Messerschmitt Bf.109G-6 Easy-Click System (03653)
1:32 Carrera Revell
With almost 34,000 examples constructed over a 10-year period, the Messerschmitt Bf.109 is one of the most widely produced aircraft in history and it saw active service in every theatre in which German armed forces were engaged. Designed in the mid-1930s, the Bf.109 shared a similar configuration to the Spitfire, deploying monocoque construction and V12 engine, albeit an inverted V with fuel injection rather than a carburettor as used in the Spit. Initially designed as a lightweight interceptor, like many German types during WWII, the Bf.109 evolved beyond its original brief into a bomber escort, fighter bomber, night fighter, ground-attack and reconnaissance platform.
The Bf.109G series, colloquially known as the Gustav, was first produced in 1942. The airframe and wing were extensively modified to accommodate a more powerful engine, greater internal fuel capacity and additional armour. In contrast to early 109s, which were powered by engines delivering less than 700hp, some of the later Gustavs could output almost 2000hp with water injection and high-performance superchargers. The Gustav series accounted for a dizzying array of sub-variants, some of which featured a larger tail of wooden construction. Odd number suffixed aircraft had pressurised cockpits for high altitude operation, Erla Haube clear view canopy with clear rear head armour, underwing points for tanks, cannon or rockets and larger main wheels resulting in square fairings on the inner upper wings to accommodate them.
The Kit
This is a new tooling from Carrera Revell, but it isn’t a traditional plastic model kit, instead it is one of their Easy-Click system, but unlike any that we have seen previously, as it snaps together in a manner similar to the famous Lego bricks.  The kit arrives in a standard end-opening box with a render of the finished product on the front, and inside are five sprues of parts, one grey, one green, two light blue, and one black, each one ready to clip together once cut from the sprue.  There is also a clear sprue with a single canopy part, a sheet of decals, a sheet of stickers, and the instruction booklet that is printed in colour and has decaling and sticker application guides on the rear.  Each part joins to the other by friction fit, and each location turret has a corresponding circular receiver, and here an issue has crept in that might concern a “serious” modeller, as some of the receivers have resulted in shallow sink marks in the self-coloured plastic, which is most evident on the green coloured plastic.  I suspect that we’re not the intended audience however, as this is an ideal method of introducing modelling to a younger person, removing paint and glue from the equation, but keeping the cutting of parts from the sprues, and giving them a choice of decals or stickers, depending on their skill level or impatience.
Construction begins with the main landing gear, which are made up from two parts including the wheel, and can be lowered or retracted thanks to a short axle at the top of the legs.  They are placed in the lower wing halves, and each wing is fitted to a central black former that has some of the cockpit detail moulded-in, including the control column.  The wing roots are added, with optional painting instructions for the more advanced modeller, fitting the seat back into the cockpit, then surrounding it by two cockpit sides.  The exhaust stubs are fixed to the front of the central former, and is surrounded by cowling parts on both sides and under the chin, adding another panel under the wings, hiding the central former.  The instrument panel has two decals to apply, and this is inserted into the front of the cockpit, fixing the supercharger intake on the port side of the fuselage, then fitting the upper cowling gun troughs, the black barrel insert, and the rear cowling in front of the cockpit.
The upper wing parts are then clipped into place in green and grey to create the splinter camouflage out to the rounded tips of the wings, trapping the gear legs in position at the same time.  The starboard side of the rear fuselage is clipped into position on the central former, then a black extension is added, and locked in place by the port rear fuselage side, pausing to clip the canopy into the upper fuselage part, which has recesses to accept the moulded-in framework, which has caused a little distortion of the clear parts.  The centre former is extended again with a short part that includes the tail wheel, closed in by more tapering fuselage sections, then adding a short length of spine in green, and the tail fin on both sides of the centre, filling in the rest of the spine and slotting the elevators into a groove in the tail fin, then finishing off with the rudder.  To complete the model, the three-bladed prop is clipped onto the axle, and a spinner tip completes the prop.  Underneath, a two-part drop-tank plugs into a two-hole recess after clipping the two halves together.
Markings
There is one scheme in the box, but as there are decals and stickers included, the process is shown twice, as the numbers differ between the sheets.  Even though this is an Easy-Click kit, there is still a good number of stencils and other markings, so your model will have plenty of visual interest once completed.  From the box you can build the following:
The decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin satin carrier film cut close to the printed areas.
Conclusion
This kind of kit is a great introduction to modelling for today’s impatient youth, who probably wouldn’t even notice the slight sink marks on some parts.
Recommended.
Carrera Revell model kits are available from all good toy and model retailers. For further information visit
