I measured the full range of Vallejo Air paints using a spectrophotometer.
I did this work because Vallejo is known for giving sometimes random labels to their paints - the label on their bottles are not always a good information about the color they are supposed to be, and sometimes they are misleading - there are better matches in their own paint range.
With this data, it is possible to give a definite answer to the questions:
  • "Which paint from the Vallejo Air range is the closest match to a given color."
  • "Is Vallejo Air XYZ a good match for ABC"
  • What other paint vendor color is equivalent for Vallejo XYZ (or the other way around)
I will prepare some answers to the first question on separate threads focusing on given color range topics, like ANA, FS, RAF, or Luftwaffe. If you need other answers - feel free to ask.
This post is just a snapshot of the raw data from this measurement task which I hope could be useful to someone. It is also quite technical.
How to interpret the data:
  • Name, for example 71.082 | Fluorescent Red | Rojo Fluorescente | FS38903 | RAL2005 | GU 2.5 | Fluorescent | Opacity 32.63%
    • 71.082
      • it is a Vallejo AIR vendor code
    • Fluorescent Red | Rojo Fluorescente | FS38903 | RAL2005
      • those are all names that appear on bottle, they are just separated with "|"
    • GU 2.5
      • Gloss Unit measurement of color. It is a measurement from a Glossmeter device and represents how glossy the paint is. https://en.wikipedia.org/wiki/Glossmeter
      • It is a very important factor for human color perception. Very glossy colors appear darker than they really are, and the difference in gloss is quite often more visible than the color difference.
      • The number scale is not defined by any standard, but generally, you can think of them as <5 is very matt, <10 is matt, 10-25 is satin, 25-40 is semi-gloss, 40-80 is gloss, >80 is very glossy, >90 is mirror-like.
      • The above example is 2.5 - which means the paint is very matt
    • Fluorescent (or Metallic)
      • optional note, meaning the paint is Fluorescent or Metallic. In the above example, the paint is Fluorescent.
    • Opacity %
      • optional note with a % number, it means the paint is only that many percent opaque at a 254-micron thickness (very thick). In the above example, the paint is only 1/3 opaque, which makes it very transparent. Don't expect good coverage with transparent paints.
  • R,G,B
    • RGB of the paint color
  • Color simulation
    • A color swatch with the above RGB
  • L*a*b*
    • Color coordinates in L*a*b* color space. https://en.wikipedia.org/wiki/CIELAB_color_space
    • This color representation is much more precise than sRGB and takes into account human color sensitivity.
    • The three coordinates of CIELAB represent the lightness of the color (L* = 0 yields black, and L* = 100 indicates diffuse white; specular white may be higher), its position between red and green (a*, where negative values indicate green and positive values indicate red) and its position between yellow and blue (b*, where negative values indicate blue and positive values indicate yellow).
  • LRV
  • H V C (Munsell)
  • Light source and Test mode
    • Those are spectrophotometer settings, If you are curious about what they mean, read the technical details below for more info.
Even more technical details:
Spoiler
Paints were mixed on a vortex mixer for at least 3 minutes each, then prepared on drawdown cards using 10 mil wet film
Samples were left to dry and fully harden for at least 7 days
All samples were measured using the following devices:
  • Integrating sphere spectrophotometer using the following settings:
    • Measurement of reflected light wavelengths from 400 to 700nm (covering the visible spectrum from ultraviolet to infrared)
    • UV filter with 400nm cutoff to eliminate UV light fluorescence
    • Light source and observer: D65/10 deg
      • D65 is a daylight
      • 10 deg represents modern human color perception model used to convert the color
    • Specular Component Included
      • It means the paint color is measured at all angles simultaneously, which eliminates the effect of paint finish (gloss/matte/satin) from color readouts - that allows measurement of true paint color.
  • Gloss meter
    • Measures paint finish independently from color
    • Measurement is done at a 60deg angle
Now the raw data:
Update 2024-11-26: Added 2 new paints in the range
Edited by Casey
Added 2 more paints that are new to the range.
  • Like 9
  • Thanks 17
I already did the full range of Humbrol and Revell and will do Tamiya next. I do not plan to do any other lines of Vallejo for now, I have too many paints already, and I sense a pattern of all their paints being randomly labeled as anything.
I have a full range of Army Painter measured too, but I'll do a different compilation here - I'll try to add some modeler's specific labels to each of the paint because there are some pretty good matches - for example WP1118 - Uniform Grey is an almost perfect match for RAF Dark Sea Grey.
Question. Is there an actual list out there of Federal Standard measurements? Or R.A.L., BS381, ANA…? As a modeler, I strive to match those more than anything. And, I think those like minded are painting aircraft and armor — not so much concerned with matching Game Air for Warhammer with anything…
You’re going God’s work. I know I’m looking a gift horse in the mouth but Mr. Color. 😇
Edited by CFster
So, the values given for those colors are determined using the same method you use? LRV, HVC, RGB…you know that your readings on paint you’ve tested in house are consistent with those published numbers? Or, do you compare with physical paint chips in house.
Edited by CFster
As for RGB - definitely not, I use D65, they use the D50 setting. They are more of an outlier than the standard for that conversion, but they warn about it.
Also, physical decks sometimes vary a bit between themselves (and much more between versions/issue years), but the results should be comparable.
L*a*b* should be consistent. I just checked my spectrophotometer readouts on the physical AMS deck I have (all values in L*a*b*)
15051 mine: 34.82, -1.73, -23.02, theirs: 34.41, -1.18, -22.92 - DE 0.5612
26307 mine: 61.22, -1.87, 4.31, theirs: 61.78, -1.91, 4.49 - DE 0.5066
34540 mine: 74.10, -26.58, 29.63, theirs: 74.81, -26.13, 29.59 - DE 0.477
So yes, they are very close, and they seem to use the same spectrophotometer geometry as I do (D/8 SCI)
I always compare using physical paint chips.
Edited by Casey
  • 4 weeks later...
I must commend you for your effort, however it has been a pointless and futile exercise. Paint as a colour system is very poor, too many variable in them. I can bet you it you get the same colour from a new batch of paint, their values will differ. Paint has too many aspects which cannot be controlled; chemical ratio's, pigment, carrier fluids, temperature, dry age of the paint, etc, etc, etc. This is why we have so many problems comparing model paint to the FS595 range from the USA. Paint is never the same. So the exercise is not completely useless as it does give us something to work from when using Vallejo AIR. Well done in the effort!
I think you’ve just described exactly why she did it.
I did this work to get an representative sample of how this particular vendor (Vallejo) interprets certain target colors. Target colors are known and they do not change.
Some vendors do it really good, like Revell - they keep their paints within 2.0 of the RAL targets if they call them that name:
Paint vendor have their targets database, and if they cant keep their paints within certain error range from those targets then they should fix their process. I am trying to reverse-engineer what targets they use for each paint without getting too fixed on their labels.
Edited by Casey
  • 4 months later...
@Casey this is interesting work. I have been pouring over Vallejo colours on websites for hours today.
A couple things would be helpful
1. organized by appearance rather than model number... I have spent a few hours trying to compare similar colours recently to see if:
(a) colour A and colour B are close enough that I don't need to buy B
(b) maybe I could buy A and tweak it to become close enough to B
(c) maybe I can buy RAF colours I will use more often and just tweak them to be simialr to Armee de L'air France colours
2. searchable in the webpage vs. an image
On my computer I have it searchable vs any color with given tolerances.
But there is another thing you can use, you can directly use LAB values from my table in e-paint website I've mentioned:
https://www.e-paint.co.uk/convert-lab.asp
Do not use my RGB values in their searches, as I mentioned - they use D50 light source, I use D65, they are not comparable.
5 hours ago, marvinneko said:
i found this online app that explains how to mix colours to achieve any known paint colour, or another interface allows you to choose a target (using hex, rgb) and mix cmyk to achieve it. it includes model paint brands.
https://trycolors.com
https://trycolors.com/paints/vallejo-model-air
This mixer works in RGB color space, which is sadly not representative of how physical paints work, real pigments behave differently.
Good starting point for mathematical models for correctly mixing pigments is this one: https://en.wikipedia.org/wiki/Kubelka–Munk_theory.
This models requires physical measurements of pigments - that means you need multiple physical samples preparation (drawdowns), equipment (at minimum an spectrophotometer) and a lot of math works.
I did that exercise starting with my own software and creating databases for couple of paint ranges, for example selected Tamiya paints, Liquitex Basics Acrylics, Golden Fluid acrylics and few of Vallejo paints, and this is what I now base my mixes calculations that you might see me spamming sharing on this forum.
As an example: Try mixing Tamiya XF-1 Flat Black and XF-3 Flat Yellow in proportion 1:10 (1 part black, 10 part yellow)
In reality, the XF1 I measured had color of #3D3D3E and XF3 was #FFBE16 (in D65 light using sRGB conversion). The correct result is: #8C8142. The mixer above gives #EDB219. RGB math ignores unique property of black + yellow pigments which give olive green colors, and the fact that carbon black is much more powerful than any existing yellow.
Edited by Casey
  • Thanks 2
  • 5 months later...
Stumbled across this now I’ve discovered I can brush Valair with a bit of care though my first branching out beyond the silver has been a minor disaster, old stock of 053 when it was labelled Dark Sea Green is quite a bit different, much darker then your measurements something akin to fs26044, of course Vallejo labelled is fs36118/ral7011, teach me for not looking at the bottle properly. Thanks again for your superb service
Edited by PhantomBigStu
  • 7 months later...
Thank you. I was just organizing my Vallejo paints for the first time (instead of my habit of fishing through a pile of random paint bottles). I've always had the feeling the numbers were meaningless, but when I put them in order by number I became more convinced. I still thought perhaps there was some method to the madness, but apparently not.
Just to let you all know, there are 2 more new paints in the Vallejo AIR range, 71.420 N17. Earth Yellow and 71.421 Pinkish White (which in reality is not pink at all).
The main table is updated too
Edited by Casey
  • Thanks 2
Just seen this following on from your comments on the spraying Vallejo thread.
Given the RGB readings I wonder if they can be recreated on something like Photoshop using the histogram.
Thinking more of using the colour picker to then find the nearest match from your list
Is your chart available to download in a suitable format please?
Edited by Tijuana Taxi
Please do not use RGB for any paint color matching :) - this will not work as you hope - but if you are interested more about color matching and the rabbit hole of paint colors, pm me. I'll try to give you as much knowledge as you want.
I'll also try to get the raw data from my newest spectrophotometer somehow. I wonder how since this site do not allow attachments :)
Update:
Let me try this way, it is a CSV data. In spoiler because it is kind of large. The data might be slightly different than the table above, because I got a new device (slightly more accurate) and I've re-measured all the samples. You have spectral data there too (which is missing in original screens above) and separate data for SCI and SCE spectrophotometer modes (that's why each sample appears twice).
RAW NUMERICAL DATA FROM SPECTROPHOTOMETER IN CSV FORMAT IN A SPOILER SECTION BELOW
Spoiler
Name,R,G,B,L*,a*,b*,H(Munsell),V(Munsell),C(Munsell),LRV,Light source/angle,Test mode,UV settings,400nm,410nm,420nm,430nm,440nm,450nm,460nm,470nm,480nm,490nm,500nm,510nm,520nm,530nm,540nm,550nm,560nm,570nm,580nm,590nm,600nm,610nm,620nm,630nm,640nm,650nm,660nm,670nm,680nm,690nm,700nm
71.001 | White | Blanco | FS37925 | RAL9016 | RLM21 | GU 3.5,246,245,239,96.75,-0.79,3.17,6.65RP,9.68,3.2,91.84,D65/10°,SCI,UV400,43.02,67.57,81.31,86.59,87.88,88.59,89.19,89.78,90.21,90.56,90.93,91.14,91.43,91.68,92.07,92.39,92.18,92.33,92.44,92.54,92.6,92.68,92.77,92.85,92.96,93.12,93.2,93.37,93.37,93.57,93.72
71.001 | White | Blanco | FS37925 | RAL9016 | RLM21 | GU 3.5,243,243,237,95.86,-0.84,2.77,5.87RP,9.59,2.43,89.67,D65/10°,SCE,UV400,42.71,66.86,79.87,84.96,86.37,87.14,87.51,88.11,88.43,88.78,89.25,89.3,89.44,89.53,89.81,90.16,89.86,89.94,90.05,90.2,90.24,90.37,90.56,90.42,90.57,90.59,90.29,90.19,90,90.45,90.58
71.002 | Medium Yellow | Amarillo Medio | GU 3.0 | Opacity 59.78%,255,175,0,78.61,22.92,90.92,10.03YR,8.09,15.09,54.25,D65/10°,SCI,UV400,3.82,3.85,3.9,4.01,4,4.04,4.23,4.78,5.87,6.5,7.34,10.21,17.9,33.38,53.58,68.21,77.17,80.34,81.87,82.73,83.25,83.7,84.23,85.02,85.9,86.66,87.2,87.46,87.27,87.05,87.14
71.002 | Medium Yellow | Amarillo Medio | GU 3.0 | Opacity 59.78%,255,174,0,78.32,22.65,89.19,10.02YR,8.05,14.94,53.76,D65/10°,SCE,UV400,4.28,4.2,4.13,4.23,4.27,4.26,4.47,5.03,6.14,6.78,7.61,10.38,17.91,33.09,52.98,67.46,76.45,79.69,81.16,81.9,82.35,82.68,83.19,83.76,84.52,85.15,85.33,85.42,85.09,85.12,85.19
71.003 | Red RLM 23 | RLM23 Rot | RLM23 | GU 1.6 | Opacity 92.19%,164,53,48,39.21,45.58,28.62,7.15R,3.97,11.94,10.78,D65/10°,SCI,UV400,3.57,3.65,3.68,3.68,3.68,3.67,3.67,3.67,3.71,3.72,3.81,3.9,4.03,4.14,4.25,4.55,5.01,5.87,8.08,13.25,21.73,31.87,41.6,49.57,55.25,59.4,62.89,65.78,68.16,70.09,71.97
71.003 | Red RLM 23 | RLM23 Rot | RLM23 | GU 1.6 | Opacity 92.19%,164,53,49,39.17,45.37,27.8,5.13R,3.96,12.63,10.76,D65/10°,SCE,UV400,3.97,3.89,3.82,3.84,3.84,3.78,3.8,3.76,3.8,3.8,3.87,3.96,4.09,4.13,4.21,4.39,5.09,6,8.16,13.24,21.73,31.57,41.21,49.2,54.79,58.94,62.27,65.02,67.17,69.21,70.99
71.004 | Blue | Azul | GU 1.4,53,53,86,23.99,9.06,-19.91,8.00PB,2.31,4.6,4.1,D65/10°,SCI,UV400,6.24,7.31,7.24,7.65,9.46,10.87,10.28,8.71,6.71,5.12,4.19,3.69,3.52,3.51,3.53,3.61,3.51,3.55,3.62,3.69,3.78,3.91,4.01,4.11,4.17,4.2,4.25,4.18,4.2,4.2,4.3
71.004 | Blue | Azul | GU 1.4,53,54,87,24.07,9.3,-20.4,8.02PB,2.32,4.73,4.12,D65/10°,SCE,UV400,6.96,7.66,7.51,7.91,9.67,11.01,10.43,8.89,6.89,5.29,4.29,3.74,3.56,3.49,3.49,3.48,3.55,3.61,3.64,3.69,3.82,3.93,4.03,4.15,4.21,4.21,4.22,4.1,4.07,4.08,4.16
71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5,65,79,95,33.18,-1.07,-11.05,5.51PB,3.23,2.69,7.62,D65/10°,SCI,UV400,10.51,11.38,11.39,11.33,11.27,11.17,11.04,10.87,10.61,10.08,9.47,8.84,8.23,7.75,7.54,7.4,6.82,6.58,6.51,6.52,6.51,6.39,6.21,6.21,6.28,6.49,6.79,6.95,6.98,6.92,6.73
71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5,67,79,96,33.54,-0.79,-11.04,5.58PB,3.26,2.73,7.79,D65/10°,SCE,UV400,11.15,11.68,11.61,11.56,11.52,11.39,11.23,11.04,10.76,10.26,9.68,9.06,8.41,7.88,7.59,7.39,7.03,6.81,6.71,6.72,6.74,6.61,6.43,6.44,6.53,6.71,6.96,7.02,7.03,6.94,6.79
71.006 | Light Green Chromate | Verde Claro Chromo | GU 1.3,95,101,62,41.58,-9.37,21.28,5.05GY,4.16,3.73,12.23,D65/10°,SCI,UV400,4.3,4.59,4.78,5.13,5.58,5.86,6.05,6.21,6.52,7.07,8.39,10.18,11.96,13.68,15.14,15.96,15.86,15.33,14.14,12.45,10.74,9.55,8.89,8.58,8.29,8.15,8.3,8.69,9.28,9.86,10.31
71.006 | Light Green Chromate | Verde Claro Chromo | GU 1.3,95,101,65,41.76,-8.9,20.03,6.71GY,4.18,4.02,12.35,D65/10°,SCE,UV400,4.85,5.04,5.12,5.49,5.97,6.24,6.41,6.56,6.81,7.37,8.68,10.39,12.07,13.7,15.08,15.82,15.92,15.4,14.24,12.56,10.92,9.75,9.11,8.83,8.56,8.39,8.49,8.78,9.34,9.91,10.38
71.007 | Olive Green | Verde Oliva | GU 1.2,50,58,55,23.87,-4.1,1.07,7.09G,2.36,1.33,4.06,D65/10°,SCI,UV400,3.49,3.67,3.72,3.75,3.79,3.83,3.91,3.98,4.03,4.04,4.19,4.42,4.63,4.65,4.52,4.38,3.99,3.83,3.69,3.59,3.52,3.51,3.51,3.5,3.53,3.55,3.64,3.68,3.76,3.76,3.78
71.007 | Olive Green | Verde Oliva | GU 1.2,51,59,56,24.19,-3.93,0.41,10.09G,2.38,2.8,4.16,D65/10°,SCE,UV400,3.95,3.99,3.93,3.99,4.02,4.02,4.12,4.17,4.2,4.21,4.35,4.59,4.78,4.74,4.54,4.33,4.11,3.96,3.79,3.66,3.62,3.59,3.56,3.61,3.6,3.6,3.66,3.65,3.73,3.72,3.72
71.008 | Pale Blue | Azul Claro | FS35414 | GU 2.0,116,149,148,59.37,-11.23,-3.34,9.44BG,5.8,2.33,27.43,D65/10°,SCI,UV400,24.18,27.95,28.65,28.76,29.18,29.55,29.81,30.32,30.67,30.71,31.04,31.65,32.02,31.78,31.08,29.87,27.45,25.51,23.91,22.58,21.3,20.29,19.77,19.58,19.46,19.59,20.06,20.45,20.5,20.22,19.66
71.008 | Pale Blue | Azul Claro | FS35414 | GU 2.0,117,148,147,59.24,-10.98,-3.25,9.40BG,5.79,2.29,27.29,D65/10°,SCE,UV400,24.43,27.87,28.33,28.57,28.96,29.38,29.6,30.11,30.45,30.52,30.89,31.46,31.81,31.55,30.77,29.52,27.33,25.45,23.86,22.6,21.41,20.36,19.81,19.61,19.51,19.66,20.13,20.43,20.44,20.19,19.6
"71.009 | Eau De Nil ""D.E. Green"" | Verde Huevo Pato | BS216 | GU 1.8",155,167,122,66.73,-11.98,21.99,7.04GY,6.64,4.03,36.27,D65/10°,SCI,UV400,19.28,21.64,21.76,21.27,21.06,21.06,21.15,21.65,22.65,24.68,28.78,34.34,40.02,44.23,45.7,44.61,41.01,37.75,35.13,33.11,31.72,30.97,30.87,31.32,31.97,32.89,34.25,35.79,37.2,38.36,39.63
"71.009 | Eau De Nil ""D.E. Green"" | Verde Huevo Pato | BS216 | GU 1.8",155,166,122,66.51,-11.77,21.62,7.04GY,6.61,4.03,35.98,D65/10°,SCE,UV400,19.66,21.69,21.66,21.26,21.09,21.11,21.15,21.64,22.61,24.61,28.66,34.05,39.64,43.86,45.25,44.11,40.62,37.41,34.77,32.86,31.55,30.84,30.76,31.18,31.88,32.75,34,35.4,36.73,37.9,39.14
71.010 | Interior Green | Verde Interior | FS34098 | GU 3.5,113,99,72,42.77,1.08,17.54,5.09Y,4.28,2.57,13,D65/10°,SCI,UV400,5.91,6.33,6.47,6.7,7.11,7.32,7.46,7.67,7.92,8.07,8.61,9.7,11.3,12.82,13.57,13.66,14,15.7,17.22,16.76,15.23,13.98,13.27,12.91,12.65,12.48,12.63,13.04,13.64,14.18,14.54
71.010 | Interior Green | Verde Interior | FS34098 | GU 3.5,112,98,72,42.55,1.3,16.77,5.07Y,4.25,2.46,12.86,D65/10°,SCE,UV400,6.43,6.58,6.6,6.87,7.25,7.43,7.55,7.72,7.93,8.11,8.63,9.69,11.19,12.61,13.3,13.32,13.83,15.54,17.02,16.58,15.11,13.85,13.14,12.81,12.56,12.38,12.48,12.81,13.39,13.94,14.32
71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2,76,75,62,31.7,-1.99,7.76,5.07GY,3.16,2.4,6.95,D65/10°,SCI,UV400,4.49,4.79,4.83,4.92,5.01,5.09,5.18,5.35,5.5,5.55,5.8,6.23,6.81,7.21,7.34,7.35,7.3,7.9,8.27,7.87,7.17,6.61,6.24,6.09,5.95,5.84,5.95,6.14,6.43,6.7,6.84
71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2,77,75,64,32.1,-1.68,7,7.08GY,3.19,1.04,7.13,D65/10°,SCE,UV400,5.11,5.19,5.14,5.23,5.36,5.4,5.49,5.63,5.76,5.81,6.05,6.49,7.01,7.36,7.4,7.31,7.51,8.12,8.43,8.06,7.39,6.82,6.47,6.32,6.17,6.06,6.1,6.21,6.48,6.72,6.91
71.012 | Dark Green | Verde Oscuro | GU 2.6,96,95,81,40.32,-2.88,8.56,5.07GY,4,2.38,11.45,D65/10°,SCI,UV400,9.82,9.62,9.05,8.46,8.26,8.15,8.34,8.91,9.38,9.37,9.78,10.94,12.34,13.05,12.56,11.65,10.96,11.69,12.44,12.35,11.73,11.11,10.81,10.75,10.77,11.1,11.72,11.98,11.68,11.15,10.39
71.012 | Dark Green | Verde Oscuro | GU 2.6,96,96,82,40.43,-2.56,7.85,7.05GY,4.01,1.16,11.51,D65/10°,SCE,UV400,10.38,9.96,9.32,8.76,8.56,8.44,8.62,9.15,9.57,9.56,9.97,11.06,12.39,13.04,12.49,11.54,11.05,11.78,12.48,12.42,11.84,11.22,10.93,10.89,10.94,11.25,11.78,11.96,11.66,11.15,10.43
