1/350 HMS Resolution 1942
thekz
3 hours ago, Courageous said:
The sailing boat looks really neat. I know  it's not THE build but how did you build it?
Stuart
The hull is from the Warspite kit from the Academy. It's slightly modified. The masts are soldered from copper wire. The sails are foil. The crew is carved from sprue.
Continuing to saw the sides:
As a result, the starboard side now looks like this:
And the slightly behind port side looks like this:
During the breaks, I entertained my date by sculpting small forms and raft-building:
Happy New Year, everyone!
  • Like 16
8 minutes ago, El Búho de Sevilla said:
The only remaining question is whether this difference will be anywhere close to visible on the ship as a whole 🫤
Don't you know who's hiding in the little things!🙀
My building is moving from the midships to the stern:
Some detailing can already be seen in the barbette area of Tower X - experience with Malaya has shown that it will be difficult to get there later.
But what is undoubtedly visible progress is the increased community of rafts:
and progress to you!
  • Like 12
The news from my shipyard this time causes cautious optimism: I managed to round the stern.
Several cuts were made on the feed pieces and they were bent after heating in a cup of coffee. Did you believe it? Well, not with coffee, but just with boiling water :nod:
This was enough for soft Trumpeter plastic. On the bottom is the result after several days of sanding.
Thus the external shape of the hull is completed!
It is interesting to compare the resulting hull with the Malaya hull photographed about 2 years ago.
I think many will agree with me that in the photos of the 20s-30s, before ships of the Queen Elizabeth class received hangars and tower superstructures, it is sometimes quite difficult to distinguish them from ships of the Revenge class. Only a completely different funnel shape is an obvious sign. But if we look at the hulls without turrets and superstructures, the difference is very striking and it is not difficult to guess that they were designed by different designers. And the Revenge type suddenly looks much more modern.
I'm starting to work on the superstructures.
On the photo is the only part of the superstructure (I do not know its correct name, I will be grateful if someone will tell me), which will fit after some modifications. All the rest will have to be made by myself.
For example, this still rather shapeless piece of gray plastic dreams of becoming a shelterdeck when it grows up.
PS I won’t hide my sin. A close look from some angles reveals that the body is oblique and crooked. I hope you will forgive me that I will not post photos from these angles. As often happens, a compromise is made with conscience: write about it, but not redo it, and hope that in the finished diorama it will be quite difficult to notice my crookedness. Moreover, 99.9% of viewers will see it only in my photos.
In short, we wanted the best, it turned out as always  :headbang:
Edited by thekz
  • Like 11
Yeah, I've noticed that the hulls of Revenge class look more modern than the Queen Elizabeth's ones after the first look at the drawings, but of course on a model this difference is even more noticeable. Anyway, they clearly were worse ships - in the context of WWII, only useful for keeping something like KMS Hipper, RM Zara, or IJN Mogami from trying to harass a convoy in question (and probably something even more boring - like shore bombardment routines) 🫤
I think there are people here who can explain better than I can why this happened.
I've read about two factors:
1. There was less space for the propulsion system in the hull of the Revenge class, so modernisation with its replacement was carried out first of all on Queen Elizabeth class (3 out of 5 were modernised), and the Revenge had already worn out mechanisms by the beginning of the Second World War.
2. The Revenge class was built in the conditions of the war that had already started and therefore the quality of hull construction was worse than that of the Queen Elizabeth class.
       Gidday @thekz, I think you've done a terrific job of Resolution's rounded stern. And if you think parts are crooked then I'll have to take your word, because they don't look crooked to me. I think you're doing very well with this, something I'd like to do in the future.
       Gidday too. I think you're being a little unkind to the R class ships. Like the QE class they were products of an earlier age but built to different parameters. The QE class were I think the first attempt at a 'fast battleship'. The following 'R' class were built to stay in the battle line and slug it out with their opposing numbers so they were a little smaller and slower but tough and powerful. By WW2 they were both past their prime and as the battle line was no longer WW2 tactics (except at Surigao Strait in 1944) the R class were somewhat obsolete. But they could take on more than just heavy cruisers. Adm Lutjens had both Scharnhorst and Gneisenau when he attempted to attack a convoy escorted by an R class battleship, whose mere presence forced him to break off the attack. And had Bismarck escaped into the Atlantic in 1941 one of these battleships would have been sufficient to protect a convoy from her. Although 'on paper' these were no match for Bismarck or Tirpitz they only had to damage the German ships, not sink them. Due to their limited numbers the German ships could not afford damage when out in the Atlantic. They didn't have many places they could go to for repair.
       The issue is probably a little more complex but those are my thoughts anyway. Regards, Jeff.
I'll let you in on a little secret. I have been doing professional photography for more than 20 years. So to photograph something crooked in such a way that it doesn't look crooked on the photo is a banal professional skill for me :nod:
  • Haha 3
Gidday again, there's no point in having skills if they can't be used to advantage. 👍 Well done. Regards, Jeff.
  • Haha 2
Yep, sure. A duel against a battle cruiser (but not so many nations - except British themselves - had them during WWII) or a German pocket battleship would give an R class battleship pretty solid chances to win. I just didn't remember by hearth what armour and what armament every of these beasts had (and didn't want to make my list of ships too long), so simply mentioned some obvious examples ;)
