US Army G7105 4x4 1.5T Panel Delivery Truck (35405) 1:35
Mike
1:35 MiniArt via Creative Models Ltd
The Chevrolet G506 truck formed the basis of a range of 4x4 load-carrying vehicles that could carry up to 1.5 tonnes of cargo, men or equipment.  They were initially made under the 4100 code, then were renamed as the 7100 series, and usually had a standard enclosed cab, with a 3.9L straight-6 engine under the bonnet, and a four-speed “crash” (non-synchromesh) gearbox putting out a little over 80hp through all four wheels.  It rapidly became the Allies’ standard light truck, and served in substantial quantities on the Western Front, with the Soviets on the Eastern Front, and the forces fighting Japan in the Far East.  There were plenty of variants, some in US Army service, others in USAAF service, with almost 50,000 of two specific types, the G7107 and G7117 sent over to the Soviets in large numbers under the Lend/Lease program.
The G7105 variant was a fully-enclosed van bodied truck that had a full metal bodyshell to protect the contents, and thanks to its twin wheeled rear axle, it was capable of carrying the same load as its open-topped siblings.  They were used extensively by the Signal Corps, but are relatively rare in the overall panoply of chassis types for this series.  Their low production quantities and participation in WWII trimmed their numbers further, so they are quite rare compared to others of the type, but some still survive of course, and can be seen occasionally at historic vehicle rallies and get-togethers of like-minded enthusiasts.
The Kit
This is a new boxing of a recent G506 tooling from MiniArt, and is one of an expanding range that is to be found in your favourite model shop.  It’s a full interior kit, with engine, cab and load area all included along with some appealing moulding and detail, particularly in the cab and those chunky tyres.  It arrives in one of MiniArt’s medium-sized top-opening boxes, and inside are fourteen modular sprues in grey styrene, a clear sprue, Photo-Etch (PE) sheet in a card envelope, decal sheet and glossy instruction booklet with colour profiles on the front and rear pages.  Detail is excellent, and well up to MiniArt’s usual standards, using PE parts to enhance the model, and finely moulded details of the chassis, running gear, cab and interior areas.
Construction begins with the ladder chassis, which has leaf-springs fore and aft, cross-braces and rear towing eye fitted to create the structure, then has the fuel tank with PE retention bands, PE rear bumper irons folded around a styrene jig, and axles installed on leaf springs, before the brake drums/hubs, battery and external brackets are added to the chassis rails.  The transfer box and drive-shaft join the two axles together, and a steering linkage and box are inserted into the front of the chassis, then the engine is built up based on the straight six-cylinder block, with carburettor, dynamo and transmission added, plus the serpentine pulleys and fan at the front.  The engine and substantial front bumper iron are fitted to the chassis, assembling the exhaust and its muffler, which slip into the underside of the chassis from below, held in position on PE brackets at the exit.
The wheels are made up with singles at the front, made from two parts each, and with twin wheels at the rear, again with separate outer sidewalls.  Each wheel slips over its respective axle, with the hub projecting through the central hole.  The three-part radiator housing is layered, with the rear part having a hole that allows the air from the fan to cool the radiator when stationary, mounting on the front of the chassis and mating to the input and outlet pipes already in position.  The crew cab is next, beginning with the firewall and forward sidewalls.  The firewall is detailed with dash pots fixed to the forward side, and is set aside until it is needed toward the end of building the bodyshell, which is next.  The sides of the van have a separate ribbing insert on the insides, to be joined to the floor after the raised platform for the crew seats is installed, fixing two four-part seats on top, and a small forest of levers in the centre of the floor.  The rear light clusters are mounted on PE brackets on the rear of the side panels, one per side, and as is often the case with instruction steps, they may be better left of until after main painting.  The floor is inverted to install the sidewalls, putting a short fuel filler tube on the outside that matches up with the extension within that leads to the tank.  The rear valance plugs into the floor on two pins, joining the two side panels together on the lower edge.  The rear doors and their interior cards are assembled with their handles, locking mechanism in a fairing with a flat PE surround, plus handles on both sides of the right door, and clear window glass with rounded corners.  The dashboard inserts into the A-pillars that are moulded into the roof, with seven decals for the instruments and stencils on the glove box, plus two more on the headliner by the rear-view mirror, which installs into the front of the roof panel.  The steering column is joined to the underside of the dash, adding a courtesy light and six curved ribs to the inside of the roof in grooves.  The crew doors and their interior cards are assembled with handles and window winders, plus the clear window glass that can be posed open or closed at your whim.  The windscreen frame has the two clear panes fitted, and has a pair of PE brackets and styrene wingnuts that are installed either vertically for closed, or at an angle for open, with a scrap diagram showing the correct orientation of the various parts, and below it on the scuttle is a ventilator panel that can be posed open or closed as you prefer.  The steering wheel is fixed to the top of the column, the diagonal kick panel is joined with the firewall and fitted out with three foot pedals, and a button that I think is the parking brake.
The roof and firewall assembly are fitted to the growing bodyshell assembly, while the rear doors are installed within the frame in the open or closed position if you prefer, adding a short stay from wire of your own stock.  Two rear arches are fitted under the floor into recesses, projecting past the line of the bodywork to encompass the twin rear wheels, then with the body righted, a pair of wing mirrors are glued onto the cab in front of the doors at handle-height on long struts with PE brackets at the bottom, posing the doors open or closed again as you wish.  The body and chassis are mated, and a choice of cowling panels fit to the sides of the engine compartment after adding a V-brace under the bonnet, then fitting the front wings that incorporate the section of running boards under the doors that joins up with the rear boards.  The front of the vehicle has its headlights with clear lenses plus sidelights fitted to the wings, and PE windscreen wiper blades are hung from the top of the frame on styrene arms, then the front grille is built.  You may have noticed that this appears on the sprues too for a simpler build process, but a more detailed and realistic grille can be fabricated from the PE parts on the fret.  It is constructed completely from PE, and two styrene jigs are included on the sprues to assist with accurately creating the correct shape.  The lower rail, light cages and curved side panels are made up on one jig from a single piece of PE, while the centre panel is folded up on another, then they’re joined together ready to be attached to the front of the engine bay.  There are two PE brackets stretched across the front of the radiator, but if you elected to use the styrene grille, this process is condensed down to nipping the part from the sprue, cleaning the sprue gates, and gluing it to the front of your truck, removing a small curved section from the left of the styrene grille for one decal option as it is glued in place.  The bonnet can be fitted open or closed with a PE stay that is provided in the centre of the panel for the open option.  The spare tyre is built from two parts like the rest of the wheels, and is mounted on a two-part bracket, the bottom tubular end gluing into a hole in the left side of the bodywork.
Markings
There are five decal options on the sheet, most in green, one in Navy grey, and from the box you can build one of the following:
  • 15th Army Air Force Combat Camera Unit, Guadalcanal, 1943
  • US Navy, 1945
  • 161st Sig. Photo Corps, US Army, Fort Bennig, 1942
  • 1st Signal Company, 1st Infantry Division, US Army, ETO, 1945
  • French Army, French Indochina, Late 1940s
Decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin matt carrier film cut close to the printed areas.
Conclusion
This is an interesting variant of the G506 chassis, and looks substantially different from its siblings, which with the detail that MiniArt pack into all their kits, it’s a very tempting offering.  Get one quick before creative run out!
Highly recommended.
Review sample courtesy of