71.013 | Yellow Olive | Oliva Amarillo | FS34062 | RAL6016 | GU 3.7,69,71,64,29.86,-2.15,3.7,10.11GY,2.96,2.75,6.18,D65/10°,SCI,UV400,5.23,5.45,5.4,5.28,5.24,5.22,5.29,5.43,5.55,5.55,5.71,6,6.36,6.53,6.52,6.47,6.28,6.55,6.66,6.42,6.07,5.79,5.6,5.5,5.44,5.38,5.48,5.56,5.74,5.82,5.89
71.013 | Yellow Olive | Oliva Amarillo | FS34062 | RAL6016 | GU 3.7,70,72,66,30.33,-1.81,2.99,2.12G,3.01,0.83,6.37,D65/10°,SCE,UV400,5.96,5.91,5.73,5.65,5.6,5.53,5.62,5.74,5.83,5.81,5.97,6.26,6.58,6.68,6.59,6.47,6.51,6.77,6.86,6.63,6.31,6.01,5.8,5.74,5.64,5.57,5.6,5.64,5.76,5.85,5.9
71.014 | Gunship Green | Verde Acorazado | GU 2.7,75,89,74,36.37,-8.37,6.84,10.02GY,3.6,2.18,9.2,D65/10°,SCI,UV400,6.32,6.72,6.75,6.75,6.91,7.02,7.27,7.69,8.04,8.19,8.63,9.39,10.19,10.63,10.77,10.73,10.17,9.76,9.17,8.43,7.7,7.13,6.78,6.66,6.54,6.48,6.63,6.87,7.2,7.44,7.54
71.014 | Gunship Green | Verde Acorazado | GU 2.7,76,89,76,36.58,-7.85,6.09,10.02GY,3.62,2.19,9.31,D65/10°,SCE,UV400,7.11,7.18,7.07,7.09,7.24,7.32,7.56,7.94,8.25,8.4,8.83,9.57,10.29,10.68,10.73,10.61,10.29,9.89,9.29,8.57,7.88,7.32,6.98,6.86,6.74,6.68,6.77,6.94,7.21,7.44,7.57
71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.6,83,77,62,33.11,-0.56,9.64,2.06GY,3.3,1.4,7.59,D65/10°,SCI,UV400,4.54,4.8,4.86,4.96,5.12,5.2,5.32,5.5,5.68,5.75,6.03,6.51,7.14,7.61,7.77,7.76,7.83,8.79,9.56,9.27,8.38,7.64,7.18,6.96,6.75,6.63,6.74,7.01,7.37,7.71,7.94
71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.6,83,78,64,33.51,-0.3,8.81,4.06GY,3.34,2.08,7.78,D65/10°,SCE,UV400,5.15,5.21,5.17,5.3,5.49,5.53,5.64,5.8,5.96,6.04,6.31,6.78,7.36,7.76,7.82,7.75,8.05,9,9.72,9.43,8.6,7.86,7.41,7.21,7.01,6.87,6.93,7.1,7.43,7.76,8.01
71.016 | USAF Olive Drab | USAF Verde Oliva | FS34088 | ANA613 | GU 2.6,101,89,66,38.68,0.82,14.99,5.04Y,3.87,2.22,10.47,D65/10°,SCI,UV400,4.9,5.27,5.41,5.65,5.95,6.18,6.42,6.58,6.73,6.94,7.43,8.19,9.23,10.24,11.04,11.6,11.84,12,12.01,11.91,11.86,11.77,11.64,11.52,11.39,11.28,11.24,11.21,11.18,11.14,11.05
71.016 | USAF Olive Drab | USAF Verde Oliva | FS34088 | ANA613 | GU 2.6,101,90,69,38.92,0.99,13.93,5.24Y,3.89,2.04,10.61,D65/10°,SCE,UV400,5.58,5.74,5.76,6.02,6.33,6.55,6.78,6.92,7.02,7.24,7.73,8.46,9.43,10.36,11.04,11.52,11.96,12.14,12.11,12.05,12.01,11.9,11.78,11.69,11.58,11.47,11.38,11.26,11.24,11.21,11.14
71.017 | Russian Green 4BO | Verde Ruso 4BO | FS34082 | GU 2.6,83,80,63,34.04,-1.94,10.56,2.03GY,3.4,1.66,8.03,D65/10°,SCI,UV400,4.43,4.77,4.87,5.03,5.28,5.44,5.5,5.56,5.73,5.97,6.38,6.93,7.7,8.41,8.93,9.19,8.94,8.75,8.5,8.28,8.16,8.08,8.04,8.08,8.07,8.13,8.28,8.41,8.54,8.6,8.64
71.017 | Russian Green 4BO | Verde Ruso 4BO | FS34082 | GU 2.6,84,81,65,34.41,-1.65,9.65,3.77GY,3.43,2.02,8.21,D65/10°,SCE,UV400,5.1,5.2,5.2,5.4,5.66,5.78,5.83,5.88,6,6.25,6.67,7.21,7.9,8.56,8.98,9.16,9.14,8.95,8.67,8.46,8.36,8.29,8.25,8.29,8.32,8.35,8.44,8.48,8.58,8.65,8.71
71.018 | Black Green | Verde Negro | GU 3.2,67,73,71,30.64,-3.07,0.26,10.11G,3.02,3.04,6.5,D65/10°,SCI,UV400,6.18,6.55,6.5,6.43,6.39,6.33,6.41,6.46,6.55,6.5,6.57,6.71,6.89,6.95,6.95,6.95,6.61,6.51,6.33,6.13,5.93,5.78,5.65,5.57,5.51,5.45,5.51,5.55,5.67,5.72,5.76
71.018 | Black Green | Verde Negro | GU 3.2,68,74,73,31.11,-2.7,-0.35,10.12G,3.07,3.12,6.7,D65/10°,SCE,UV400,6.97,7.03,6.87,6.8,6.77,6.7,6.73,6.79,6.82,6.79,6.86,6.98,7.1,7.11,7.04,6.93,6.84,6.75,6.53,6.34,6.17,6,5.85,5.81,5.72,5.65,5.65,5.63,5.71,5.75,5.76
71.019 | Cam. Dark Green | RAL6007 Grün | FS34083 | RAL6007 | GU 3.5,69,73,64,30.64,-3.25,4.65,10.08GY,3.04,2.55,6.5,D65/10°,SCI,UV400,4.73,5.07,5.13,5.22,5.32,5.4,5.52,5.59,5.66,5.72,5.9,6.15,6.58,6.93,7.15,7.27,7.03,6.93,6.7,6.4,6.12,5.9,5.74,5.66,5.61,5.56,5.68,5.77,5.96,6.01,6.07
71.019 | Cam. Dark Green | RAL6007 Grün | FS34083 | RAL6007 | GU 3.5,71,74,67,31.16,-2.87,3.9,2.10G,3.09,1.05,6.72,D65/10°,SCE,UV400,5.39,5.53,5.49,5.61,5.73,5.76,5.87,5.92,5.96,6.02,6.2,6.45,6.81,7.11,7.26,7.29,7.28,7.18,6.94,6.65,6.38,6.14,5.97,5.93,5.84,5.8,5.85,5.87,6,6.08,6.08
71.020 | Green Brown | Verde Pardo | GU 2.0,86,78,67,34.04,1.26,7.71,3.94GY,3.39,1.98,8.03,D65/10°,SCI,UV400,6.15,6.7,6.56,6.22,5.95,5.8,5.82,5.91,6.12,6.37,6.69,7.03,7.52,7.85,8.01,8.13,8.27,8.85,9.38,9.39,8.96,8.51,8.28,8.3,8.33,8.48,8.97,9.73,10.67,11.57,12.35
71.020 | Green Brown | Verde Pardo | GU 2.0,87,79,69,34.36,1.5,6.89,5.13GY,3.42,2.74,8.18,D65/10°,SCE,UV400,6.89,7.17,6.92,6.59,6.31,6.12,6.12,6.21,6.37,6.63,6.95,7.26,7.7,7.97,8.04,8.09,8.45,9.04,9.52,9.54,9.13,8.69,8.47,8.5,8.53,8.68,9.1,9.77,10.68,11.59,12.37
71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 0.6,68,74,68,30.88,-3.96,2.89,2.08G,3.06,1.19,6.6,D65/10°,SCI,UV400,5.01,5.4,5.49,5.63,5.79,5.9,6.05,6.12,6.21,6.26,6.41,6.59,6.87,7.09,7.23,7.31,6.97,6.84,6.61,6.29,5.98,5.75,5.6,5.54,5.53,5.51,5.65,5.79,5.99,6.11,6.17
71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 0.6,69,75,70,31.32,-3.59,2.2,5.09G,3.1,2.83,6.79,D65/10°,SCE,UV400,5.71,5.84,5.83,5.98,6.16,6.24,6.37,6.44,6.48,6.54,6.69,6.85,7.07,7.24,7.29,7.27,7.19,7.07,6.81,6.5,6.21,5.96,5.79,5.77,5.72,5.7,5.78,5.86,6.02,6.14,6.2
71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 1.3,74,76,58,31.92,-4.77,10.47,4.46GY,3.19,1.99,7.05,D65/10°,SCI,UV400,4.1,4.4,4.42,4.45,4.51,4.61,4.72,4.82,4.92,5.1,5.49,6.09,7.12,8.1,8.53,8.46,7.86,7.72,7.45,7,6.56,6.26,6.08,6.06,6.06,6.14,6.43,6.61,6.63,6.51,6.25
71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 1.3,75,77,60,32.39,-4.4,9.71,5.01GY,3.23,2.07,7.26,D65/10°,SCE,UV400,4.75,4.8,4.72,4.75,4.86,4.91,5.04,5.12,5.19,5.38,5.78,6.39,7.36,8.26,8.6,8.46,8.1,7.96,7.66,7.23,6.82,6.5,6.33,6.33,6.31,6.4,6.64,6.75,6.73,6.57,6.34
71.023 | Hemp | Tan Green | FS34201 | GU 2.8,130,119,95,50.62,0.05,14.57,6.97Y,5.03,1.8,18.94,D65/10°,SCI,UV400,9.3,10.26,10.59,11.17,12.12,12.8,13.12,13.38,13.68,14.06,14.82,15.98,17.34,18.69,19.77,20.37,20.65,21.17,21.46,21.28,20.9,20.48,20.15,19.96,19.76,19.57,19.55,19.65,19.78,19.82,19.88
71.023 | Hemp | Tan Green | FS34201 | GU 2.8,130,119,96,50.67,0.28,14.13,5.01Y,5.03,2.08,18.98,D65/10°,SCE,UV400,10.02,10.64,10.89,11.47,12.35,13,13.28,13.48,13.76,14.14,14.92,16.05,17.41,18.72,19.67,20.21,20.68,21.21,21.49,21.39,21.03,20.58,20.24,20.04,19.82,19.67,19.64,19.68,19.77,19.82,19.84
71.024 | Khaki Brown | Marron Caqui | GU 2.4,139,109,80,48.5,7.76,20.65,2.10Y,4.84,3.55,17.19,D65/10°,SCI,UV400,8.07,8.57,8.52,8.52,8.78,8.98,9.27,9.85,10.36,10.53,11.1,12.35,13.97,15.31,15.69,15.54,16.35,19.91,24.12,25.48,24.1,22.32,21.22,20.72,20.26,19.97,20.27,21.18,22.31,23.31,24.08
71.024 | Khaki Brown | Marron Caqui | GU 2.4,139,109,82,48.58,7.91,19.74,2.11Y,4.85,3.6,17.26,D65/10°,SCE,UV400,8.86,9.01,8.89,8.87,9.17,9.31,9.59,10.12,10.59,10.75,11.31,12.5,14.06,15.34,15.66,15.4,16.42,19.96,24.12,25.46,24.14,22.43,21.34,20.8,20.35,20.09,20.38,21.16,22.23,23.24,24.03
71.025 | Dark Yellow | RAL7028 Dunkelgelb | RAL7028 | GU 3.0,154,120,72,52.72,7.22,30.9,2.07Y,5.28,4.62,20.79,D65/10°,SCI,UV400,5.9,6.39,6.64,7.11,7.84,8.31,8.66,9.11,9.59,10.03,11.04,12.89,15.41,18.04,19.95,20.87,22.48,26.41,30.4,30.87,28.67,26.39,24.96,24.23,23.6,23.21,23.59,24.63,26.05,27.44,28.69
71.025 | Dark Yellow | RAL7028 Dunkelgelb | RAL7028 | GU 3.0,153,120,74,52.73,7.31,29.74,2.06Y,5.28,4.61,20.8,D65/10°,SCE,UV400,6.65,6.91,7.06,7.52,8.23,8.66,8.98,9.4,9.84,10.26,11.23,13,15.48,18.07,19.86,20.73,22.49,26.38,30.28,30.72,28.59,26.36,24.99,24.24,23.67,23.31,23.6,24.53,25.87,27.3,28.45
71.026 | US Flat Brown | Marron US | FS30215 | GU 2.5,140,99,68,45.78,12.28,24.43,8.83YR,4.59,4.39,15.11,D65/10°,SCI,UV400,5.31,5.7,5.87,6.15,6.56,6.88,7.21,7.36,7.5,7.77,8.32,9.19,10.56,12.09,13.22,13.99,15.2,17.73,20.47,22.06,22.64,22.72,22.63,22.56,22.4,22.29,22.28,22.27,22.27,22.21,22.2
71.026 | US Flat Brown | Marron US | FS30215 | GU 2.5,140,100,70,45.93,12.33,23.23,8.87YR,4.61,4.34,15.22,D65/10°,SCE,UV400,6.01,6.19,6.26,6.56,6.97,7.27,7.56,7.72,7.81,8.06,8.62,9.45,10.74,12.18,13.22,13.88,15.29,17.78,20.52,22.14,22.74,22.82,22.74,22.63,22.51,22.4,22.34,22.24,22.2,22.16,22.18
71.027 | Light Brown | Marron Claro | GU 5.2,172,137,106,59.86,8.63,21.67,7.03YR,5.97,4.03,27.97,D65/10°,SCI,UV400,15.08,16.37,16.31,15.98,15.85,15.9,16.02,16.24,16.55,17.01,17.96,19.73,22.52,25.29,27.28,28.68,30.17,31.83,33.55,34.81,35.36,35.68,36.09,36.79,37.64,38.71,40.19,41.91,43.53,44.93,46.47
71.027 | Light Brown | Marron Claro | GU 5.2,171,137,107,59.73,8.57,21.1,6.94YR,5.95,3.99,27.82,D65/10°,SCE,UV400,15.44,16.52,16.55,16.17,16.02,16.07,16.16,16.35,16.64,17.11,18.03,19.78,22.49,25.17,27.07,28.4,30.04,31.67,33.3,34.51,35.08,35.38,35.79,36.49,37.4,38.43,39.84,41.47,42.98,44.43,45.93
71.028 | Sand Yellow | Amarillo Arena | GU 4.2,153,130,105,56.15,4.68,17.19,2.09Y,5.58,0.73,24.06,D65/10°,SCI,UV400,11.23,12.41,12.85,13.65,14.81,15.64,16.03,16.41,16.76,17.17,18.01,19.28,20.87,22.46,23.46,23.93,24.72,26.83,28.87,29.62,29.49,29.12,28.75,28.5,28.22,28.03,28.04,28.18,28.35,28.45,28.58
71.028 | Sand Yellow | Amarillo Arena | GU 4.2,153,130,105,56.11,4.76,16.7,2.08Y,5.57,0.85,24.02,D65/10°,SCE,UV400,11.91,12.7,13.06,13.87,15.02,15.85,16.18,16.52,16.88,17.28,18.1,19.36,20.88,22.39,23.32,23.7,24.69,26.79,28.78,29.51,29.41,29.07,28.71,28.44,28.22,28,27.96,27.98,28.13,28.3,28.39
71.029 | Dark Earth | Tierra Oscura | GU 1.0,96,82,65,36.03,3.24,11.85,2.03Y,3.6,1.75,9.02,D65/10°,SCI,UV400,4.83,5.18,5.27,5.46,5.74,5.88,6,6.14,6.34,6.42,6.75,7.28,7.96,8.53,8.81,8.92,9.04,10.07,11.04,11.3,11.09,10.79,10.51,10.37,10.21,10.09,10.16,10.28,10.41,10.5,10.53
71.029 | Dark Earth | Tierra Oscura | GU 1.0,97,83,68,36.37,3.38,10.87,10.05YR,3.63,2.31,9.2,D65/10°,SCE,UV400,5.5,5.62,5.66,5.84,6.15,6.24,6.36,6.48,6.63,6.73,7.05,7.57,8.19,8.69,8.86,8.88,9.27,10.26,11.19,11.45,11.28,10.95,10.7,10.58,10.43,10.32,10.31,10.35,10.5,10.58,10.63
71.030 | Brown Green | Marron Verdoso | GU 1.7,147,112,78,50.13,9.26,24.4,10.01YR,5.01,4.07,18.53,D65/10°,SCI,UV400,6.58,7.19,7.42,7.84,8.48,8.91,9.28,9.71,10.17,10.5,11.24,12.53,14.22,15.87,16.81,17.11,18.21,21.74,25.92,27.49,26.57,25.13,24.18,23.77,23.39,23.23,23.64,24.45,25.43,26.22,26.85
71.030 | Brown Green | Marron Verdoso | GU 1.7,147,112,79,50.14,9.37,23.45,10.01YR,5.01,3.91,18.54,D65/10°,SCE,UV400,7.39,7.67,7.78,8.17,8.82,9.21,9.55,9.98,10.36,10.68,11.41,12.64,14.27,15.86,16.73,16.94,18.24,21.77,25.86,27.39,26.5,25.11,24.21,23.76,23.46,23.3,23.62,24.34,25.24,26.08,26.69
71.031 | Middlestone | Piedra Medio | GU 1.5,150,118,75,51.86,7.05,28.14,2.04Y,5.19,4.03,20.02,D65/10°,SCI,UV400,6.41,6.96,7.15,7.44,8,8.36,8.78,9.64,10.72,11.3,12.21,13.8,15.82,17.76,18.96,19.42,20.56,23.77,27.23,28.35,27.54,26.35,25.48,25.01,24.57,24.3,24.52,25.12,25.9,26.53,27.08
71.031 | Middlestone | Piedra Medio | GU 1.5,150,118,77,51.88,7.15,27.08,2.03Y,5.19,4.02,20.04,D65/10°,SCE,UV400,7.23,7.46,7.53,7.83,8.4,8.7,9.1,9.92,10.9,11.49,12.38,13.9,15.88,17.8,18.9,19.27,20.58,23.8,27.17,28.26,27.48,26.33,25.5,25.01,24.63,24.36,24.53,25.02,25.72,26.4,26.93
71.032 | Golden Brown | Marron Dorado | GU 1.2,132,93,58,42.94,11.76,26,9.08YR,4.32,4.82,13.12,D65/10°,SCI,UV400,3.9,4.18,4.34,4.67,5.15,5.49,5.63,5.73,5.91,6.2,6.78,7.63,8.76,10.11,11.52,12.83,14.24,15.79,17.42,18.72,19.54,19.87,19.94,19.92,19.87,19.83,19.92,20.08,20.3,20.49,20.75
71.032 | Golden Brown | Marron Dorado | GU 1.2,132,93,61,43.11,11.72,24.71,8.06YR,4.33,4.28,13.23,D65/10°,SCE,UV400,4.47,4.55,4.64,4.99,5.54,5.86,5.99,6.05,6.21,6.5,7.08,7.9,8.97,10.22,11.53,12.73,14.31,15.86,17.46,18.8,19.63,19.95,19.99,19.99,19.93,19.92,20,20.09,20.29,20.48,20.72
71.033 | Yellow Ochre | RAL1006 Gelb | RAL1006 | GU 1.7,197,130,47,60.13,18.59,53.12,10.04YR,6.09,8.87,28.26,D65/10°,SCI,UV400,3.93,4.17,4.35,4.81,5.48,6,6.25,6.4,6.72,7.26,8.31,10.04,12.77,16.85,22.58,29.21,37.47,42.49,45.01,45.37,44.62,43.53,42.36,41.51,40.91,40.67,40.87,41.43,42.39,43.64,45.28
71.033 | Yellow Ochre | RAL1006 Gelb | RAL1006 | GU 1.7,196,130,50,60.05,18.51,51.42,10.03YR,6.08,8.58,28.18,D65/10°,SCE,UV400,4.49,4.56,4.67,5.14,5.9,6.4,6.63,6.77,7.03,7.56,8.6,10.28,12.87,16.89,22.46,28.94,37.13,42.24,44.77,45.17,44.42,43.3,42.14,41.25,40.7,40.42,40.54,41.01,41.9,43.15,44.8
71.034 | Sand Brown | Marron Arena | GU 1.6,147,98,77,46.38,17.55,20.13,3.14YR,4.64,5.43,15.55,D65/10°,SCI,UV400,7.32,7.78,7.77,7.84,8.1,8.23,8.42,8.72,8.98,8.99,9.26,9.86,10.76,11.56,11.67,11.5,12.37,16.31,22.56,26.82,27.13,25.93,25,24.52,24.12,23.89,24.27,25.13,26.15,27,27.66
71.034 | Sand Brown | Marron Arena | GU 1.6,147,98,79,46.51,17.46,19.15,4.01YR,4.65,4.49,15.65,D65/10°,SCE,UV400,8.13,8.26,8.17,8.21,8.48,8.59,8.74,9.04,9.25,9.26,9.52,10.11,10.93,11.65,11.69,11.42,12.49,16.4,22.6,26.78,27.08,25.94,25.03,24.54,24.19,23.97,24.27,25.02,25.98,26.87,27.54
71.035 | Cam. Pale Brown | Cam. Pardo Claro | FS30140 | RAL8025 | GU 2.1,109,87,72,38.83,6.82,11.94,9.66YR,3.87,2.16,10.56,D65/10°,SCI,UV400,6.63,6.91,6.83,6.76,6.82,6.85,7.02,7.29,7.53,7.53,7.75,8.24,8.92,9.43,9.52,9.4,9.7,11.58,13.76,14.62,14.34,13.76,13.33,13.12,12.92,12.8,12.92,13.25,13.55,13.81,13.96
71.035 | Cam. Pale Brown | Cam. Pardo Claro | FS30140 | RAL8025 | GU 2.1,109,87,74,39.04,6.87,11.04,7.02YR,3.89,1.84,10.68,D65/10°,SCE,UV400,7.43,7.36,7.18,7.1,7.2,7.2,7.32,7.58,7.78,7.79,8.01,8.48,9.08,9.54,9.53,9.36,9.87,11.7,13.83,14.7,14.44,13.84,13.43,13.22,13.05,12.93,12.98,13.2,13.53,13.78,13.95
71.036 | Mahogany | Caoba | GU 1.9,67,59,53,25.56,2.41,4.69,7.18GY,2.54,-0.01,4.6,D65/10°,SCI,UV400,3.5,3.65,3.68,3.68,3.7,3.71,3.76,3.83,3.86,3.85,3.96,4.09,4.2,4.26,4.29,4.42,4.48,4.96,5.45,5.61,5.45,5.28,5.09,4.97,4.87,4.76,4.75,4.68,4.7,4.63,4.59
71.036 | Mahogany | Caoba | GU 1.9,68,59,55,25.98,2.78,4.16,3.41R,2.59,1.59,4.74,D65/10°,SCE,UV400,3.95,3.96,3.91,3.91,3.94,3.93,3.98,4.01,4.03,4.03,4.13,4.25,4.35,4.35,4.32,4.37,4.64,5.16,5.65,5.79,5.67,5.47,5.28,5.17,5.04,4.91,4.85,4.75,4.69,4.63,4.58
71.037 | Mud Brown | Marron Lodo | GU 2.0,141,96,73,45.2,15.37,20.34,6.10YR,4.53,3.95,14.68,D65/10°,SCI,UV400,7.1,7.44,7.36,7.31,7.47,7.53,7.71,8.02,8.29,8.35,8.67,9.39,10.4,11.3,11.54,11.45,12.31,15.94,21.32,24.63,24.54,23.32,22.45,22.07,21.76,21.62,22.02,22.83,23.75,24.47,24.96
71.037 | Mud Brown | Marron Lodo | GU 2.0,141,97,75,45.34,15.35,19.33,3.67YR,4.54,4.33,14.79,D65/10°,SCE,UV400,7.94,7.91,7.74,7.68,7.85,7.89,8.04,8.33,8.56,8.61,8.95,9.64,10.57,11.39,11.55,11.39,12.43,16.01,21.36,24.63,24.56,23.38,22.55,22.14,21.85,21.73,22.05,22.78,23.62,24.37,24.91
71.038 | Cam. Medium Brown | Cam Pardo Medio | FS30097 | GU 1.3,96,77,60,34.49,5.41,13.14,10.03YR,3.45,2.22,8.25,D65/10°,SCI,UV400,4.41,4.65,4.69,4.77,4.9,4.98,5.06,5.23,5.37,5.45,5.73,6.2,6.86,7.4,7.65,7.75,8,9.4,10.93,11.4,11,10.44,10.05,9.86,9.69,9.6,9.75,10.03,10.31,10.52,10.59
71.038 | Cam. Medium Brown | Cam Pardo Medio | FS30097 | GU 1.3,97,78,62,34.89,5.42,12.25,10.02YR,3.49,2.14,8.44,D65/10°,SCE,UV400,5.04,5.08,5.01,5.09,5.26,5.3,5.41,5.54,5.66,5.74,6.03,6.51,7.1,7.58,7.75,7.75,8.26,9.62,11.09,11.56,11.18,10.63,10.25,10.08,9.93,9.84,9.93,10.12,10.39,10.59,10.73
71.039 | Hull Red | Marron Rojizo | GU 2.6,68,60,55,26.07,2.53,4.43,7.19GY,2.59,-0.05,4.77,D65/10°,SCI,UV400,3.71,3.88,3.89,3.9,3.9,3.91,3.96,4,4.02,4.03,4.14,4.26,4.37,4.44,4.45,4.57,4.62,5.09,5.61,5.8,5.67,5.5,5.31,5.17,5.07,4.97,4.96,4.88,4.88,4.81,4.78
71.039 | Hull Red | Marron Rojizo | GU 2.6,69,60,56,26.34,2.91,3.88,2.17R,2.62,0.23,4.86,D65/10°,SCE,UV400,4.12,4.15,4.09,4.11,4.12,4.08,4.13,4.14,4.16,4.16,4.26,4.38,4.48,4.47,4.43,4.48,4.73,5.24,5.75,5.94,5.84,5.65,5.43,5.33,5.2,5.06,5,4.87,4.83,4.75,4.68
71.040 | Burnt Umber | Sombra Tostada | RAL8014 | GU 1.6,69,61,53,26.68,1.6,6.33,5.14GY,2.66,2.7,4.98,D65/10°,SCI,UV400,3.44,3.61,3.65,3.7,3.71,3.75,3.84,3.9,3.95,3.96,4.14,4.35,4.56,4.64,4.63,4.69,4.82,5.6,6.71,6.8,5.91,5.21,4.85,4.67,4.58,4.5,4.6,4.7,4.88,4.97,5.01
71.040 | Burnt Umber | Sombra Tostada | RAL8014 | GU 1.6,70,62,55,27.1,1.87,5.81,5.15GY,2.7,2.77,5.13,D65/10°,SCE,UV400,3.86,3.9,3.87,3.93,3.97,3.95,4.05,4.09,4.12,4.14,4.31,4.54,4.74,4.74,4.66,4.66,4.99,5.83,6.91,7,6.14,5.39,5,4.85,4.71,4.63,4.67,4.72,4.87,4.97,5
71.041 | Armour Brown | RAL8017 Rotbraun | RAL8017 | GU 1.1,73,61,59,27.26,4.83,3.11,2.12R,2.71,0.7,5.19,D65/10°,SCI,UV400,4.51,4.72,4.69,4.64,4.57,4.52,4.53,4.53,4.53,4.49,4.51,4.53,4.56,4.63,4.68,4.81,4.88,5.32,5.88,6.27,6.41,6.38,6.31,6.34,6.31,6.42,6.72,6.91,6.97,6.85,6.61
71.041 | Armour Brown | RAL8017 Rotbraun | RAL8017 | GU 1.1,75,62,61,27.79,5.2,2.48,2.12R,2.76,0.73,5.38,D65/10°,SCE,UV400,5.12,5.16,5.02,4.96,4.92,4.83,4.82,4.79,4.77,4.72,4.75,4.75,4.77,4.76,4.74,4.79,5.09,5.58,6.11,6.51,6.67,6.63,6.57,6.61,6.6,6.69,6.92,7.04,7.03,6.91,6.7
71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.6,71,64,62,27.99,2.63,2.05,7.84RP,2.78,1.2,5.45,D65/10°,SCI,UV400,5.11,5.3,5.22,5.12,5,4.95,4.97,5,5,4.95,4.96,4.97,5.06,5.16,5.15,5.21,5.19,5.68,6.17,6.31,6.24,6.11,5.95,5.89,5.81,5.73,5.78,5.8,5.87,5.87,5.87
71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.6,72,65,65,28.56,2.96,1.41,7.66RP,2.83,1.07,5.67,D65/10°,SCE,UV400,5.85,5.76,5.59,5.45,5.39,5.29,5.29,5.3,5.3,5.22,5.22,5.24,5.3,5.31,5.24,5.22,5.42,5.94,6.41,6.56,6.51,6.37,6.22,6.16,6.05,5.97,5.96,5.92,5.94,5.94,5.93
71.043 | US Olive Drab | US Verde Oliva | FS34087 | GU 3.0,98,92,78,39.42,-0.44,8.93,5.08GY,3.92,2.48,10.91,D65/10°,SCI,UV400,6.78,7.25,7.39,7.58,7.91,8.11,8.26,8.47,8.65,8.8,9.16,9.72,10.32,10.8,11.15,11.46,11.64,12.06,12.32,12.19,11.78,11.31,10.97,10.81,10.65,10.56,10.7,10.95,11.28,11.54,11.7
71.043 | US Olive Drab | US Verde Oliva | FS34087 | GU 3.0,97,92,79,39.37,-0.2,8.26,5.09GY,3.91,2.56,10.88,D65/10°,SCE,UV400,7.39,7.55,7.59,7.78,8.11,8.27,8.41,8.59,8.75,8.89,9.25,9.78,10.32,10.73,11.01,11.22,11.6,12.01,12.26,12.15,11.76,11.3,10.97,10.83,10.7,10.61,10.68,10.85,11.17,11.45,11.63
71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.9,121,118,101,49.57,-1.8,9.5,5.05GY,4.91,2.38,18.06,D65/10°,SCI,UV400,12.68,13.62,13.62,13.51,13.53,13.66,13.83,14.05,14.33,14.7,15.31,16.27,17.63,18.8,19.5,19.8,19.54,19.28,18.88,18.51,18.28,18.11,18.06,18.1,18.13,18.19,18.36,18.55,18.72,18.8,18.92
71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.9,121,118,102,49.6,-1.61,9.18,5.24GY,4.91,2.28,18.08,D65/10°,SCE,UV400,13.22,13.86,13.79,13.72,13.72,13.84,13.95,14.14,14.41,14.77,15.4,16.33,17.69,18.8,19.42,19.65,19.55,19.29,18.9,18.58,18.37,18.19,18.11,18.17,18.21,18.31,18.46,18.56,18.7,18.79,18.86
71.045 | Cement Grey | Gris Cemento | RAL7033 | GU 2.8,136,137,126,57.01,-2.78,5.75,10.08GY,5.61,2.88,24.93,D65/10°,SCI,UV400,19.99,22.01,22.01,21.35,21.03,20.99,21.17,22.08,23.05,23.34,23.82,24.77,25.62,25.97,25.99,25.95,25.54,25.34,25.13,24.92,24.76,24.58,24.38,24.26,24.05,23.88,23.81,23.72,23.62,23.46,23.32
71.045 | Cement Grey | Gris Cemento | RAL7033 | GU 2.8,136,137,126,56.95,-2.6,5.63,10.08GY,5.61,2.91,24.87,D65/10°,SCE,UV400,20.35,22.05,21.9,21.31,21.06,21.02,21.21,22.1,23.02,23.31,23.81,24.74,25.54,25.84,25.82,25.71,25.49,25.32,25.09,24.9,24.78,24.61,24.43,24.28,24.12,23.94,23.82,23.65,23.51,23.4,23.29
71.046 | Pale Blue Grey | Azul Gris Claro | GU 3.6,144,154,158,63.27,-2.87,-2.98,4.44PB,6.21,2.69,31.91,D65/10°,SCI,UV400,28.21,33.71,34.68,34.42,34.15,34.07,33.96,33.97,33.86,33.66,33.55,33.47,33.38,33.17,32.87,32.53,31.73,31.19,30.69,30.21,29.74,29.33,29.04,28.95,28.85,28.78,28.78,28.71,28.62,28.4,28.38
71.046 | Pale Blue Grey | Azul Gris Claro | GU 3.6,144,154,157,63.01,-2.72,-2.9,4.52PB,6.18,2.74,31.6,D65/10°,SCE,UV400,28.16,33.31,34.23,34.01,33.8,33.72,33.57,33.57,33.45,33.27,33.2,33.15,33.03,32.78,32.43,32.08,31.47,30.96,30.46,29.99,29.56,29.16,28.88,28.77,28.73,28.63,28.55,28.4,28.27,28.13,28.09
71.047 | Grey | Gris | GU 2.0,80,89,95,37.29,-1.95,-4.89,9.09BG,3.66,2.39,9.69,D65/10°,SCI,UV400,11.05,11.87,11.86,11.65,11.5,11.35,11.24,11.07,10.94,10.77,10.63,10.47,10.33,10.22,10.06,9.9,9.35,9.12,8.94,8.77,8.67,8.6,8.53,8.6,8.61,8.63,8.67,8.62,8.52,8.42,8.35
71.047 | Grey | Gris | GU 2.0,81,89,96,37.6,-1.64,-5.03,10.12BG,3.69,2.99,9.86,D65/10°,SCE,UV400,11.67,12.18,12.09,11.91,11.74,11.61,11.47,11.3,11.12,10.96,10.85,10.67,10.51,10.33,10.11,9.87,9.56,9.36,9.14,8.99,8.91,8.82,8.78,8.84,8.88,8.89,8.86,8.73,8.62,8.49,8.44
