Lockheed Martin F-16B Fighting Falcon, Italeri 1/72
Hello, evryone! I bought the Italeri F-16 C/D Night Falcon kit by chance at a discount. I just wanted to assemble a model of a contemporary jet aircraft out of a box, carefully paint it and put it on a shelf. It would have turned out that way, unless the decal failed - it was completely worthless. Then I bought the another decal. But it turned out that the prototype on a new decal was from the early blocks and could not carry modern pods. Well, never mind: I decided to assemble the plane in the classic three-color gray camouflage carrying CBU and Sidewinders.
A few words about the assembling the kit: the weakest point is the jointing it doesn't correspond to reality. I didn’t want to change things dramatically, so I corrected only some of the most outstanding places.
The cockpit is given bare. Slightly improved it (instrument panels, pilot seats, canopy lifting mechanism, gun sight). The canopy covered with Tamiya smoke from inside.
I modified the exhaust nozzle so that from a distance it looked like the one, and not like an empty bucket.
ALL F-16 manufacturers (except Tamiya) produce a simplified air intake and cover it with a grid like a radiator. Therefore, I decided to depict something resembling a real air intake.
I trimmed the stabilizers to match the prototype (early blocks). Cut out several antennas from a beer can.
Improved the landing gear and niches simulating the electrical system, hydraulics, battery, gas cylinder, and spotlights (Elf).
Static dischargers - fishing line. This is far better than a wire, since one often touches them during the construction and painting process. I made all the necessary formation lights.
The aftermarket used: a PITOT tube (the Master kit also included the angle of attack indicators). As well as Hasegawa armament (bombs and missiles).
Painting mostly Hobby Color acrylic - “bottom” FS36375, “top” FS 36118, but side surfaces FS 36270 from HATAKA. Nitro varnish (orange) NATAKA. Weathering and some highlights for a panel effect mainly with oil paints,  watercolor pencils and AK wet effects fluid. Oil paints diluted with white spirit were applied by an airbrush freehand and through a stencil. Super Scale Decals. Stencils partially Printscale decal. Some pictures showing stages of assembling and painting at the end.
F-16B block 10, 428 TFS, 474 TFW, Nellis AFB, Arizona, mid-1980s.
Hope you'll enjoy it and good luck!
921140718_LockheedMartinF-16BFightingFal
1975103602_LockheedMartinF-16BFightingFa
364432766_LockheedMartinF-16BFightingFal
265309740_LockheedMartinF-16BFightingFal
785157345_LockheedMartinF-16BFightingFal
2092790017_LockheedMartinF-16BFightingFa
1977422306_LockheedMartinF-16BFightingFa
450340984_LockheedMartinF-16BFightingFal
2032274455_LockheedMartinF-16BFightingFa
704284569_LockheedMartinF-16BFightingFal
737195523_LockheedMartinF-16BFightingFal
1663236932_LockheedMartinF-16BFightingFa
601097777_LockheedMartinF-16BFightingFal
1625459010_LockheedMartinF-16BFightingFa
1305611107_LockheedMartinF-16BFightingFa
1798963046_LockheedMartinF-16BFightingFa
1493968071_LockheedMartinF-16BFightingFa
814092537_LockheedMartinF-16BFightingFal
2006782157_LockheedMartinF-16BFightingFa
368868335_LockheedMartinF-16BFightingFal
1761219535_LockheedMartinF-16BFightingFa
326413318_LockheedMartinF-16BFightingFal
2072373235_LockheedMartinF-16BFightingFa
35674255_LockheedMartinF-16BFightingFalc
889019066_LockheedMartinF-16BFightingFal
231447326_LockheedMartinF-16BFightingFal
693530259_LockheedMartinF-16BFightingFal
252663302_LockheedMartinF-16BFightingFal
362498504_LockheedMartinF-16BFightingFal
  • Like 31
