What's better than a Sabre?   A Sea Sabre of course!  :D    Except that the Sea Sabre was known as the Fury.
Esci issued this kit in 1979.  It was one of their earliest 1/48 kits.  It was re-released by Italeri forty-two years later.
As you can see, it's a nice simple kit befitting its late-70s origins.
Lovely!  :thumbsup:   But there is a major problem with this kit.   It was adapted from the Esci F-86 kit and as such you cannot actually build an FJ-3 from this kit.  You cannot even build an FJ-2!  The tail fin is pure F-86.  On the FJ-2/3 it was moved forward.  The panel for the cannons is incorrect as the cannon ports need to be further forwards and angled downwards.
The intake is suitabe for an FJ-2, which had the same General Electric J47 engine as the F-86.  The FJ-3 had a Wright J65 engine which required a much deeper nose and intake, similar to that of the F-86H.  This is not included in the kit, so it will need some surgery.
Wikipedia has a nice history of the type.
https://en.wikipedia.org/wiki/North_American_FJ-2/-3_Fury
@Jon Kunac-Tabinor built this kit seven years ago which turned out to be a tour de force.  As imitation is the sincerest form of flattery, I will be using his build as reference for mine.  As mine is the Italeri repop I'm hoping that I won't have the same problems with the plastic as Jon had.
https://www.britmodeller.com/forums/index.php?/topic/234981173-north-american-fj-3-fury-148th-esci-with-added-elbow-grease/
I will be building it in a different colour scheme: that of a drone chaser.
Oh...   and I might fold the wings...   :mental:
  • Like 17
A great project Enzo, really looking forward to seeing what you can do with this kit.
Its quite a bit of work to get something that resembles an FJ-3 but from the sound of things an FJ-2 is a bit easier.
This is the icing on the cake for me, I really like the schemes worn by both the drones and their controllers.
  • 3 weeks later...
What's not to like about a Fury, Enzo!!!!! A great choice :)
Martin
  • 1 month later...
The first step was to deal with the nose.  I sawed off the lower parts of both fuselage halves and assembled them around the nose gear well.  I hacked the gun port panels around so that the ports were in the correct position.  All the gaps were filled with a mix of bicarbonate of soda and superglue.
I have also decided to use the Hypersonic resin intake intended for the Kinetic FJ-3.   It has the correct square appeareance but I believe it is still too shallow.   I will need to cut it in half and add plastic to deepen the intake.  I am currently intending to model intake trunking from Milliput but if that turns to worms, I will simply model the aircraft with an intake blank.
The Aires cockpit painted up.  I have used a Yahu instrument panel.
Ready for fitment.
Like so.  Plenty of room for ballast behind the cockpit.   I have also started to build up the intake trunking from Milliput, smoothed down with a wet finger.
On to the wings.   The three parts suddenly become eleven!  :yikes:
  • Like 11
I built up the wingfold hinges from laminated plastic card.
...and fitted the wing to the fuselage.
I built up the base of the fin from plasticard and fitted it.  At this point I realised that the gunport panels were set too tapered, so I removed them.  The Hypersonic intake was split into upper and lower halves and fitted.
  • 3 weeks later...
After what seems like weeks of an interminable round of fill-sand-prime-repeat, I think it's time to move on.
I modified the tailplanes with strips of plastic card.  It worked out rather well.
This is how the finished model should look.
Finally got some paint on.  The yellow is from a rattle can: Fiat Broom Yellow to be precise.   The International Orange is Lifecolor UA-829 Railfreight Red.
The wing and fin leading edges were sprayed with aluminium from a rattle can.  The grey was then sprayed with Lifecolor UA-030 FS36081.  The anti-glare panel is Tamiya XF-69.
6 minutes ago, JOCKNEY said:
There's a lot of work going into this one !
Indeed.   At one point, while I was in the middle of the fill-sand-prime-repeat cycle, I asked myself "Why am I putting myself through this torture?!?!? "
But now I know.  :)
Most of the greeblies painted up and ready for fitment.  The notable exceptions are the flaps which are still in the paint shop.
Up on its gear.
Very sharp!
Post-war yellow wings - presumably a distinctive colour scheme so you could tell it apart from the drone.
Regards,
Adrian
Finished!  :yahoo:
I would say this is a representation of an FJ-3 rather than an accurate scale model.  All the changes were made by eye rather than referring to plans.  However, I'm quite happy with the result as I feel it captures the essence of the Fury.  I must admit that I did not enjoy all the filling, sanding and priming involved in the major surgery. At one point I was seiously considering chucking it.  I'm glad I persevered.  Let's say I enjoy having built it. :lol:
Many :thanks:  to @JOCKNEY for hosting this GB.
So now I suppose I had better buckle to and get my F-104C completed.
  • Like 9