71.048 | Engine Grey | Gris Motor | FS36076 | GU 2.2,81,89,94,37.46,-1.69,-4.02,9.16BG,3.68,2.46,9.79,D65/10°,SCI,UV400,10.6,11.36,11.39,11.32,11.28,11.22,11.12,10.97,10.83,10.66,10.54,10.42,10.29,10.19,10.13,10.05,9.5,9.23,9.19,9.14,9.05,8.93,8.8,8.74,8.65,8.61,8.67,8.67,8.65,8.56,8.41
71.048 | Engine Grey | Gris Motor | FS36076 | GU 2.2,82,89,95,37.74,-1.39,-4.18,9.25BG,3.71,2.53,9.94,D65/10°,SCE,UV400,11.2,11.66,11.61,11.57,11.53,11.45,11.32,11.16,10.98,10.84,10.75,10.61,10.45,10.29,10.17,10,9.69,9.45,9.36,9.33,9.26,9.13,9.02,8.98,8.9,8.85,8.86,8.78,8.72,8.61,8.5
71.049 | Sea Grey | Gris Mar | GU 3.2,93,102,105,42.71,-2.39,-3.14,7.69BG,4.19,1.68,12.97,D65/10°,SCI,UV400,13.12,14.16,14.26,14.26,14.33,14.35,14.26,14.12,13.98,13.85,13.79,13.75,13.69,13.62,13.51,13.33,12.77,12.47,12.23,11.99,11.85,11.73,11.63,11.64,11.65,11.64,11.66,11.59,11.46,11.32,11.25
71.049 | Sea Grey | Gris Mar | GU 3.2,94,102,106,42.83,-2.04,-3.33,7.73BG,4.21,1.69,13.04,D65/10°,SCE,UV400,13.67,14.4,14.46,14.48,14.52,14.53,14.4,14.21,14.04,13.91,13.89,13.82,13.76,13.64,13.46,13.23,12.87,12.6,12.33,12.14,12.02,11.87,11.79,11.82,11.85,11.84,11.78,11.64,11.52,11.38,11.32
71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1,129,138,145,57.25,-1.84,-4.96,5.05PB,5.6,2.52,25.18,D65/10°,SCI,UV400,24.69,28.66,29.22,28.92,28.63,28.41,28.12,27.85,27.54,27.19,26.87,26.5,26.24,25.99,25.69,25.35,24.64,24.37,24.13,23.81,23.49,23.15,22.88,22.76,22.59,22.52,22.61,22.55,22.41,22.12,21.8
71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1,129,138,145,57.18,-1.68,-4.87,5.05PB,5.6,2.54,25.11,D65/10°,SCE,UV400,24.92,28.48,28.96,28.74,28.47,28.3,28,27.74,27.42,27.1,26.79,26.45,26.15,25.86,25.5,25.07,24.61,24.37,24.11,23.83,23.54,23.21,22.98,22.81,22.68,22.62,22.63,22.51,22.33,22.09,21.78
71.051 | Neutral Gray | Gris Neutral | FS36173 | GU 3.4,112,120,125,50.15,-1.99,-3.98,9.85BG,4.92,2.92,18.55,D65/10°,SCI,UV400,18.81,20.99,21.32,21.06,20.8,20.63,20.43,20.21,20.01,19.79,19.64,19.49,19.36,19.18,19.07,18.89,18.37,18.09,17.74,17.42,17.2,16.98,16.8,16.66,16.49,16.36,16.33,16.28,16.21,16.09,15.98
71.051 | Neutral Gray | Gris Neutral | FS36173 | GU 3.4,112,120,126,50.19,-1.86,-4,9.86BG,4.92,2.95,18.57,D65/10°,SCE,UV400,19.15,21.06,21.27,21.04,20.86,20.7,20.46,20.26,20.07,19.87,19.7,19.55,19.38,19.2,19,18.73,18.41,18.12,17.8,17.51,17.31,17.08,16.88,16.77,16.62,16.5,16.4,16.27,16.2,16.08,15.97
71.052 | Anthracite Grey | Gris Antracita | GU 2.2,75,81,83,34.07,-1.61,-2.42,5.14BG,3.35,3.26,8.04,D65/10°,SCI,UV400,8.2,8.86,8.91,8.84,8.81,8.74,8.71,8.65,8.62,8.52,8.46,8.41,8.4,8.35,8.35,8.29,7.9,7.77,7.64,7.52,7.46,7.4,7.35,7.38,7.37,7.34,7.39,7.38,7.35,7.27,7.22
71.052 | Anthracite Grey | Gris Antracita | GU 2.2,76,81,85,34.44,-1.28,-2.77,5.92BG,3.39,2.5,8.22,D65/10°,SCE,UV400,8.93,9.26,9.22,9.17,9.15,9.04,9.01,8.92,8.85,8.76,8.72,8.65,8.58,8.5,8.4,8.27,8.12,7.99,7.83,7.72,7.69,7.64,7.59,7.62,7.61,7.6,7.57,7.46,7.4,7.34,7.3
71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9,72,81,86,33.96,-1.94,-4.52,8.13BG,3.33,1.87,7.99,D65/10°,SCI,UV400,9.39,9.91,9.86,9.63,9.48,9.32,9.2,9.06,8.94,8.78,8.68,8.56,8.48,8.39,8.32,8.26,7.8,7.62,7.43,7.24,7.14,7.06,6.95,6.92,6.85,6.84,6.9,6.91,6.9,6.85,6.75
71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9,73,81,88,34.34,-1.6,-4.8,10.13BG,3.37,2.96,8.17,D65/10°,SCE,UV400,10.03,10.29,10.13,9.94,9.81,9.61,9.49,9.34,9.17,9.02,8.93,8.79,8.66,8.53,8.39,8.24,8.02,7.85,7.62,7.46,7.37,7.29,7.19,7.17,7.12,7.07,7.08,6.99,6.97,6.9,6.82
71.054 | Dark Grey Blue | Gris Azul Oscuro | RAL7024 | GU 2.2,69,74,78,31.34,-1.33,-2.93,5.31BG,3.08,3.08,6.8,D65/10°,SCI,UV400,7.32,7.85,7.85,7.75,7.66,7.55,7.5,7.41,7.35,7.24,7.16,7.1,7.07,7.07,7.04,7.04,6.65,6.55,6.44,6.33,6.28,6.25,6.17,6.19,6.17,6.13,6.16,6.16,6.18,6.11,6.12
71.054 | Dark Grey Blue | Gris Azul Oscuro | RAL7024 | GU 2.2,70,75,79,31.79,-0.96,-3.35,7.53BG,3.13,1.47,6.99,D65/10°,SCE,UV400,8.08,8.29,8.19,8.09,8.02,7.88,7.82,7.7,7.6,7.51,7.44,7.36,7.28,7.21,7.11,7.01,6.89,6.79,6.66,6.56,6.53,6.47,6.42,6.44,6.41,6.36,6.34,6.25,6.22,6.16,6.14
71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 1.7,71,77,79,32.53,-2.08,-2.27,5.13BG,3.2,3.15,7.32,D65/10°,SCI,UV400,7.36,7.96,8.01,7.98,8.01,7.96,7.94,7.87,7.83,7.76,7.72,7.66,7.69,7.68,7.68,7.64,7.24,7.1,6.94,6.79,6.71,6.63,6.53,6.52,6.45,6.43,6.5,6.51,6.52,6.48,6.39
71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 1.7,72,78,81,32.96,-1.69,-2.69,5.62BG,3.24,2.75,7.52,D65/10°,SCE,UV400,8.16,8.4,8.36,8.34,8.38,8.29,8.26,8.17,8.08,8.01,7.99,7.93,7.89,7.83,7.74,7.63,7.48,7.34,7.16,7.01,6.95,6.87,6.79,6.77,6.71,6.69,6.7,6.63,6.6,6.52,6.46
71.056 | Panzer Dk. Grey | RAL7021 Dunkelgrau | RAL7021 | GU 1.6,64,68,67,28.55,-1.59,0.02,10.14G,2.82,3.3,5.66,D65/10°,SCI,UV400,5.17,5.54,5.6,5.63,5.68,5.66,5.68,5.67,5.69,5.67,5.7,5.73,5.8,5.87,5.93,5.99,5.68,5.63,5.55,5.46,5.37,5.34,5.27,5.23,5.2,5.16,5.21,5.22,5.29,5.28,5.27
71.056 | Panzer Dk. Grey | RAL7021 Dunkelgrau | RAL7021 | GU 1.6,65,69,69,29.07,-1.24,-0.6,10.15G,2.87,3.38,5.87,D65/10°,SCE,UV400,5.89,6,5.97,5.98,6.05,6.01,6.01,5.99,5.97,5.95,5.98,5.99,6.04,6.04,6,5.97,5.92,5.88,5.77,5.67,5.62,5.56,5.47,5.47,5.41,5.35,5.34,5.3,5.32,5.3,5.3
71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3,52,53,53,22.33,-0.42,0.01,7.80G,2.21,1.26,3.61,D65/10°,SCI,UV400,3.41,3.61,3.62,3.64,3.6,3.59,3.6,3.6,3.62,3.59,3.6,3.58,3.6,3.67,3.7,3.76,3.58,3.58,3.55,3.55,3.54,3.55,3.54,3.54,3.54,3.52,3.58,3.57,3.61,3.61,3.62
71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3,53,54,55,22.72,-0.11,-0.71,10.18G,2.24,3.51,3.72,D65/10°,SCE,UV400,3.92,3.95,3.89,3.89,3.88,3.82,3.82,3.79,3.8,3.77,3.76,3.73,3.75,3.75,3.73,3.72,3.72,3.73,3.68,3.65,3.68,3.67,3.64,3.67,3.64,3.62,3.63,3.58,3.61,3.58,3.58
71.062 | Aluminium | Aluminio | GU 45.5 | Metallic,213,216,221,86.49,-0.34,-2.8,5.03P,8.62,2.58,68.96,D65/10°,SCI,UV400,73.64,73.06,73.6,73.11,72.95,72.75,71.83,71.32,70.99,70.67,70.42,70.15,69.77,69.39,69.02,68.69,68.54,68.3,68.13,68.06,67.96,67.69,67.31,67.1,66.97,66.65,66.03,65.1,64.37,63.84,63.43
71.062 | Aluminium | Aluminio | GU 45.5 | Metallic,200,203,208,81.83,-0.33,-2.69,5.04P,8.14,2.66,59.98,D65/10°,SCE,UV400,64.12,63.69,64.1,63.58,63.5,63.27,62.47,62.04,61.69,61.39,61.21,61,60.69,60.28,60.05,59.86,59.59,59.41,59.26,59.21,59.09,58.82,58.52,58.3,58.21,57.94,57.34,56.56,55.9,55.51,55.14
71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic,205,209,214,83.89,-0.49,-2.91,5.03P,8.35,2.62,63.86,D65/10°,SCI,UV400,68.2,67.99,68.53,67.98,67.76,67.57,66.69,66.24,65.87,65.56,65.34,65.05,64.71,64.37,63.99,63.75,63.45,63.21,63,62.86,62.72,62.43,62.06,61.84,61.67,61.36,60.74,59.92,59.21,58.69,58.27
71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic,195,199,204,80.18,-0.45,-2.88,5.04P,7.97,2.67,57,D65/10°,SCE,UV400,61.17,60.81,61.25,60.73,60.62,60.4,59.63,59.19,58.83,58.54,58.33,58.08,57.77,57.37,57.12,56.97,56.61,56.42,56.22,56.12,55.99,55.72,55.39,55.17,55.03,54.75,54.12,53.36,52.71,52.33,51.95
71.064 | Chrome | Cromo | FS17178 | GU 41.7 | Metallic,208,213,218,85.18,-0.65,-3.03,5.03P,8.49,2.61,66.37,D65/10°,SCI,UV400,70.83,70.61,71.19,70.7,70.54,70.35,69.42,68.97,68.61,68.28,68.03,67.77,67.39,66.95,66.63,66.29,65.93,65.61,65.35,65.21,65,64.68,64.3,64.06,63.93,63.63,63.05,62.24,61.51,60.95,60.53
71.064 | Chrome | Cromo | FS17178 | GU 41.7 | Metallic,198,203,208,81.54,-0.61,-2.93,5.04P,8.11,2.66,59.46,D65/10°,SCE,UV400,63.72,63.33,63.77,63.3,63.22,63.02,62.24,61.8,61.42,61.16,60.96,60.69,60.35,59.93,59.64,59.47,59.06,58.78,58.56,58.44,58.26,57.95,57.6,57.38,57.24,56.98,56.4,55.64,54.95,54.53,54.1
71.065 | Steel | Acero | GU 29.0 | Metallic,205,211,216,84.46,-1.04,-3.18,2.04P,8.41,1.7,64.96,D65/10°,SCI,UV400,69.35,69.22,69.76,69.31,69.19,69.05,68.21,67.73,67.41,67.14,66.88,66.59,66.23,65.84,65.39,65.06,64.51,64.08,63.73,63.46,63.22,62.84,62.43,62.18,62,61.78,61.28,60.56,59.84,59.24,58.76
71.065 | Steel | Acero | GU 29.0 | Metallic,196,202,207,81.18,-0.94,-3.08,2.04P,8.07,1.69,58.79,D65/10°,SCE,UV400,62.9,62.67,63.14,62.7,62.68,62.49,61.72,61.32,60.98,60.7,60.49,60.27,59.93,59.48,59.14,58.9,58.39,58.02,57.67,57.48,57.27,56.91,56.57,56.33,56.22,56.03,55.5,54.82,54.17,53.73,53.29
71.066 | Gold | Oro | FS17043 | GU 19.8 | Metallic,195,159,93,67.56,5.41,38.97,2.03Y,6.77,6.02,37.38,D65/10°,SCI,UV400,17.8,15.18,13.28,11.43,11,11.94,14.06,16.91,20.04,22.97,25.84,28.7,31.48,34.08,36.34,38.19,40.69,42.76,44.71,46.34,47.63,48.64,49.39,50.21,50.96,51.53,51.77,51.84,51.9,52.09,52.39
71.066 | Gold | Oro | FS17043 | GU 19.8 | Metallic,184,148,86,63.61,5.46,37.87,2.04Y,6.36,6.03,32.33,D65/10°,SCE,UV400,14.72,12.54,10.98,9.55,9.26,10.06,11.9,14.42,17.2,19.71,22.16,24.64,27.04,29.25,31.28,32.93,35.18,37.09,38.87,40.32,41.49,42.37,43.04,43.72,44.4,44.92,45.13,45.13,45.19,45.42,45.69
71.067 | Bright Brass | Laton | GU 32.1 | Metallic,204,168,94,70.75,4.32,42.88,4.70Y,7.11,6.59,41.82,D65/10°,SCI,UV400,18.14,15.44,13.53,11.64,11.19,12.17,14.47,17.89,21.86,25.42,28.81,32.28,35.62,38.54,41.18,43.41,46.32,48.17,49.81,51.3,52.62,53.64,54.43,55.26,56.03,56.62,56.9,56.93,56.99,57.18,57.47
71.067 | Bright Brass | Laton | GU 32.1 | Metallic,189,155,82,65.76,4.27,42.3,3.82Y,6.59,6.35,35.02,D65/10°,SCE,UV400,13.83,11.69,10.23,8.86,8.61,9.46,11.49,14.46,17.92,20.91,23.78,26.71,29.53,32.07,34.4,36.41,38.89,40.55,41.97,43.27,44.38,45.27,45.94,46.66,47.39,47.9,48.12,48.13,48.17,48.4,48.66
71.068 | Copper | Cobre | GU 11.1 | Metallic,197,139,111,63.01,18.87,23.87,2.04YR,6.29,6.03,31.6,D65/10°,SCI,UV400,16.01,16.09,16.27,16.54,16.89,17.4,17.92,18.61,19.4,20.09,20.74,21.26,22.06,23.26,24.74,26.46,30.01,35.2,41.15,45.86,48.59,49.92,50.51,50.94,51.23,51.41,51.28,51.11,50.95,50.99,51.14
71.068 | Copper | Cobre | GU 11.1 | Metallic,189,132,105,60.36,18.96,23.2,2.04YR,6.02,6.03,28.52,D65/10°,SCE,UV400,14.5,14.56,14.7,14.93,15.23,15.68,16.09,16.69,17.37,17.98,18.55,19.03,19.71,20.74,22.03,23.58,26.95,31.71,37.32,41.78,44.38,45.63,46.22,46.6,46.95,47.13,46.99,46.77,46.64,46.71,46.89
71.069 | Rust | Oxido | GU 7.1 | Metallic,152,113,91,51.25,12.16,18.3,5.24YR,5.11,3.81,19.48,D65/10°,SCI,UV400,10.43,10.69,10.82,10.96,11.17,11.41,11.7,12.11,12.61,13.05,13.56,14.08,14.59,15.27,16.25,17.56,19.77,22.05,24.37,26.3,27.59,28.24,28.45,28.57,28.61,28.64,28.66,28.61,28.63,28.62,28.77
71.069 | Rust | Oxido | GU 7.1 | Metallic,148,109,88,49.68,12.62,17.85,4.89YR,4.95,3.85,18.15,D65/10°,SCE,UV400,10.1,10.08,10.14,10.25,10.48,10.66,10.91,11.23,11.63,12.03,12.52,12.97,13.44,14.05,14.92,16.1,18.35,20.6,22.83,24.73,26.03,26.68,26.93,27.05,27.14,27.16,27.15,27.04,27.04,27.13,27.26
71.070 | Signal Red | Rojo Señal | GU 6.2 | Metallic | Opacity 82.48%,207,82,100,52.22,50.74,15.77,2.01R,5.22,12.44,20.34,D65/10°,SCI,UV400,16.53,15.75,15.16,14.55,14.04,13.51,12.88,12.11,11.31,10.5,9.6,8.79,8.55,8.6,8.43,8.23,8.78,11.6,18.73,31.1,45.83,58.86,68.23,73.78,77.02,79.17,80.65,81.78,82.47,83.03,83.74
71.070 | Signal Red | Rojo Señal | GU 6.2 | Metallic | Opacity 82.48%,205,82,99,51.92,50.34,15.68,2.01R,5.18,12.38,20.07,D65/10°,SCE,UV400,16.39,15.57,14.96,14.39,13.84,13.33,12.7,11.94,11.17,10.41,9.58,8.81,8.53,8.53,8.28,8.02,8.8,11.51,18.44,30.57,45.15,57.96,67.14,72.58,75.87,78.04,79.4,80.37,80.85,81.41,81.92
71.071 | Arctic Blue | Azul Artico | GU 6.3 | Metallic,52,94,131,38.72,-2.83,-25.17,5.13PB,3.69,6.42,10.5,D65/10°,SCI,UV400,17.11,18.78,19.78,20.79,21.81,22.64,22.58,22.03,20.88,19.05,17.04,14.95,12.75,11,9.89,8.92,7.4,6.72,6.56,6.66,6.73,6.67,6.68,7.09,7.77,8.62,9.3,9.42,8.98,8.48,8.33
71.071 | Arctic Blue | Azul Artico | GU 6.3 | Metallic,51,90,126,37.08,-2.11,-24.49,6.20PB,3.53,6.74,9.58,D65/10°,SCE,UV400,15.96,17.35,18.22,19.07,20.01,20.72,20.59,20.07,19,17.32,15.42,13.5,11.53,9.95,8.91,8.01,6.85,6.25,6.11,6.2,6.27,6.22,6.24,6.62,7.25,8,8.56,8.58,8.16,7.7,7.61
71.072 | Gunmetal | Fusil | FS37200 | GU 17.3 | Metallic,148,151,156,62.46,-0.1,-2.98,5.07P,6.13,3.16,30.95,D65/10°,SCI,UV400,34.04,33.9,33.92,33.62,33.44,33.31,32.74,32.42,32.15,31.92,31.72,31.55,31.35,31.13,30.93,30.77,30.73,30.57,30.47,30.41,30.36,30.27,30.06,29.98,29.89,29.77,29.5,29.07,28.75,28.43,28.23
71.072 | Gunmetal | Fusil | FS37200 | GU 17.3 | Metallic,139,141,145,58.67,0.01,-2.42,7.07P,5.76,1.39,26.67,D65/10°,SCE,UV400,29.01,28.85,28.82,28.61,28.52,28.43,27.97,27.73,27.51,27.34,27.22,27.11,26.94,26.73,26.6,26.52,26.53,26.44,26.34,26.32,26.32,26.23,26.08,26,25.96,25.83,25.59,25.19,24.85,24.66,24.49
71.073 | Black | Negro | GU 14.6 | Metallic,100,105,111,44.51,-0.8,-3.95,4.00P,4.37,2.84,14.19,D65/10°,SCI,UV400,16.73,16.59,16.48,16.29,16.14,16,15.7,15.46,15.25,15.08,14.95,14.8,14.64,14.46,14.3,14.19,14.05,13.91,13.73,13.57,13.49,13.36,13.21,13.12,12.99,12.88,12.74,12.52,12.37,12.23,12.11
71.073 | Black | Negro | GU 14.6 | Metallic,90,95,101,40.31,-0.57,-3.91,9.94BG,3.96,3.22,11.44,D65/10°,SCE,UV400,13.82,13.55,13.4,13.25,13.12,13,12.73,12.5,12.31,12.16,12.09,11.95,11.8,11.62,11.46,11.33,11.33,11.22,11.08,10.96,10.9,10.79,10.65,10.6,10.51,10.4,10.27,10.04,9.93,9.83,9.72
71.074 | Beige | Beige | FS33695 | GU 2.7,228,189,130,78.84,6.41,34.83,2.14Y,7.97,6.01,54.65,D65/10°,SCI,UV400,17.11,19.42,20.57,22.49,25.14,27.25,28.17,28.79,29.57,30.91,33.36,36.92,41.54,47.35,53.96,59.97,65.78,68.67,69.48,68.79,67.24,65.66,64.56,63.92,63.53,63.32,63.72,64.61,65.72,66.76,67.83
71.074 | Beige | Beige | FS33695 | GU 2.7,227,188,130,78.58,6.49,34.56,2.22Y,7.95,5.98,54.2,D65/10°,SCE,UV400,17.47,19.44,20.55,22.4,25.04,27.16,28.05,28.64,29.38,30.73,33.12,36.6,41.18,46.98,53.38,59.42,65.19,68.08,68.9,68.24,66.7,65.18,64.16,63.52,63.16,62.99,63.28,64.03,65.04,66.19,67.05
71.075 | Ivory | RAL1001 Elfenbein | RAL1001 | GU 3.9,189,169,135,70.41,1.91,20.27,5.03Y,7.02,2.89,41.34,D65/10°,SCI,UV400,20.51,22.91,23.44,23.88,24.77,25.53,26.34,28.76,31.93,33.53,34.75,36.29,38.06,39.73,40.74,41.19,42.17,44.66,47.09,48.13,48.15,47.88,47.54,47.32,47.07,46.89,46.85,47.04,47.21,47.3,47.38
71.075 | Ivory | RAL1001 Elfenbein | RAL1001 | GU 3.9,189,169,135,70.19,2.13,20.09,5.10Y,7,2.86,41.02,D65/10°,SCE,UV400,20.82,22.9,23.31,23.78,24.67,25.46,26.23,28.59,31.67,33.23,34.44,35.95,37.69,39.32,40.27,40.71,41.82,44.38,46.83,47.9,47.95,47.65,47.31,47.05,46.87,46.65,46.53,46.59,46.67,46.81,46.89
71.076 | Skin Tone | Color Piel | GU 5.1,253,192,140,82.37,15.56,34.75,7.02YR,8.32,6.02,60.98,D65/10°,SCI,UV400,27.05,30.78,30.26,28.86,28.42,28.58,29.52,32.26,34.95,36,38.39,43.57,50.01,54.74,56.08,55.82,57.59,64.63,75,83.69,87.92,89.18,89.49,89.53,89.61,89.69,90,90.65,91.08,91.51,91.85
71.076 | Skin Tone | Color Piel | GU 5.1,251,192,140,81.99,15.13,34.4,7.02YR,8.28,6.01,60.28,D65/10°,SCE,UV400,27.19,30.52,29.96,28.68,28.27,28.46,29.35,32.02,34.6,35.66,38.09,43.28,49.65,54.21,55.51,55.25,57.11,64.1,74.43,82.74,86.34,87.44,87.8,87.69,87.78,87.81,87.73,88.06,88.25,88.92,89.16
71.077 | Wood | Madera | GU 1.7,163,108,59,50.71,17.16,35.76,7.04YR,5.11,6.24,19.02,D65/10°,SCI,UV400,4.61,4.93,5.07,5.4,5.87,6.19,6.39,6.61,6.92,7.22,7.96,9.28,11.21,13.49,15.35,16.47,18.53,23.57,30.51,33.86,32.54,30.23,28.69,27.92,27.38,27.17,27.75,29.03,30.66,32.18,33.51
71.077 | Wood | Madera | GU 1.7,163,108,62,50.72,17.06,34.33,7.02YR,5.1,6.23,19.03,D65/10°,SCE,UV400,5.23,5.35,5.42,5.75,6.27,6.56,6.74,6.95,7.19,7.51,8.24,9.51,11.34,13.51,15.29,16.35,18.56,23.59,30.4,33.6,32.36,30.14,28.63,27.84,27.36,27.13,27.63,28.8,30.38,31.93,33.26
71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7,224,153,42,68.85,17.49,64.01,10.03YR,7,10.65,39.14,D65/10°,SCI,UV400,5.22,5.44,5.55,5.79,6.1,6.3,6.64,7.47,8.71,9.59,11.13,14.5,20.05,27.29,35.3,42.78,51.05,56.05,58.73,59.59,59.38,58.72,57.92,57.32,56.95,56.81,57.05,57.67,58.51,59.63,61.14
71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7,223,153,46,68.68,17.54,62.45,2.05Y,6.98,10,38.9,D65/10°,SCE,UV400,5.86,5.88,5.89,6.13,6.48,6.65,6.98,7.77,8.94,9.8,11.29,14.54,20.04,27.11,34.87,42.29,50.68,55.6,58.29,59.21,59,58.33,57.57,56.91,56.59,56.47,56.63,57.11,57.93,59.12,60.55
71.079 | Tan Earth | Tierra | GU 2.4,168,125,104,56.16,14.12,17.73,3.79YR,5.59,4.16,24.08,D65/10°,SCI,UV400,12.59,13.65,13.88,14.26,14.82,15.3,15.64,15.75,15.75,15.89,16.25,16.9,18.28,19.85,20.68,20.94,22.25,26.12,30.86,33.82,34.93,35.29,35.35,35.42,35.48,35.52,35.6,35.62,35.65,35.56,35.62
71.079 | Tan Earth | Tierra | GU 2.4,167,124,105,56.07,14,17.23,3.76YR,5.58,4.15,23.98,D65/10°,SCE,UV400,13.14,13.86,14.06,14.47,14.98,15.48,15.75,15.85,15.85,15.95,16.31,16.95,18.29,19.81,20.54,20.78,22.25,26.06,30.71,33.55,34.64,34.97,35.07,35.13,35.22,35.26,35.31,35.28,35.27,35.29,35.36
71.080 | Rust | Oxido | FS30111 | BS435 | GU 2.7,113,82,74,37.95,11.79,9.73,4.43YR,3.79,2.4,10.06,D65/10°,SCI,UV400,6.37,6.8,6.84,6.93,7.16,7.25,7.34,7.42,7.47,7.39,7.41,7.48,7.75,8.07,8.1,8.08,8.43,10.4,13.05,14.66,15.16,15.14,15,14.88,14.74,14.62,14.61,14.6,14.61,14.59,14.58
71.080 | Rust | Oxido | FS30111 | BS435 | GU 2.7,113,82,75,38.18,11.74,8.91,2.07YR,3.81,1.13,10.19,D65/10°,SCE,UV400,7.16,7.25,7.2,7.28,7.52,7.57,7.63,7.72,7.7,7.63,7.65,7.71,7.93,8.18,8.15,8.03,8.63,10.55,13.12,14.74,15.24,15.2,15.09,14.97,14.86,14.72,14.63,14.56,14.57,14.54,14.54
71.081 | Ochre | Ocre | GU 2.1,120,101,58,43.91,1.27,27.13,7.05Y,4.42,4.04,13.77,D65/10°,SCI,UV400,4.26,4.53,4.64,4.88,5.23,5.45,5.6,5.8,6.07,6.34,7.03,8.31,10.27,12.58,14.57,15.8,17.01,19.04,20.11,18.76,16.29,14.39,13.39,12.96,12.64,12.49,12.83,13.62,14.62,15.55,16.26
71.081 | Ochre | Ocre | GU 2.1,120,101,60,43.97,1.42,25.94,7.05Y,4.42,4.04,13.82,D65/10°,SCE,UV400,4.82,4.88,4.9,5.18,5.56,5.74,5.88,6.08,6.32,6.59,7.26,8.53,10.39,12.57,14.46,15.63,17.02,19,20.08,18.78,16.34,14.44,13.47,13.04,12.75,12.6,12.87,13.57,14.54,15.47,16.15
71.082 | Fluorescent Red | Rojo Fluorescente | FS38903 | RAL2005 | GU 2.5 | Fluorescent | Opacity 32.63%,254,58,32,56.35,71.12,59.23,7.03R,5.69,19.39,24.26,D65/10°,SCI,UV400,3.94,3.54,3.48,3.53,3.45,3.39,3.46,3.57,3.74,3.82,3.71,3.56,3.47,3.61,4.19,6.42,5.21,8.11,17.39,43.02,82.91,108.03,111.19,108.35,106.92,105.27,102.09,98.2,94.84,92.94,92.45
71.082 | Fluorescent Red | Rojo Fluorescente | FS38903 | RAL2005 | GU 2.5 | Fluorescent | Opacity 32.63%,253,59,35,56.42,70.87,58.05,7.02R,5.69,19.4,24.33,D65/10°,SCE,UV400,4.47,3.84,3.69,3.78,3.68,3.58,3.67,3.78,3.94,4.01,3.88,3.7,3.62,3.7,4.25,6.45,5.41,8.35,17.44,42.93,82.8,108.18,110.97,108.07,106.57,105.17,101.66,97.64,94.14,90.93,90.53
71.083 | Orange | Naranja | GU 2.5 | Opacity 64.68%,208,64,44,48.79,55.28,43.59,7.06R,4.92,13.89,17.42,D65/10°,SCI,UV400,3.49,3.64,3.69,3.77,3.82,3.87,4,4.09,4.14,4.18,4.44,4.92,5.65,6.2,6.23,6.13,6.58,8.53,13.87,26.01,44.55,61.02,71.04,76.3,79.46,81.59,83.1,84.09,84.38,84.51,84.95
71.083 | Orange | Naranja | GU 2.5 | Opacity 64.68%,207,65,46,48.8,54.79,42.45,7.04R,4.92,13.88,17.43,D65/10°,SCE,UV400,3.94,3.93,3.89,3.99,4.06,4.07,4.19,4.28,4.31,4.35,4.61,5.11,5.84,6.33,6.28,6.09,6.78,8.69,13.93,25.91,44.3,60.59,70.45,75.68,78.89,80.95,81.99,82.65,82.79,83.11,83.41
71.084 | Fire Red | Rojo Fuego | GU 3.1,125,63,54,34.51,25.57,17.77,8.46R,3.47,6.3,8.26,D65/10°,SCI,UV400,3.84,4.02,4.05,4.05,4.06,4.07,4.12,4.25,4.49,4.58,4.59,4.59,4.64,4.71,4.76,4.89,5.13,6.24,9.06,13.83,18.24,20.29,20.77,20.67,20.36,20.03,19.79,19.61,19.45,19.28,19.14
71.084 | Fire Red | Rojo Fuego | GU 3.1,125,64,55,34.63,25.47,17,8.50R,3.48,6.3,8.31,D65/10°,SCE,UV400,4.3,4.29,4.23,4.27,4.27,4.23,4.29,4.4,4.65,4.72,4.72,4.72,4.75,4.74,4.73,4.78,5.26,6.4,9.15,13.88,18.24,20.29,20.77,20.63,20.33,20.02,19.78,19.53,19.33,19.17,19.02
71.085 | Ferrari Red | Rojo Ferrari | GU 2.9 | Opacity 95.6%,155,59,51,38.7,39.41,25.6,7.01R,3.9,9.81,10.49,D65/10°,SCI,UV400,3.67,3.8,3.84,3.88,3.91,3.93,4.03,4.28,4.55,4.51,4.43,4.36,4.37,4.43,4.5,4.66,5.03,6.16,9.31,15.91,24.69,32.08,36.57,38.61,39.47,39.91,40.25,40.51,40.72,40.85,41.1
71.085 | Ferrari Red | Rojo Ferrari | GU 2.9 | Opacity 95.6%,155,60,53,38.79,39.01,24.64,7.03R,3.91,9.84,10.54,D65/10°,SCE,UV400,4.06,4.09,4.04,4.11,4.14,4.11,4.23,4.46,4.72,4.69,4.58,4.5,4.5,4.5,4.5,4.59,5.18,6.37,9.44,15.97,24.65,31.87,36.23,38.27,39.19,39.6,39.87,40.04,40.14,40.3,40.5
