robgizlu Posted September 20, 2023 Posted September 20, 2023 Well, for the first time in months I had a full day at the desk yesterday - Bliss. Multiple episodes of "The Rest is History" and more accomplished than in the last 2 months. After having put together the raised bridge on the LCT-5 and being in the mood I though I'd crack on with the Flower Corvette from Black Cat Models which needs similar treatment. Jon @Faraway has done one iteration as HMS Begonia And Michal @socjo1 recently opted for HMS Hibiscus which I had orignially eyed up with it's striking zig-zag camo pattern It would have been perverse to have 2 ships being modelled with the same camo pattern given the enormous numbers of Corvettes and their multiple morphologies and colour schemes. So I searched for an alternative - given that this is a short focsle Flower, there wasn't a huge choice until I stumbled across a photo of HMS Abelia. With many thanks to IWM collections for once again providing such an evocative image. For once there appears to be consensus that the colour scheme is a variant of Western Approaches Sadly I have only been able to find this one photo of her in her Short Focsle iteration. She was slightly peculiar as so many Corvettes are and has a number of distinctive features. From stern forwards: 1) She is fitted with minesweeping gear including winch (Good as the kit supplies all ) 2) She lacks rear splash guards 3) 2 pounder platform is amidships (unlike most Canadian vessels including HMCS Agassiz that the kit portrays, (which had the platform at the rearmost part of the aft superstructure) 4) 2 pounder platform has an extended searchlight platform 5) She carries double Carley floats in an atypical position and a futher raft is mounted at an angle abrest the funnel 6) The ?14/16ft ship's boat platforms are further aft than for the kit's HMCS Agassiz 7) She carries 274 radar and was one of the first Flowers to be so fitted. It is mounted on a tall raised platform that communicates with the bridge deck 8/ The Bridge is almost unique in being a type A with wheelhouse and charthouse below and compass house above. The compass house has a "Flying bridge" above that, which is solid panelled (vs railings) as evidenced by the presence of pominent wind deflectors. The radar tower integrates with the bridge deck. Lantern cover is round and multi-facetted which is a "late" feature. (Early versions were octagonal and had fewer frames) 9) There appears to be no secondary anti-aircraft armament - she carries searchlights on the bidge - not Lewis guns. There might just be a pair of Lewis guns on the rear superstructure 10) Mast is forward of the bridge 11) The 4" gun shield is rounded 12) She lacks portholes beneath the gun platform Some modifications will be required fom the supplied resin kit The resin hull is beautifully and flawlessly moulded Superstructure and Bridge parts are separate and "plug" into the hull First order of business was to construct the Radar tower. Without plans the only option is to work from the photo using "proportions" and comparators as to regards size and height. The supplied bridge deck was definitely extended backwards on Abelia. I had a Micromaster 274 platform with lantern, so construction of the tower could be divided into base with it's distinctive "arch", square tower abutting the rear bridge deck and likely envaginated by it (Can't take the anatomist out of the modeller ) and finally the lantern platform atop. A former is shaped and then stuck to a second piece of plastruct with CA glue so that a second can be shaped accurately My little set-square is used to "square" parts up The first try was too wide so start again...... The middle "box" section was constructed using my cheap guillotine to get uniformity of length and the set square to .....ahem "square". The edges were bevelled with a file so as to get a neat join Test fitting showed it was too high so it was sawed down The metal "credit card" appeared as a windscreen scraper one Christmas and is one of my most useful tools The "Flying bridge" has been added and comparison with the originial photo shows it is still too high. More soon Thanks for looking Rob 17
Faraway Posted September 20, 2023 Posted September 20, 2023 Two on the go at once ? Is there no stopping the man ? Jon 1
robgizlu Posted September 20, 2023 Author Posted September 20, 2023 Taking a leaf out of your book Jon Rob (it won't last) 1
