Greek Mirage F1
I've just completed a trio of Mirage F1s.
One would have thought that got them out of my system, but apparently not.  :)  Here I am diving straight back down that rabbit hole again.
This is a Greek Mirage F1CG using the Special Hobby kit.
As you can see, it's been in The Stash for some time.
This will be finished in the wonderful Aegean Ghost scheme.
  • Like 18
Oo, now you're talking :). I remember seeing many of these while pretending to be having a spot of lunch under the Tanagra approach with my mates :).
Were your mates Darmok and Jalad?
  • Haha 2
Let's all hope to avoid Shaka, when the model shelf fell 😁
Getting the underside color right on the Aegean scheme has always been my hesitancy in attempting it. I'm convinced the correct color is an aluminum metallic with a monotone grayish appearance, but that description alone hints at the subtle complexities involved.
The ghost scheme I will be doing is a wraparound scheme so I neatly avoid that problem.  :)
  • 1 month later...
Assembly proceeds as usual.  I have built so many of these kits that I can almost do it with my eyes closed.  :fool:
Probable overkill on the ballast again.
I always build this kit using the nose half without the IFR probe irregardless of whether the subject actually carried one.  I just know it's going to get knocked off at some point and I'll have to do battle with the dreaded carpet monster.  Best to avoid that experience altogether.  (Enzo listens...   )
Primed using my usual technique of numerous this coats of clear lacquer from a rattle can followed by a coat of grey plastic car primer, also from a rattle can, to even everything up.
I then sprayed a coat of Lifecolor UA-835 Grigio Beige.
Maksing of the disruptive pattern was carried out using my usual technique of Blutak worms, masking tape squares and Copydex.
The other two colours where Lifecolor UA-555 Aegean Ghost Grey and UA-554 Aegean Ghost Blue Grey.   These colours give the very low contrast of the scheme, which I like.  The nose was masked and sprayed UA-565 Spartan Grey.
  • 1 month later...
