG_6029.avifIMG_6028.avif
The overhead console was added inside the canopy & the canopy was masked with Tamiya tape.
Must not forget to add the rotor brake handle to the overhead console and do a check to see what else needs to be added to the cockpit area.
Chris
22 minutes ago, hendie said:
that is looking very impressive Chris.The extinguisher is a nice touch.
Don't forget the wiper motors on the floor.
Thanks Alan - got them in place already between the yaw? pedals- a bit hard to photograph that part of the cockpit- I think it's getting close to closing up the fuselage halves so hope there is nothing else significant to add - then I guess the canopy can go on.
Chris
Ah, just saw 'em after zooming in.
If you want to add a further splash of color to that gearbox area, the swash plate was normally a grey color. Check out the HC2 in the walkrounds area - there's some good shots of the gearbox and rotor head at the end of the thread.
Chris
Living dangerously again Martin...
Colin
Hi Alan - I have been provided with some RAN Wessex photos by @abat and as luck would have it they show the main rotor head area on  RAN HAS31's as being painted white matching the upper camouflage colour - hope this is useful for anyone contemplating a RAN Wessex build.
cheers Chris
Lovely work! You are making me want tackle another Wessex/SH-34 kit. Someone save me from myself!
Easily Led of Mars 👽
well now that you mention it that sounds like a great idea! - detailed with that airframe detail you do so well & you could save yourself some work & time using Hendie's detail sets😀
Chris
2 hours ago, bigbadbadge said:
Shat a great catch up Chris , love the seats and your use of the felt, cockpit is looking fantastic.
Great work
Chris
Thanks Chris - I put the instrument panel decal on today so almost ready to glue the fuselage halves together.
Chris
Settle down Martin, no need t torture yourself!
Colin
  • Haha 2
Colin
Dont be daft Colin its an excellent idea, come on me ol' alien get with it
No Chance!
Gondor