Faraway Posted September 20, 2023 Posted September 20, 2023 8 minutes ago, robgizlu said: Taking a leaf out of your book Jon Rob (it won't last) At least I only do ONE at a time. Jon 1
dickrd Posted September 20, 2023 Posted September 20, 2023 You have got to love the IWM caption to that photo of Abelia: "HMS ABELIA, Flower class corvette at Hvalfjord, Iceland after a patrol in the North Atlantic in search of the German battleship TIRPITZ." Good thing she did not find Tirpitz I think! More seriously, pretty as that colour illustration is, I very much doubt that it was a 2 colour plus white WA scheme. None of the official Western Approaches camouflage designs surviving have all one colour on the hull and all another colour above. Where there are two colours you get alternating panels in each area. Also I see absolutely no difference in tone between the coloured areas in the photo. Normally if there were two colours in a Western Approaches scheme they show as different tones, the green usually appearing (probably due to camera settings, film, filters etc) as darker. (Although this is a 1942 photo the design is pretty close to the Plate 18 one in CB3908R of 1943.) Personally I suspect we are looking at white and WA blue. 5 2
Faraway Posted September 20, 2023 Posted September 20, 2023 17 minutes ago, dickrd said: Good thing she did not find Tirpitz I think! Would have made for an heroic story. Jon 1
robgizlu Posted September 20, 2023 Author Posted September 20, 2023 36 minutes ago, dickrd said: You have got to love the IWM caption to that photo of Abelia: "HMS ABELIA, Flower class corvette at Hvalfjord, Iceland after a patrol in the North Atlantic in search of the German battleship TIRPITZ." Good thing she did not find Tirpitz I think! More seriously, pretty as that colour illustration is, I very much doubt that it was a 2 colour plus white WA scheme. None of the official Western Approaches camouflage designs surviving have all one colour on the hull and all another colour above. Where there are two colours you get alternating panels in each area. Also I see absolutely no difference in tone between the coloured areas in the photo. Normally if there were two colours in a Western Approaches scheme they show as different tones, the green usually appearing (probably due to camera settings, film, filters etc) as darker. (Although this is a 1942 photo the design is pretty close to the Plate 18 one in CB3908R of 1943.) Personally I suspect we are looking at white and WA blue. Thanks Dick. I had wondered but Raven and Bob Pearson had so confidentlly stated and presented........... and you're right it is attractive However - as ever - I deeply value your input and you've potentiated my suspicion so WA Blue it will be. (Damn - I did like that green stripe ) Rob 3
ArnoldAmbrose Posted September 20, 2023 Posted September 20, 2023 Gidday Rob, this looks like a nice build, and a Flower class is always a worthy subject I think. I also like seeing scratch built alterations. But if you don't mind my saying, that platform you've done for the type 274 radar lantern looks VERY high to me. The diagram and photo at the top show the platform with the rails about level with the top of the flying bridge balustrading but in your final photo it looks much higher. Regards, Jeff.
robgizlu Posted September 21, 2023 Author Posted September 21, 2023 19 hours ago, ArnoldAmbrose said: Gidday Rob, this looks like a nice build, and a Flower class is always a worthy subject I think. I also like seeing scratch built alterations. But if you don't mind my saying, that platform you've done for the type 274 radar lantern looks VERY high to me. The diagram and photo at the top show the platform with the rails about level with the top of the flying bridge balustrading but in your final photo it looks much higher. Regards, Jeff. Fear not Jeff - as per my last post - further cutting down was needed. It's trial and error using proportionality. I think that's it. Next up were the wind deflectors for the flying bridge. and while thta was going on - work commenced on the base. Once again I'll be using some embossed plastic card (Thankyou alan Blythe) Which gets us to here - it's all dry fitted so don't worry if the funnel etc is a bit wonkey And you'll notice the aft 2 pdr bandstand mount loose after having been micro-sawed off from it's original (more aft) position. More soon Thanks for looking Rob 12