71.086 | Light Red | Rojo Claro | GU 3.2 | Opacity 68.56%,200,60,46,46.79,54.5,39.86,7.04R,4.72,13.48,15.86,D65/10°,SCI,UV400,3.69,3.82,3.86,3.89,3.92,3.93,4.02,4.09,4.11,4.15,4.35,4.69,5.17,5.54,5.57,5.58,6,7.55,11.91,21.75,38.23,55.03,66.51,72.85,76.63,79.27,81.23,82.6,83.18,83.56,84.16
71.086 | Light Red | Rojo Claro | GU 3.2 | Opacity 68.56%,199,61,48,46.77,54.08,38.77,7.03R,4.72,13.47,15.84,D65/10°,SCE,UV400,4.13,4.09,4.05,4.11,4.13,4.12,4.19,4.25,4.27,4.27,4.48,4.84,5.32,5.62,5.59,5.49,6.16,7.71,11.94,21.76,37.9,54.6,65.97,72.18,76.02,78.72,80.48,81.49,81.85,82.31,82.79
71.087 | Steel Blue | Azul Acero | RAL5013 | GU 2.3,50,57,74,24.35,1.3,-11.21,6.36PB,2.36,2.19,4.21,D65/10°,SCI,UV400,5.87,6.6,6.53,6.61,6.96,6.99,6.77,6.41,6.04,5.6,5.2,4.78,4.42,4.17,3.98,3.91,3.62,3.59,3.58,3.6,3.63,3.71,3.77,3.83,3.89,3.9,3.95,3.92,3.91,3.92,3.99
71.087 | Steel Blue | Azul Acero | RAL5013 | GU 2.3,50,58,76,24.72,1.54,-11.91,8.29PB,2.4,2.27,4.33,D65/10°,SCE,UV400,6.66,7.04,6.9,6.97,7.32,7.33,7.09,6.73,6.3,5.86,5.44,4.98,4.59,4.26,4,3.86,3.74,3.72,3.68,3.68,3.75,3.82,3.86,3.96,3.99,4,4.01,3.91,3.9,3.89,3.94
71.088 | French Blue | Azul Francés | GU 3.0,26,77,119,31.64,-1.24,-28.66,7.04PB,2.96,7.99,6.93,D65/10°,SCI,UV400,8.68,10.44,11.19,12.37,14.84,18.71,21.46,21.76,19.45,15.9,12.41,9.47,7.37,6.05,5.29,4.89,4.34,4.2,4.15,4.15,4.15,4.21,4.27,4.37,4.48,4.52,4.56,4.46,4.39,4.35,4.44
71.088 | French Blue | Azul Francés | GU 3.0,28,77,119,31.8,-1.16,-28.51,7.08PB,2.97,8.04,7,D65/10°,SCE,UV400,9.4,10.75,11.37,12.55,14.97,18.75,21.4,21.7,19.44,15.93,12.49,9.63,7.53,6.16,5.3,4.8,4.44,4.33,4.24,4.21,4.26,4.3,4.35,4.49,4.57,4.6,4.59,4.44,4.34,4.3,4.35
71.089 | Light Sea Blue | Azul Mar Claro | GU 3.5,0,156,203,59.34,-22.69,-35.17,10.09B,5.59,10.43,27.4,D65/10°,SCI,UV400,30.26,40.13,43.55,47.83,54.56,59.92,62.33,63.23,61.63,58.26,53.7,47.73,41.01,34.33,28.15,22.98,17.2,14.14,12.35,11.25,10.43,9.83,9.52,9.45,9.43,9.65,10.09,10.3,10.12,9.73,9.17
71.089 | Light Sea Blue | Azul Mar Claro | GU 3.5,0,156,202,59.13,-22.35,-34.92,10.09B,5.57,10.35,27.17,D65/10°,SCE,UV400,30.14,39.8,43.11,47.34,53.96,59.23,61.6,62.5,60.91,57.6,53.11,47.32,40.55,33.88,27.82,22.68,17.14,14.14,12.36,11.29,10.51,9.92,9.63,9.58,9.57,9.76,10.15,10.28,10.09,9.7,9.16
71.090 | Deep Sky | Azul Oscuro | FS35056 | GU 1.9,48,63,88,26.54,1.85,-17.13,7.08PB,2.55,4.06,4.93,D65/10°,SCI,UV400,6.92,8.13,8.2,8.64,9.71,10.29,10.04,9.43,8.57,7.58,6.64,5.81,5.15,4.76,4.48,4.34,4,3.94,3.9,3.9,3.93,3.98,4.01,4.06,4.11,4.12,4.18,4.13,4.15,4.11,4.18
71.090 | Deep Sky | Azul Oscuro | FS35056 | GU 1.9,49,63,89,26.81,1.93,-17.45,7.08PB,2.57,4.06,5.03,D65/10°,SCE,UV400,7.68,8.51,8.49,8.93,9.99,10.51,10.25,9.65,8.76,7.79,6.87,6.01,5.33,4.82,4.48,4.26,4.09,4.04,3.99,3.97,4.02,4.06,4.08,4.16,4.18,4.19,4.19,4.1,4.07,4.05,4.11
71.091 | Signal Blue | Azul Señal | FS35044 | RAL5004 | ANA605 | BS106 | GU 1.7,53,54,60,23.04,0.97,-3.88,7.18P,2.27,1.19,3.81,D65/10°,SCI,UV400,4.63,4.89,4.8,4.71,4.66,4.56,4.45,4.33,4.22,4.1,4,3.89,3.83,3.81,3.79,3.82,3.63,3.62,3.61,3.65,3.67,3.74,3.78,3.82,3.86,3.88,3.91,3.88,3.89,3.88,3.95
71.091 | Signal Blue | Azul Señal | FS35044 | RAL5004 | ANA605 | BS106 | GU 1.7,53,55,62,23.23,1.33,-4.73,6.59P,2.28,1.81,3.87,D65/10°,SCE,UV400,5.24,5.25,5.07,5,4.95,4.78,4.66,4.5,4.38,4.23,4.13,3.99,3.91,3.83,3.76,3.72,3.69,3.7,3.67,3.67,3.75,3.8,3.83,3.9,3.92,3.9,3.91,3.83,3.83,3.81,3.85
71.092 | Medium Olive | RAL6003 Olivgrün | RAL6003 | GU 1.9,85,85,65,35.84,-3.77,11.58,2.02GY,3.57,1.8,8.92,D65/10°,SCI,UV400,4.81,5.12,5.22,5.38,5.63,5.79,5.97,6.19,6.46,6.62,7.02,7.77,8.75,9.53,9.86,9.91,9.84,10.42,10.61,9.91,8.89,8.11,7.67,7.49,7.34,7.26,7.45,7.78,8.22,8.55,8.74
71.092 | Medium Olive | RAL6003 Olivgrün | RAL6003 | GU 1.9,86,86,67,36.13,-3.4,10.65,3.22GY,3.6,1.97,9.08,D65/10°,SCE,UV400,5.45,5.54,5.56,5.74,6,6.12,6.29,6.51,6.74,6.88,7.3,8.02,8.93,9.64,9.88,9.83,9.99,10.57,10.74,10.06,9.08,8.32,7.89,7.72,7.58,7.5,7.62,7.86,8.26,8.6,8.84
71.093 | Nato Green | Verde Otan | FS34094 | GU 2.0,78,86,71,35.73,-6.28,7.83,7.01GY,3.54,1.88,8.87,D65/10°,SCI,UV400,7.7,8.33,7.93,7.16,6.57,6.23,6.15,6.2,6.46,7.12,8.45,9.8,10.55,10.57,10.37,10.03,8.94,8.43,8.24,8.06,7.88,7.77,7.77,7.96,8.15,8.43,8.91,9.42,9.87,10.26,10.61
71.093 | Nato Green | Verde Otan | FS34094 | GU 2.0,80,87,73,36.07,-5.75,7.02,7.03GY,3.57,1.65,9.04,D65/10°,SCE,UV400,8.44,8.78,8.29,7.53,6.98,6.59,6.5,6.53,6.74,7.4,8.72,10.02,10.7,10.66,10.39,9.98,9.15,8.65,8.44,8.27,8.12,8.01,8.03,8.21,8.42,8.68,9.1,9.51,9.95,10.31,10.65
71.094 | Green Zinc Chromate | Verde Zinc | GU 2.0,78,87,54,35.64,-10,18.15,7.06GY,3.57,4.04,8.82,D65/10°,SCI,UV400,3.69,3.89,3.94,4.04,4.16,4.25,4.39,4.68,5.04,5.25,5.76,6.9,8.77,10.58,11.73,12.15,11.52,10.73,9.59,8.25,7.12,6.4,6.03,5.9,5.8,5.75,5.93,6.18,6.56,6.89,7.08
71.094 | Green Zinc Chromate | Verde Zinc | GU 2.0,79,88,56,35.93,-9.55,17.26,7.06GY,3.6,4.05,8.97,D65/10°,SCE,UV400,4.14,4.21,4.19,4.32,4.45,4.5,4.66,4.94,5.3,5.51,6.03,7.18,8.95,10.67,11.73,12.03,11.65,10.89,9.75,8.45,7.36,6.64,6.27,6.15,6.03,5.97,6.08,6.29,6.63,6.94,7.14
71.095 | Pale Green | Verde Pálido | RAL6011 | GU 2.4,113,130,84,52.14,-14.3,22.61,7.08GY,5.19,4.44,20.27,D65/10°,SCI,UV400,8.95,9.88,9.93,9.85,9.97,10.17,10.52,10.95,11.56,12.59,14.2,16.75,20.99,25.49,28.21,28.41,25.66,22.62,19.88,17.55,15.73,14.6,14.2,14.26,14.47,14.9,15.81,17.18,18.66,19.99,21.18
71.095 | Pale Green | Verde Pálido | RAL6011 | GU 2.4,114,130,86,52.14,-13.86,21.85,6.69GY,5.19,4.19,20.26,D65/10°,SCE,UV400,9.69,10.27,10.23,10.16,10.29,10.44,10.76,11.16,11.7,12.69,14.29,16.81,20.98,25.38,27.97,28.12,25.59,22.63,19.9,17.62,15.84,14.71,14.33,14.4,14.64,15.04,15.88,17.17,18.64,19.99,21.19
71.096 | Olive Grey | Verde Oliva Grisáceo | GU 4.6,75,83,77,34.65,-4.58,2.34,5.07G,3.42,2.68,8.32,D65/10°,SCI,UV400,7.44,7.78,7.71,7.56,7.54,7.49,7.6,7.78,7.95,7.97,8.16,8.54,8.93,9.1,9.12,9.08,8.68,8.55,8.29,7.89,7.49,7.15,6.9,6.8,6.69,6.64,6.71,6.84,7.01,7.12,7.11
71.096 | Olive Grey | Verde Oliva Grisáceo | GU 4.6,75,83,78,34.67,-4.2,1.8,5.93G,3.42,2.2,8.33,D65/10°,SCE,UV400,8.04,8.04,7.88,7.74,7.73,7.65,7.74,7.92,8.03,8.05,8.25,8.6,8.94,9.06,8.99,8.87,8.72,8.58,8.31,7.93,7.55,7.22,6.97,6.89,6.78,6.71,6.73,6.78,6.92,6.99,7.05
71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1,90,98,104,41.35,-1.75,-4.43,2.28PB,4.06,1.55,12.08,D65/10°,SCI,UV400,12.9,14.02,14.07,13.98,13.93,13.85,13.77,13.63,13.49,13.33,13.18,13.01,12.86,12.71,12.48,12.2,11.55,11.29,11.15,11.03,10.96,10.9,10.96,11.19,11.44,11.66,11.82,11.83,11.67,11.5,11.48
71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1,91,98,105,41.45,-1.44,-4.56,2.31PB,4.07,1.56,12.15,D65/10°,SCE,UV400,13.41,14.2,14.22,14.17,14.06,14,13.89,13.7,13.52,13.36,13.26,13.08,12.93,12.72,12.44,12.08,11.65,11.41,11.25,11.16,11.1,11.04,11.11,11.34,11.62,11.8,11.91,11.83,11.68,11.54,11.54
71.101 | Light Blue RLM78 | RLM78 Hellblau | RLM78 | GU 5.3,122,148,147,59.63,-9.29,-2.38,7.01BG,5.84,1.96,27.71,D65/10°,SCI,UV400,25.11,28.88,29.28,28.93,28.79,28.87,29.11,29.8,30.3,30.31,30.55,31.06,31.37,31.19,30.6,29.74,28.01,26.6,25.28,24.02,22.7,21.61,21.02,20.79,20.61,20.64,21.05,21.46,21.66,21.6,21.28
71.101 | Light Blue RLM78 | RLM78 Hellblau | RLM78 | GU 5.3,123,148,147,59.53,-9.04,-2.3,7.01BG,5.83,1.96,27.61,D65/10°,SCE,UV400,25.36,28.72,29,28.73,28.63,28.74,28.96,29.64,30.13,30.15,30.41,30.92,31.21,30.96,30.32,29.45,27.92,26.55,25.24,24.02,22.8,21.73,21.13,20.86,20.7,20.75,21.1,21.44,21.61,21.55,21.26
71.102 | Red | Rojo | GU 3.6 | Opacity 91.71%,139,51,54,34.4,37.51,18.06,5.03R,3.48,9.27,8.2,D65/10°,SCI,UV400,3.95,4.07,4.09,4.09,4.08,4.06,4.05,4.05,4.1,4.1,4.13,4.17,4.28,4.41,4.42,4.47,4.53,4.83,5.33,6.63,10.21,16.82,25.98,37.31,49.78,59.49,64.45,66.29,66.68,66.66,66.87
71.102 | Red | Rojo | GU 3.6 | Opacity 91.71%,138,50,54,34.17,37.64,17.59,5.02R,3.45,9.21,8.09,D65/10°,SCE,UV400,4.28,4.19,4.11,4.11,4.12,4.07,4.06,4.06,4.05,4.07,4.09,4.11,4.22,4.28,4.25,4.22,4.48,4.81,5.3,6.62,10.16,16.63,25.73,36.8,49.36,58.94,63.75,65.43,65.73,65.81,65.96
71.103 | Grey Blue RLM84 | RLM84 Graublau | FS36559 | RLM84 | GU 1.7,155,157,144,64.49,-3.42,6.54,10.07GY,6.37,2.81,33.4,D65/10°,SCI,UV400,22.21,26.19,27.16,27.77,28.52,29.08,29.25,29.46,29.81,30.49,31.48,32.64,33.99,35.04,35.57,35.63,34.92,34.21,33.45,32.83,32.39,32.15,32.07,32.18,32.36,32.66,33.1,33.49,33.77,33.9,34.09
71.103 | Grey Blue RLM84 | RLM84 Graublau | FS36559 | RLM84 | GU 1.7,154,157,144,64.28,-3.27,6.42,10.07GY,6.35,2.84,33.14,D65/10°,SCE,UV400,22.56,26.09,26.93,27.6,28.38,28.95,29.09,29.3,29.66,30.33,31.3,32.46,33.72,34.69,35.17,35.18,34.61,33.95,33.2,32.62,32.23,32,31.97,32.05,32.27,32.54,32.93,33.23,33.51,33.66,33.81
71.104 | Green RLM62 | RLM62 Grün | RLM62 | GU 3.4,93,96,71,39.86,-5.92,13.87,2.07GY,3.97,1.28,11.17,D65/10°,SCI,UV400,7.12,7.64,7.45,7.02,6.79,6.65,6.68,6.8,7.07,7.55,8.29,9.45,11.4,13.28,14.15,14.09,12.92,11.83,10.89,10.24,9.94,9.88,9.97,10.27,10.62,11.11,11.73,12.37,12.86,13.29,13.72
71.104 | Green RLM62 | RLM62 Grün | RLM62 | GU 3.4,92,95,72,39.71,-5.56,13.1,2.05GY,3.96,1.46,11.08,D65/10°,SCE,UV400,7.66,7.86,7.6,7.2,6.95,6.8,6.82,6.9,7.14,7.61,8.34,9.47,11.31,13.09,13.9,13.77,12.8,11.75,10.81,10.2,9.93,9.84,9.96,10.26,10.63,11.09,11.63,12.17,12.68,13.11,13.53
71.105 | Brown RLM26 | RLM26 Braun | RLM26 | GU 2.6,134,63,53,35.94,29.14,20.1,8.16R,3.63,7.16,8.98,D65/10°,SCI,UV400,3.95,4.18,4.2,4.22,4.2,4.16,4.16,4.17,4.19,4.18,4.23,4.25,4.32,4.5,4.7,5.11,5.98,7.89,10.92,14.73,18.47,21.29,23.26,24.67,25.75,26.91,28.28,29.79,31.5,33.36,35.42
71.105 | Brown RLM26 | RLM26 Braun | RLM26 | GU 2.6,134,64,55,36.17,28.9,19.14,7.04R,3.65,7.33,9.1,D65/10°,SCE,UV400,4.52,4.54,4.47,4.49,4.49,4.41,4.41,4.39,4.39,4.37,4.4,4.42,4.49,4.59,4.75,5.07,6.21,8.11,11.05,14.83,18.53,21.37,23.31,24.64,25.74,26.86,28.13,29.54,31.22,33.09,35.12
71.106 | Ivory RLM05 | RLM05 Elfenbein | GU 6.3,196,170,101,70.58,0.28,38.93,7.04Y,7.1,6.04,41.58,D65/10°,SCI,UV400,15.74,16.17,15.73,15.2,15.08,15.11,15.59,17.69,20.75,22.24,24.27,29.18,36.68,43,45.48,45.52,46.27,49.95,53.5,52.99,49.63,46.56,44.79,44.05,43.58,43.37,44.06,45.68,47.58,49.18,50.25
71.106 | Ivory RLM05 | RLM05 Elfenbein | GU 6.3,195,169,100,70.24,0.44,38.57,5.05Y,7.06,5.51,41.09,D65/10°,SCE,UV400,15.82,16.08,15.72,15.15,15.01,15.04,15.49,17.54,20.53,22,23.99,28.84,36.09,42.4,44.83,44.86,45.74,49.48,52.88,52.42,49.19,46.09,44.36,43.58,43.16,42.9,43.51,45.06,46.86,48.47,49.55
71.107 | US Interior Yellow | US Amarillo Inter. | GU 3.0,198,156,85,66.95,7.76,42.38,2.05Y,6.73,6.04,36.56,D65/10°,SCI,UV400,11.6,11.8,11.45,11.16,11.29,11.47,12.06,13.8,15.79,16.83,18.77,22.95,28.82,34.04,36.54,37.14,38.98,44.52,50.77,52.43,50.14,47.43,45.77,45,44.48,44.24,44.93,46.51,48.32,49.88,50.99
71.107 | US Interior Yellow | US Amarillo Inter. | GU 3.0,198,155,86,66.75,7.91,41.6,2.04Y,6.71,6.03,36.31,D65/10°,SCE,UV400,12.18,12.06,11.64,11.42,11.51,11.69,12.24,13.84,15.88,16.9,18.81,22.93,28.66,33.69,36.07,36.61,38.61,44.26,50.42,52.08,49.85,47.17,45.52,44.72,44.25,44,44.58,46.07,47.78,49.37,50.46
71.108 | Uk Azure Blue | Uk Azul Azure | FS35231 | ANA609 | GU 3.1,94,132,166,53.86,-4.38,-21.9,5.04PB,5.19,5.97,21.85,D65/10°,SCI,UV400,27.46,34.03,35.52,36.21,36.87,37.08,36.85,36.67,35.79,33.46,30.59,27.77,24.91,22.78,21.62,20.65,18.55,17.22,16.67,16.6,16.34,15.73,15.19,15.09,15.49,16.37,17.5,18.15,17.98,17.4,16.51
71.108 | Uk Azure Blue | Uk Azul Azure | FS35231 | ANA609 | GU 3.1,94,132,165,53.81,-4.21,-21.62,5.04PB,5.19,5.9,21.79,D65/10°,SCE,UV400,27.57,33.75,35.19,35.9,36.62,36.83,36.54,36.37,35.45,33.17,30.43,27.68,24.83,22.68,21.48,20.48,18.56,17.26,16.73,16.68,16.45,15.81,15.29,15.21,15.63,16.49,17.57,18.12,17.95,17.35,16.46
71.109 | Faded P.R.U. Blue | M485 Blue Gray | FS35189 | BS636 | GU 1.6,95,122,128,49.61,-8.39,-6.44,5.04B,4.84,2.39,18.09,D65/10°,SCI,UV400,19.3,21.57,21.75,21.46,21.28,21.23,21.22,21.42,21.55,21.41,21.36,21.36,21.21,20.76,20.08,19.18,17.43,16.21,15.24,14.55,14.01,13.57,13.35,13.32,13.32,13.48,13.78,13.86,13.63,13.23,12.74
71.109 | Faded P.R.U. Blue | M485 Blue Gray | FS35189 | BS636 | GU 1.6,95,122,128,49.56,-8.19,-6.42,5.04B,4.84,2.37,18.05,D65/10°,SCE,UV400,19.63,21.55,21.63,21.38,21.26,21.2,21.15,21.34,21.49,21.38,21.34,21.33,21.15,20.67,19.91,18.95,17.43,16.21,15.26,14.6,14.09,13.63,13.43,13.4,13.42,13.56,13.79,13.8,13.56,13.2,12.76
71.110 | Dark Grey | Gris Oscuro | BS640 | GU 3.7,79,87,93,36.74,-2.14,-4.33,8.94BG,3.61,2.29,9.4,D65/10°,SCI,UV400,10.58,11.33,11.31,11.11,10.97,10.82,10.71,10.56,10.44,10.29,10.17,10.05,9.96,9.88,9.78,9.69,9.22,9.01,8.78,8.57,8.44,8.33,8.2,8.15,8.08,8.04,8.1,8.11,8.1,8.01,7.9
71.110 | Dark Grey | Gris Oscuro | BS640 | GU 3.7,80,88,94,37.07,-1.83,-4.5,9.04BG,3.64,2.36,9.57,D65/10°,SCE,UV400,11.27,11.66,11.56,11.4,11.24,11.07,10.95,10.8,10.64,10.49,10.4,10.27,10.14,10,9.83,9.68,9.43,9.22,8.97,8.78,8.67,8.56,8.45,8.41,8.34,8.3,8.31,8.23,8.18,8.1,7.99
71.111 | USAF Light Blue | USAF Azul Claro | FS35109 | GU 2.1,64,97,115,39.63,-6.95,-13.55,10.05B,3.84,3.61,11.03,D65/10°,SCI,UV400,13.99,15.66,15.98,16.3,16.66,16.85,16.75,16.53,16.13,15.6,14.96,14.22,13.3,12.46,11.82,11.16,9.73,8.88,8.35,8.02,7.74,7.44,7.22,7.21,7.25,7.47,7.85,8.03,7.95,7.73,7.35
71.111 | USAF Light Blue | USAF Azul Claro | FS35109 | GU 2.1,66,97,115,39.85,-6.45,-13.51,2.06PB,3.86,3.7,11.16,D65/10°,SCE,UV400,14.31,15.86,16.23,16.5,16.85,16.99,16.87,16.63,16.26,15.68,15.05,14.29,13.39,12.51,11.82,11.1,9.93,9.09,8.55,8.24,7.99,7.68,7.47,7.47,7.54,7.74,8.04,8.13,8.04,7.8,7.45
71.112 | Sand | Arena | GU 3.5,154,131,121,56.86,6.92,8.92,3.88YR,5.62,1.9,24.78,D65/10°,SCI,UV400,16.27,17.86,18.26,18.84,19.65,20.23,20.37,20.43,20.47,20.47,20.7,21.11,21.86,22.7,23.04,22.99,23.54,25.94,28.75,30.23,30.59,30.56,30.36,30.17,29.98,29.82,29.76,29.69,29.63,29.52,29.51
71.112 | Sand | Arena | GU 3.5,154,131,121,56.79,6.94,8.69,3.86YR,5.62,1.91,24.71,D65/10°,SCE,UV400,16.6,17.94,18.4,18.9,19.75,20.3,20.39,20.46,20.48,20.53,20.75,21.15,21.84,22.61,22.88,22.79,23.52,25.91,28.67,30.11,30.47,30.46,30.28,30.08,29.93,29.75,29.62,29.46,29.39,29.34,29.29
71.113 | IDF Blue | Azul IDF | FS35177 | GU 2.4,69,110,126,44.2,-9.4,-13.76,7.90B,4.28,4.2,13.98,D65/10°,SCI,UV400,17.58,20.05,20.44,20.5,20.55,20.6,20.45,20.3,20.04,19.55,18.93,18.13,17.39,16.56,15.52,14.3,12.37,11.27,10.47,9.85,9.3,8.86,8.62,8.57,8.54,8.73,9.13,9.33,9.18,8.85,8.32
71.113 | IDF Blue | Azul IDF | FS35177 | GU 2.4,70,110,127,44.34,-9.03,-13.63,10.06B,4.3,3.88,14.08,D65/10°,SCE,UV400,17.94,20.12,20.45,20.49,20.64,20.65,20.49,20.36,20.12,19.65,19.01,18.21,17.45,16.6,15.49,14.18,12.5,11.45,10.64,10.04,9.53,9.1,8.87,8.82,8.82,9,9.35,9.44,9.28,8.95,8.43
71.114 | Medium Gray | Gris Medio | FS35237 | GU 4.2,111,127,130,52.23,-4.97,-3.67,10.05BG,5.11,2.61,20.35,D65/10°,SCI,UV400,19.99,22.61,22.85,22.52,22.29,22.21,22.17,22.27,22.29,22.12,22.08,22.13,22.16,22.01,21.67,21.21,20.19,19.53,18.89,18.31,17.77,17.29,17,16.86,16.74,16.75,16.92,17.01,16.92,16.67,16.36
71.114 | Medium Gray | Gris Medio | FS35237 | GU 4.2,112,127,130,52.22,-4.81,-3.65,10.06BG,5.11,2.64,20.34,D65/10°,SCE,UV400,20.43,22.6,22.76,22.47,22.31,22.21,22.16,22.27,22.27,22.14,22.11,22.17,22.15,21.95,21.54,21.05,20.21,19.56,18.92,18.37,17.86,17.37,17.08,16.97,16.87,16.88,17.01,17,16.88,16.65,16.3
71.115 | Blue Grey | RAL7016 Blaugrau | RAL7016 | GU 2.0,64,72,75,30.3,-2.84,-2.59,5.12BG,2.98,2.99,6.36,D65/10°,SCI,UV400,6.36,6.94,7,7.03,7.04,7.02,7.02,6.97,6.95,6.89,6.87,6.83,6.84,6.82,6.79,6.72,6.23,6.03,5.84,5.72,5.6,5.55,5.49,5.49,5.51,5.51,5.62,5.61,5.63,5.56,5.48
71.115 | Blue Grey | RAL7016 Blaugrau | RAL7016 | GU 2.0,65,73,77,30.78,-2.49,-3.09,7.20BG,3.03,1.41,6.56,D65/10°,SCE,UV400,7.19,7.42,7.38,7.37,7.44,7.37,7.35,7.28,7.22,7.17,7.15,7.11,7.06,6.99,6.86,6.71,6.47,6.27,6.05,5.91,5.84,5.76,5.7,5.73,5.71,5.72,5.76,5.7,5.65,5.58,5.49
71.116 | Camouflage Grey Green | RAL7008 Graugrün | RAL7008 | GU 2.3,118,99,72,43.36,3.41,18.15,2.10Y,4.33,2.12,13.4,D65/10°,SCI,UV400,5.91,6.37,6.49,6.74,7.12,7.35,7.57,7.88,8.23,8.47,9.04,10.11,11.5,12.76,13.45,13.67,14.04,15.48,16.81,17.08,16.63,16.05,15.63,15.43,15.24,15.13,15.25,15.57,15.89,16.13,16.3
71.116 | Camouflage Grey Green | RAL7008 Graugrün | RAL7008 | GU 2.3,118,99,74,43.48,3.6,17.11,3.12Y,4.34,1.88,13.48,D65/10°,SCE,UV400,6.71,6.86,6.88,7.11,7.49,7.7,7.89,8.18,8.48,8.72,9.3,10.31,11.63,12.8,13.38,13.52,14.12,15.54,16.87,17.16,16.73,16.13,15.74,15.54,15.37,15.26,15.31,15.52,15.85,16.07,16.22
71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0,171,137,108,59.8,8.32,20.71,6.94YR,5.95,3.99,27.9,D65/10°,SCI,UV400,11.83,13.08,13.6,14.57,15.97,16.98,17.42,17.75,18.12,18.63,19.55,20.89,22.7,24.71,26.16,26.9,28.21,31.33,34.85,36.48,36.67,36.42,36.03,35.73,35.47,35.28,35.3,35.45,35.65,35.75,35.91
71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0,170,137,108,59.67,8.26,20.18,6.92YR,5.94,3.98,27.75,D65/10°,SCE,UV400,12.43,13.3,13.76,14.78,16.16,17.13,17.51,17.83,18.2,18.71,19.61,20.94,22.67,24.57,25.95,26.63,28.11,31.2,34.53,36.19,36.4,36.11,35.74,35.44,35.24,35.04,35.02,35.09,35.29,35.49,35.65
71.118 | Camouflage Grey | RAL7027 Grau | RAL7027 | GU 2.7,134,116,91,50.02,3.1,16.22,4.99Y,4.97,2.46,18.44,D65/10°,SCI,UV400,10.71,11.12,10.93,10.81,11.01,11.21,11.59,12.29,12.85,13.02,13.66,14.94,16.52,17.76,18.11,17.94,18.45,20.91,23.39,23.75,22.57,21.24,20.43,20.05,19.75,19.56,19.81,20.46,21.24,21.8,22.18
71.118 | Camouflage Grey | RAL7027 Grau | RAL7027 | GU 2.7,134,116,92,50.02,3.3,15.72,2.06Y,4.97,1.2,18.43,D65/10°,SCE,UV400,11.29,11.39,11.15,11.05,11.24,11.42,11.75,12.39,12.88,13.06,13.72,14.97,16.55,17.75,18.03,17.74,18.44,20.93,23.34,23.74,22.62,21.29,20.47,20.08,19.76,19.61,19.85,20.42,21.13,21.74,22.13
71.119 | White Grey | RAL9002 Grauweiss | RAL9002 | GU 5.2,204,204,195,82,-1.42,4.48,5.07R,8.18,2.98,60.3,D65/10°,SCI,UV400,36.61,48.98,52.86,54.15,55.37,56.23,56.55,56.81,56.98,57.29,58,58.9,59.9,60.83,61.47,61.94,61.8,61.72,61.4,61.02,60.58,60.21,59.86,59.63,59.42,59.21,59.16,59.24,59.27,59.27,59.24
71.119 | White Grey | RAL9002 Grauweiss | RAL9002 | GU 5.2,204,203,194,81.73,-1.33,4.57,5.07R,8.16,2.97,59.79,D65/10°,SCE,UV400,36.55,48.23,52.26,53.5,54.86,55.67,56,56.22,56.42,56.75,57.47,58.41,59.39,60.23,60.87,61.26,61.26,61.23,60.95,60.63,60.23,59.82,59.53,59.24,59.09,58.88,58.74,58.68,58.69,58.73,58.68
71.120 | Dark Ghost Gray | Gris Oscuro USAF | FS36320 | GU 5.9,132,149,158,60.96,-4.41,-6.42,10.01B,5.96,2.12,29.2,D65/10°,SCI,UV400,26.62,32.5,33.68,33.84,33.92,34.01,33.86,33.66,33.31,32.93,32.56,32.07,31.67,31.26,30.57,29.67,28.11,27.38,26.84,26.29,25.66,25.08,24.82,24.86,24.97,25.28,25.72,25.83,25.46,24.89,24.23
71.120 | Dark Ghost Gray | Gris Oscuro USAF | FS36320 | GU 5.9,132,149,157,60.82,-4.25,-6.26,10.01B,5.95,2.07,29.05,D65/10°,SCE,UV400,26.81,32.21,33.35,33.52,33.67,33.74,33.56,33.35,33,32.67,32.34,31.88,31.49,31.06,30.3,29.34,28.02,27.32,26.77,26.23,25.63,25.09,24.85,24.85,25.01,25.29,25.67,25.68,25.29,24.78,24.16
71.121 | Light Gull Gray | Gris Gaviota USN | FS36440 | ANA620 | GU 2.6,165,167,159,68.37,-2.1,3.99,2.81G,6.76,1.54,38.47,D65/10°,SCI,UV400,26.52,31.54,32.94,33.91,35.11,35.96,36.17,36.24,36.32,36.58,37.14,37.84,38.58,39.22,39.65,39.88,39.57,39.28,38.9,38.52,38.13,37.83,37.53,37.3,37.09,37,37,36.93,36.83,36.52,36.29
71.121 | Light Gull Gray | Gris Gaviota USN | FS36440 | ANA620 | GU 2.6,165,166,158,68.09,-2,3.94,2.90G,6.73,1.61,38.09,D65/10°,SCE,UV400,26.68,31.27,32.57,33.59,34.83,35.68,35.84,35.9,35.96,36.2,36.78,37.48,38.19,38.8,39.19,39.35,39.18,38.94,38.57,38.2,37.84,37.5,37.21,36.97,36.81,36.68,36.62,36.5,36.37,36.2,35.98
71.122 | US Desert Armour 686 | US Camuflaje Moderno 686 | FS33446 | ANA620 | GU 8.0,175,153,129,64.73,4.57,15.41,2.05Y,6.43,1.19,33.71,D65/10°,SCI,UV400,19.34,21.38,21.84,22.22,22.97,23.62,24.01,24.7,25.34,25.64,26.43,27.99,30.08,31.93,32.59,32.47,33.48,37.29,41.48,42.54,40.91,39,37.74,37.13,36.7,36.45,36.83,37.78,38.97,39.9,40.61
