Newby requiring some help please regards wartime traffic
I'm usually a everything RAF type of builder but I'm researching an airfield that was served with a platform for delivering bombs direct to the site.
I intend to build a 'layout' approx 4ft long with numerous wagons and some RAF vehicle by way of an illustration of the set-up . . . shunt to unload basically
Questions:
In 1944 on the LNER line so what colour would the rolling stock be ?
That is open 5/7 planks wagons, some box wagons and possibly some war-flats for carrying the large 4000 Ibs bombs or
Would they be usual flat wagons with a low dropside ??
Was there a standard height for the bed of the wagons ? I have to build a platform  . . .
I'm thinking that they probably used an '0-6' or a J27  . .  so I am told ??
 I presume they will be austerity Black with just the letters 'N E' on all the railway wagons & train ??
Or - Could it be mixed wagons, using what was available ?
I have a series of books out lining the history of LNER but no wartime pics are shown
Any help will be gratefully received, hopefully to keep the interest going  . ..
regards
Ian
Prior to the war goods trains would include a mix of wagons from various owners LMS, LNER, GWR, SR & Private Owners regardless of who owned the line the train was on. During the war more mixing occured as general goods wagons, such as opens, were 'pooled' and the requirement for 'foreign' wagons to head for home territory when empty was replaced by a need to use the first available wagon for the next available load. So don't get fixated on all wagons being LNER wagons.
Wagon liveries is a complex subject however if you bear in mind that the majority of wagons during the war were not fitted with automatic brakes then the livery become much simplified in that 3 of the 4 railway companies used grey with large white letters signifying ownership NE (LNER), GW(GWR) & LMS. SR wagons were brown and Private Owner wagons were more elaborate. Do a Bing image search to see the variations. Don't worry about depicting unfitted wagons it was a lot more common than you'd believe.
Flat's - forget them a standard open could carry 5 or 6 of the 4000lb bombs you mention and flats were more useful carrying more specialised items.
Box wagon, 1 or maybe two for the fuzes. Again in grey livery.
Consider including a crane to assist in the unloading.
Floor height of wagons would be around 3 ft  to 3 ft 3 in above rail level, platform height about 3 ft.
Difficult to advise on the possible loco type without knowing the whereabout of the airfield. Engines tended not to wander far from their origin, thinking GER (East Anglia), GNR (Lincs), GCR (north Lincs) or NER (east Yorks) types all possibilities along with LNER standards. A 0-6-0 (J##) would be more suitable for shunting than a large 2-8-0 (O##). Livery plain black, lettered most likely NE.
Have a search on the net for "Soham rail disaster" some of the reports contain quite deatiled info on munition trains
I think that very useful information.
I am in N.E. Lincolnshire (LNER territory)  so yes N E wagons with a mix thrown in. I also have a Jinty 3F for the use of.
I have three box wagons so will be giving them a grey coat, along with the open 12 ton wagons
As for a crane, I intend to convert an Airfix  AEC refueller to a crane vehicle , I also have a Brake wagon for the back end, Would that be kept as a brown wooden body ??
The transcript I have said that the siding was to hold up to 50 wagons but I'm going with about 15, purely for an illustrative purposes
What was the separation between track on a two track main line please ?? . ..
Thanks for the help
rgds
Ian
Thanks for the help
rgds
Ian
Unfortunately the Jinty was an LMS engine which would not normally be seen this far into LNER territory. That said  it's your layout and Rule 1 always applies - "It's my Railway & I'll run what I want". Some creditbility can be retained as at the beginning of hostilities the war department declared these would be the standard shunting engine and were loaned a few at the begining of hostilities. See here for brief details. There was a change in what would become the standard shunting loco but yours could be a Jinty that either escaped being sent to France or was found to be useful and its whereabouts 'lost' in the paperwork.
I'll see if I can turn up some livery details.
Regarding the brake van, again more likely grey than brown but brown would not be implausable. (Brown signifies the van would be fitted with vaccum brakes, in this case they would be none operational and the hand brake only used replicating how a grey unfitted brake van would be used).