ArnoldAmbrose Posted September 21, 2023 Posted September 21, 2023 13 minutes ago, robgizlu said: Fear not Jeff - as per my last post - further cutting down was needed. It's trial and error using proportionately. Gidday, please forgive me for ever having doubted you - that looks much for accurate. 🙂 And the detail on that kit looks very good. She's coming along very well. Regards, Jeff. 1
Jagdtiger1 Posted September 21, 2023 Posted September 21, 2023 Looking very nice Rob, will be good to see her painted up. Always have liked the look of the Flowers with the foremast ahead of the bridge. First time I've heard of embossed plasticard as a water base. Have you got a link to the site you bought it off? James. 2
robgizlu Posted September 21, 2023 Author Posted September 21, 2023 2 hours ago, Jagdtiger1 said: Looking very nice Rob, will be good to see her painted up. Always have liked the look of the Flowers with the foremast ahead of the bridge. First time I've heard of embossed plasticard as a water base. Have you got a link to the site you bought it off? James. Hi James - Thanks http://www.amera.co.uk/product.php?range=p HTH Rob 1
Courageous Posted September 21, 2023 Posted September 21, 2023 Glad you've found your way back to Maritime. Great work Rob, nice to see that these resin kits can get modified. Hopefully we'll see this completed before you go walkabout again. Stuart 1
robgizlu Posted November 2, 2023 Author Posted November 2, 2023 Back to the bench after an extended roving maritime jaunt. The bandstand built reasonably OK The rear 2 pounder platform had a searchlight platform fitted, so some scratching produced this The bandstand supports are fitted and "A Stand" Mig ammo (formerly Alclad) primer is applied after first vigorously degreasing the hull with cycle degreaser A quick anti-slip grey is sprayed. Reference to the original photo shows areas on the white hull of much darker shade, likely 507A beneath the layer of white paint. So - I sprayed 507A onto patches of the hull and then applied some liquid mask And whilst waiting for all this to dry, I committed the cardinal sin of bringing out my last Mirage Hobbies hull Fatal.........before you know it, it's built itself This wouldn't be such a Silly move IF Ben Druel at Black Cat hsn't just released the new Long Foc'sle Corvettes And you won't be suprised to hear that HMS Snowberry is winging it's way as we speak soon to be produced at Matthews Shipyards as HMS Mignonette So in essence we are getting a bit Corvette-tastic !!! And nowt wrong with that. The Mirage Hobby hull will be built as HMS Jonquil and I'm not going to blog it as it will mimic the HMCS Eyebright build. However it is worth mentioning that the hull itself is really excellent with realistic hull plating and detail. It's just such a shame that the rest is absolute pants, and there is no earthly excuse to build one now with the Excellent Black Cat kits readily avilable. AND - Ben has released "Rope coils" after all my nagging - Yay Though there's a possibility he'll amend the initial release and add "Flaked" ropes etc. Either way they are very very welcome and IMHO all should have them Finally the base is nearing completion Not a lot to show for a near 6 week absence! Thanks for looking Rob 11
beefy66 Posted November 2, 2023 Posted November 2, 2023 Good to see you back at the bench Rob it all looks like the shipyard is set to get busy over the winter months. Stay Safe beefy 2
Courageous Posted November 2, 2023 Posted November 2, 2023 8 hours ago, robgizlu said: Not a lot to show for a near 6 week absence! Will have to chain you to your model bench...6 weeks! Stuart 3
S-boat 55 Posted November 2, 2023 Posted November 2, 2023 It's amazing how things can build themselves isn't it ......... 😉 1
robgizlu Posted November 7, 2023 Author Posted November 7, 2023 And first Western Approaches Blue sprayed. Not used it on a model before - what a beautiful colour It's easy to copy Bob Pearson's profile...... However careful and prolonged study of the ONLY photo I can find and available suggests some differences....possibly only of interest to the pedants amongst us But if you follow me like a Lidenbrock to my Arne Saknussemm here's some musings: 1) As @dickrd has pointed out the lower hull colour - not white, is likely WA Blue 2) The 2 Pdr bandstand is likely white as is evidenced by the contrast with the obvious WA blue on the searchlight platform (Green circle) 3) The Funnel has a definite divide approx half way down and in truth the cowl vents appear white below