71.122 | US Desert Armour 686 | US Camuflaje Moderno 686 | FS33446 | ANA620 | GU 8.0,174,152,129,64.34,4.58,15.26,2.04Y,6.39,1.23,33.22,D65/10°,SCE,UV400,19.43,21.15,21.49,21.89,22.71,23.34,23.69,24.39,24.99,25.32,26.1,27.64,29.68,31.45,32.04,31.88,32.97,36.71,40.94,42.02,40.4,38.44,37.21,36.57,36.18,35.91,36.21,37.08,38.2,39.16,39.89
71.123 | Dark Grey RLM42 | RLM42 Dunkelgrau | RLM42 | GU 3.2,87,90,90,38.25,-1.35,-0.57,10.14G,3.77,3.5,10.23,D65/10°,SCI,UV400,9.81,10.56,10.62,10.51,10.5,10.41,10.36,10.29,10.29,10.3,10.36,10.42,10.53,10.6,10.61,10.58,10.23,10.09,9.94,9.8,9.76,9.75,9.7,9.73,9.73,9.76,9.83,9.88,9.9,9.89,9.88
71.123 | Dark Grey RLM42 | RLM42 Dunkelgrau | RLM42 | GU 3.2,87,90,91,38.27,-1.07,-0.89,2.14BG,3.77,1.03,10.24,D65/10°,SCE,UV400,10.32,10.78,10.73,10.67,10.63,10.54,10.48,10.38,10.34,10.35,10.43,10.49,10.55,10.56,10.5,10.39,10.26,10.14,9.96,9.85,9.83,9.8,9.77,9.81,9.82,9.83,9.87,9.82,9.84,9.85,9.84
71.124 | USAF Green | Verde USAF | FS34092-ANA612 | GU 2.7,68,84,75,34.37,-8.25,2.9,5.01G,3.39,2.14,8.19,D65/10°,SCI,UV400,7.01,7.36,7.26,7.12,7.14,7.13,7.32,7.65,7.93,8,8.32,8.93,9.53,9.74,9.62,9.37,8.52,7.98,7.48,6.99,6.56,6.24,6.04,5.99,5.95,5.96,6.13,6.3,6.42,6.43,6.35
71.124 | USAF Green | Verde USAF | FS34092-ANA612 | GU 2.7,69,84,77,34.57,-7.78,2.31,7.02G,3.41,1.85,8.29,D65/10°,SCE,UV400,7.69,7.72,7.54,7.38,7.42,7.4,7.57,7.87,8.12,8.19,8.5,9.09,9.62,9.77,9.59,9.26,8.66,8.13,7.59,7.12,6.72,6.4,6.2,6.17,6.11,6.12,6.24,6.31,6.42,6.41,6.33
71.125 | USAF Brown | Marrón USAF | FS30219 | ANA628 | GU 2.6,135,108,86,47.76,7.43,16.18,6.30YR,4.76,2.98,16.6,D65/10°,SCI,UV400,8.34,8.96,9.11,9.4,9.89,10.25,10.53,10.89,11.23,11.38,11.84,12.68,13.78,14.81,15.23,15.23,15.92,18.56,21.41,22.59,22.29,21.6,21.11,20.87,20.63,20.5,20.65,21.06,21.48,21.79,21.96
71.125 | USAF Brown | Marrón USAF | FS30219 | ANA628 | GU 2.6,135,108,87,47.84,7.62,15.49,3.98YR,4.76,3.66,16.67,D65/10°,SCE,UV400,9.1,9.41,9.46,9.73,10.23,10.53,10.79,11.11,11.37,11.54,12.03,12.79,13.86,14.83,15.19,15.12,16,18.58,21.45,22.65,22.4,21.71,21.22,20.94,20.72,20.6,20.74,21.04,21.43,21.76,21.98
71.126 | IDF/IAF Green | Verde IDF/IAF | FS34227 | BS283 | GU 4.1,115,126,105,51.62,-8.55,10.08,7.03GY,5.1,1.58,19.81,D65/10°,SCI,UV400,13.21,14.09,14.05,14.01,14.25,14.53,15.03,16.02,16.97,17.38,18.21,19.67,21.2,22.12,22.35,22.2,21.65,21.41,20.78,19.47,17.85,16.49,15.71,15.35,15.08,14.92,15.18,15.78,16.5,17.06,17.43
71.126 | IDF/IAF Green | Verde IDF/IAF | FS34227 | BS283 | GU 4.1,115,126,106,51.62,-8.28,9.76,7.02GY,5.1,1.66,19.81,D65/10°,SCE,UV400,13.73,14.3,14.2,14.19,14.41,14.69,15.14,16.13,17.06,17.47,18.25,19.72,21.18,22.03,22.19,22.02,21.66,21.43,20.79,19.53,17.92,16.57,15.81,15.47,15.22,15.06,15.23,15.75,16.44,17.01,17.37
71.128 | Gris Violeta | Gray Violet | FS36134 | GU 4.0,99,100,95,42.39,-1.34,2.7,2.12G,4.19,0.7,12.76,D65/10°,SCI,UV400,10.52,11.19,11.3,11.43,11.69,11.79,11.86,11.94,12,12.03,12.21,12.53,12.84,13.06,13.17,13.25,13.04,13.01,12.92,12.78,12.7,12.6,12.47,12.39,12.26,12.17,12.15,12.09,12.05,11.97,11.92
71.128 | Gris Violeta | Gray Violet | FS36134 | GU 4.0,99,100,95,42.26,-1.06,2.38,5.13G,4.17,3.43,12.67,D65/10°,SCE,UV400,10.96,11.36,11.37,11.51,11.72,11.84,11.87,11.92,11.95,11.99,12.19,12.47,12.76,12.93,12.98,12.95,12.95,12.95,12.85,12.75,12.68,12.55,12.44,12.37,12.28,12.18,12.09,11.96,11.93,11.89,11.86
71.129 | Light Rust | Óxido Claro | GU 3.2,146,92,68,44.68,19.26,22.74,3.60YR,4.48,5.29,14.31,D65/10°,SCI,UV400,5.09,5.52,5.73,6.08,6.62,6.92,7.12,7.3,7.54,7.74,8.1,8.58,9.29,10.04,10.56,10.95,12.01,14.94,19.23,22.87,24.97,25.84,26.12,26.2,26.19,26.25,26.41,26.59,26.83,27.01,27.3
71.129 | Light Rust | Óxido Claro | GU 3.2,145,92,70,44.78,19.16,21.64,3.58YR,4.49,5.25,14.38,D65/10°,SCE,UV400,5.8,5.96,6.05,6.43,6.98,7.27,7.43,7.6,7.78,7.98,8.34,8.81,9.44,10.13,10.56,10.85,12.11,15,19.23,22.9,24.94,25.79,26.08,26.14,26.17,26.2,26.31,26.4,26.58,26.85,27.12
71.130 | Orange Rust | Óxido Aanaranjado | RAL2010 | GU 4.5,180,95,54,49.85,30.9,38.36,2.07YR,5,8.06,18.29,D65/10°,SCI,UV400,3.99,4.13,4.19,4.28,4.36,4.41,4.66,5.75,8.57,10.43,10.55,10.21,10.18,10.4,10.41,10.42,11.58,15.62,23.07,31.84,38.47,42.41,44.48,45.66,46.52,47.43,48.6,50.05,51.67,53.57,55.77
71.130 | Orange Rust | Óxido Aanaranjado | RAL2010 | GU 4.5,179,95,55,49.8,30.68,37.29,2.06YR,5,8.05,18.25,D65/10°,SCE,UV400,4.44,4.42,4.38,4.49,4.59,4.61,4.88,5.98,8.75,10.54,10.68,10.34,10.27,10.42,10.36,10.29,11.63,15.62,23.01,31.6,38.17,42.08,44.18,45.34,46.26,47.15,48.21,49.56,51.09,53.01,55.14
71.131 | Concrete | Cemento | GU 3.4,116,107,93,45.86,1.33,8.94,3.46GY,4.55,1.7,15.17,D65/10°,SCI,UV400,9.12,9.92,10.2,10.67,11.41,11.85,12.06,12.22,12.39,12.55,12.93,13.5,14.17,14.81,15.17,15.32,15.47,16.27,16.92,17.06,16.95,16.75,16.54,16.4,16.24,16.09,16.05,16.08,16.1,16.06,16.08
71.131 | Concrete | Cemento | GU 3.4,117,107,94,45.9,1.57,8.49,3.46GY,4.55,1.65,15.2,D65/10°,SCE,UV400,9.82,10.28,10.46,10.94,11.63,12.05,12.21,12.33,12.45,12.62,13.03,13.55,14.2,14.8,15.11,15.18,15.52,16.31,16.95,17.12,17.03,16.81,16.6,16.48,16.33,16.2,16.11,16.02,16.03,16.04,16.02
71.132 | Aged White | Blanco Envejecido | FS37769 | RAL1015 | GU 4.9,220,203,172,82.45,1.36,17.71,5.61Y,8.28,1.99,61.13,D65/10°,SCI,UV400,30.25,37.02,39.04,40.6,42.72,44.4,45.22,45.9,46.64,47.57,49.36,51.99,55.29,58.94,62.17,64.57,66.45,68.29,69.28,68.85,67.47,66.02,65.06,64.49,64.1,63.83,64.15,64.87,65.72,66.46,67.11
71.132 | Aged White | Blanco Envejecido | FS37769 | RAL1015 | GU 4.9,220,202,171,82.17,1.44,17.56,5.04Y,8.25,2.39,60.61,D65/10°,SCE,UV400,30.24,36.76,38.69,40.26,42.46,44.15,44.9,45.63,46.32,47.28,49.02,51.59,54.81,58.34,61.56,63.86,65.85,67.7,68.68,68.3,66.92,65.52,64.62,64.04,63.72,63.51,63.68,64.3,65.07,65.87,66.38
71.133 | Dirt | Suciedad | GU 6.0,118,95,66,42.01,5.49,20,2.13Y,4.21,1.29,12.51,D65/10°,SCI,UV400,4.93,5.24,5.4,5.73,6.2,6.4,6.54,6.72,7,7.25,7.79,8.72,9.97,11.2,12,12.33,12.78,14.74,17.35,18.11,16.97,15.59,14.74,14.29,13.96,13.74,13.89,14.38,14.98,15.54,15.92
71.133 | Dirt | Suciedad | GU 6.0,118,94,67,41.82,5.65,19.15,2.13Y,4.19,1.34,12.38,D65/10°,SCE,UV400,5.35,5.45,5.53,5.88,6.35,6.55,6.66,6.82,7.05,7.29,7.84,8.73,9.89,11.05,11.76,12,12.65,14.59,17.16,17.93,16.82,15.44,14.61,14.17,13.85,13.63,13.71,14.09,14.71,15.25,15.63
71.134 | IJA Midouri Green | IJA Verde Midouri | GU 5.3,64,74,59,30.29,-7.15,7.33,7.03GY,3.01,1.66,6.35,D65/10°,SCI,UV400,4.12,4.34,4.4,4.51,4.63,4.68,4.76,4.9,5.06,5.16,5.47,6.04,6.86,7.51,7.83,7.83,7.2,6.75,6.22,5.69,5.23,5,4.87,4.8,4.79,4.77,4.89,4.98,5.18,5.25,5.37
71.134 | IJA Midouri Green | IJA Verde Midouri | GU 5.3,65,74,61,30.56,-6.88,6.68,10.02GY,3.04,2.17,6.47,D65/10°,SCE,UV400,4.64,4.65,4.64,4.76,4.88,4.9,4.99,5.1,5.24,5.35,5.65,6.24,7.02,7.6,7.81,7.73,7.36,6.92,6.36,5.81,5.39,5.11,4.95,4.92,4.87,4.85,4.91,4.95,5.11,5.22,5.28
71.135 | IJA Chrome Yellow | IJA Amarillo Cromado | FS33655 | RAL1003 | GU 3.4 | Opacity 67.5%,243,159,0,72.31,22.1,78.71,10.01YR,7.4,12.87,44.12,D65/10°,SCI,UV400,3.93,4.01,4.04,4.15,4.17,4.21,4.42,5.09,6.6,7.68,8.88,11.98,18.23,27.73,38.8,49.15,59.53,65.2,68.29,69.76,69.9,69.51,69.19,69.09,69.37,69.81,70.43,71.16,71.84,72.68,73.96
71.135 | IJA Chrome Yellow | IJA Amarillo Cromado | FS33655 | RAL1003 | GU 3.4 | Opacity 67.5%,242,158,0,72.09,22.01,77.19,10.01YR,7.37,12.71,43.79,D65/10°,SCE,UV400,4.41,4.33,4.28,4.38,4.43,4.43,4.63,5.35,6.86,7.91,9.11,12.07,18.23,27.52,38.34,48.67,58.98,64.64,67.7,69.21,69.33,68.93,68.6,68.51,68.8,69.26,69.71,70.38,70.94,71.93,73.13
71.136 | IJA Earth Brown | IJA Marrón Tierra | GU 1.9,124,98,74,43.63,7.15,17.47,2.11Y,4.36,2.13,13.58,D65/10°,SCI,UV400,6.04,6.53,6.71,7,7.46,7.75,7.97,8.24,8.51,8.7,9.17,9.96,10.92,11.8,12.36,12.74,13.61,15.64,17.88,18.88,18.54,17.76,17.2,16.93,16.71,16.59,16.89,17.6,18.45,19.18,19.73
71.136 | IJA Earth Brown | IJA Marrón Tierra | GU 1.9,124,98,76,43.77,7.25,16.48,8.22YR,4.37,2.84,13.68,D65/10°,SCE,UV400,6.86,7.03,7.1,7.39,7.85,8.08,8.29,8.54,8.77,8.96,9.43,10.17,11.06,11.87,12.36,12.65,13.69,15.73,17.93,18.96,18.63,17.81,17.27,17.03,16.82,16.72,16.98,17.61,18.42,19.16,19.69
71.137 | US Light Green | US Verde Claro | FS34151 | ANA611 | GU 3.1,105,99,62,41.82,-3.93,21.9,4.50GY,4.19,3.48,12.39,D65/10°,SCI,UV400,4.72,5.04,5.13,5.31,5.54,5.67,5.87,6.2,6.62,6.87,7.56,9.01,11.14,13.18,14.34,14.77,14.95,15.75,15.85,14.55,12.78,11.44,10.72,10.43,10.2,10.1,10.35,10.93,11.62,12.23,12.66
71.137 | US Light Green | US Verde Claro | FS34151 | ANA611 | GU 3.1,105,99,64,41.94,-3.61,20.72,4.49GY,4.2,3.4,12.46,D65/10°,SCE,UV400,5.4,5.46,5.46,5.64,5.9,6.01,6.18,6.5,6.87,7.12,7.81,9.24,11.25,13.15,14.26,14.61,14.99,15.79,15.89,14.63,12.89,11.56,10.87,10.59,10.38,10.28,10.48,10.96,11.63,12.25,12.69
71.138 | US Sand | US Arena | FS30277 | GU 3.2,146,130,108,55.53,2.08,14.25,3.54Y,5.51,2.03,23.45,D65/10°,SCI,UV400,14.41,15.29,15.16,15.14,15.49,15.84,16.28,17.11,17.69,17.87,18.58,19.9,21.55,22.88,23.22,22.99,23.55,26.22,28.74,28.95,27.53,25.98,25,24.53,24.16,23.96,24.3,25.05,25.91,26.57,27.05
71.138 | US Sand | US Arena | FS30277 | GU 3.2,146,130,109,55.49,2.2,13.84,2.02Y,5.5,1.72,23.41,D65/10°,SCE,UV400,14.72,15.52,15.4,15.34,15.68,16.02,16.41,17.18,17.78,17.96,18.63,19.96,21.53,22.79,23.07,22.81,23.54,26.19,28.65,28.85,27.46,25.95,25.03,24.53,24.21,24.01,24.29,24.95,25.73,26.42,26.88
71.139 | US Field Drab | US Marrón Verdoso | FS30118 | ANA617 | GU 3.9,111,90,67,39.84,5.32,16.49,2.09Y,3.98,1.13,11.15,D65/10°,SCI,UV400,5.69,5.95,5.93,5.93,5.99,6.01,6.15,6.66,7.37,7.61,7.95,8.66,9.59,10.3,10.46,10.37,10.6,12.34,14.36,15.15,14.91,14.39,14.01,13.78,13.57,13.42,13.5,13.69,13.92,14.09,14.21
71.139 | US Field Drab | US Marrón Verdoso | FS30118 | ANA617 | GU 3.9,111,89,68,39.74,5.47,15.7,10.08YR,3.97,2.52,11.09,D65/10°,SCE,UV400,6.26,6.21,6.09,6.08,6.17,6.16,6.31,6.79,7.45,7.68,8.04,8.72,9.57,10.21,10.29,10.12,10.57,12.27,14.26,15.06,14.84,14.32,13.93,13.71,13.54,13.39,13.37,13.48,13.72,13.92,14.06
71.140 | US Desert Sand | US Arena Desierto | FS30279 | ANA616 | GU 3.1,161,135,118,58.45,7.09,12.62,9.41YR,5.79,2.22,26.44,D65/10°,SCI,UV400,15.32,16.74,17.12,17.9,18.97,19.72,20.02,20.25,20.45,20.61,21.06,21.8,22.89,24.05,24.55,24.59,25.43,28.51,31.87,33.36,33.37,32.96,32.49,32.12,31.8,31.55,31.57,31.72,31.98,32.1,32.29
71.140 | US Desert Sand | US Arena Desierto | FS30279 | ANA616 | GU 3.1,160,135,119,58.35,7.09,12.28,9.38YR,5.78,2.22,26.34,D65/10°,SCE,UV400,15.68,16.87,17.32,18.02,19.07,19.82,20.05,20.28,20.48,20.67,21.12,21.83,22.86,23.95,24.36,24.33,25.38,28.44,31.69,33.13,33.18,32.76,32.34,31.99,31.73,31.49,31.42,31.48,31.69,31.91,32.04
71.141 | IDF Sand Grey 73 | IDF Gris Arena 73 | GU 4.0,164,152,128,63.43,0.58,14.21,5.01Y,6.29,2.11,32.11,D65/10°,SCI,UV400,17.24,19.19,19.91,21.01,22.46,23.49,23.91,24.26,24.68,25.25,26.37,27.98,29.77,31.51,32.87,33.81,34.5,35.14,35.49,35.47,35.22,34.9,34.54,34.25,34.01,33.81,33.76,33.8,33.88,33.85,33.87
71.141 | IDF Sand Grey 73 | IDF Gris Arena 73 | GU 4.0,164,151,128,63.24,0.62,13.93,5.01Y,6.27,2.12,31.87,D65/10°,SCE,UV400,17.55,19.24,19.94,20.99,22.43,23.48,23.84,24.2,24.6,25.19,26.31,27.89,29.63,31.28,32.56,33.4,34.2,34.83,35.18,35.18,34.95,34.63,34.31,34.03,33.84,33.63,33.57,33.54,33.59,33.63,33.65
71.142 | IDF Sinai Grey 82 | IDF Gris Sinai 82 | GU 3.6,119,114,104,48.39,0.35,6.01,7.77GY,4.78,1.02,17.1,D65/10°,SCI,UV400,13.6,14.38,14.24,14.09,14.17,14.26,14.42,14.81,15.06,15.06,15.31,15.91,16.64,17.15,17.23,17.04,17.05,18.05,18.92,18.94,18.45,17.84,17.41,17.17,16.97,16.8,16.89,17.15,17.42,17.6,17.72
71.142 | IDF Sinai Grey 82 | IDF Gris Sinai 82 | GU 3.6,120,114,105,48.43,0.53,5.7,7.76GY,4.79,0.96,17.14,D65/10°,SCE,UV400,14.05,14.62,14.45,14.32,14.36,14.45,14.55,14.9,15.16,15.13,15.39,15.97,16.69,17.17,17.18,16.92,17.1,18.08,18.95,19.03,18.53,17.91,17.48,17.27,17.06,16.92,16.97,17.12,17.38,17.58,17.64
71.143 | UK Light Stone | UK Piedra Clara | BS361 | GU 3.9,177,150,103,63.58,3.63,28.62,5.03Y,6.36,4.31,32.29,D65/10°,SCI,UV400,13.01,13.94,14.05,14.4,15.1,15.62,16.09,16.97,17.79,18.36,19.89,23.03,27.24,31.11,33.64,34.94,36.19,38.17,39.79,39.98,39.23,38.37,37.7,37.3,36.99,36.81,36.98,37.42,37.92,38.27,38.56
71.143 | UK Light Stone | UK Piedra Clara | BS361 | GU 3.9,176,149,103,63.41,3.69,27.95,5.03Y,6.34,4.03,32.08,D65/10°,SCE,UV400,13.56,14.18,14.24,14.6,15.31,15.82,16.23,17.06,17.89,18.47,19.96,23.04,27.14,30.9,33.29,34.49,35.84,37.88,39.51,39.72,38.99,38.08,37.43,37.02,36.76,36.55,36.66,37,37.48,37.89,38.2
71.244 | Sand Beige | Sandbeige | RAL1039 | GU 1.8,188,165,137,69.16,4.08,17.45,2.07Y,6.89,0.64,39.57,D65/10°,SCI,UV400,19.39,22.29,23.2,24.41,26.08,27.41,28.07,28.71,29.29,29.91,31.11,32.9,35.16,37.41,38.92,39.68,40.93,43.71,46.31,47.15,46.75,46.11,45.54,45.19,44.9,44.69,44.78,45.15,45.53,45.8,46.08
71.244 | Sand Beige | Sandbeige | RAL1039 | GU 1.8,187,164,137,68.97,4.24,17.26,2.07Y,6.87,0.68,39.3,D65/10°,SCE,UV400,19.83,22.31,23.14,24.32,26.02,27.34,27.95,28.59,29.14,29.78,31,32.72,34.85,37.02,38.5,39.2,40.61,43.46,46.08,46.94,46.57,45.9,45.34,44.97,44.71,44.5,44.49,44.73,45.05,45.38,45.59
71.245 | Loam Beige | Lehmbeige | RAL1040 | GU 3.9,148,130,101,55.62,2.21,18.2,5.09Y,5.53,2.67,23.54,D65/10°,SCI,UV400,11.67,12.34,12.51,13.02,13.91,14.58,15,15.53,15.98,16.41,17.43,19.02,20.88,22.78,24,24.4,24.55,26.63,28.49,28.61,27.75,26.81,26.14,25.76,25.46,25.28,25.42,25.8,26.25,26.55,26.84
71.245 | Loam Beige | Lehmbeige | RAL1040 | GU 3.9,148,130,102,55.45,2.33,17.83,5.08Y,5.51,2.62,23.37,D65/10°,SCE,UV400,12.07,12.48,12.57,13.09,13.95,14.63,15.01,15.51,15.97,16.39,17.38,18.94,20.75,22.56,23.72,24.05,24.38,26.47,28.27,28.39,27.57,26.64,26,25.62,25.36,25.16,25.26,25.54,25.93,26.3,26.54
71.246 | Yellow Brown | Sandbraun | RAL8031 | GU 4.3,137,119,102,51.41,4.21,11.63,10.01YR,5.1,2.1,19.63,D65/10°,SCI,UV400,11.54,12.46,12.7,13.19,13.96,14.45,14.7,14.98,15.2,15.36,15.8,16.55,17.55,18.47,18.91,18.92,19.37,21.28,23.32,24.07,23.75,23.16,22.69,22.45,22.19,22.01,22.08,22.34,22.6,22.74,22.84
71.246 | Yellow Brown | Sandbraun | RAL8031 | GU 4.3,137,119,103,51.43,4.36,11.29,10.02YR,5.1,2.13,19.64,D65/10°,SCE,UV400,12.15,12.72,12.88,13.41,14.12,14.63,14.84,15.07,15.29,15.44,15.88,16.6,17.6,18.49,18.81,18.76,19.39,21.31,23.31,24.07,23.8,23.22,22.79,22.49,22.28,22.1,22.14,22.27,22.48,22.69,22.81
71.247 | Light Olive | Helloliv | RAL6040 | GU 4.2,95,88,70,37.67,-0.3,11.33,2.05GY,3.75,1.44,9.9,D65/10°,SCI,UV400,6.2,6.47,6.43,6.39,6.43,6.47,6.64,6.94,7.21,7.28,7.66,8.43,9.39,10.06,10.21,10.11,10.16,11.29,12.33,12.11,11.12,10.2,9.64,9.38,9.18,9.08,9.26,9.67,10.15,10.54,10.8
71.247 | Light Olive | Helloliv | RAL6040 | GU 4.2,95,88,72,37.89,-0.04,10.41,2.06GY,3.77,1.36,10.02,D65/10°,SCE,UV400,6.99,6.94,6.79,6.73,6.81,6.81,6.96,7.23,7.46,7.54,7.9,8.65,9.54,10.14,10.21,10.03,10.29,11.4,12.4,12.21,11.26,10.34,9.81,9.57,9.38,9.28,9.41,9.7,10.18,10.57,10.83
71.248 | Brown Grey | Gris Marrón | RAL7050 | GU 5.6,93,89,85,38.31,0.35,3.2,2.15G,3.79,0.45,10.26,D65/10°,SCI,UV400,9.32,9.61,9.44,9.21,9.15,9.07,9.14,9.31,9.43,9.37,9.45,9.74,10.08,10.29,10.28,10.15,10.03,10.69,11.34,11.36,10.98,10.53,10.2,10.03,9.85,9.75,9.8,9.95,10.13,10.25,10.3
71.248 | Brown Grey | Gris Marrón | RAL7050 | GU 5.6,92,89,85,38.26,0.56,2.71,2.15G,3.79,0.4,10.24,D65/10°,SCE,UV400,9.77,9.83,9.57,9.36,9.32,9.2,9.25,9.42,9.5,9.43,9.52,9.78,10.08,10.24,10.12,9.94,10.04,10.68,11.29,11.33,10.97,10.51,10.21,10.05,9.91,9.78,9.8,9.86,10.01,10.14,10.2
71.249 | Nato Brown | Lederbraun | FS30051 | RAL8027 | GU 1.9,89,70,62,31.85,6.53,8.41,2.59YR,3.18,1.55,7.02,D65/10°,SCI,UV400,4.77,5.02,5,4.99,5.01,5.02,5.08,5.18,5.25,5.23,5.33,5.52,5.89,6.17,6.21,6.18,6.28,7.55,9.14,9.84,9.63,9.18,8.83,8.67,8.51,8.42,8.51,8.73,8.98,9.17,9.25
71.249 | Nato Brown | Lederbraun | FS30051 | RAL8027 | GU 1.9,90,72,64,32.32,6.57,7.63,2.73YR,3.22,1.53,7.23,D65/10°,SCE,UV400,5.45,5.46,5.33,5.33,5.38,5.35,5.41,5.48,5.54,5.51,5.61,5.81,6.13,6.36,6.31,6.2,6.55,7.8,9.34,10.02,9.83,9.39,9.07,8.91,8.77,8.66,8.72,8.84,9.06,9.24,9.33
71.250 | Bronze Green | Bronzegrün | RAL6031 | GU 2.3,74,78,64,32.54,-4.11,7.64,7.04GY,3.24,1.57,7.33,D65/10°,SCI,UV400,4.72,5,5.08,5.19,5.32,5.41,5.54,5.72,5.9,5.99,6.29,6.84,7.51,7.95,8.17,8.23,7.95,8.06,7.96,7.51,6.98,6.56,6.28,6.19,6.1,6.05,6.17,6.35,6.58,6.74,6.78
71.250 | Bronze Green | Bronzegrün | RAL6031 | GU 2.3,76,78,66,32.99,-3.69,6.85,7.05GY,3.28,1.43,7.53,D65/10°,SCE,UV400,5.37,5.45,5.43,5.53,5.71,5.76,5.88,6.04,6.18,6.28,6.59,7.13,7.71,8.11,8.23,8.2,8.19,8.3,8.16,7.73,7.23,6.81,6.55,6.45,6.35,6.29,6.35,6.47,6.66,6.81,6.9
71.251 | Nato Black | Teerschwarz | FS37030 | RAL9021 | GU 0.4,50,52,52,21.69,-0.94,-0.62,10.16G,2.14,3.33,3.43,D65/10°,SCI,UV400,3.33,3.52,3.54,3.56,3.54,3.53,3.53,3.51,3.52,3.49,3.49,3.47,3.49,3.54,3.56,3.58,3.41,3.38,3.34,3.3,3.28,3.26,3.24,3.22,3.21,3.18,3.2,3.2,3.22,3.22,3.2
71.251 | Nato Black | Teerschwarz | FS37030 | RAL9021 | GU 0.4,50,53,54,22.14,-0.65,-1.34,2.17BG,2.18,0.96,3.55,D65/10°,SCE,UV400,3.8,3.86,3.8,3.83,3.84,3.77,3.77,3.72,3.71,3.68,3.67,3.64,3.65,3.64,3.6,3.56,3.55,3.54,3.46,3.42,3.42,3.39,3.35,3.36,3.31,3.28,3.27,3.23,3.23,3.23,3.2
71.255 | Light Blue RLM65 | RLM65 Hellblau | RLM65 | GU 1.7,117,144,143,57.96,-9.45,-2.84,9.01BG,5.67,2.06,25.92,D65/10°,SCI,UV400,22.61,26.15,26.76,26.86,27.05,27.26,27.65,28.69,29.72,29.95,29.83,29.56,29.21,28.76,28.16,27.43,25.85,24.61,23.44,22.3,21.16,20.22,19.69,19.46,19.33,19.32,19.66,20.02,20.2,20.15,19.87
71.255 | Light Blue RLM65 | RLM65 Hellblau | RLM65 | GU 1.7,118,144,143,57.89,-9.18,-2.79,8.99BG,5.66,2.04,25.85,D65/10°,SCE,UV400,22.92,26.08,26.57,26.75,26.95,27.2,27.53,28.55,29.56,29.81,29.71,29.45,29.08,28.6,27.96,27.15,25.8,24.6,23.43,22.38,21.3,20.32,19.78,19.54,19.4,19.44,19.76,20.03,20.21,20.16,19.88
71.256 | Green RLM73 | RLM73 Grün | RLM73 | GU 3.2,66,73,69,30.37,-3.43,0.93,7.10G,3,1.2,6.39,D65/10°,SCI,UV400,5.7,6.06,6.09,6.08,6.12,6.1,6.16,6.23,6.32,6.3,6.4,6.55,6.76,6.86,6.92,6.92,6.56,6.44,6.25,6.01,5.79,5.61,5.48,5.4,5.37,5.33,5.43,5.5,5.64,5.71,5.71
71.256 | Green RLM73 | RLM73 Grün | RLM73 | GU 3.2,67,73,71,30.79,-3.08,0.31,10.11G,3.04,3.04,6.56,D65/10°,SCE,UV400,6.45,6.51,6.43,6.42,6.46,6.43,6.48,6.54,6.57,6.56,6.65,6.8,6.94,7.01,6.95,6.89,6.79,6.66,6.45,6.2,6,5.81,5.65,5.62,5.55,5.49,5.53,5.55,5.64,5.69,5.72
71.257 | Light Blue RLM76 | RLM76 Lichtblau | RLM76 | GU 1.7,142,165,161,66.1,-9.04,-0.57,5.02BG,6.49,2.29,35.45,D65/10°,SCI,UV400,26.97,32.38,33.57,34.28,35.15,35.85,36.26,37.21,38.23,38.65,38.92,39.13,39.23,39.11,38.62,37.72,35.71,33.98,32.51,31.33,30.21,29.31,28.81,28.6,28.49,28.74,29.28,29.55,29.4,28.87,28.13
71.257 | Light Blue RLM76 | RLM76 Lichtblau | RLM76 | GU 1.7,141,164,160,65.87,-8.8,-0.57,5.02BG,6.47,2.33,35.16,D65/10°,SCE,UV400,27.1,32.08,33.22,33.96,34.9,35.57,35.96,36.91,37.89,38.33,38.61,38.79,38.87,38.72,38.18,37.2,35.36,33.73,32.31,31.18,30.12,29.24,28.77,28.53,28.49,28.7,29.17,29.36,29.15,28.71,27.95
71.258 | Grey Green RLM74 | RLM74 Graugrün | RLM74 | GU 1.4,79,84,81,35.44,-2.99,1.1,7.11G,3.5,1.13,8.72,D65/10°,SCI,UV400,8.08,8.48,8.39,8.31,8.33,8.28,8.37,8.48,8.59,8.57,8.67,8.89,9.12,9.24,9.24,9.25,8.92,8.83,8.67,8.39,8.15,7.93,7.73,7.65,7.53,7.46,7.52,7.6,7.7,7.77,7.74
71.258 | Grey Green RLM74 | RLM74 Graugrün | RLM74 | GU 1.4,79,85,82,35.65,-2.65,0.63,7.11G,3.52,1.06,8.83,D65/10°,SCE,UV400,8.71,8.82,8.65,8.59,8.6,8.53,8.59,8.7,8.77,8.74,8.86,9.07,9.24,9.3,9.23,9.14,9.05,8.98,8.77,8.53,8.31,8.08,7.89,7.82,7.73,7.65,7.64,7.63,7.71,7.76,7.78
71.259 | Grey Violet RLM75 | RLM75 Grauviolett | RLM75 | GU 1.5,91,94,94,39.93,-1.29,-0.54,10.13G,3.93,3.53,11.21,D65/10°,SCI,UV400,10.82,11.49,11.5,11.43,11.44,11.41,11.38,11.35,11.31,11.24,11.27,11.35,11.45,11.52,11.51,11.52,11.23,11.19,11.07,10.92,10.83,10.73,10.6,10.51,10.39,10.29,10.28,10.26,10.22,10.18,10.11
71.259 | Grey Violet RLM75 | RLM75 Grauviolett | RLM75 | GU 1.5,92,95,95,40.12,-1.01,-0.82,2.14BG,3.95,1.04,11.32,D65/10°,SCE,UV400,11.45,11.82,11.7,11.66,11.69,11.65,11.58,11.53,11.46,11.4,11.45,11.51,11.58,11.59,11.52,11.43,11.38,11.35,11.21,11.08,11.01,10.9,10.78,10.7,10.61,10.5,10.43,10.32,10.29,10.25,10.2
