A-20G Havoc MPM 1/72 - 453rd BG Museum Build
On 6/4/2023 at 10:45 AM, CedB said:
I wish I'd done this as it would have solved my current masking problems.
Anything can be overcome!  As for the invasion stripes, the more uneven and random, the better.  These were applied in haste.
Thanks Alex. I can do uneven!
The primer, as usual, showed up some faults that needed filling / shaving / sanding:
Then on with the Neutral Grey:
Dead, again :D
That's not a horrid seam, it's the bomb bay. Honest. I re-scribed it a bit.
Pondering the wavy demarcation line masking I had a happy trip around the ceiling to see where else I'd done this.
Hudson. Just the Hudson.
What did I do there?
Well, that was over-complicated.
It did remind me though that I have Tape for Curves and the black Panzer Putty.
I will ponder.
  • Like 9
If you’re not too fussy, my preferred way is to take some wide masking tape (or scrap Oramask film) and freehand a wavy line along it with a sharp scalpel blade. Stick the wavy bit on the model and apply more tape to mask as required.
  • Thanks 2
Very intense masking job there, Ced  - what with the invasion stripes and all? KUDOs :worthy:
And BTW, very smart "masking" technique for the struts! :clap:
Ciao
Thanks Heather, good tip.
Thanks Giorgio.
I should have taken a photo of the masking but couldn't wait to do this:
I think I'll hand paint the small area of green so next job is to de-mask the black stripes and spray those.
And the props.
Maybe later.
  • Like 16
Wait, what the.....
Where did this pop up from?
Nearly finished too!
Oh well, I'll join Bill at the bar, there's time for another pint or two yet.
Lovely job so far Ced, but...iron weights instead of lead....I hope that glue doesn't react.
Ian
Looking great! May I ask at what psi do you spray and with what you thin vallejo at, and with what airbrush? The finish looks very good!
Edited by frapes75
Blimey - this is some rapid progress, Ced. I pop in after a couple of days away and it’s nearly finished!
The OD looks smoooooooooth…
Nice fix on the nose, too - you’re on a roll.
Tom
As usual by the time I see this you are 3-4 steps down the road.  It is looking good so far.
I was hoping to catch you before you sprayed the grey primer but oh well.  Was going to say I see a lot of guys painting the window frames the interior color first before adding the primer.
Nevermind, carry on.
Did you really get that finish with Vallejo Ced? Very impressed with that! Looking really good!
As to the correct width tape for invasion stripes, very surprised you don't have an Infini tape cutting mat thing - cut tape to any width your heart desires! :)
Cracking work again!
Keith
Catching up after a long weekend away, all’s looking very good, Ced :)
James
19 hours ago, Brandy said:
Wait, what the.....
Ian
Hiding in the long grass! :D
Thanks Ian. I hope the weight description is right that they're non-corrosive but hopefully the latex will keep the air out.
Of course you may. 25psi through a 0.4mm in my H&S Ultra.
Vallejo Model AIR doesn't need thinning - it's designed to be airbrushed straight from the bottle.
I've been using it for some time and, after an email with their MD, I think they've sorted the early colour match problems.
18 hours ago, giemme said:
Very smooth paint job there, Ced! :clap:
Almost done now :D
Ciao
Thanks Giorgio.
Tom
Thanks Tom.
Thanks Phil. I did think of that, then I forgot.
Rats.
Keith
Cheers Keith. Of course I have the cutting mat thingy.
But I also have a reel of tape. Save the planet!
James
Thanks James.
While waiting for the paint to dry I thought I'd tackle the props:
Give us a break guys.
Couldn't get a saw in so had to clip them off close to the tree.
That took some tidying up.
Masking off. Lots of it:
That white's too white.
And, although I sealed the tape with Klear I obviously hadn't burnished it into the panel lines:
And black overspray. In my defence I'd switched to the 0.2mm in my H&S Evolution and it blocked. Unusual with Model air. Probably a dirty brush (now cleaned).
The tape also lifted some Neutral Grey (dead one again):
The wavy line sort of worked:
You'll notice that the dampers are gone. Again. I took them off but the nose wheel one has gone somewhere.
More rats.
I don't mind the bright white on the fin but I've toned down the stripes with some Model Air 'Aged White':
Better.
I've also applied the Medium Green bits.
Can you see them on the scheme?