up to the cowls themselves which appear Blue (upper Red circle) 4) The 273 platform is white from the Compass deck upwards. I have NO idea what the black rectangle is below the lantern - I'm sure it's not a window. Anyone got any guesses? The whole compass platform railings are confused and likely have anti-splinter mattresses untidily hung. 5) Bizzarely the WA blue appears to run in a band from the lower bridge all the way aft past the depth charges that appear blackish against it. Magnify the pic and see for yourself, with a distinct line visible above the hull side parapet OR am I confusing things here? HMCS Eyebright definitely had a similar arrangment but in a dark colour ? the Antislip paint extended up onto the superstructure walls. I can't say that I've noticed this in any other corvettes. It seems odd painting the superstrucutre walls next to the deck where it's largely shielded by the hull sides. (Lower Red circles) 6) Oddly the ships boat appears dark ? Grey 7) The 4" gun side splinter protection Boards could be either white or WA blue - It's really difficult to discern. Following the examples of some other vessels (HMCS Amherst) I'm opting for WA blue And progress on the hull has slowed as I had some rather nasty sink holes form the portholes I filled that needed refilling sanding, painting and then more sanding sitting too proud. Damn even with an optivisor the vision is definitley degrading Thanks for looking Rob 8
Rich75 Posted November 8, 2023 Posted November 8, 2023 Hi Rob, looking good so far sorry I cant offer advice on your questions, you know the class much better than me, so I'll just watch and learn usual, out of interest there's some great photos of HMS Alisma on IWM, that, to my untrained eye, looks similar to your build? 1
robgizlu Posted November 9, 2023 Author Posted November 9, 2023 1 hour ago, Rich75 said: Hi Rob, looking good so far sorry I cant offer advice on your questions, you know the class much better than me, so I'll just watch and learn usual, out of interest there's some great photos of HMS Alisma on IWM, that, to my untrained eye, looks similar to your build? Thanks Rich - I was familiar with the colour scheme of Alisma but had not realised how similar she was. Oh for 3 different views of every ship! What I did notice was the base of the 273 tower has some cross bars - now added Dioch yn fawr! Of note is the "Reversible" wood liferaft below the carley raft on the stand. May have a go at scratching one of those. Rob 4
beefy66 Posted November 9, 2023 Posted November 9, 2023 On 11/7/2023 at 9:38 PM, robgizlu said: However careful and prolonged study of the ONLY photo I can find and available suggests some differences....possibly only of interest to the pedants amongst us But if you follow me like a Lidenbrock to my Arne Saknussemm here's some musings: I follow your builds does that count. Going from the photo of previous post and Bob Pearson's drawing I would think it was just WA Blue and A very worn White you are looking at think the WA Green should be Blue As to my eye both lower hull and forward gun top colour look the same just my point of view mind. Those Black Cat new releases are looking very tempting but have enough to keep me going for a while yet. Stay Safe beefy 1
Rich75 Posted November 9, 2023 Posted November 9, 2023 10 hours ago, robgizlu said: Dioch yn fawr! No problem (I had to look that up!) 😁 1
robgizlu Posted November 9, 2023 Author Posted November 9, 2023 6 hours ago, beefy66 said: I follow your builds does that count. Those Black Cat new releases are looking very tempting but have enough to keep me going for a while yet. Stay Safe beefy Certainly does young Beefy The Black Cat Models are really things of beauty - superb models IMHO Rob
robgizlu Posted November 9, 2023 Author Posted November 9, 2023 5 hours ago, Rich75 said: No problem (I had to look that up!) 😁 Hi Rich Partly I'm sure because I spelt it wrong Though in fairness it was the wee small hours as you'd sent me on a mission to pimp my tower and begin a scratch build of the "reversible" life raft Rob 2
Faraway Posted November 9, 2023 Posted November 9, 2023 48 minutes ago, robgizlu said: The Black Cat Models are really things of beauty - superb models IMHO Of all the resin models I’ve built, Black Cat are by far the best. I’ve yet to have a part that doesn’t fit. And although they can seem expensive, I don’t think they are, as you don’t have to add ANY aftermarket parts. Jon 2
