7.5cm PaK40 Ammo Boxes with Shells Set 2 (35402) 1:35
Mike
1:35 MiniArt via Creative Models Ltd
We reviewed MiniArt’s fabulous new Pak.40 75mm Anti-Tank Gun here, and it contained a few sprues of shells and boxes to scatter some ready rounds nearby, but you can always use more if you plan on depicting a well-stocked battery that’s prepared for a long battle, and this is the second set we’ve had in, with different containers and shell type.
This set includes seven sprues, two box sprues, two canister sprues, two shell sprues that are the same as in the PaK40 kit, and one spent shell casing sprue that have hollow necks, as do the canisters, thanks to some slide moulding magic.  It also includes a sheet of decals to stencil the shells and their containers once they’re painted and before you begin the weathering process.  A set of twenty ready rounds are included, with another four empty brass casings, plus four light-weight planked boxes that have slots for three shells each, and are made from individual perforated upper and lower, solid sides, ends, plus handles, and can be posed open or closed if you wish, although with these you will need to place shells inside if you expect your audience to believe they are full, as the contents can be seen through the slots, even when closed.  The two sprues of cylindrical wicker single shell cases have separate caps and fluted sides for strength, which have an open end if you want to display them discarded after use with their lids open.
Markings
The back of the box has instructions, sprue diagrams and colour information printed on it, including a chart that gives codes for Vallejo, Mr Color, AK Real Color, Mission Models, AMMO, Tamiya, as well as colour swatches and generic colour names.
Decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin matt carrier film cut close to the printed areas.
Conclusion
If you have a PaK.40 from any manufacturer at this scale in the stash already, or intend to get one (which should be the MiniArt kit – it’s gorgeous), this set will add a healthy stack of shells in super detail with all the stencils you could need to complete the task to the best of your ability, along with some of the more unusual metal cases to provide some individuality.
Highly recommended.
Review sample courtesy of