Me neither, even after I'd sourced a copy on the 'net and printed it on A4.
They're on now and touch ups have been down:
Drying now before the pre-transfer gloss coat.
  • Like 17
Stunning paintwork on the A-20 finish line in sight now!
   Stay safe            Roger
Nice modelling. The Boston never seems to get its fair share of attention from modellers, so thanks for redressing the balance a bit!
Regards,
Adrian
Looking good!
BTW the "dampers" are actually torque links. They do 2 things:
Stop the lower half of the gear falling too far when the weight is off the wheels, and stop the lower half rotating.
I had one fail on landing one time and the right main wheel rotated almost (but not quite) 180 degrees.
It tests the strength of your legs trying to keep the aircraft straight!
https://1drv.ms/i/s!AuF2JD2u35lBg4IRoRLGn39Z566PTw
Ian
   Stay safe            Roger
Thanks Roger, very kind.
Regards,
Adrian
Thanks Adrian. Havoc / Boston… now I want a Boston in MY collection!
44 minutes ago, Brandy said:
Lookknvbgood!
Ian
Thanks Ian.
Flippin' 'eck, I bet that was scary!
Torque links, got it.
Props and wheels ready:
I'm trying to wait for the gloss coat for a bit.
Patience is not my best virtue as you know.
The rest of this post will only amuse fellow 'absent minded old blokes'.
Still here?
Giorgio suggested I stick the torque links on with UV glue. I have some BlueFixx… somewhere.
Here are the refills:
Where's the little light?
Not in these places:
Hmmm.
Not here either:
…but at least it reminded me what tools I have. Must tidy up.
When did I use it last.
Search BM.
Bought in 2016 and used on many models before I found Canopy Glue.
Used on the Rapide in 2017 and the windows popped so I lost confidence in it.
Used on the Nimrod in 2019 for landing light gaps.
Where did I put it?
Look in my Flickr 'purchases' album:
Oh, it's in a BOX! I was just looking for the little light.
Idiot.
Does it still work?
Yep.
OK, don't lose it again you old…
  • Haha 6
4 hours ago, CedB said:
Does it still work?
Yep.
That must be what they call light relief...
Seriously though Ced, you've gotten that aircraft looking very spiffy already and as Adrian said, nice to see this aircraft getting some affection by your hand.
Very true! I dare say it's one of your smoothest paint jobs ever! :clap:
Ciao
PS: boy, you do have some tools! :frantic:
:D
18 hours ago, Brandy said:
At least that kept you out of mischief for a while!
Ian
A while. I really should empty all the drawers and redid myself what I have.
:D Thanks Tony
Ciao
:D
Thanks Giorgio. Tools help compensate for my lack of skills :)
1 hour ago, Spookytooth said:
Well Ced, you are cracking on with this build mate.
With all the trials and tribulations you `re beating her.
Simon.
Thanks Simon.
What a morning.
I'm a nervous wreck.
Why?
Transfers (or decals if you prefer).
Set up the station with warm water in the oil diffuser.
Cut the port fuselage transfers from the sheet.
Soak them in water…
WAIT! These are really quick to detach.
OK, in the water for a count of five and then on to the decal tray.
First two applied.
'5H' next.
On the model, crikey these are delicate transfers.
WAIT! What's this:
Can you see?
Obviously in real life the D-day stripes were applied after the ident markings.
In 'modelling world' the stripes were done first.
Can you see on the scheme that the stripes don't go, er, over the markings? Obviously.
Future modellers beware: the stripes don't go over where the transfers will, later, be applied.
I panicked.
I managed with some difficulty to get the '5H' back on the backing paper.
Sloshed some OD over the area.
Applied transfers to the other parts of the model.
Back to the fuselage sides.
I think I got away with it:
Not my best work:
I don't mind the rough edges on the OD - I can pretend it's the hastily applied stripes.
The '5' is right up against the wing root. Perhaps it should be on it.
The transfers are a bit opaque - look at the stars and bars.
They're very fragile; look at the 'H'; you can see where it broke up even though it was floated on.
Also various 'prod marks' as I tried to position the thing.
Nightmare.
Off for a lie down.
  • Like 12
  • Sad 1
Decals are the spawn of the devil, Ced.... you should have painted those markings on.... :winkgrin:  :D
Ciao
  • Haha 4
  • Sad 2
