Triumph 3HW (1/9 Italeri)
APA
A good weekend with the back of the pillion seat broken.
The kit one, as usual, doesn't bare any relation to a real one.
20240324_155418
20240324_155429
Pasticard cover. Still needs shaping but I'm happy so far.
20240324_155545
Couple of springs and bolts for the rear which will be put in place once everything is fettled.
20240324_155507
Cheers all
Andrew
  • Like 11
Finally!! Starting to see the end of the tunnel. Bit the bullet and powered through the front forks.
All dry fitted for now. Actually starting to look like a motorbike now 😊
20240401_180054
Started on a couple of cables
20240401_180108
Replaced the kit handlebar grips with more appropriate ones including the accelerator thingy.
20240401_180123
Also thinned out the brake and clutch handles. Cit version for comparison. The real things are quite long.
20240401_181228
New headlight blackout visor. The small round hole will have a white acrylic lens in it.
20240401_180143
Had a go ate weighting the tyres and it seems to have worked. I Proxxon'd out the solid inside and slipped in a piece of plasticard to spread the side out.
20240401_180204
And flattened the tyre bottom.
20240401_180211
20240401_180258
Subtle but does the job I hope.
20240401_180738
Not a great deal to do now. I think it's just the wiring loom and cables. I need to put everything together just to make sure they all fit !! 🙄. Wish me luck!! 🤞🏻
Cheers all
Andrew
  • Like 18
On 4/1/2024 at 10:37 PM, Gogser1 said:
Superb work, I continue to be amazed by it 😊
Thanks Gogser. Really glad your enjoying it 😁👍
On 4/2/2024 at 1:20 PM, Stef N. said:
Fantastic work and a massive thumbs up for the tyre. Looks spot on to me. 👍👍
Cheers Stef, much appreciated and thanks for following along 😀👍
Cheers all
Andrew
There is some very impressive work going on here!  It goes to show how inaccurate the kit is ...
The tyre looks great .... just enough 'bulge' in the walls 👌
Keith 😁
Keith 😁
Cheers keith. There's not a lot of it left 😂
Andrew
3 hours ago, Bullbasket said:
I don't think that Italeri ever envisaged this kit turning out like this. Brilliant work Andrew.
If Italeri put this much fabulous detail in you'd need a mortgage to buy one!
Agree with everyone else - you’re taking this to another level, only wish you’d been around to help out when I had my old Trail bike!
Andrew, what did you use for the grips?  I’m looking for something similar for a project……..Thanks
Rob
On 4/5/2024 at 9:06 PM, fikolo said:
very nice .😃
Thank you fikolo
On 4/5/2024 at 9:38 PM, Farmerboy said:
This has become a ‘tour de force’ of modelling, brilliant work.
Ha ha! appreciated FB
John.
Hi John, no I  doubt it too. They gave it a half assed shot back in '72 😂
I agree echen. Imagine if Gecko, Riich or Miniart tried their hand. Now that I would definitely buy 😉
Rob
Thanks Rob. I wouldn't know one end from another on a real one 🤡 My big brother, on the other hand, used to have a couple of Trials Bikes back in the day. A lime green Kawasaki with a diamond shaped tank springs to mind but I was about 12 at the time 😊
The grips are wrapped with some random material I've picked up along the way. It's very elastic. I suggest you go rooting through Mrs robgizlu's sideboard draws with a pair of scissors for inspiration 😉😎😜
20240407_182931
Cheers All
Andrew
Big day today. First full dry fit of almost everything.
Suffice to say, and you won't be suprised, there are a lot of fit issues. I'm going to have a lot of problems with this and it may turn out a bit bent!
20240407_182746
20240407_182734
I wrapped the seats with some tin foil from an easter egg which had some very subtle texture which hopefully will look a little like the leatherette type material used. I also added a bit of sag to the main seat. (See above pic)
20240407_182721
20240407_182702
20240407_182651
Apologies for the gratuitous knee 😳
20240407_182550
20240407_182541
20240407_182529
20240407_182515
Still got a few kit parts to add and a few scratch bits before I start painting. Probably more than I think 🫣
Cheers all
Andrew
  • Like 18
20240407_182931
Cheers All
Andrew
Thanks Andrew - when she finds me - I will of course quote you!  Looks interesting fabric
Rob
Wiring and a few odds and sods this weekend.
Done the loom and all the wiring I can do without the engine in place.
Horn cable
20240414_161130
Seat springs and brackets sorted (Springs just placed hence wonkyness)
20240414_161242
Cable for rear light
20240414_161346
First cable to the regulator and the dangling cable is for the battery positive. Also added a rubber boot on the alternator. All the restored versions have bare wires going in but they originally had this boot.
20240414_161357
Loom and additional wiring coming out of the headlight where most of the electrics are.
20240414_161411
I do believe that the next step is to crack out the airbrush!! 🫣
Cheers all
Andrew
  • Like 16
Outstanding work!  This just keeps getting better and better .....
Keith 😁
On 4/14/2024 at 9:37 PM, edjbartos said:
That looks tremendous, unbelievable detail work, I keep looking back at what you have done, just superb...
Ed
Thanks Ed really glad your liking the build 👍
Keith 😁
Cheers Keith 😀 still plenty to go wrong 😂
Cheers all
Andrew
On 4/18/2024 at 10:48 PM, Gogser1 said:
I have to agree with the others, fabulous work which I, personally, have found mesmerising 😎
Thank you very much Gogser 😁 Look into the Triumph, not around the Triumph.......😵‍💫
A
Finally put on all the extra nuts and bolts. I was going to add some grease nipples and then I had a stern word with myself 🙄
All finished
20240427_143805
All Primed. I was wondering about pre shading and then decided that apart from the tank there isn't really anything to pre shade!
20240427_191429
Base coat and basic colours done with a few bits of detail here and there.
20240428_164029
I haven't actually used any Vallejo for the main colours. They are all AK and because I don't like the Vallejo varnishes I got some VMS. I tried blending the Satin and Matte to get a soft sheen but it just went Matte so I sprayed the Satin as is. These are an excellent varnish. Sprays straight out of the bottle. Doesn't block or build up on the tip and goes down very even. I'm a fan 😁. Only thing is they are very fast drying and so are almost useless for brush.
20240428_164055
I'm liking the sheen. Early bikes and vehicles had white tips on extremities when black out visors was introduced so for a bit of bling I've added some on the mudguards.. I didn't want to use the kit decals and was going to use rub down transfers but I didn't have the right size. The kit ones worked excellently with no silvering and you can't see the edges now the varnish is on. Only issue is the tide mark where the microsol was which is annoying but not a major as I can blend it as weathering. Oh and this is supposed to be SSC2. Out the bottle the AK did look very close to Mike Starmer's swatch but once on it's a dead ringer for Kahki Green G3
20240428_164105
I can now actually assemble the thing all bar the wheels!!
Cheers all
Andrew
Looking fantastic ..... You're almost at the finish line! 👌
Keith 😁