71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5,102,104,90,43.62,-3.25,7.67,7.06GY,4.32,1.29,13.58,D65/10°,SCI,UV400,9.09,9.79,9.87,10.03,10.4,10.65,10.9,11.28,11.59,11.71,12.11,12.82,13.6,14.21,14.42,14.44,14.33,14.77,14.91,14.39,13.55,12.79,12.32,12.08,11.85,11.73,11.88,12.21,12.6,12.9,13.08
71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5,103,104,91,43.74,-2.9,7.13,7.06GY,4.33,1.16,13.66,D65/10°,SCE,UV400,9.84,10.21,10.17,10.35,10.71,10.92,11.14,11.47,11.72,11.86,12.27,12.93,13.68,14.23,14.4,14.31,14.41,14.88,15.01,14.51,13.7,12.93,12.47,12.23,12.05,11.92,12,12.25,12.61,12.96,13.13
71.263 | Green RLM72 | RLM72 Grün | RLM72 | GU 2.6,70,75,72,31.69,-2.63,1,7.11G,3.13,1.08,6.95,D65/10°,SCI,UV400,7.24,7.86,7.61,7.1,6.7,6.43,6.37,6.36,6.49,6.65,6.85,7.08,7.43,7.63,7.64,7.56,7.03,6.8,6.59,6.4,6.34,6.32,6.31,6.4,6.43,6.52,6.7,6.85,7,7.07,7.11
71.263 | Green RLM72 | RLM72 Grün | RLM72 | GU 2.6,72,76,74,32.15,-2.23,0.4,7.12G,3.18,1,7.15,D65/10°,SCE,UV400,7.99,8.28,7.95,7.46,7.09,6.81,6.72,6.69,6.75,6.93,7.14,7.35,7.64,7.78,7.72,7.55,7.27,7.04,6.79,6.63,6.58,6.56,6.56,6.65,6.7,6.77,6.89,6.96,7.05,7.11,7.15
71.264 | Brown Violet RLM81 | RLM81 Braunviolett | RLM81 | GU 1.2,99,87,68,37.76,1.96,12.69,5.02Y,3.77,2.14,9.96,D65/10°,SCI,UV400,4.95,5.37,5.52,5.81,6.17,6.38,6.57,6.76,7,7.14,7.51,8.11,8.87,9.54,9.92,10.07,10.26,11.31,12.22,12.29,11.87,11.36,10.98,10.78,10.57,10.46,10.53,10.75,11.03,11.22,11.33
71.264 | Brown Violet RLM81 | RLM81 Braunviolett | RLM81 | GU 1.2,100,87,70,38.06,2.12,11.69,2.66Y,3.8,1.8,10.12,D65/10°,SCE,UV400,5.68,5.86,5.91,6.19,6.58,6.77,6.94,7.12,7.28,7.43,7.81,8.39,9.07,9.69,9.96,10.04,10.46,11.48,12.35,12.43,12.04,11.51,11.16,10.97,10.8,10.67,10.7,10.83,11.08,11.3,11.45
71.265 | Olive Green RLM80 | RLM80 Olivgrün | RLM80 | GU 2.9,70,75,59,31.08,-5.05,8.45,6.85GY,3.09,1.66,6.69,D65/10°,SCI,UV400,4.25,4.44,4.48,4.57,4.65,4.71,4.81,4.95,5.12,5.23,5.59,6.22,7.05,7.62,7.8,7.73,7.29,7.25,7.05,6.61,6.16,5.84,5.64,5.54,5.49,5.45,5.6,5.7,5.87,5.94,5.96
71.265 | Olive Green RLM80 | RLM80 Olivgrün | RLM80 | GU 2.9,71,75,61,31.46,-4.7,7.82,7.03GY,3.13,1.68,6.85,D65/10°,SCE,UV400,4.78,4.79,4.73,4.82,4.94,4.97,5.07,5.2,5.33,5.45,5.82,6.47,7.22,7.74,7.84,7.69,7.49,7.46,7.23,6.81,6.38,6.04,5.82,5.75,5.67,5.63,5.7,5.76,5.88,5.95,5.97
71.266 | Dark Blue RLM24 | RLM24 Dunkelblau | RLM24 | GU 4.9,43,84,114,34.41,-4.46,-21.46,2.11PB,3.29,4.66,8.21,D65/10°,SCI,UV400,12.62,14.76,15.23,15.8,16.48,16.76,16.55,16.09,15.29,14.11,12.75,11.39,10.01,8.89,8.2,7.59,6.36,5.75,5.4,5.24,5.06,4.94,4.84,4.83,4.9,5.02,5.27,5.36,5.36,5.21,5.08
71.266 | Dark Blue RLM24 | RLM24 Dunkelblau | RLM24 | GU 4.9,45,85,114,34.63,-4.18,-21.3,2.10PB,3.31,4.7,8.31,D65/10°,SCE,UV400,13.14,14.95,15.41,15.96,16.6,16.85,16.61,16.13,15.32,14.1,12.82,11.5,10.12,8.98,8.21,7.57,6.56,5.95,5.58,5.38,5.25,5.08,4.97,4.99,5.03,5.15,5.37,5.41,5.35,5.19,5
71.267 | Light Green RLM25 | RLM25 Hellgrün | RLM25 | GU 4.7,67,114,103,44.63,-18.85,1.03,2.04BG,4.37,4.03,14.28,D65/10°,SCI,UV400,9.47,10.49,10.99,11.74,12.73,13.67,14.6,15.6,16.43,17.01,17.48,17.83,18.09,18.03,17.69,16.87,14.99,13.41,11.76,10.07,8.6,7.64,7.13,6.96,6.81,6.78,7.01,7.41,7.88,8.23,8.41
71.267 | Light Green RLM25 | RLM25 Hellgrün | RLM25 | GU 4.7,68,114,103,44.68,-18.27,0.78,2.04BG,4.37,4.03,14.31,D65/10°,SCE,UV400,10.11,10.81,11.21,11.95,12.88,13.81,14.69,15.66,16.49,17.05,17.5,17.85,18.06,18.04,17.59,16.66,15.02,13.46,11.83,10.2,8.78,7.84,7.35,7.19,7.05,6.99,7.18,7.48,7.91,8.25,8.45
71.268 | German Grey | RAL6006 Feldgrau | RAL6006 | GU 2.2,69,72,65,30.44,-2.74,4.07,10.10GY,3.02,2.69,6.42,D65/10°,SCI,UV400,5.06,5.32,5.36,5.32,5.34,5.35,5.43,5.63,5.87,5.92,6.06,6.31,6.64,6.81,6.87,6.9,6.62,6.61,6.54,6.35,6.19,6.06,5.93,5.89,5.83,5.78,5.84,5.89,5.99,6.02,6.04
71.268 | German Grey | RAL6006 Feldgrau | RAL6006 | GU 2.2,71,73,67,30.85,-2.38,3.4,2.11G,3.06,0.92,6.59,D65/10°,SCE,UV400,5.69,5.76,5.67,5.65,5.68,5.64,5.74,5.92,6.11,6.16,6.31,6.56,6.82,6.94,6.92,6.87,6.83,6.82,6.71,6.55,6.41,6.26,6.13,6.1,6.03,5.96,5.98,5.95,6.01,6.03,6.01
71.269 | Red | RAL3000 Rot | RAL3000 | GU 5.3,154,59,56,38.53,39.73,22.71,5.29R,3.88,10.41,10.39,D65/10°,SCI,UV400,4.6,4.71,4.68,4.62,4.54,4.5,4.49,4.49,4.46,4.4,4.42,4.45,4.52,4.61,4.66,4.84,5.11,5.85,8.17,14.37,23.95,32.37,37.03,39,39.56,39.79,40.79,42.91,45.52,47.91,49.75
71.269 | Red | RAL3000 Rot | RAL3000 | GU 5.3,154,59,58,38.62,39.34,21.64,5.04R,3.89,10.25,10.44,D65/10°,SCE,UV400,5.17,5.09,4.96,4.88,4.82,4.73,4.73,4.68,4.64,4.57,4.59,4.61,4.66,4.67,4.68,4.77,5.27,6.05,8.32,14.44,23.92,32.11,36.66,38.63,39.25,39.41,40.38,42.4,44.91,47.36,49.15
71.270 | Off-White | RAL9001 Weiss | RAL9001 | GU 4.9,223,212,190,85.27,0.24,12.18,10.04YR,8.54,2.37,66.53,D65/10°,SCI,UV400,34.74,46.28,49.86,50.92,52.19,53.14,53.77,55.28,58.09,60.13,61.46,62.68,63.93,65.24,66.47,67.48,68.41,69.41,70.27,70.89,71.18,71.34,71.29,71.26,71.19,71.15,71.11,71.21,71.25,71.27,71.25
71.270 | Off-White | RAL9001 Weiss | RAL9001 | GU 4.9,222,211,189,84.93,0.29,12.19,10.04YR,8.51,2.36,65.86,D65/10°,SCE,UV400,34.68,45.75,49.32,50.33,51.63,52.57,53.19,54.67,57.47,59.5,60.86,62.05,63.3,64.53,65.71,66.73,67.74,68.73,69.61,70.26,70.55,70.69,70.66,70.62,70.58,70.5,70.37,70.4,70.34,70.46,70.42
71.271 | German Red Brown | RAL8012 Rotbraun | RAL8012 | GU 3.2,97,66,61,31.38,12.83,8.19,2.49YR,3.14,1.53,6.82,D65/10°,SCI,UV400,4.83,5.04,5.02,4.94,4.93,4.89,4.93,5,5.1,5.05,5.03,4.99,5.04,5.14,5.16,5.27,5.45,6.49,8.39,10.24,11.15,11.33,11.24,11.13,10.96,10.84,10.78,10.71,10.65,10.57,10.49
71.271 | German Red Brown | RAL8012 Rotbraun | RAL8012 | GU 3.2,97,66,63,31.5,12.92,7.45,9.34R,3.14,2.61,6.86,D65/10°,SCE,UV400,5.4,5.35,5.23,5.16,5.16,5.08,5.11,5.17,5.23,5.18,5.15,5.11,5.13,5.14,5.12,5.15,5.54,6.6,8.46,10.28,11.18,11.35,11.26,11.17,11.03,10.89,10.78,10.64,10.57,10.5,10.42
71.272 | German Yellow Brown | RAL8000 Gelbbraun | RAL8000 | GU 2.3,133,107,77,47.13,6.13,20.71,2.10Y,4.71,3.1,16.12,D65/10°,SCI,UV400,6.51,7.06,7.24,7.58,8.14,8.48,8.77,9.15,9.53,9.81,10.49,11.67,13.18,14.61,15.44,15.72,16.45,18.75,21.03,21.76,21.29,20.58,20.08,19.85,19.64,19.49,19.63,20.03,20.48,20.82,21.01
71.272 | German Yellow Brown | RAL8000 Gelbbraun | RAL8000 | GU 2.3,133,107,78,47.15,6.32,19.8,2.10Y,4.71,3.15,16.13,D65/10°,SCE,UV400,7.27,7.51,7.57,7.9,8.44,8.76,9.04,9.38,9.7,9.99,10.65,11.75,13.21,14.57,15.34,15.57,16.45,18.7,20.99,21.77,21.35,20.6,20.09,19.86,19.63,19.51,19.67,19.98,20.4,20.72,20.95
71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629 | GU 3.9,99,112,121,46.8,-2.9,-6.45,10.03B,4.58,2.26,15.87,D65/10°,SCI,UV400,16.89,18.82,19.14,19.13,19.11,19.1,18.93,18.7,18.44,18.13,17.82,17.45,17.05,16.66,16.43,16.16,15.31,14.78,14.44,14.24,14.06,13.8,13.56,13.51,13.57,13.74,14.02,14.12,14.02,13.79,13.5
71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629 | GU 3.9,99,112,121,46.68,-2.71,-6.52,2.03PB,4.57,1.86,15.77,D65/10°,SCE,UV400,17.06,18.74,19.07,19.02,19.06,19.05,18.85,18.63,18.38,18.07,17.73,17.36,16.94,16.54,16.22,15.87,15.24,14.73,14.4,14.22,14.06,13.77,13.54,13.51,13.58,13.74,13.95,13.96,13.87,13.66,13.37
71.274 | Aggressor Gray | Gris Aggressor | FS36251 | GU 4.7,121,125,125,52.19,-1.34,-0.42,10.11P,5.13,4.16,20.32,D65/10°,SCI,UV400,17.73,19.77,20.21,20.41,20.6,20.75,20.68,20.57,20.48,20.43,20.47,20.53,20.66,20.71,20.77,20.75,20.43,20.28,20.09,19.88,19.74,19.62,19.48,19.39,19.24,19.06,18.96,18.9,18.82,18.71,18.61
71.274 | Aggressor Gray | Gris Aggressor | FS36251 | GU 4.7,121,125,125,52.2,-1.2,-0.48,10.11P,5.13,4.12,20.32,D65/10°,SCE,UV400,17.96,19.8,20.22,20.4,20.64,20.8,20.71,20.59,20.51,20.48,20.52,20.58,20.64,20.67,20.65,20.6,20.44,20.31,20.11,19.94,19.85,19.69,19.53,19.44,19.29,19.15,19.07,18.9,18.8,18.68,18.53
71.275 | USAF Medium Gray | USAF Gris Medio | FS36270 | GU 5.5,117,123,126,51.35,-1.18,-2.78,4.98P,5.04,3.32,19.57,D65/10°,SCI,UV400,19.01,21.21,21.58,21.38,21.22,21.12,20.93,20.72,20.53,20.35,20.24,20.12,20.08,19.97,19.92,19.82,19.46,19.3,19.08,18.84,18.71,18.58,18.41,18.28,18.1,17.92,17.79,17.69,17.6,17.48,17.38
71.275 | USAF Medium Gray | USAF Gris Medio | FS36270 | GU 5.5,117,123,126,51.33,-1.07,-2.79,4.99P,5.04,3.3,19.55,D65/10°,SCE,UV400,19.4,21.23,21.47,21.32,21.21,21.12,20.91,20.72,20.55,20.39,20.28,20.16,20.04,19.92,19.79,19.65,19.45,19.29,19.08,18.9,18.78,18.61,18.44,18.34,18.16,18.01,17.87,17.67,17.56,17.43,17.29
71.276 | USAF Light Gray | Gris Claro | FS36495 | GU 6.2,185,190,186,76.73,-2.77,1.45,10.08G,7.62,3.71,51.09,D65/10°,SCI,UV400,34.17,46.58,50.06,50.06,49.72,49.66,49.64,49.71,49.97,50.5,51.13,51.73,52.5,52.97,53.05,52.77,51.73,50.84,50.08,49.46,49,48.8,48.74,48.98,49.2,49.57,50.08,50.64,50.94,51.08,51.14
71.276 | USAF Light Gray | Gris Claro | FS36495 | GU 6.2,184,190,185,76.48,-2.63,1.51,10.09G,7.6,3.75,50.67,D65/10°,SCE,UV400,34.15,45.99,49.54,49.47,49.3,49.2,49.17,49.28,49.55,50.06,50.71,51.32,52.03,52.44,52.44,52.19,51.31,50.53,49.78,49.16,48.78,48.55,48.51,48.72,49,49.31,49.77,50.21,50.45,50.6,50.64
71.277 | Dark Gull Gray | Gris Gaviota Oscuro | FS36231 | ANA621 | GU 1.7,124,131,134,54.63,-2.11,-2.47,6.89BG,5.36,3.33,22.57,D65/10°,SCI,UV400,20.69,23.52,24.04,24.08,24.12,24.17,24.04,23.88,23.73,23.58,23.5,23.41,23.39,23.31,23.21,23.03,22.46,22.16,21.88,21.55,21.27,21.02,20.81,20.73,20.58,20.48,20.48,20.44,20.32,20.1,19.88
71.277 | Dark Gull Gray | Gris Gaviota Oscuro | FS36231 | ANA621 | GU 1.7,124,131,134,54.57,-1.92,-2.42,5.34P,5.35,1.25,22.52,D65/10°,SCE,UV400,20.97,23.47,23.9,23.96,24.04,24.1,23.95,23.81,23.64,23.52,23.44,23.36,23.29,23.19,23.02,22.8,22.44,22.16,21.87,21.6,21.38,21.08,20.87,20.77,20.63,20.55,20.54,20.4,20.28,20.07,19.86
71.278 | Sand Yellow RLM79 | RLM79 Sandgelb | RLM79 | GU 3.7,150,116,79,51.34,8.5,25.52,10.02YR,5.12,4.18,19.56,D65/10°,SCI,UV400,7.59,7.92,7.91,7.95,8.17,8.33,8.78,10.29,12.63,13.73,14.31,15.13,16.13,16.95,17.3,17.33,18.27,21.18,24.83,27.11,27.81,27.77,27.56,27.44,27.27,27.2,27.33,27.59,27.86,28.04,28.22
71.278 | Sand Yellow RLM79 | RLM79 Sandgelb | RLM79 | GU 3.7,149,115,79,51.12,8.68,24.8,10.01YR,5.1,4.12,19.37,D65/10°,SCE,UV400,8.19,8.17,8.08,8.11,8.36,8.49,8.88,10.33,12.53,13.57,14.2,15,15.98,16.79,17.03,17,18.11,21.03,24.6,26.83,27.55,27.52,27.33,27.19,27.07,26.97,27.06,27.22,27.46,27.68,27.86
71.279 | Insignia White | Blanco Insignia | FS37875 | ANA601 | GU 5.2,223,221,206,87.96,-1.61,7.26,10.07R,8.81,2.76,71.99,D65/10°,SCI,UV400,37.88,53.51,59.58,61.45,63.09,64.3,64.84,65.34,65.79,66.41,67.55,69.16,70.89,72.44,73.72,74.54,74.74,74.64,74.31,73.74,72.99,72.32,71.82,71.58,71.36,71.19,71.19,71.54,71.84,72.12,72.21
71.279 | Insignia White | Blanco Insignia | FS37875 | ANA601 | GU 5.2,222,219,205,87.58,-1.56,7.28,10.07R,8.77,2.76,71.2,D65/10°,SCE,UV400,37.68,52.9,58.76,60.69,62.37,63.58,64.09,64.57,65.05,65.65,66.84,68.45,70.07,71.61,72.85,73.61,73.89,73.87,73.54,73,72.29,71.62,71.12,70.84,70.65,70.47,70.42,70.68,70.88,71.19,71.27
71.280 | Camouflage Gray | Gris Camuflaje | FS36170 | GU 5.0,104,106,104,44.91,-1.26,1.18,7.12G,4.43,0.91,14.48,D65/10°,SCI,UV400,13.14,13.93,13.9,13.84,13.94,14.01,14.02,14.06,14.08,14.05,14.16,14.4,14.65,14.83,14.9,14.88,14.62,14.66,14.61,14.44,14.3,14.13,13.95,13.83,13.67,13.55,13.53,13.52,13.49,13.44,13.36
71.280 | Camouflage Gray | Gris Camuflaje | FS36170 | GU 5.0,105,106,104,44.98,-0.96,0.95,7.13G,4.43,0.87,14.53,D65/10°,SCE,UV400,13.58,14.13,14.08,14.05,14.12,14.19,14.13,14.13,14.13,14.09,14.24,14.46,14.7,14.83,14.82,14.71,14.69,14.75,14.7,14.56,14.43,14.24,14.07,13.96,13.84,13.7,13.6,13.52,13.5,13.44,13.39
71.281 | 3B Russian Green | 3B Verde Ruso | GU 6.7,71,72,70,30.72,-1.04,1.2,5.22G,3.04,3.21,6.53,D65/10°,SCI,UV400,5.75,6.02,6.1,6.16,6.28,6.27,6.28,6.25,6.28,6.27,6.34,6.43,6.58,6.69,6.75,6.77,6.55,6.67,6.72,6.61,6.48,6.34,6.18,6.16,6.06,6.01,6.04,6.03,6.09,6.05,6.05
71.281 | 3B Russian Green | 3B Verde Ruso | GU 6.7,70,71,70,30.45,-0.71,0.62,7.16G,3.01,0.76,6.42,D65/10°,SCE,UV400,6.12,6.18,6.14,6.21,6.33,6.31,6.29,6.25,6.25,6.23,6.3,6.39,6.48,6.53,6.5,6.45,6.48,6.6,6.62,6.52,6.4,6.26,6.11,6.08,6,5.92,5.9,5.82,5.82,5.81,5.77
71.282 | 6K Russian Brown | 6K Marrón Ruso | GU 5.5,75,69,64,29.92,1.37,3.85,10.17GY,2.97,3.19,6.2,D65/10°,SCI,UV400,5.22,5.42,5.37,5.28,5.27,5.24,5.31,5.4,5.49,5.47,5.55,5.7,5.93,6.08,6.12,6.08,6.01,6.5,6.95,7.02,6.91,6.74,6.58,6.53,6.43,6.39,6.44,6.51,6.6,6.62,6.61
71.282 | 6K Russian Brown | 6K Marrón Ruso | GU 5.5,75,70,66,30.2,1.69,3.2,10.18GY,3,3.26,6.32,D65/10°,SCE,UV400,5.84,5.8,5.63,5.55,5.54,5.5,5.54,5.62,5.68,5.64,5.73,5.87,6.06,6.16,6.1,6.01,6.16,6.65,7.06,7.15,7.05,6.88,6.74,6.7,6.61,6.53,6.55,6.52,6.58,6.59,6.58
71.283 | 7K Russian Tan | 7K Tierra Rusa | GU 8.6,117,104,83,45,1.42,14.14,5.03Y,4.48,2.19,14.54,D65/10°,SCI,UV400,7.4,7.91,8.12,8.52,9.13,9.5,9.7,9.9,10.15,10.4,10.95,11.9,13.07,14.15,14.83,15.11,15.4,16.44,17.36,17.41,16.87,16.24,15.76,15.51,15.27,15.1,15.12,15.33,15.55,15.69,15.77
71.283 | 7K Russian Tan | 7K Tierra Rusa | GU 8.6,117,104,83,44.7,1.67,13.6,5.03Y,4.45,2.19,14.33,D65/10°,SCE,UV400,7.83,8.09,8.17,8.56,9.18,9.51,9.69,9.89,10.09,10.31,10.88,11.76,12.86,13.87,14.5,14.72,15.19,16.22,17.14,17.2,16.7,16.04,15.59,15.35,15.13,14.95,14.92,15.02,15.24,15.39,15.44
71.284 | Uk Light Mud | Uk Marrón Claro | GU 9.3,128,123,105,51.7,-1.03,10.31,4.71GY,5.12,2.31,19.88,D65/10°,SCI,UV400,11.3,12.27,12.72,13.51,14.7,15.47,15.72,15.81,16,16.38,17.06,17.98,19.02,19.96,20.78,21.25,21.33,21.33,21.23,21.03,20.89,20.72,20.54,20.43,20.26,20.11,20,19.93,19.85,19.76,19.66
71.284 | Uk Light Mud | Uk Marrón Claro | GU 9.3,128,122,105,51.44,-0.82,10.09,4.79GY,5.09,2.36,19.65,D65/10°,SCE,UV400,11.65,12.3,12.63,13.49,14.61,15.39,15.57,15.65,15.86,16.21,16.88,17.78,18.77,19.69,20.41,20.83,21.08,21.11,21.01,20.87,20.76,20.55,20.36,20.23,20.07,19.93,19.82,19.68,19.58,19.49,19.38
71.285 | IJA Dark Green | IJA Verde Oscuro | GU 10.3,85,83,67,35.16,-1.75,9.51,3.54GY,3.5,1.94,8.58,D65/10°,SCI,UV400,5.28,5.57,5.64,5.76,5.95,6.02,6.12,6.28,6.47,6.57,6.89,7.5,8.3,8.89,9.07,9.02,9,9.81,10.47,10.02,9.04,8.24,7.78,7.62,7.43,7.36,7.49,7.77,8.13,8.44,8.6
71.285 | IJA Dark Green | IJA Verde Oscuro | GU 10.3,85,82,67,34.8,-1.51,8.88,5.06GY,3.47,2.34,8.4,D65/10°,SCE,UV400,5.72,5.71,5.67,5.78,5.98,6.03,6.11,6.24,6.4,6.5,6.82,7.41,8.14,8.67,8.78,8.65,8.84,9.63,10.24,9.83,8.87,8.1,7.64,7.47,7.33,7.22,7.31,7.5,7.81,8.1,8.27
71.286 | IJA Olive Green | IJA Verde Oliva | GU 6.9,77,74,63,31.67,-0.92,7.27,5.10GY,3.15,2.52,6.94,D65/10°,SCI,UV400,4.63,4.86,4.93,5.05,5.15,5.22,5.27,5.39,5.53,5.61,5.84,6.22,6.71,7.05,7.15,7.15,7.11,7.77,8.35,8.09,7.4,6.84,6.49,6.37,6.24,6.2,6.29,6.46,6.7,6.87,6.94
71.286 | IJA Olive Green | IJA Verde Oliva | GU 6.9,77,74,63,31.51,-0.63,6.65,6.83GY,3.14,1.03,6.87,D65/10°,SCE,UV400,5.04,5.02,5,5.11,5.27,5.28,5.33,5.44,5.56,5.62,5.85,6.23,6.67,6.94,6.95,6.85,7.08,7.72,8.27,8.02,7.36,6.8,6.45,6.34,6.22,6.14,6.21,6.29,6.48,6.62,6.72
71.287 | IJA Khaki Brown | IJA Marrón Caqui | GU 4.7,96,84,68,36.78,1.85,11.28,3.05Y,3.67,1.87,9.42,D65/10°,SCI,UV400,5.79,6.08,6.01,6,6.08,6.1,6.28,6.61,6.94,7.05,7.37,7.97,8.69,9.18,9.33,9.28,9.34,10.4,11.5,11.69,11.26,10.73,10.32,10.14,9.95,9.83,9.93,10.15,10.41,10.61,10.68
71.287 | IJA Khaki Brown | IJA Marrón Caqui | GU 4.7,96,85,70,37.06,2.03,10.37,3.00Y,3.69,1.75,9.57,D65/10°,SCE,UV400,6.54,6.54,6.39,6.36,6.45,6.45,6.59,6.91,7.21,7.31,7.63,8.21,8.87,9.31,9.35,9.23,9.53,10.56,11.6,11.81,11.41,10.87,10.5,10.32,10.15,10.02,10.07,10.21,10.47,10.65,10.73
71.288 | UK BSC 64 Portland Stone | UK BSC 64 Piedra Portland | GU 9.9,195,178,140,73.4,-0.11,22.02,4.04Y,7.35,3.36,45.78,D65/10°,SCI,UV400,19.17,21.95,23.16,24.98,27.51,29.48,30.3,30.88,31.59,32.76,34.77,37.57,40.9,44.5,47.89,50.34,51.93,52.29,52.05,51.29,50.29,49.42,48.73,48.36,48.02,47.78,47.81,48.15,48.5,48.79,48.98
71.288 | UK BSC 64 Portland Stone | UK BSC 64 Piedra Portland | GU 9.9,194,177,139,73.07,0.05,21.99,2.09Y,7.32,4.07,45.26,D65/10°,SCE,UV400,19.42,21.81,22.87,24.67,27.18,29.13,29.92,30.5,31.19,32.32,34.3,37.05,40.36,43.96,47.27,49.72,51.34,51.77,51.5,50.8,49.89,49.01,48.35,47.96,47.66,47.37,47.36,47.57,47.83,48.11,48.32
71.289 | US Dark Green | US Verde Oscuro | FS34102 | GU 4.4,88,89,70,37.37,-3.7,10.94,2.85GY,3.72,1.92,9.74,D65/10°,SCI,UV400,5.41,5.82,5.91,6.12,6.42,6.57,6.76,6.98,7.25,7.43,7.88,8.7,9.67,10.41,10.88,11.13,10.91,10.76,10.47,10.06,9.63,9.27,9,8.89,8.74,8.68,8.77,8.93,9.1,9.22,9.25
71.289 | US Dark Green | US Verde Oscuro | FS34102 | GU 4.4,89,89,72,37.67,-3.32,10.01,5.03GY,3.75,2.15,9.9,D65/10°,SCE,UV400,6.15,6.31,6.32,6.5,6.82,6.95,7.11,7.31,7.53,7.71,8.18,8.96,9.84,10.53,10.9,11.05,11.07,10.93,10.63,10.24,9.85,9.48,9.22,9.12,9,8.92,8.96,9.03,9.18,9.29,9.35
71.290 | US Earth Brown | US Tierra Marrón | FS30099 | GU 5.1,98,85,72,37.13,3.33,9.58,7.08YR,3.7,1.25,9.61,D65/10°,SCI,UV400,6.03,6.42,6.43,6.53,6.72,6.81,6.96,7.17,7.34,7.39,7.63,8.06,8.63,9.11,9.27,9.3,9.42,10.46,11.49,11.8,11.65,11.38,11.13,11.01,10.85,10.76,10.8,10.91,11.04,11.1,11.12
71.290 | US Earth Brown | US Tierra Marrón | FS30099 | GU 5.1,98,85,73,37.33,3.47,8.75,5.09YR,3.72,2.57,9.71,D65/10°,SCE,UV400,6.79,6.84,6.77,6.84,7.05,7.12,7.25,7.42,7.56,7.6,7.86,8.26,8.78,9.19,9.28,9.21,9.56,10.57,11.57,11.88,11.75,11.47,11.24,11.12,11,10.89,10.89,10.92,11.03,11.12,11.15
71.291 | US Earth Yellow | US Tierra Amarilla | FS30257 | GU 4.6,174,134,95,59.07,10.04,26.85,10.06YR,5.89,4.54,27.1,D65/10°,SCI,UV400,11.52,12.13,12.09,12.19,12.67,13.03,13.46,14.35,15.28,15.76,16.79,18.84,21.57,24.01,25.26,25.6,26.87,30.77,35.47,37.72,37.83,37.3,36.72,36.38,36.07,35.85,35.95,36.32,36.79,37.07,37.34
71.291 | US Earth Yellow | US Tierra Amarilla | FS30257 | GU 4.6,173,134,96,58.94,9.97,26.24,10.05YR,5.88,4.43,26.96,D65/10°,SCE,UV400,12.13,12.42,12.29,12.41,12.86,13.22,13.57,14.43,15.37,15.83,16.85,18.88,21.53,23.9,25.07,25.35,26.78,30.67,35.15,37.42,37.56,36.99,36.44,36.08,35.8,35.57,35.67,35.95,36.38,36.71,37.02
71.292 | US Loam | US Marrón Barro | FS34086 | GU 7.6,87,87,81,37.03,-1.36,3.39,2.12G,3.66,0.74,9.56,D65/10°,SCI,UV400,7.57,8.04,8.08,8.23,8.48,8.57,8.61,8.67,8.78,8.8,8.97,9.26,9.58,9.81,9.9,9.87,9.71,9.94,10.07,9.92,9.66,9.38,9.15,9.03,8.89,8.81,8.81,8.84,8.89,8.91,8.84
71.292 | US Loam | US Marrón Barro | FS34086 | GU 7.6,86,86,81,36.78,-1.11,2.92,2.13G,3.64,0.68,9.42,D65/10°,SCE,UV400,8,8.15,8.13,8.26,8.52,8.57,8.6,8.66,8.72,8.74,8.92,9.18,9.45,9.63,9.64,9.55,9.6,9.82,9.93,9.78,9.55,9.28,9.05,8.95,8.82,8.72,8.69,8.63,8.66,8.66,8.62
71.293 | US Earth Red | US Tierra Roja | FS30117 | GU 6.8,120,90,79,41.34,10.48,11.49,6.45YR,4.12,1.65,12.08,D65/10°,SCI,UV400,8.15,8.42,8.3,8.16,8.23,8.21,8.29,8.46,8.59,8.53,8.67,9.05,9.66,10.13,10.16,10.01,10.46,12.83,16.16,18.01,17.87,17.08,16.47,16.15,15.87,15.67,15.8,16.21,16.67,17.01,17.23
71.293 | US Earth Red | US Tierra Roja | FS30117 | GU 6.8,120,90,80,41.27,10.55,10.84,4.72YR,4.11,2.58,12.03,D65/10°,SCE,UV400,8.72,8.68,8.46,8.34,8.43,8.38,8.42,8.58,8.68,8.62,8.75,9.12,9.66,10.07,10.03,9.81,10.46,12.77,16.06,17.91,17.78,16.99,16.39,16.1,15.83,15.62,15.7,16,16.45,16.81,16.99
71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1,88,86,71,36.59,-2.33,8.97,5.05GY,3.64,2.31,9.32,D65/10°,SCI,UV400,5.78,6.12,6.19,6.35,6.59,6.72,6.91,7.13,7.37,7.5,7.82,8.39,9.11,9.69,9.93,9.94,9.87,10.44,10.74,10.32,9.58,8.96,8.57,8.41,8.26,8.19,8.35,8.65,8.96,9.22,9.33
71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1,88,87,73,36.82,-2,8.16,5.75GY,3.66,1.93,9.44,D65/10°,SCE,UV400,6.44,6.56,6.52,6.65,6.92,7.04,7.2,7.41,7.61,7.72,8.05,8.6,9.26,9.77,9.9,9.85,10.01,10.56,10.83,10.43,9.74,9.12,8.74,8.6,8.47,8.39,8.49,8.7,9.01,9.22,9.38
71.295 | USN Sea Blue | USN Azul Marino | FS35042 | ANA607 | GU 2.2,65,70,73,29.46,-1.21,-2.56,5.15BG,2.9,3.25,6.02,D65/10°,SCI,UV400,6.4,6.84,6.82,6.76,6.72,6.62,6.61,6.51,6.49,6.39,6.34,6.25,6.24,6.23,6.22,6.24,5.9,5.81,5.72,5.66,5.6,5.56,5.51,5.49,5.49,5.48,5.55,5.56,5.59,5.56,5.53
71.295 | USN Sea Blue | USN Azul Marino | FS35042 | ANA607 | GU 2.2,66,71,75,29.92,-0.9,-3.1,5.16BG,2.94,3.3,6.2,D65/10°,SCE,UV400,7.18,7.29,7.2,7.14,7.08,6.96,6.91,6.81,6.75,6.66,6.6,6.52,6.45,6.38,6.3,6.21,6.12,6.04,5.92,5.84,5.82,5.77,5.7,5.71,5.67,5.66,5.67,5.62,5.61,5.55,5.51