For clearances this diagram gives all you need.   clearances  However if you want to include points then the track centre distances will depend on the manufacturer of the track (Peco, Hornby etc)
Given the geographical setting, the sort of locomotive that immediately leaps to my mind would be one of the various ancient ex-Great Eastern 0-6-0Ts eg classes J66/67/68/69 or maybe even a J15 0-6-0 tender engine (also GER, also antiquated).  But, as the man said, "It's my railway and I run what I want."
Fine for the GER who's territory was London, Peterborough, Boston & East Anglia however the OP referenced Lincolnshire which was either GNR (Peterborough, Doncaster, Lincoln, Grimsby & Boston) where eithe a
J39 tender loco or J50 tank loco would be more common, or GCR (Doncaster, Lincoln, Grimsby & Scunthorpe) where J11 tender loco would prevail.  Of course the WD Austerity 0-6-0 saddle tank loco (later LNER J94) began to appear in 1943 this is available redy to run or for a static layout the old Kitmaster/airfix plastic kits appear fom time to time on a certain website.
If sticking with the Jinty then 8 were used by the WD (No.s 11-18) from March 1940. All were sent to France with a further 6 (WD numbers 19-24) were prepared but not used.
I've not turned up any specific livery details but it appears loco's requisitioned from the mainline comanies were painted a 'khaki green' which can be interpreted many ways. @Mike Starmer may be able to assist.
As @Mancunian airman indicates in his opening post there are very few pictures of "bomb trains". The key book for LNER Wartime traffic is "BY RAIL TO VICTORY THE STORY OF THE L. N. E. R IN WARTIME" by Norman Crump. Nearly all pictures just shown bombs being carried in "normal" open wagons as there was very little wagon building during the war years. Due to pooling wagons from all the companies could be seen anywhere. Colliery wagon were still used for the transport of coal. so were more rarely seen on other traffic.
In his  opening post  @Mancunian airman says he has researched a  particular airfield, if he could name that airfield it would help with suggesting locomotives, as many lines serving airfields had route availability limitations. In reality very few airfields has direct delivery of bombs via trains as the RAF had an efficient system of "Air Ammunition Parks" which were served by rail with forward onward distribution by road. There is a reasonable summary on Wikipedia
https://en.wikipedia.org/wiki/RAF_munitions_storage_during_World_War_II , there are other, more scholarly accounts available. All of bomber command was served from Barnham in Suffolk. Local sidings were more commonly used for other provisions, including food.
I thank you Paul for the info.
I am trying to get a copy of the book you quoted.
The RAF station was at North Killingholme, bombs delivered to the purpose built sidings provided bombs for two other RAF stations; It opened  late 1944.
cheers
Ian
PS Book now order via IBAY  . .
Edited by Mancunian airman
Additional PS info
Note to self: read the exam question carefully first.
Thanks for the Info that you are basing this on North Killingholme. My own area of interest is the WW2 era in East Anglia so my resources regarding Lincolnshire are few:
The very rare book "Wings on Rails", which is a comprehensive gazetteer of RAF logistics does not mention North Killingholme, but your own research shows that there were sidings installed at this location. However lack of an entry does mean that it is fairly certain that there were no locomotives based at the site.
As North Killingholme is very close to Immingham, this has three implications:
1) By May 1944 this was the major port for the import of bombs into the UK as it had good rail links to most of the sites where bombs were stored.
2) The Airfield was next to an ex  Great Central line, as it still is,
3) Some of the loco's would have been based at Immingham shed, the useful website https://www.brdatabase.info/sites.php?page=depots&action=list gives a snapshot allocation for Immingham in May 1944 as being of loco's type: O4's (2-8-0) of various sub types and J11 (0-6-0) .This not a comprehensive list but based on observations around the time. Additional types of loco would have served Immingham from depots such as March, but these wold have been large 2-8-0 types.
Both the J11 and O2 have been available as 1:76 (OO) models but both are rather dear for use on a static layout. As loco's would only have been present for 20 minutes of so, and uploading would not have taken place at the time, you could dispense with them.
In addition signals would be an important part of the infrastructure, and possibly a signal box
The following websites might help you..
http://www.lymmobservatory.net/railways/railways.htm
http://www.gcrsociety.co.uk/
https://www.s-r-s.org.uk/home.php
For anyone interested in the more general topic of railways in conflict the MRSG is worth joining:
https://www.mrsg.org.uk/
