Mike Posted July 4, 2023 Posted July 4, 2023 A6M2-N Rufe Landing Flaps (648851 for Eduard) 1:48 Eduard Brassin We’ve just finished our review of the brand-new Mitsubishi A6M Zero derived Floatplane, the Suisen 2, more commonly known as the Rufe, which you can see here, and it’s a beautiful kit that’s every bit as well-detailed as its cousin, also from Eduard. If you’re inclined to cram as much detail into your models as you can, then Eduard also have you covered, with a raft of individual upgrade sets that allows the modeller to pick and choose which areas they’re interested in improving, or go mad and splurge on the lot, as your budget and inclination dictates. You’ll find the first batch of sets here, wing gun bays here, and now the landing flaps are in our sights. Inside the shallow Brassin card box are six 3D printed parts, two of which are in a crystal clear plastic clamshell box to protect them from damage, as they are quite delicate. A fret of Photo-Etch (PE) is also included in its own card backed ziploc bag, with the two flap sections also separately bagged. The combination of PE and printed resin has conspired to simplify the installation of the set, requiring just the flap area in the lower wing to be removed to provide space for the new parts. The delicate boxed parts are the spine and ribs for each bay, and are joined together, then have more smaller PE parts layered over them to create the bays that slide into the trailing edge of the wing and are joined by a small resin divider between the flaps and ailerons. The flaps themselves have been printed as a single part, which fits into the flap bay on two hinges near the centre of the bay, painting the bays and flap interior surfaces in Aotake, that mysterious metallic blue/green primer. There is also a stencil decal shown on the final step of the instructions, which can be found on the stencil decal sheet provided with every Eduard Rufe kit boxing except for the Overtrees. Highly recommended. Review sample courtesy of
