Gloss sea blue
Grumman58
I looked up that paint. It appears to be an enamel. I've put enamel over acrylic before with no issues. I would let the primer thoroughly cure, though. That's just me.
You should be fine.
9 hours ago, Grumman58 said:
Have got a tin of Colourcoats Gloss sea blue / ANA623 to go on Sword TBM3  Avengers. Would be ok to use Tamiya surface primer.
Thanks
it's enamel.  you don't need primer.  @Jamie @ Sovereign Hobbies
this is over a black base, but you could do this with GSB.
Links to Colorcoats video tutorials
https://youtu.be/58lB-xxaGAw
https://youtu.be/T-WqrJR5SDY
HTH
PS -  GSB ANA 623 was changed in in 1947,  as the original color faded.   Colourcoats do the post 1947 color, which became FS 15042, in case you are doing later TBM-3
https://www.sovereignhobbies.co.uk/blogs/sovereign-about-us-research-and-development/references-how-to-tell-the-good-from-the-bad
3 hours ago, Grumman58 said:
Thanks the Avenger will be around 1950-52
Do you have a reference photo?   If it look faded and tatty,  then the pre 1947 color is likely,  if not then you want  this
https://www.sovereignhobbies.co.uk/collections/colourcoats/products/acus35-post-war-usn-glossy-sea-blue-fs15042
This and the wartime color are not massively different,  FS15042 is greener and darker from the chips.   I have the Elliot book and a FS595 deck for reference.
HTH
7 hours ago, Grumman58 said:
Thanks.  The only reference I can go is B/W photo page 42 some ref details on page 60 Warpaint book on the Avenger. Seems VS21 operated the -3W 1950-51
\\the reason for the 1947 color switch was the original ANA 623 faded badly,
F4U-4 in 1946
F4U-4_of_VBF-82_on_USS_Randolph_(CV-15)_
I'd expect that a 1950 era USN type would be in the post 1947 color.
HTH
4 hours ago, Grumman58 said:
found a Tamiya rattle can seems a close match
Tamiya AS-8 Navy Blue (US Navy) – 100ml Spray Can 86508
Your thoughts pls.
Another forum member sent me a swatch of AS-8 to compare to my copy of the US Navy Monogram chips. Here is the comparison.
Tamiya_AS-8_versus_US_Navy_ANA_Sea_Blues
Is that the pre 47 AN623?
how does the swatch compare to FS15042?    As from the above the TBM-3W  by 1950/51 would be in the post 1947 ANA 623, which AFAIK became FS15042.
@Jamie @ Sovereign Hobbies CIE76 math is giving different values than than CIEDE2000 that I use but difference of 5.0 as the best is quite a lot.
Just for my personal curiosity, your spectrophotometer is 45°:0° ring illumination optics geometry, and the renders are sRGB?
Edited by Casey
Hi Casey, those ones were, yes. They were done a few years ago when the Nix was all we had at home. It's definitely not as accurate as a proper one but it's definitely got uses. I couldn't have carried a desktop around Portsmouth naval base for example :D
The renders were sRGB. I suppose the key takeaway is that the Tamiya AS paint samples I was sent aren't/weren't especially good for any of the US Navy colours either aircraft or ship types.