71.296 | USAAF Light Gray | Curtiss Grey | FS36622 | GU 5.1,185,182,170,74.02,-0.95,6.18,8.16R,7.36,0.42,46.73,D65/10°,SCI,UV400,28.71,36.12,38.19,39.48,40.96,42.02,42.37,42.5,42.71,43.12,43.88,44.81,45.9,46.89,47.72,48.17,48.3,48.25,48.09,47.85,47.67,47.57,47.34,47.21,47.01,46.86,46.71,46.69,46.63,46.54,46.45
71.296 | USAAF Light Gray | Curtiss Grey | FS36622 | GU 5.1,184,181,170,73.82,-0.84,6.2,8.10R,7.34,0.37,46.43,D65/10°,SCE,UV400,28.75,35.84,37.85,39.16,40.71,41.75,42.04,42.19,42.38,42.8,43.59,44.52,45.55,46.53,47.27,47.79,47.99,48.01,47.84,47.64,47.49,47.35,47.13,46.97,46.82,46.61,46.44,46.29,46.14,46.04,45.98
71.297 | JGSD Brown 3606 | JGSD Marrón 3606 | GU 6.4,107,93,85,40.81,3.91,6.75,10.09R,4.05,2.66,11.75,D65/10°,SCI,UV400,8.52,9,9.01,9.13,9.4,9.52,9.58,9.68,9.78,9.75,9.9,10.22,10.69,11.08,11.18,11.11,11.23,12.42,13.74,14.25,14.12,13.81,13.52,13.33,13.12,12.97,12.92,12.95,12.99,12.98,12.93
71.297 | JGSD Brown 3606 | JGSD Marrón 3606 | GU 6.4,106,93,85,40.65,4.11,6.24,7.18R,4.03,0.59,11.65,D65/10°,SCE,UV400,9.02,9.17,9.11,9.21,9.51,9.58,9.63,9.72,9.77,9.75,9.91,10.2,10.61,10.94,10.96,10.8,11.15,12.33,13.62,14.14,14.05,13.71,13.42,13.24,13.07,12.89,12.8,12.75,12.79,12.79,12.79
71.298 | M495 Light Gray | M495 Gris Claro | FS36357 | GU 1.8,153,149,133,61.73,-1.51,8.9,7.07GY,6.1,0.9,30.09,D65/10°,SCI,UV400,19.04,21.76,22.41,23.01,23.9,24.58,24.94,25.43,25.86,26.25,27.08,28.31,29.6,30.57,31.22,31.6,31.6,31.54,31.37,31.15,30.98,30.83,30.62,30.46,30.27,30.12,30.06,29.99,29.94,29.78,29.74
71.298 | M495 Light Gray | M495 Gris Claro | FS36357 | GU 1.8,152,148,133,61.58,-1.39,8.77,7.08GY,6.08,0.87,29.92,D65/10°,SCE,UV400,19.53,21.8,22.34,22.95,23.84,24.53,24.84,25.32,25.74,26.13,26.98,28.21,29.43,30.36,30.93,31.25,31.43,31.38,31.2,30.99,30.85,30.71,30.53,30.35,30.21,30.03,29.94,29.77,29.66,29.58,29.55
71.299 | Intermediate Blue | Azul Intermedio | FS35164 | ANA608 | GU 2.5,91,110,122,45.42,-3.94,-9.16,10.06B,4.43,2.5,14.84,D65/10°,SCI,UV400,17.3,19.28,19.45,19.44,19.34,19.27,19.08,18.81,18.48,18.06,17.59,17.04,16.49,15.94,15.48,14.96,13.94,13.39,13.02,12.73,12.41,12.06,11.8,11.72,11.73,11.94,12.32,12.48,12.36,12.09,11.61
71.299 | Intermediate Blue | Azul Intermedio | FS35164 | ANA608 | GU 2.5,92,110,122,45.48,-3.71,-9.17,2.06PB,4.44,1.72,14.89,D65/10°,SCE,UV400,17.57,19.33,19.51,19.47,19.43,19.34,19.11,18.87,18.56,18.12,17.64,17.08,16.52,15.96,15.42,14.81,14,13.49,13.12,12.84,12.55,12.17,11.94,11.87,11.91,12.1,12.42,12.5,12.38,12.12,11.72
71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6,59,65,69,27.38,-1.46,-2.95,6.54BG,2.69,1.86,5.23,D65/10°,SCI,UV400,5.79,6.01,5.99,5.95,5.95,5.9,5.85,5.78,5.78,5.7,5.66,5.56,5.51,5.48,5.4,5.33,5.09,4.97,4.88,4.84,4.79,4.77,4.74,4.73,4.74,4.74,4.79,4.75,4.76,4.7,4.69
71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6,48,55,60,22.85,-1.7,-4.34,10.14BG,2.24,2.84,3.76,D65/10°,SCE,UV400,4.76,4.78,4.67,4.64,4.64,4.54,4.5,4.43,4.39,4.31,4.25,4.15,4.1,3.97,3.87,3.72,3.63,3.53,3.41,3.33,3.31,3.27,3.21,3.25,3.23,3.19,3.2,3.15,3.14,3.09,3.05
71.301 | Amt-4 Camouflage Green | Amt-4 Camuflaje Verde | GU 5.8,106,97,69,41.54,-1.21,17.45,7.09Y,4.15,1.11,12.2,D65/10°,SCI,UV400,5.46,5.82,5.94,6.21,6.57,6.74,6.91,7.14,7.47,7.68,8.28,9.44,10.98,12.39,13.13,13.28,13.58,14.9,15.9,15.13,13.51,12.21,11.48,11.15,10.88,10.75,10.94,11.41,12.01,12.54,12.89
71.301 | Amt-4 Camouflage Green | Amt-4 Camuflaje Verde | GU 5.8,106,97,70,41.36,-0.97,16.62,7.07Y,4.13,1.3,12.09,D65/10°,SCE,UV400,6.03,6.08,6.1,6.35,6.74,6.89,7.03,7.26,7.51,7.73,8.33,9.44,10.9,12.21,12.87,12.98,13.43,14.76,15.75,15.01,13.43,12.11,11.39,11.08,10.86,10.71,10.85,11.23,11.82,12.35,12.72
71.302 | Sky Type S | Verde Cielo | BS210 | GU 2.5,154,155,133,63.66,-4.59,11.36,5.03GY,6.3,2.24,32.39,D65/10°,SCI,UV400,18.77,21.19,21.95,22.87,24.17,25.18,25.71,26.29,26.86,27.44,28.58,30.31,32.17,33.72,34.86,35.46,35.41,35.06,34.33,33.25,31.97,30.87,30.09,29.66,29.29,29.07,29.2,29.63,30.12,30.46,30.69
71.302 | Sky Type S | Verde Cielo | BS210 | GU 2.5,153,155,133,63.46,-4.42,11.14,5.03GY,6.28,2.28,32.14,D65/10°,SCE,UV400,19.18,21.23,21.85,22.8,24.12,25.12,25.6,26.2,26.75,27.32,28.47,30.17,31.96,33.42,34.44,34.98,35.07,34.74,34.03,33.01,31.8,30.76,30.02,29.58,29.25,28.98,29.09,29.41,29.86,30.2,30.44
71.303 | A-24M Camouflage Green | A-24M Verde Camuflaje | GU 7.1,87,90,75,37.78,-4.3,8.45,7.04GY,3.75,1.55,9.96,D65/10°,SCI,UV400,6.14,6.6,6.69,6.96,7.33,7.5,7.6,7.72,7.92,8.08,8.48,9.21,10.09,10.79,11.19,11.34,11.06,10.82,10.45,9.97,9.53,9.15,8.85,8.71,8.55,8.44,8.46,8.54,8.66,8.69,8.69
71.303 | A-24M Camouflage Green | A-24M Verde Camuflaje | GU 7.1,87,89,75,37.59,-3.98,7.8,7.04GY,3.73,1.52,9.86,D65/10°,SCE,UV400,6.67,6.81,6.83,7.09,7.46,7.59,7.67,7.77,7.92,8.08,8.5,9.19,10,10.62,10.95,11.03,10.95,10.72,10.33,9.88,9.47,9.09,8.81,8.69,8.54,8.42,8.41,8.39,8.46,8.48,8.5
71.304 | Amt-11 Blue Grey | Amt-11 Azul Grisáceo | GU 6.7,82,88,93,37.32,-1.05,-3.73,9.14BG,3.67,2.5,9.71,D65/10°,SCI,UV400,10.99,11.58,11.48,11.29,11.14,10.96,10.82,10.66,10.52,10.37,10.26,10.14,10.05,9.98,9.92,9.89,9.55,9.44,9.31,9.16,9.08,9,8.9,8.84,8.73,8.67,8.64,8.6,8.56,8.5,8.4
71.304 | Amt-11 Blue Grey | Amt-11 Azul Grisáceo | GU 6.7,82,88,93,37.19,-0.81,-3.95,9.10BG,3.66,2.48,9.64,D65/10°,SCE,UV400,11.4,11.63,11.46,11.3,11.15,10.97,10.82,10.63,10.48,10.34,10.24,10.11,9.99,9.87,9.74,9.62,9.52,9.41,9.25,9.12,9.07,8.99,8.87,8.84,8.75,8.67,8.61,8.48,8.42,8.34,8.28
71.305 | Interior Grey Green | Interior Gris Verde | FS34373 | GU 3.7,147,156,132,63.36,-7.99,11.62,7.02GY,6.27,1.68,32.03,D65/10°,SCI,UV400,18.86,21.31,21.89,22.48,23.49,24.35,25.01,25.96,26.76,27.4,28.7,30.81,33.02,34.66,35.67,36.06,35.65,34.88,33.59,31.79,29.68,27.97,26.88,26.36,25.95,25.72,26.01,26.76,27.62,28.28,28.79
71.305 | Interior Grey Green | Interior Gris Verde | FS34373 | GU 3.7,146,156,132,63.06,-7.76,11.42,7.02GY,6.24,1.75,31.66,D65/10°,SCE,UV400,19.15,21.23,21.71,22.3,23.33,24.19,24.8,25.75,26.54,27.16,28.47,30.55,32.64,34.2,35.13,35.44,35.18,34.46,33.21,31.47,29.48,27.79,26.75,26.22,25.85,25.6,25.86,26.49,27.28,27.99,28.45
71.306 | Sky Blue | Azul Cielo | FS35550 | GU 3.5,188,206,208,81.68,-5.68,-2.82,5.03B,8.12,2.42,59.72,D65/10°,SCI,UV400,38.03,54.73,60.82,62.34,63.05,63.47,63.58,63.63,63.61,63.63,63.72,63.72,63.64,63.32,62.65,61.66,59.5,57.71,56.23,55.09,54.07,53.29,52.86,52.82,52.81,53.19,53.73,54.07,53.72,53.1,52.18
71.306 | Sky Blue | Azul Cielo | FS35550 | GU 3.5,188,205,207,81.38,-5.56,-2.73,5.03B,8.09,2.45,59.17,D65/10°,SCE,UV400,37.97,54.24,60.09,61.58,62.4,62.82,62.87,62.97,62.99,62.97,63.1,63.14,62.99,62.64,61.97,60.99,58.94,57.23,55.78,54.71,53.72,52.91,52.52,52.44,52.51,52.82,53.35,53.54,53.2,52.59,51.65
71.307 | BS Medium Sea Grey | BS Gris Mar Medio | BS637 | GU 5.3,129,140,145,57.83,-3.3,-3.61,10.07BG,5.66,2.9,25.78,D65/10°,SCI,UV400,24.1,27.94,28.47,28.32,28.15,28.05,27.95,27.94,27.92,27.78,27.58,27.35,27.16,26.91,26.65,26.35,25.62,25.09,24.59,24.1,23.63,23.17,22.86,22.69,22.51,22.41,22.47,22.5,22.42,22.26,22
71.307 | BS Medium Sea Grey | BS Gris Mar Medio | BS637 | GU 5.3,129,140,144,57.73,-3.13,-3.52,10.08BG,5.66,2.94,25.68,D65/10°,SCE,UV400,24.4,27.81,28.18,28.11,27.96,27.93,27.8,27.8,27.79,27.64,27.48,27.26,27.03,26.75,26.42,26.07,25.55,25.07,24.54,24.09,23.66,23.24,22.93,22.74,22.59,22.49,22.51,22.44,22.34,22.19,22
71.308 | Amt-12 Dark Grey | Amt-12 Gris Oscuro | GU 6.0,64,70,75,29.49,-0.76,-4.2,7.15BG,2.9,1.24,6.03,D65/10°,SCI,UV400,7.13,7.47,7.4,7.28,7.22,7.09,6.99,6.85,6.74,6.59,6.48,6.34,6.26,6.19,6.15,6.17,5.83,5.75,5.68,5.64,5.58,5.54,5.46,5.43,5.44,5.42,5.48,5.45,5.46,5.43,5.38
71.308 | Amt-12 Dark Grey | Amt-12 Gris Oscuro | GU 6.0,64,69,76,29.19,-0.49,-4.78,9.76BG,2.87,2.83,5.91,D65/10°,SCE,UV400,7.54,7.58,7.43,7.33,7.28,7.11,6.98,6.83,6.7,6.55,6.44,6.29,6.16,6.05,5.93,5.84,5.74,5.68,5.58,5.52,5.5,5.44,5.35,5.36,5.33,5.31,5.31,5.23,5.2,5.13,5.08
71.309 | Dark Slate Grey | Gris Pizarra Oscuro | FS34096 | BS634 | GU 1.9,83,86,76,36.19,-3.02,5.07,10.08GY,3.58,2.63,9.11,D65/10°,SCI,UV400,8.19,8.25,7.85,7.48,7.37,7.3,7.48,7.84,8.14,8.13,8.39,9.06,9.86,10.21,9.87,9.32,8.76,9.17,9.53,9.4,8.97,8.58,8.35,8.33,8.33,8.56,8.98,9.14,8.94,8.58,8.08
71.309 | Dark Slate Grey | Gris Pizarra Oscuro | FS34096 | BS634 | GU 1.9,84,86,78,36.43,-2.66,4.42,10.10GY,3.6,2.73,9.23,D65/10°,SCE,UV400,8.84,8.63,8.17,7.81,7.69,7.6,7.74,8.1,8.36,8.33,8.62,9.26,9.96,10.27,9.85,9.26,8.93,9.32,9.66,9.53,9.14,8.73,8.55,8.52,8.54,8.75,9.12,9.18,8.96,8.58,8.11
71.310 | IJN Deep Dark Green | IJN Verde Oscuro Intenso | GU 2.0,54,80,77,32.13,-10.49,-1.36,5.32BG,3.15,2.14,7.14,D65/10°,SCI,UV400,5.79,6.34,6.48,6.71,7.02,7.29,7.79,8.28,8.66,8.78,8.78,8.69,8.59,8.43,8.21,7.92,7.1,6.57,5.99,5.43,4.98,4.74,4.61,4.56,4.55,4.55,4.66,4.77,4.96,5.06,5.12
71.310 | IJN Deep Dark Green | IJN Verde Oscuro Intenso | GU 2.0,55,80,78,32.43,-10.07,-1.92,5.38BG,3.18,2.14,7.28,D65/10°,SCE,UV400,6.53,6.78,6.83,7.06,7.34,7.59,8.04,8.54,8.86,8.98,8.99,8.89,8.74,8.53,8.23,7.86,7.29,6.77,6.15,5.57,5.15,4.88,4.72,4.7,4.65,4.63,4.72,4.78,4.93,5.03,5.08
71.311 | IJN Ash Grey | IJN Gris Ceniza | GU 2.4,144,133,114,56.31,0.52,11.99,7.18Y,5.57,2.29,24.22,D65/10°,SCI,UV400,14.95,16.35,16.46,16.76,17.3,17.74,18.08,18.64,19.15,19.44,20.21,21.52,23.02,24.16,24.75,24.9,25.11,26.08,26.97,27.11,26.74,26.24,25.85,25.6,25.36,25.21,25.27,25.44,25.63,25.71,25.75
71.311 | IJN Ash Grey | IJN Gris Ceniza | GU 2.4,144,133,114,56.24,0.66,11.66,5.53Y,5.57,1.87,24.15,D65/10°,SCE,UV400,15.33,16.48,16.67,16.9,17.45,17.84,18.13,18.7,19.19,19.5,20.26,21.55,22.96,24.04,24.53,24.65,25.05,26.05,26.9,27.03,26.67,26.2,25.82,25.58,25.38,25.2,25.23,25.32,25.44,25.56,25.63
71.312 | IJN Medium Grey | IJN Gris Medio | GU 2.2,143,140,128,58.4,-1.23,7.05,7.09GY,5.76,0.68,26.39,D65/10°,SCI,UV400,17.23,19.27,19.88,20.83,21.94,22.74,22.95,23,23.15,23.49,24.09,24.89,25.78,26.6,27.28,27.68,27.68,27.58,27.42,27.24,27.06,26.88,26.66,26.48,26.27,26.11,25.99,25.88,25.79,25.6,25.48
71.312 | IJN Medium Grey | IJN Gris Medio | GU 2.2,143,140,128,58.31,-1.1,6.93,7.84GY,5.75,1.23,26.29,D65/10°,SCE,UV400,17.53,19.3,19.91,20.78,21.96,22.73,22.9,22.97,23.1,23.43,24.06,24.84,25.68,26.46,27.06,27.42,27.58,27.55,27.36,27.15,27.02,26.85,26.64,26.44,26.27,26.08,25.95,25.76,25.6,25.48,25.39
71.313 | Dark Mediterranean Blue | Azul Mediterraneo Oscuro | GU 1.3,46,52,59,21.53,-0.88,-5.09,3.01B,2.11,1.55,3.39,D65/10°,SCI,UV400,3.67,3.92,3.97,4.12,4.26,4.34,4.41,4.4,4.32,4.14,3.94,3.7,3.54,3.45,3.37,3.36,3.12,3.07,3.04,3.04,3.02,3.04,3.04,3.06,3.1,3.14,3.25,3.34,3.49,3.61,3.76
71.313 | Dark Mediterranean Blue | Azul Mediterraneo Oscuro | GU 1.3,46,53,61,21.91,-0.57,-5.9,5.85B,2.14,2.76,3.49,D65/10°,SCE,UV400,4.17,4.26,4.25,4.41,4.58,4.63,4.68,4.64,4.55,4.34,4.12,3.86,3.68,3.53,3.4,3.31,3.24,3.2,3.14,3.1,3.13,3.13,3.12,3.18,3.19,3.2,3.3,3.34,3.49,3.61,3.75
71.314 | Seaplane Gray | Gris Hidroavión | FS36081 | ANA625 | GU 3.8,73,76,77,32.36,-1.09,-0.89,2.15BG,3.19,1.03,7.24,D65/10°,SCI,UV400,7.12,7.52,7.52,7.52,7.57,7.5,7.47,7.4,7.38,7.33,7.33,7.34,7.42,7.44,7.47,7.5,7.22,7.18,7.1,7.01,6.97,6.92,6.82,6.79,6.71,6.66,6.67,6.66,6.64,6.63,6.55
71.314 | Seaplane Gray | Gris Hidroavión | FS36081 | ANA625 | GU 3.8,73,76,78,32.39,-0.75,-1.35,2.15BG,3.19,0.99,7.26,D65/10°,SCE,UV400,7.67,7.78,7.69,7.67,7.72,7.65,7.59,7.52,7.47,7.41,7.41,7.41,7.43,7.41,7.37,7.31,7.27,7.24,7.14,7.05,7.02,6.97,6.89,6.87,6.8,6.73,6.68,6.58,6.57,6.51,6.49
71.315 | Tire Black | Negro Caucho | GU 1.2,73,76,75,32.18,-1.29,0.28,7.68G,3.18,1.3,7.16,D65/10°,SCI,UV400,6.96,7.35,7.25,7.12,7.08,7,7.03,7.08,7.14,7.09,7.11,7.2,7.34,7.39,7.4,7.38,7.12,7.23,7.25,7.12,6.98,6.84,6.68,6.64,6.55,6.5,6.55,6.59,6.66,6.71,6.65
71.315 | Tire Black | Negro Caucho | GU 1.2,74,77,77,32.58,-0.92,-0.28,10.15G,3.22,3.48,7.34,D65/10°,SCE,UV400,7.77,7.8,7.6,7.48,7.43,7.32,7.34,7.39,7.4,7.34,7.37,7.44,7.52,7.52,7.44,7.36,7.33,7.44,7.43,7.32,7.2,7.06,6.92,6.88,6.8,6.72,6.72,6.68,6.71,6.73,6.71
71.316 | N. 41 Dark Olive Drab | N. 41 Verde Oliva Oscuro | GU 2.9,83,77,63,33,0.02,8.99,2.08GY,3.29,1.21,7.54,D65/10°,SCI,UV400,4.74,4.97,5.01,5.11,5.23,5.31,5.41,5.56,5.73,5.8,6.03,6.46,7.06,7.52,7.66,7.7,7.73,8.59,9.3,9.08,8.36,7.75,7.38,7.24,7.1,7.05,7.18,7.43,7.74,7.99,8.11
71.316 | N. 41 Dark Olive Drab | N. 41 Verde Oliva Oscuro | GU 2.9,83,77,65,33.16,0.28,8.26,4.18GY,3.3,2.13,7.61,D65/10°,SCE,UV400,5.27,5.28,5.21,5.33,5.49,5.54,5.62,5.74,5.88,5.95,6.2,6.62,7.15,7.55,7.63,7.56,7.83,8.69,9.35,9.14,8.46,7.86,7.49,7.36,7.24,7.16,7.25,7.41,7.68,7.92,8.06
71.317 | AII SV. Gol Light Blue | AII SV. Gol Azul Claro | GU 3.2,95,186,204,71.05,-22.13,-17.52,5.05B,6.9,6.5,42.26,D65/10°,SCI,UV400,34.61,47.04,51.27,54.31,58.14,60.85,61.77,62.07,62.07,61.94,61.71,60.55,57.95,53.87,48.75,43.22,35.95,31.11,28.04,26.15,24.54,23.32,22.79,22.76,22.87,23.49,24.53,24.96,24.38,23.35,21.96
71.317 | AII SV. Gol Light Blue | AII SV. Gol Azul Claro | GU 3.2,95,185,203,70.73,-21.9,-17.38,5.04B,6.86,6.44,41.79,D65/10°,SCE,UV400,34.36,46.25,50.57,53.52,57.46,60.11,61,61.32,61.32,61.19,61,59.89,57.28,53.2,48.15,42.62,35.42,30.84,27.81,25.94,24.42,23.22,22.74,22.68,22.82,23.41,24.37,24.69,24.1,23.13,21.79
71.318 | Amt-7 Greyish Blue | Amt-7 Azul Grisáceo | GU 1.7,84,134,152,53.32,-11.86,-14.67,7.05B,5.16,4.36,21.34,D65/10°,SCI,UV400,24.19,29.27,30.02,30.27,30.53,30.65,30.5,30.32,29.95,29.39,28.7,27.85,26.9,25.67,24.01,22.01,19.11,17.24,15.87,14.85,14,13.32,13.01,12.93,12.95,13.23,13.77,14.02,13.77,13.23,12.46
71.318 | Amt-7 Greyish Blue | Amt-7 Azul Grisáceo | GU 1.7,85,134,151,53.28,-11.62,-14.44,7.05B,5.16,4.35,21.31,D65/10°,SCE,UV400,24.51,29.09,29.74,30.02,30.32,30.47,30.29,30.12,29.77,29.22,28.59,27.75,26.78,25.54,23.84,21.86,19.12,17.29,15.94,14.96,14.15,13.45,13.15,13.08,13.12,13.39,13.86,14.02,13.77,13.25,12.55
71.319 | A-28M Greyish Blue | A-28M Azul Grisáceo | GU 2.8,105,150,142,58.9,-17.25,-0.48,4.33BG,5.76,3.55,26.92,D65/10°,SCI,UV400,18.69,21.44,22.55,23.92,25.52,27.12,28.71,30.23,31.14,31.54,31.58,31.4,31.46,31.54,30.98,29.9,28.31,27.47,25.58,22.19,18.62,16.12,14.85,14.3,13.89,13.67,14.06,15.02,16.25,17.38,18.17
71.319 | A-28M Greyish Blue | A-28M Azul Grisáceo | GU 2.8,105,149,141,58.69,-16.96,-0.48,4.27BG,5.74,3.54,26.7,D65/10°,SCE,UV400,19,21.36,22.33,23.72,25.32,26.93,28.43,29.94,30.82,31.21,31.29,31.14,31.17,31.21,30.61,29.45,28.09,27.3,25.41,22.12,18.6,16.1,14.87,14.33,13.94,13.71,14.03,14.9,16.11,17.23,18.01
71.320 | Amt-1 Light Greyish Brown | Amt-1 Marrón Grisác. Claro | GU 1.6,142,132,122,55.97,2.05,6.76,10.08R,5.52,2.73,23.88,D65/10°,SCI,UV400,18.02,19.69,19.67,19.59,19.73,19.94,20.22,20.78,21.14,21.09,21.29,21.84,22.68,23.34,23.3,22.93,23.22,25.31,27.35,27.71,26.85,25.79,25.07,24.71,24.39,24.23,24.44,24.93,25.48,25.85,26.1
71.320 | Amt-1 Light Greyish Brown | Amt-1 Marrón Grisác. Claro | GU 1.6,142,132,122,55.91,2.15,6.61,8.63R,5.52,1.24,23.82,D65/10°,SCE,UV400,18.3,19.73,19.71,19.6,19.78,20,20.23,20.8,21.15,21.12,21.32,21.86,22.63,23.23,23.14,22.72,23.21,25.3,27.28,27.62,26.8,25.77,25.09,24.72,24.45,24.25,24.43,24.83,25.3,25.7,25.96
71.321 | Sky Green | IJA Light Grey Green | FS34424 | ANA610 | GU 2.4,162,165,143,67.19,-5.24,10.99,7.03GY,6.66,1.59,36.88,D65/10°,SCI,UV400,21.81,25.23,26,26.76,27.95,28.94,29.68,30.67,31.51,32.06,33.23,35.13,37.19,38.79,39.57,39.6,39.41,39.78,39.61,38.26,36.23,34.48,33.37,32.84,32.49,32.39,32.86,33.72,34.62,35.17,35.47
71.321 | Sky Green | IJA Light Grey Green | FS34424 | ANA610 | GU 2.4,161,164,143,66.93,-5.08,10.85,7.03GY,6.63,1.57,36.54,D65/10°,SCE,UV400,22.09,25.15,25.77,26.57,27.75,28.78,29.45,30.46,31.25,31.8,32.97,34.8,36.79,38.38,39.1,39.1,39.03,39.45,39.29,37.95,35.94,34.19,33.17,32.65,32.36,32.23,32.67,33.44,34.29,34.88,35.18
71.322 | IJN Black Green | IJN Verde Negro | GU 1.3,62,73,57,29.79,-8.16,8.32,7.06GY,2.96,1.38,6.15,D65/10°,SCI,UV400,3.74,3.95,3.98,4.1,4.24,4.31,4.41,4.59,4.77,4.89,5.22,5.85,6.73,7.41,7.74,7.73,7.07,6.58,5.98,5.39,4.9,4.64,4.51,4.46,4.43,4.43,4.55,4.69,4.9,5.02,5.12
71.322 | IJN Black Green | IJN Verde Negro | GU 1.3,63,74,59,30.24,-7.87,7.67,7.04GY,3.01,1.51,6.33,D65/10°,SCE,UV400,4.26,4.31,4.25,4.38,4.54,4.57,4.68,4.85,5.01,5.13,5.49,6.12,6.95,7.58,7.8,7.73,7.32,6.83,6.2,5.58,5.11,4.82,4.66,4.63,4.59,4.56,4.66,4.75,4.92,5.04,5.08
71.323 | BS Dark Earth | BS Tierra Oscura | BS450 | GU 1.6,116,94,73,41.67,5.44,15.5,2.07Y,4.16,1.27,12.29,D65/10°,SCI,UV400,5.94,6.35,6.47,6.72,7.15,7.38,7.55,7.77,8.01,8.16,8.58,9.33,10.33,11.21,11.65,11.77,12.19,13.92,15.8,16.43,16.07,15.46,15.04,14.79,14.56,14.42,14.52,14.79,15.1,15.32,15.46
71.323 | BS Dark Earth | BS Tierra Oscura | BS450 | GU 1.6,116,94,75,41.82,5.57,14.54,10.05YR,4.17,2.36,12.39,D65/10°,SCE,UV400,6.69,6.84,6.83,7.08,7.5,7.71,7.87,8.07,8.27,8.41,8.83,9.55,10.45,11.28,11.63,11.66,12.29,14.01,15.85,16.49,16.17,15.56,15.13,14.89,14.7,14.53,14.57,14.76,15.05,15.27,15.39
71.324 | BS Dark Green | BS Verde Oscuro | BS241 | GU 1.7,68,69,56,29.07,-3.17,7.99,5.05GY,2.9,2.24,5.86,D65/10°,SCI,UV400,3.85,4.04,4.05,4.11,4.15,4.17,4.24,4.31,4.37,4.41,4.65,5.1,5.83,6.43,6.64,6.62,6.4,6.7,6.7,6.18,5.62,5.26,5.07,4.97,4.94,4.91,5.01,5.14,5.34,5.45,5.53
71.324 | BS Dark Green | BS Verde Oscuro | BS241 | GU 1.7,69,70,57,29.33,-2.92,7.5,7.06GY,2.92,1.34,5.97,D65/10°,SCE,UV400,4.32,4.3,4.23,4.29,4.36,4.33,4.4,4.46,4.5,4.55,4.78,5.26,5.97,6.52,6.63,6.52,6.56,6.86,6.82,6.32,5.77,5.38,5.16,5.1,5.03,4.98,5.05,5.12,5.28,5.38,5.45
71.325 | IJN Dark Black Green | IJN Verde Negro Oscuro | GU 2.4,69,70,64,29.54,-1.54,3.45,10.12GY,2.93,2.84,6.05,D65/10°,SCI,UV400,5.19,5.39,5.31,5.22,5.18,5.17,5.24,5.37,5.47,5.46,5.6,5.84,6.15,6.32,6.3,6.24,6.08,6.39,6.55,6.37,6.05,5.8,5.62,5.54,5.48,5.43,5.53,5.6,5.77,5.84,5.9
71.325 | IJN Dark Black Green | IJN Verde Negro Oscuro | GU 2.4,70,70,65,29.86,-1.24,2.81,2.13G,2.96,0.71,6.18,D65/10°,SCE,UV400,5.83,5.8,5.58,5.49,5.48,5.42,5.49,5.61,5.67,5.65,5.8,6.05,6.31,6.41,6.31,6.19,6.25,6.56,6.7,6.52,6.22,5.96,5.76,5.69,5.62,5.56,5.6,5.63,5.74,5.79,5.85
71.326 | IJA Grey Green | IJA Gris Verdoso | GU 7.2,184,174,155,71.59,0.43,10.75,10.05YR,7.12,2.49,43.05,D65/10°,SCI,UV400,27.32,31.59,32.25,32.78,33.73,34.43,34.89,35.68,36.34,36.71,37.68,39.42,41.39,42.95,43.64,43.67,44,45.62,47.29,47.51,46.66,45.65,44.87,44.44,44.07,43.82,43.87,44.3,44.79,45.14,45.37
71.326 | IJA Grey Green | IJA Gris Verdoso | GU 7.2,183,173,154,71.19,0.55,10.85,10.05YR,7.08,2.47,42.46,D65/10°,SCE,UV400,27.2,31.06,31.65,32.19,33.17,33.9,34.28,35.09,35.74,36.09,37.09,38.83,40.77,42.28,42.94,42.97,43.41,45.1,46.77,47.02,46.18,45.14,44.37,43.92,43.6,43.29,43.31,43.62,44.02,44.36,44.59
71.327 | IAF Sand | Arena IAF | FS33531 | GU 1.7,179,165,146,68.59,1.85,11.66,9.47YR,6.81,1.98,38.78,D65/10°,SCI,UV400,22.83,26.54,27.37,28.26,29.51,30.44,30.89,31.44,31.89,32.3,33.23,34.69,36.42,37.88,38.78,39.13,39.83,41.43,42.82,43.24,43.02,42.68,42.3,42.05,41.8,41.64,41.6,41.74,41.88,41.93,42.01
71.327 | IAF Sand | Arena IAF | FS33531 | GU 1.7,178,164,146,68.36,1.99,11.55,9.40YR,6.79,1.95,38.47,D65/10°,SCE,UV400,23.12,26.47,27.15,28.07,29.33,30.28,30.67,31.22,31.69,32.07,33,34.41,36.04,37.5,38.32,38.66,39.47,41.15,42.56,42.98,42.79,42.42,42.06,41.79,41.58,41.37,41.29,41.3,41.38,41.41,41.44
71.328 | Light Blue | Azul Claro | FS35622 | GU 2.6,194,200,188,80.11,-4.67,5.59,2.06G,7.99,1.28,56.88,D65/10°,SCI,UV400,34.81,45.97,48.85,49.63,50.48,51.22,51.93,52.93,53.66,54.04,54.96,56.39,57.9,58.99,59.5,59.58,59.25,59.15,58.55,57.03,54.93,53.16,52.02,51.49,51.06,50.85,51.17,52.15,53.07,53.85,54.31
71.328 | Light Blue | Azul Claro | FS35622 | GU 2.6,193,200,187,79.83,-4.56,5.65,2.06G,7.96,1.26,56.37,D65/10°,SCE,UV400,34.73,45.5,48.37,49.05,50.01,50.68,51.35,52.36,53.12,53.51,54.44,55.89,57.36,58.42,58.86,58.93,58.68,58.68,58.08,56.64,54.57,52.78,51.7,51.16,50.81,50.55,50.84,51.65,52.55,53.28,53.75
