Eduard Bf 110 1/72 (Not a sharkmouth!) ++Finished++
Happy New Year everyone
I'll be kicking off 2024 with this Bf 110 from Eduard
It's one of the oldest stash residents and has nearly made it to the build pile on a number of occasions
It's time has now come
Here's the plastic
Instructions, decals, PE, masks and, for some reason, a loose nose-piece (everything is still bagged :confused: )
I also have these, As it transpires, the camo paint masks will be of little use
There are several schemes, at least one of which has a sharkmouth. That seems to be the popular option for other Bf110 builds, so I plan to do this ....
It's a strange mix, mainly due to replacement parts having been fitted but not overpainted
More soon(ish)
/P
  • Like 17
Welcome, Peter :) Not this boxing, but I have an Eduard 1/72 110 in the stash and it looks to be a nice kit. I like the mismatched panels on that scheme too
James
Welcome, I have built one myself. I used leftover Ju 88 decals for the wide white upper half-only fuselage band. I brush painted it with Revell Anthrazit instead of full black, and was very happy with the result. V-P
Thanks everyone
Plastic (and PE) was bothered earlier
First job was to sort the sprues and remove all the unneeded parts
Then I attacked the cockpit
The first of the PE replaces the pilot's pedals
Ready for paint
I think/hope I can stick on the PE bits after it's all beed sprayed. There seems to be (just) enough rooom to manouever
Then I just started winging it
And here's where I left everything
Tomorrow should see the rest of the internals stuck together then RLM02 sprayed
More soon(ish)
/P
  • Like 13
That's a fantastic start, Peter! And a lot nicer looking a kit than my Airfix one. I like your sprue holder as well
James
It's really useful but I'm thinking on replacing it with the Hobbyzone module to save some desk space
13 hours ago, Touvdal said:
they are a joy to build fit is super
I completely agree. It's a great kit
Anyway
The bits on the insides of the fuselage were fitted
then I sprayed it all with Halfords rattlecan primer
While that was drying, I started on the landing gear
Then sprayed the interior parts with SMS RLM02
It's the first tiome I've tried SMS paints, but it won't be the last
These were "fun"
And in case you were wondering, I did manage to stick the PE into the cockpit
Only the seatbelts to go then I can button 'er up
More soon(ish)
/P
  • Like 9
Not much progress to report, but surprisingly it's almost ready for paint
the PE seatbelts were installed then I joined both sides
And stuck it all to the wings
Prep for canopy masking
I usually remove the unused tape as it makes lifting the masks easier
And all of the canopy masking complete
Then stuck on to the fuselage
PE added to the landing gear
and started sticking the remaining bits on the underside
there are only about a dozen parts left, so I should be in the paintshop next weekend
Mpre soon(ish)
/P
  • Like 12
  • 1 month later...
thanks everyone
On 1/16/2024 at 11:30 AM, 81-er said:
I'm looking forward to the paint
Your wait is over
Primer on
(There's a Mossie in there as well, in case you were wondering)
Tail camo
And underside bits that ain'tn't black
then all the bits that are black
(I nearly forgot to paint the whie bit on the fuselage, but remembered just in time)
Need to mottle the tail, then gloss for stickers
The end is nigh
More soon(ish)
/P
  • Like 11
Quick update
Most of the making removed from the airframe
It'll do
It's also since been clearcoated
Some of the greeblies appear to have disappeared. I may need to dig out the platicard
After which, decals and final assembly
More soon(ish)
/P
  • Like 10
Thanks everyone
On 2/26/2024 at 6:14 AM, vppelt68 said:
want to get yet one of these Eduard beauties to build!
The partially camouflaged tail and a dash of white really light up the otherwise black airplane
I think I need to add a few more to the stash.
The scheme really tells a tale of the aircraft, field replacements of parts, probably due to battle damage
Time to start the decorations
Port and upper half done. I think I used the wrong crosses
It's also a bit strange that the "D" is white outlined, but the others aren't
And starboard
Finally the underside
There are stencils 😱
More soon(ish)
/P
  • Like 12
Probably the outlined "D" only, because the Geschwader and Staffel codes were irrelevant when you were the only Bf 110 equipped Nachtjagdstaffel in the whole Mediterranean and North Africa theater :giggle:
It's looking good with the markings on, Peter. I've seen other Luftwaffe aircraft with only the aircraft's identifier onlined like that, maybe to aide in identification of particular airframes?
James
All the way to decals and still on page 1.  Glad I caught this one before you finish it (at this rate, in the next post!).  Great work, especially crisp paint.
That sprue organiser is a game changer.
Thanks Mark.
I tend not to waffle, so my threads are short
I've upgraded from the plastic sprue organiser to a HobbyZone module. Although the original was great, the slots were too narrow to cope with some kits
I added some stencils
the rest are black and are not being applied as they won't ever be seen. Life's too short for that kind of effort
More soon(ish)
/P
She's looking very nice, Peter :) You made the right call on the stencils. I went as far as making my own replacement stencil decals in red for my Ar 555 as the kit ones were black and I'd painted the underside black. They still aren't visible :cwl:
James
Thanks everyone
Final few steps to get this over the line
Satin coat applied
Then started I unmasking the canopy
This is when a minor disaster struck
I spent nearly 30 minutes trying to remove the last piece of tape from the side windows
It just wouldnt budge
The canopy started to come apart, which is when I discovered I had stuck the part on the wrong way round
:swear:
The masking tape was inside the plane
It's all sort of recovered now but it's not pretty, and no, I didn't take pictures that show how much of a numpty I was :banghead:
Anyhow, it's done
Thanks to @vppelt68 and @81-er for the GB, @Enzo the Magnificent for keeping the twins well behaved, and everyone else for likes, comments or just for looking
I'll continue here with my Mossie build and I'm heading over to the Baby Boomers to play with my chopper
i'll post some pics in the gallery soon(ish)
/P
  • Like 11
