Revell Battlestar Galactica++Finished++
Once I've cleared away some of the other WIPs on my bench, I plan to build this
(although perhaps I shoudl try to sell it on ebay; they seem to be going for silly money ATM)
Sprue shots
And the decals
More soon(ish(ish))
/P
  • Like 14
This is ‘new’ Galactica from the 2000’s.
New Galactica can be identified by the prominent ‘ribbing’ all along the hull. Old Galactica also had a prominent command bridge that’s not visible on the new one. The propulsion layouts are also very different.
There are loads of other differences too.
To my eyes at least, the re-make ship looks sleeker and curvier and generally more ‘modern’. Just like the show itself I guess.
  • 1 month later...
  • 1 month later...
Well, this escalated quickly
I thought about removing some of the locating "pins" to see if the fit was any better
Turned out, it was, so this happened
Then this. Filler will be needed, but it's not as bad as the test fitting
Then other bits happened
which lead to this
and this.
There's something amiss with the instructions
Seems like the main hull shouldn't be stuck together until after these 2 sections are joined
Too late now, so out with the razor saw......
And finally, I got to this stage
Paint will have to be applied before I can do much more assembly
More soon(ish)
/P
  • Like 10
Looking good so far, I prefer the original design to the remake. However prefer the new tv show to the original. If for no other reason than it was on for more than 2 seasons. Likewise Im a bigger fan of the original viper’s over the new ones.
Edited by Corsairfoxfouruncle
  • 3 weeks later...
On 11/9/2023 at 10:29 AM, bianfuxia said:
reckon you're in with a shot to get it finished?
Reckon so
Ready for primer
I got the first light coat on, but had to stop before my compressor threw a wobbly (it's a lot to spray)
Should get the rest of the priming done tomorrow
More soon(ish)
/P
20 hours ago, Bertie McBoatface said:
No going back now.
Indeed not
On with the light grey
Trying not to be too heavy handed on the trigger-finger (unlike standard practice) to give a bit of tonal variation
I think it's ok(ish).  A little rough round the edges, but the darker grey and some washes will help fix that
More soon(ish)
/P
  • Like 9
Thanks to the great overlord @Enzo the Magnificent,we have an extension, so I don't need to rush quite so much
Slightly darker grey sprayed on the other bits, again lightly to keep tonal variation
And gold (paint) on the stand
Next, washes and drybrushing
More soon(ish)
/P
  • Like 9
Good looking gray coat. If you feel up to it, you can brush paint individual panels (handy with the engraving separating them) with slightly lighter/darker grays. It worked good on mine,
As for the base, I found the model to be a bit top-heavy and secured the kit base to a generic, decorative wood base bought from a hobby, craft store to be safe.
Thanks everyone
More progress
Decal;s have been applied and some detail painting
You could spend a very long time painting individual panels
Nearly there now.
Some more work on the panel lines, and a quick wash should see it done and dusted
More soon(ish)
/P
