johndon Posted August 9, 2023 Posted August 9, 2023 Well that's everything I need for my first Trek build in over 20 years, the 1/350 Polar Lights K'T'inga with photo etch from Paragrafix and a lighting kit from Cozmic Scale Models. I thought about adding the PE set for the shuttle bay but as far as I recall, we've never seen the shuttle bay on screen so decided against it. I've gone for Cozmic lighting kit as I figured for a first go I'd rather have all the components together rather than having to source them all my self. As the kit comes with paint callouts for Tamiya acrylics (which I use exclusively) I'll be using those, how accurate it is I don't know but, whilst I'd never paint it pink, given the huge difference in the colour of the physical model compared to how it appeared on screen, I'm not one to get hung up about it. I'm not the fastest modeller in the world but looking forward to getting this one started... John 15
Carts Posted August 10, 2023 Posted August 10, 2023 Great looking set of stuff for a great looking ship.Will follow this👍 1
johndon Posted August 11, 2023 Author Posted August 11, 2023 Made a start with the bulb and bridge and the first light is in. Most of this is just slotted together and no attempt has been made at light blocking yet. John 9
johndon Posted August 12, 2023 Author Posted August 12, 2023 More lights done, Again, no light blocking or diffusion yet. John 7
johndon Posted August 16, 2023 Author Posted August 16, 2023 Mostly still held together with tape, she's be a big girl when she's finished... 10
johndon Posted August 18, 2023 Author Posted August 18, 2023 Bridge windows are done and this part of the model is ready for sealing up and a coat of paint. I'm going to leave gluing the bridge dome and window strip in place until after painting which saves having to mask the bridge windows. I ended up not using the PE strip for the windows and just sprayed the clear part then removed the paint on the windows with a took pick. The main window strip has been painted black/green so I can mask the two 'troughs' that the windows sit in, far easier than masking each window individuallysk 9
Thom216 Posted August 18, 2023 Posted August 18, 2023 Love the red up there. Look's like a Cylon's eye. 1
johndon Posted August 22, 2023 Author Posted August 22, 2023 More lights done. A couple of light leaks to sort out and, as always, the camera makes the LED hot spots look worse than they are in reality... John 11
johndon Posted September 25, 2023 Author Posted September 25, 2023 Work continues at my usual glacial pace, the top part of the bulb is now all put together and in it's base coat of Tamiya XF4. Window lights are a bit bright so I'm hoping a couple of coats of matt varnish on the clear windows will tone it down a bit... John 11
johndon Posted October 2, 2023 Author Posted October 2, 2023 (edited) I have a tendency to jump from part to part when building so, this evening, I have been working on the impulse engines with some of the Paragrafix photo etch for the grills. As you can see from the first photo, the PE parts are a little smaller that the openings that they fit into: so, I fitted an internal frame to not only hold the PE in place but also to fill the gaps round the edge which also provides a handy ledge to fit the kit clear parts, which have been treated to a few coats of matt varnish to diffuse them, to: and a coat of paint disguises the frame although I may fit another .5mm frame to the outer side of the PE to completely hide the fact that it's not quite large enough: John Edited October 2, 2023 by johndon 10
johndon Posted October 7, 2023 Author Posted October 7, 2023 Botton of the bulb is now lit, some light blocking still needed. 9
johndon Posted October 15, 2023 Author Posted October 15, 2023 Lots still to do but its beginning to look a lot like Klingon... 6
johndon Posted October 24, 2023 Author Posted October 24, 2023 The main hull halves of the KTinga have been glued together and I was pleased to see that all the lights still work. I'm particularly pleased with the effect the PE grilles give on the impulse engines, some light blocking still to do. The rear torpedo launcher does light up but I've put it on a separate circuit so it is not on all the time. John 9
johndon Posted October 30, 2023 Author Posted October 30, 2023 Started detail painting on the KTinga, paint is Tamiya acrylics thinned with isopropyl alcohol and almost dusted on to reduce the chances of bleed under the masking. John 6
johndon Posted November 8, 2023 Author Posted November 8, 2023 After even more masking, I'm very nearly there with this part. Some very small touch ups needed and the bit under the hanger bay entrance needs painting but, once that is done, it's be decal time then this will be put to one side as I'll weather the ship as a whole. I'm not trying to replicate the studio model and I figure that there would have been lots of variation in paint schemes so I'm not following the instructions too closely with regards to colours. John 5 1
johndon Posted November 14, 2023 Author Posted November 14, 2023 The upper rear part of the hull now has it's decals. They went on well but are quite thick but I'm pleased to see that after a coat of gloss and then two coats of matt varnish, the carrier film has all but disappeared. Detail painting on other parts has now started... John 6
Mike Sacklyn Posted December 22, 2024 Posted December 22, 2024 John, I will be building this K'tinga with the Cozmic lighting set in the near future. How did it work for you?
johndon Posted December 23, 2024 Author Posted December 23, 2024 On 12/22/2024 at 12:42 AM, Mike Sacklyn said: John, I will be building this K'tinga with the Cozmic lighting set in the near future. How did it work for you? It worked very well, I had no problems with it and it was easy to put together assuming that you have some experience of soldering. Just realised that I've not touched the model in over 12 months, I really should get back to it.
Mike Sacklyn Posted December 23, 2024 Posted December 23, 2024 Excellent! I do have some strong soldering skills so the overall application is what I was curious about. Looking forward to more posts as you have been doing a great job with it so far!
johndon Posted February 26 Author Posted February 26 After 12 months of no progress at all, I've just finished the lighting install on the KTinga, I'm particularly pleased with effect on the impulse engines. 6 1
S-boat 55 Posted February 26 Posted February 26 Those impulse engines look great, should imagine they look even better in the dark as well,
johndon Posted February 26 Author Posted February 26 38 minutes ago, S-boat 55 said: Those impulse engines look great, should imagine they look even better in the dark as well, They do but I'm struggling to get a photo as they LEDS tend to blow out the lens on the iPhone so getting a photo isn't easy...
Mike Sacklyn Posted February 28 Posted February 28 Fantastic! Very happy you have picked this back up again!
johndon Posted February 28 Author Posted February 28 Launch aft torpedos! The addition of the Paragrafix photo etch part has made a huge difference here although I made it really hard on myself by not installing it originally so it is fitted on the 'outside' of the kit parts. 3
Gimme Shelter Posted March 6 Posted March 6 wow - 100% love this - great sized kit It's going to look superb once completed 1
