1/48 SNJ-5 G-TEXN
Back in 2014, I did the Boultbee Spitfire Introduction course at Goodwood. The course involved 70 minutes in a Chipmunk, followed by 40 minutes in a Harvard and a Spitfire Tr.9. The Harvard was this one:
P1050683
I've managed to do two models of the aircraft I flew in so far and this is the second of them. WIP is here:
1/48 SNJ Texan - Work in Progress - Aircraft - Britmodeller.com
DSCN1780 DSCN1781 DSCN1782
DSCN1783 DSCN1784
One last one with the last aircraft in the training continuum:
DSCN1785
I probably should've picked out the unpainted screws in the panels but time's against me. I needed to finish this by the end of the week as everything's going into store for an extended period after Christmas while we move to the Netherlands for a year or so.
This classic Revell/Monogram kit was added to with Eduard P-51D wheels (most warbird T-6s use the Mustang wheels as they have disc brakes and anti-shimmy tailwheel tyres), Metallic Details CW-22B propeller (they're both Hamilton-Standard 2D30 props), Barracuda Studios spade grip in the front cockpit, Eduard details set (for the Occidental kit) that I used bits and pieces from and Microscale decals. Each letter and number is separate, so took a bit of mucking about! The decals on the engine cowl are from a 1/72 USAF C-130 that I had in the decals stash. None of the decals are the correct size but all are close. I made the antenna on the spine from a piece of metal rod and drilled out the pitot tube, added the ADF antenna on the belly from a modified Mirage III part and cut the elevators to show them drooped as they lock in that position on the ground. Unfortunately, the lovely artists' chalk white exhaust weathering I did on the port side disappeared with the Future clear coats; a phenomenon I experienced with the Lancaster, too despite the matt coat over them. I might need to use a different technique in future where white is used (no pun intended!) I didn't pick up until I was decalling that this particular T-6 doesn't use the standard tail nav lights on the vertical stabiliser and instead has a single one on the rudder. I wasn't about to go back and do it again!
Enjoy! The Chipmunk still to come is the Heritage Models version I hunted down about a year before Airfix release their excellent version. Oh, well.
  • Like 20
Very nice Texan (sorry from Texas so I'm prejudiced as to what this aircraft goes by).  This dark blue navy scheme is not one usually done on Texans, but it looks nice.  It is a very good representation of the real airplane you flew.  Just a nicely built and finished kit.  Thanks for sharing.
Thanks all. Despite its age, this goes together really well and there are a number of options in the kit to allow you to build a number of different versions. One of the easier models I've built in the last few years.