71.329 | Green | Verde | FS34159 | GU 5.0,94,99,92,41.6,-3.77,3.42,2.08G,4.11,1.14,12.24,D65/10°,SCI,UV400,9.59,10.18,10.26,10.5,10.87,11.07,11.18,11.3,11.46,11.56,11.84,12.26,12.68,12.96,13.11,13.12,12.84,12.64,12.33,11.93,11.55,11.19,10.91,10.77,10.62,10.51,10.55,10.65,10.75,10.82,10.81
71.329 | Green | Verde | FS34159 | GU 5.0,93,98,92,41.31,-3.46,3.04,4.85G,4.08,2.83,12.06,D65/10°,SCE,UV400,9.98,10.26,10.27,10.5,10.87,11.04,11.11,11.21,11.33,11.43,11.72,12.11,12.48,12.72,12.79,12.76,12.66,12.48,12.16,11.79,11.43,11.06,10.8,10.68,10.55,10.44,10.43,10.44,10.53,10.61,10.6
71.330 | Khaki Green Num. 3 | Verde Caqui Nº3 | GU 2.1,85,78,67,33.75,0.68,7.68,5.11GY,3.36,2.61,7.89,D65/10°,SCI,UV400,5.72,5.92,5.84,5.78,5.78,5.79,5.91,6.12,6.3,6.3,6.51,6.91,7.42,7.74,7.7,7.59,7.67,8.94,10.29,10.17,9.03,8.05,7.48,7.26,7.07,6.97,7.16,7.53,8.02,8.47,8.71
71.330 | Khaki Green Num. 3 | Verde Caqui Nº3 | GU 2.1,85,78,68,33.92,0.94,6.92,5.12GY,3.38,2.7,7.97,D65/10°,SCE,UV400,6.41,6.32,6.12,6.04,6.07,6.03,6.15,6.35,6.49,6.48,6.69,7.09,7.53,7.78,7.67,7.46,7.8,9.05,10.33,10.22,9.13,8.17,7.62,7.41,7.23,7.12,7.25,7.53,7.99,8.4,8.67
71.331 | Cockpit Eme. Green “Faded” | Verde Interior Cabina | GU 1.6,43,156,128,57.97,-38.07,5.78,10.04G,5.63,7.35,25.93,D65/10°,SCI,UV400,13.87,15.21,15.77,16.84,18.1,19.67,22.33,27.69,34.71,38.61,39.39,38.67,37.4,35.65,33.23,30.29,25.71,21.99,18.2,14.36,11.33,9.54,8.71,8.4,8.18,8.09,8.41,9.09,9.99,10.83,11.42
71.331 | Cockpit Eme. Green “Faded” | Verde Interior Cabina | GU 1.6,46,155,128,57.82,-37.26,5.55,10.04G,5.62,7.21,25.77,D65/10°,SCE,UV400,14.25,15.43,15.99,16.97,18.21,19.73,22.26,27.55,34.36,38.24,39.05,38.3,36.99,35.24,32.84,29.92,25.63,21.99,18.2,14.46,11.48,9.72,8.91,8.62,8.42,8.32,8.59,9.19,10.05,10.88,11.49
71.332 | Underside Blue “Faded” | Azul Desgastado | FS35450 | GU 2.3,112,168,193,66.28,-11.96,-18.23,10.05B,6.42,5.51,35.69,D65/10°,SCI,UV400,35.17,46.02,49.02,50.12,51.15,52.09,52.53,52.82,52.83,51.87,50.24,47.96,45.1,41.83,38.41,34.81,29.73,26.73,25.35,24.78,24.25,23.84,24.27,25.78,27.81,29.68,30.74,30.38,28.83,27.35,27.14
71.332 | Underside Blue “Faded” | Azul Desgastado | FS35450 | GU 2.3,113,168,192,66.07,-11.76,-18.01,10.06B,6.4,5.46,35.41,D65/10°,SCE,UV400,35.11,45.51,48.52,49.49,50.65,51.51,51.91,52.26,52.28,51.35,49.84,47.64,44.71,41.41,37.91,34.32,29.58,26.65,25.27,24.72,24.25,23.85,24.29,25.74,27.78,29.57,30.59,30.15,28.57,27.17,26.98
71.333 | Russian AF Blue | Azul AF Ruso | GU 2.0,0,141,177,53.74,-21.81,-28.99,10.08B,5.08,8.89,21.73,D65/10°,SCI,UV400,23.9,30.12,32.23,35.41,40.23,44.29,45.85,45.96,45.2,43.78,41.7,38.3,33.51,28.02,22.83,18.4,13.55,11.17,9.95,9.28,8.79,8.46,8.4,8.66,8.97,9.43,9.97,10.07,9.65,9.13,8.68
71.333 | Russian AF Blue | Azul AF Ruso | GU 2.0,0,140,176,53.66,-21.31,-28.73,10.07B,5.07,8.78,21.66,D65/10°,SCE,UV400,24.16,29.89,31.86,35.07,39.94,43.99,45.46,45.62,44.85,43.43,41.35,37.93,33.2,27.82,22.65,18.22,13.62,11.3,10.09,9.45,8.99,8.67,8.62,8.87,9.19,9.63,10.12,10.13,9.71,9.17,8.74
71.334 | Flanker Light Blue | Azul Claro Flanker | GU 2.9,166,191,191,75.7,-8.54,-2.75,10.01BG,7.49,2.15,49.41,D65/10°,SCI,UV400,36.42,48.23,51,51.23,51.49,51.82,52.35,53.29,53.79,53.71,53.88,54.29,54.6,54.32,53.31,51.64,48.98,47.29,45.85,44.3,42.54,41.13,40.39,40.17,40.15,40.54,41.44,42.24,42.41,42.1,41.37
71.334 | Flanker Light Blue | Azul Claro Flanker | GU 2.9,165,190,190,75.43,-8.46,-2.6,10.01BG,7.46,2.18,48.97,D65/10°,SCE,UV400,36.32,47.46,50.38,50.57,50.94,51.21,51.73,52.69,53.26,53.15,53.35,53.81,54.05,53.76,52.69,51.12,48.63,47.01,45.56,44.01,42.28,40.83,40.1,39.87,39.89,40.23,41.09,41.76,41.87,41.57,40.84
71.335 | Flanker Light Gray | Gris Claro Flanker | GU 3.8,143,164,165,66,-6.9,-3.06,10.03BG,6.48,2.38,35.32,D65/10°,SCI,UV400,29.55,36.72,37.86,37.64,37.47,37.5,37.58,37.98,38.22,38.18,38.4,38.84,39.07,38.74,38.04,37.01,35.08,33.47,32.2,31.3,30.52,29.9,29.6,29.6,29.68,30.04,30.55,30.71,30.37,29.79,29.06
71.335 | Flanker Light Gray | Gris Claro Flanker | GU 3.8,143,163,164,65.67,-6.69,-3.06,10.03BG,6.45,2.41,34.9,D65/10°,SCE,UV400,29.44,36.3,37.37,37.15,37.08,37.08,37.1,37.54,37.76,37.69,37.93,38.36,38.54,38.23,37.47,36.42,34.61,33.1,31.87,31,30.27,29.67,29.4,29.37,29.51,29.82,30.3,30.34,30,29.43,28.72
71.336 | A-14 Steel Grey | A-14 Gris Acero | GU 1.7,102,105,104,44.37,-1.63,0.47,8.23G,4.37,1.89,14.09,D65/10°,SCI,UV400,13.08,14.15,14.04,13.91,13.81,13.79,13.83,13.95,14.03,14.01,14.11,14.32,14.47,14.54,14.53,14.5,14.19,14.05,13.88,13.73,13.62,13.53,13.44,13.42,13.38,13.35,13.4,13.43,13.44,13.43,13.4
71.336 | A-14 Steel Grey | A-14 Gris Acero | GU 1.7,102,105,104,44.42,-1.32,0.25,10.13G,4.37,3.59,14.13,D65/10°,SCE,UV400,13.6,14.35,14.22,14.07,13.97,13.93,13.94,14.03,14.07,14.04,14.18,14.34,14.5,14.52,14.45,14.33,14.25,14.13,13.97,13.84,13.76,13.64,13.57,13.55,13.53,13.48,13.46,13.42,13.44,13.43,13.42
71.337 | Flanker Blue | Azul Flanker | GU 3.0,126,167,179,66.14,-10.84,-10.7,7.03B,6.45,4.02,35.5,D65/10°,SCI,UV400,32.04,40.82,42.74,43.37,44.06,44.46,44.66,45.23,45.62,45.22,44.29,43.01,41.87,40.6,38.72,36.37,32.96,30.92,29.45,28.23,27.01,25.98,25.54,25.5,25.6,26.2,27.1,27.46,26.97,26.03,24.82
71.337 | Flanker Blue | Azul Flanker | GU 3.0,126,166,178,65.87,-10.6,-10.71,7.03B,6.42,4.03,35.16,D65/10°,SCE,UV400,31.85,40.47,42.31,42.96,43.68,44.09,44.24,44.85,45.23,44.8,43.88,42.6,41.39,40.11,38.17,35.8,32.62,30.7,29.24,28.04,26.86,25.86,25.45,25.39,25.53,26.07,26.93,27.19,26.7,25.82,24.62
71.338 | Russian AF Grey Blue | Gris Azul AF Ruso | GU 2.7,155,170,171,68.64,-4.92,-2.15,9.34BG,6.76,2.5,38.85,D65/10°,SCI,UV400,31.04,37.74,39.25,39.93,40.6,41,41.08,41.08,41.05,41.07,41.19,41.27,41.32,41.21,40.88,40.25,38.89,37.67,36.64,35.89,35.22,34.73,34.42,34.3,34.28,34.49,34.83,34.91,34.6,34.04,33.41
71.338 | Russian AF Grey Blue | Gris Azul AF Ruso | GU 2.7,155,169,170,68.36,-4.81,-2.22,9.25BG,6.73,2.46,38.47,D65/10°,SCE,UV400,30.95,37.45,38.89,39.6,40.3,40.7,40.72,40.73,40.7,40.69,40.84,40.91,40.91,40.78,40.38,39.75,38.49,37.33,36.3,35.55,34.92,34.42,34.16,34.05,34.07,34.24,34.57,34.56,34.25,33.73,33.11
71.339 | Russian AF Grey N.3 | Gris N.3 AF Ruso | FS36373 | GU 2.3,143,151,154,62.09,-2.52,-2.34,7.37BG,6.09,1.56,30.51,D65/10°,SCI,UV400,26.99,31.35,32.02,32.2,32.3,32.35,32.24,32.12,31.93,31.82,31.75,31.7,31.68,31.57,31.39,31.14,30.47,29.95,29.45,29.06,28.73,28.42,28.18,28.03,27.88,27.85,27.91,27.88,27.72,27.41,27.1
71.339 | Russian AF Grey N.3 | Gris N.3 AF Ruso | FS36373 | GU 2.3,143,151,153,61.94,-2.41,-2.23,9.46PB,6.08,3.14,30.33,D65/10°,SCE,UV400,27.15,31.11,31.67,31.88,32.04,32.12,31.95,31.85,31.7,31.57,31.56,31.53,31.47,31.34,31.11,30.78,30.32,29.85,29.34,28.94,28.64,28.35,28.13,27.95,27.85,27.79,27.82,27.69,27.49,27.25,26.96
71.340 | Grey Green | Gris Verdoso | GU 1.8,114,122,118,50.53,-3.46,0.89,9.99G,4.97,3.18,18.86,D65/10°,SCI,UV400,16.84,18.87,18.88,18.61,18.36,18.22,18.18,18.24,18.41,18.73,19.14,19.51,19.93,20.15,20.22,19.94,18.96,18.25,18.1,17.98,17.66,17.33,17.18,17.2,17.26,17.37,17.62,17.98,18.27,18.45,18.63
71.340 | Grey Green | Gris Verdoso | GU 1.8,114,121,118,50.53,-3.29,0.72,9.99G,4.97,3.21,18.86,D65/10°,SCE,UV400,17.15,18.9,18.98,18.69,18.47,18.33,18.24,18.3,18.49,18.81,19.18,19.55,19.92,20.12,20.1,19.78,18.96,18.25,18.11,18.05,17.73,17.38,17.23,17.28,17.35,17.46,17.72,17.96,18.22,18.41,18.54
71.341 | Green Grey | Verde Grisáceo | GU 1.8,87,95,77,39.49,-7.22,9.72,7.04GY,3.92,1.54,10.95,D65/10°,SCI,UV400,7.94,8.14,7.83,7.55,7.47,7.46,7.75,8.29,8.78,8.92,9.53,10.8,12.02,12.6,12.77,12.62,11.87,11.32,11.21,10.87,10.06,9.3,8.83,8.64,8.45,8.36,8.54,8.89,9.29,9.59,9.77
71.341 | Green Grey | Verde Grisáceo | GU 1.8,88,96,78,39.67,-6.72,8.92,7.01GY,3.93,1.81,11.06,D65/10°,SCE,UV400,8.68,8.53,8.16,7.88,7.83,7.8,8.04,8.59,9.02,9.15,9.75,10.95,12.11,12.63,12.71,12.51,11.97,11.46,11.32,11,10.23,9.49,9.04,8.85,8.69,8.59,8.71,8.97,9.34,9.65,9.85
71.342 | Russian AF Light Blue | Azul Claro AF Ruso | GU 2.6,160,195,198,76.69,-11.2,-5.18,2.05B,7.57,1.68,51.02,D65/10°,SCI,UV400,37.68,49.23,52.55,54.15,55.69,56.78,57.33,57.77,58.25,58.52,58.76,58.75,58.47,57.61,56.09,53.9,49.81,46.6,44.26,42.67,41.32,40.32,39.89,39.83,39.95,40.61,41.58,41.96,41.48,40.55,39.16
71.342 | Russian AF Light Blue | Azul Claro AF Ruso | GU 2.6,160,194,197,76.4,-11.12,-5.04,2.04B,7.54,1.7,50.54,D65/10°,SCE,UV400,37.6,48.47,51.89,53.38,55.08,56.15,56.65,57.12,57.63,57.9,58.16,58.2,57.88,57,55.43,53.28,49.42,46.29,43.93,42.36,41.02,39.99,39.58,39.52,39.68,40.27,41.21,41.5,40.93,39.95,38.68
71.343 | Russian AF Grey N.7 | Gris N.7 AF Ruso | GU 1.9,83,144,167,56.98,-13.51,-18.13,10.06B,5.49,5.61,24.9,D65/10°,SCI,UV400,27.54,34.25,35.75,36.58,37.4,38.05,38.17,38.07,37.68,37.07,36.23,34.9,32.94,30.48,27.68,24.67,20.45,18,16.68,15.99,15.38,14.93,15.03,15.66,16.47,17.38,18.1,18.11,17.32,16.45,15.96
71.343 | Russian AF Grey N.7 | Gris N.7 AF Ruso | GU 1.9,84,144,167,56.85,-13.17,-17.93,10.07B,5.48,5.57,24.77,D65/10°,SCE,UV400,27.67,33.98,35.37,36.23,37.12,37.76,37.82,37.72,37.34,36.7,35.88,34.56,32.67,30.24,27.42,24.38,20.44,18,16.73,16.07,15.49,15.03,15.12,15.75,16.59,17.47,18.17,18.1,17.3,16.4,15.87
71.344 | Russian AF Grey Prot. Coat | Gris AF Ruso | GU 2.8,159,196,207,77.21,-10.02,-9.35,8.24B,7.6,3.69,51.88,D65/10°,SCI,UV400,38.16,51.98,56.93,59.12,61.11,62.64,63.32,63.59,63.62,63.46,63.21,62.47,61.05,58.83,55.93,52.48,47.29,44.05,42.47,41.82,41.24,40.94,41.61,43.51,45.92,48,49.08,48.74,47.01,45.45,45.32
71.344 | Russian AF Grey Prot. Coat | Gris AF Ruso | GU 2.8,159,196,206,76.91,-9.9,-9.22,8.34B,7.57,3.65,51.38,D65/10°,SCE,UV400,38.08,51.48,56.19,58.34,60.46,61.94,62.58,62.89,62.92,62.75,62.55,61.87,60.41,58.19,55.26,51.89,46.9,43.72,42.13,41.51,40.94,40.62,41.31,43.21,45.67,47.71,48.75,48.27,46.46,44.88,44.74
71.345 | Russian AF Grey N.8 | Gris N.8 AF Ruso | GU 2.3,148,177,191,70.71,-6.58,-10.68,2.05PB,6.93,4.04,41.76,D65/10°,SCI,UV400,35.25,47.26,50.53,51.33,51.73,52.03,52.07,51.86,51.44,50.87,50.24,49.21,47.82,46.13,44.19,41.84,38.13,35.69,34.8,34.67,34.31,34.1,34.66,36.12,37.86,39.31,40.04,39.74,38.53,37.28,37.14
71.345 | Russian AF Grey N.8 | Gris N.8 AF Ruso | GU 2.3,148,176,191,70.44,-6.59,-10.54,2.05PB,6.9,4.04,41.38,D65/10°,SCE,UV400,35.21,46.53,49.97,50.67,51.18,51.45,51.46,51.31,50.93,50.41,49.84,48.87,47.44,45.72,43.74,41.37,37.74,35.35,34.5,34.35,34.04,33.83,34.41,35.83,37.61,39,39.7,39.32,38.05,36.9,36.86
71.346 | Russian AF Grey N.4 | Gris N.4 AF Ruso | GU 2.5,162,162,147,66.45,-2.87,7.91,8.34GY,6.57,1.8,35.91,D65/10°,SCI,UV400,21.6,25.02,26.15,27.65,29.48,30.87,31.51,31.86,32.13,32.58,33.3,34.19,35.33,36.47,37.14,37.27,37.45,38.34,38.86,38.11,36.32,34.62,33.6,33.16,32.92,33.04,33.85,35,35.99,36.56,36.68
71.346 | Russian AF Grey N.4 | Gris N.4 AF Ruso | GU 2.5,161,161,146,66.19,-2.73,7.81,8.43GY,6.55,1.84,35.56,D65/10°,SCE,UV400,21.88,24.96,25.92,27.43,29.27,30.66,31.22,31.58,31.87,32.29,33.04,33.91,34.96,36.06,36.65,36.75,37.07,38.01,38.56,37.79,36.03,34.34,33.38,32.96,32.79,32.88,33.64,34.66,35.63,36.22,36.35
71.347 | Russian AF Dark Green | Verde Oscuro AF Ruso | GU 1.4,85,77,62,33.28,0.87,9.98,10.08Y,3.32,2.41,7.67,D65/10°,SCI,UV400,4.2,4.51,4.6,4.86,5.16,5.33,5.4,5.46,5.57,5.72,6,6.36,6.85,7.34,7.8,8.19,8.35,8.69,8.88,8.84,8.63,8.38,8.15,8.06,7.95,7.89,8,8.18,8.36,8.51,8.54
71.347 | Russian AF Dark Green | Verde Oscuro AF Ruso | GU 1.4,86,78,64,33.64,1.09,9.16,2.10GY,3.36,1.08,7.84,D65/10°,SCE,UV400,4.8,4.86,4.9,5.17,5.52,5.65,5.72,5.74,5.83,5.98,6.26,6.61,7.04,7.48,7.85,8.15,8.56,8.88,9.05,9,8.82,8.57,8.36,8.28,8.18,8.11,8.18,8.26,8.41,8.54,8.61
71.348 | USAF Tan | USAF Marrón Arena | FS20400 | GU 2.0,189,142,102,62.92,12.79,28.48,9.19YR,6.29,5.15,31.49,D65/10°,SCI,UV400,11.04,12.01,12.42,13.39,14.8,15.86,16.32,16.67,17.16,17.87,19.09,20.79,23.04,25.67,28.27,30.44,33.33,36.77,40.33,42.94,44.28,44.86,44.99,45.05,45.08,45.22,45.46,45.79,46.13,46.48,47.02
71.348 | USAF Tan | USAF Marrón Arena | FS20400 | GU 2.0,189,142,102,62.77,12.81,27.88,9.24YR,6.28,5.09,31.31,D65/10°,SCE,UV400,11.62,12.33,12.6,13.58,14.98,16.03,16.43,16.76,17.26,17.96,19.14,20.82,22.97,25.53,28.04,30.12,33.07,36.44,40.03,42.66,44.07,44.6,44.74,44.78,44.87,44.96,45.14,45.35,45.63,46,46.49
71.400 | Uk Desert Pink | Uk Rosa Desierto | GU 2.1,195,151,136,66.32,14.1,14.38,10.03R,6.59,4.14,35.74,D65/10°,SCI,UV400,23.98,26.76,26.32,25.45,25.13,25.18,25.62,26.55,27.27,27.48,28,28.83,29.9,30.72,30.5,29.88,31.15,36.42,43.39,48.25,50.19,50.77,50.85,50.85,50.77,50.7,50.62,50.65,50.58,50.49,50.4
71.400 | Uk Desert Pink | Uk Rosa Desierto | GU 2.1,194,151,135,66.11,14.13,14.27,10.03R,6.57,4.12,35.47,D65/10°,SCE,UV400,24.21,26.6,26.05,25.28,24.99,25.09,25.47,26.42,27.1,27.3,27.86,28.67,29.68,30.47,30.19,29.54,30.96,36.06,43.09,47.97,49.9,50.44,50.54,50.51,50.49,50.37,50.27,50.19,50.06,49.96,49.86
71.401 | Uk Bsc 28 Sil. Grey | Uk Bsc28 Gris Plata | GU 1.8,156,149,116,61.73,-3.19,18.37,7.07Y,6.13,0.92,30.09,D65/10°,SCI,UV400,14.38,15.86,16.23,17.14,18.39,19.34,19.93,20.67,21.39,22.05,23.44,25.73,28.4,30.78,32.44,33.29,33.87,34.49,34.44,33.33,31.57,30.04,29.03,28.45,27.93,27.61,27.8,28.44,29.3,30.06,30.68
71.401 | Uk Bsc 28 Sil. Grey | Uk Bsc28 Gris Plata | GU 1.8,155,149,117,61.57,-3.01,17.91,7.07Y,6.11,1.04,29.9,D65/10°,SCE,UV400,14.7,16.03,16.47,17.28,18.54,19.44,19.96,20.7,21.4,22.05,23.42,25.66,28.25,30.57,32.12,32.89,33.58,34.2,34.14,33.07,31.44,29.96,28.97,28.36,27.91,27.55,27.7,28.25,29.04,29.84,30.45
71.402 | Uk Bsc 49 L. Purple Br. | Uj Bsc49 Mr. Purpura | GU 2.5,78,56,55,26.19,9.34,4.73,7.02R,2.61,1.81,4.81,D65/10°,SCI,UV400,3.92,4,3.99,4,3.96,3.93,3.91,3.89,3.88,3.84,3.83,3.84,3.89,3.98,4.02,4.09,4.03,4.33,5.04,6.41,7.7,7.87,7.32,6.99,6.9,7.05,7.3,7.41,7.37,7.2,6.95
71.402 | Uk Bsc 49 L. Purple Br. | Uj Bsc49 Mr. Purpura | GU 2.5,79,56,56,26.34,9.78,4.17,5.78R,2.62,1.95,4.86,D65/10°,SCE,UV400,4.27,4.26,4.15,4.17,4.15,4.07,4.06,3.99,3.97,3.92,3.91,3.9,3.94,3.97,3.97,3.96,4.07,4.41,5.14,6.53,7.83,8,7.46,7.13,7.06,7.18,7.37,7.41,7.33,7.17,6.91
71.403 | Light Green | Verde Claro | GU 2.0,101,114,95,46.54,-8.69,8.8,8.23GY,4.6,1.75,15.67,D65/10°,SCI,UV400,10.6,11.21,11.12,11.18,11.46,11.74,12.16,12.92,13.59,13.92,14.6,15.8,16.98,17.65,17.92,17.88,17.28,16.74,15.93,14.86,13.71,12.78,12.23,11.97,11.76,11.66,11.86,12.29,12.73,13.08,13.3
71.403 | Light Green | Verde Claro | GU 2.0,101,114,96,46.57,-8.34,8.42,8.22GY,4.6,1.74,15.69,D65/10°,SCE,UV400,11.22,11.48,11.33,11.4,11.68,11.94,12.31,12.98,13.62,13.92,14.66,15.81,16.98,17.64,17.84,17.71,17.29,16.77,15.97,14.93,13.83,12.87,12.33,12.11,11.93,11.8,11.96,12.27,12.72,13.06,13.28
"71.404 | No. 1 ""Duck Egg Blue"" | Azul Huevo De Pato | GU 1.8",112,153,142,60.21,-16.28,1.34,2.05BG,5.9,3.78,28.36,D65/10°,SCI,UV400,18.92,21.97,23,24.5,26.37,27.9,28.82,29.52,30.13,30.82,31.78,32.89,33.87,34.34,33.97,32.61,29.44,26.72,24.45,22.46,20.57,19.11,18.37,18.09,17.94,18.11,18.74,19.44,19.83,19.8,19.37
"71.404 | No. 1 ""Duck Egg Blue"" | Azul Huevo De Pato | GU 1.8",113,152,141,60.06,-15.9,1.31,2.06BG,5.88,3.75,28.19,D65/10°,SCE,UV400,19.29,22,22.88,24.35,26.23,27.78,28.62,29.35,29.93,30.6,31.58,32.64,33.55,33.99,33.58,32.22,29.28,26.64,24.39,22.5,20.65,19.16,18.41,18.16,18.03,18.2,18.82,19.45,19.8,19.76,19.3
71.405 | BS Dark Sea Grey | BS Gris Mar Osc. | GU 1.3,81,83,84,35.46,-0.66,-1.03,2.15BG,3.5,0.98,8.73,D65/10°,SCI,UV400,9.06,9.57,9.38,9.18,9.07,8.95,8.94,8.94,8.95,8.84,8.8,8.83,8.91,8.92,8.9,8.87,8.58,8.65,8.66,8.6,8.55,8.48,8.34,8.28,8.2,8.17,8.19,8.22,8.25,8.24,8.14
71.405 | BS Dark Sea Grey | BS Gris Mar Osc. | GU 1.3,82,84,86,35.84,-0.38,-1.42,2.16BG,3.53,0.96,8.93,D65/10°,SCE,UV400,9.72,9.96,9.71,9.51,9.43,9.27,9.25,9.26,9.23,9.11,9.09,9.1,9.11,9.07,8.96,8.86,8.82,8.88,8.86,8.81,8.79,8.71,8.59,8.55,8.47,8.43,8.41,8.34,8.33,8.29,8.26
71.406 | Light Slate Grey | Gris Pizarra Claro | GU 1.5,96,101,85,42.14,-5.21,8.43,7.02GY,4.18,1.73,12.59,D65/10°,SCI,UV400,8.01,8.63,8.71,8.94,9.36,9.6,9.84,10.11,10.41,10.62,11.12,11.99,12.88,13.57,14.02,14.2,13.92,13.65,13.17,12.52,11.85,11.26,10.87,10.67,10.49,10.38,10.48,10.72,10.99,11.2,11.32
71.406 | Light Slate Grey | Gris Pizarra Claro | GU 1.5,96,101,86,42.24,-4.79,7.77,7.03GY,4.19,1.59,12.66,D65/10°,SCE,UV400,8.78,9.08,9.04,9.23,9.67,9.88,10.09,10.34,10.57,10.78,11.3,12.08,12.93,13.57,13.95,14.06,13.98,13.73,13.25,12.62,11.98,11.4,11.04,10.85,10.69,10.57,10.63,10.77,11.04,11.24,11.35
71.407 | Sky Grey | Gris Cielo | FS36463 | GU 3.8,165,168,168,68.8,-1.26,-0.37,10.08P,6.79,3.91,39.07,D65/10°,SCI,UV400,30.41,37.37,38.79,39.23,39.55,39.71,39.62,39.48,39.35,39.28,39.34,39.42,39.56,39.61,39.62,39.55,39.27,39.03,38.73,38.47,38.26,38.13,37.9,37.7,37.49,37.32,37.17,37,36.85,36.62,36.47
71.407 | Sky Grey | Gris Cielo | FS36463 | GU 3.8,164,167,167,68.45,-1.16,-0.43,10.08P,6.75,3.89,38.58,D65/10°,SCE,UV400,30.24,36.98,38.31,38.77,39.17,39.32,39.15,39.03,38.89,38.8,38.89,38.95,39.04,39.08,39.04,38.95,38.78,38.59,38.29,38.04,37.87,37.7,37.49,37.27,37.12,36.88,36.71,36.46,36.31,36.16,36.08
71.408 | PRU Pink | PRU Rosa | GU 3.7,216,192,184,79.63,7.16,7.08,10.04R,7.95,2.41,56.03,D65/10°,SCI,UV400,35.11,44.97,47.34,48.13,48.84,49.31,49.46,49.9,50.84,51.24,51.23,51.01,51.31,51.93,52.16,52.12,53.39,57.01,61.44,64.43,65.76,66.24,66.39,66.35,66.31,66.25,66.25,66.25,66.27,66.26,66.28
71.408 | PRU Pink | PRU Rosa | GU 3.7,215,191,183,79.34,7.2,7.07,10.04R,7.92,2.41,55.52,D65/10°,SCE,UV400,34.98,44.62,46.9,47.6,48.42,48.86,48.98,49.44,50.33,50.72,50.75,50.58,50.82,51.4,51.58,51.58,52.87,56.54,60.93,63.91,65.23,65.69,65.83,65.77,65.78,65.72,65.64,65.6,65.54,65.59,65.53
71.409 | Zaschchitnyi Khaki | Verde Zaschcitnyi | GU 1.3,97,86,66,37.17,1.38,13.3,5.01Y,3.72,2.08,9.63,D65/10°,SCI,UV400,5.05,5.39,5.46,5.62,5.83,5.97,6.15,6.23,6.34,6.49,6.88,7.44,8.36,9.34,10.11,10.67,10.86,11,11,10.93,10.89,10.82,10.75,10.73,10.68,10.65,10.7,10.69,10.66,10.64,10.61
71.409 | Zaschchitnyi Khaki | Verde Zaschcitnyi | GU 1.3,98,86,68,37.47,1.56,12.29,5.03Y,3.74,2.16,9.79,D65/10°,SCE,UV400,5.72,5.87,5.84,5.98,6.22,6.35,6.49,6.57,6.63,6.79,7.17,7.73,8.56,9.47,10.15,10.6,11.02,11.16,11.14,11.09,11.07,10.99,10.92,10.91,10.89,10.85,10.84,10.76,10.74,10.7,10.69
71.410 | AII Zashchitnyi Cam. Green | AII Verde Zaschitnyi | GU 1.2,84,80,60,33.93,-2.03,12.38,10.02Y,3.39,2.1,7.97,D65/10°,SCI,UV400,3.94,4.28,4.36,4.59,4.84,5,5.09,5.18,5.34,5.59,6.03,6.64,7.51,8.35,8.98,9.32,9.07,8.87,8.59,8.32,8.14,8.02,7.96,8.01,8.05,8.15,8.37,8.58,8.74,8.86,8.97
71.410 | AII Zashchitnyi Cam. Green | AII Verde Zaschitnyi | GU 1.2,85,80,62,34.31,-1.73,11.52,2.04GY,3.43,1.64,8.16,D65/10°,SCE,UV400,4.54,4.67,4.67,4.88,5.2,5.33,5.41,5.47,5.61,5.87,6.32,6.92,7.72,8.49,9.03,9.29,9.27,9.07,8.78,8.52,8.37,8.25,8.19,8.26,8.31,8.39,8.56,8.67,8.82,8.93,9.02
71.411 | A-19F Grass Green | A-19F Verde Hierba | GU 1.5,102,99,59,41.43,-4.9,22.82,4.59GY,4.16,3.6,12.13,D65/10°,SCI,UV400,4.6,4.86,4.91,5.03,5.2,5.3,5.48,5.79,6.16,6.41,7.08,8.57,10.87,13.13,14.49,14.96,15.06,15.64,15.51,14.01,12.14,10.76,10.04,9.75,9.52,9.44,9.69,10.29,11,11.64,12.06
71.411 | A-19F Grass Green | A-19F Verde Hierba | GU 1.5,103,99,62,41.55,-4.57,21.59,4.57GY,4.17,3.52,12.21,D65/10°,SCE,UV400,5.25,5.29,5.22,5.34,5.56,5.62,5.79,6.1,6.45,6.68,7.35,8.79,10.98,13.14,14.4,14.78,15.1,15.68,15.53,14.1,12.25,10.89,10.2,9.92,9.72,9.62,9.85,10.33,11.02,11.66,12.13
71.412 | VVS Grey Blue | VVS Gris Azulado | GU 7.4,149,160,147,64.89,-6.47,5.25,2.04G,6.4,1.52,33.91,D65/10°,SCI,UV400,24.52,27.95,28.51,28.94,29.55,30.08,30.5,31.22,31.8,32.16,32.95,34.28,35.57,36.29,36.58,36.46,35.91,35.24,34.22,32.9,31.38,30.08,29.22,28.76,28.38,28.16,28.3,28.73,29.25,29.6,29.84
71.412 | VVS Grey Blue | VVS Gris Azulado | GU 7.4,148,159,146,64.48,-6.28,5.18,2.04G,6.36,1.49,33.4,D65/10°,SCE,UV400,24.55,27.6,28.02,28.47,29.14,29.69,30.07,30.79,31.35,31.69,32.5,33.78,34.98,35.7,35.89,35.79,35.32,34.7,33.72,32.45,31.01,29.75,28.93,28.44,28.13,27.86,27.97,28.32,28.77,29.15,29.41
71.413 | A-18F Light Blue | A-18F Azul Claro | GU 8.8,127,157,155,62.63,-10.87,-2.47,7.02BG,6.13,1.87,31.15,D65/10°,SCI,UV400,27.74,32.25,32.61,32.43,32.36,32.48,32.79,33.52,34.04,34.11,34.48,35.27,35.83,35.65,34.89,33.77,31.57,29.7,27.98,26.47,24.93,23.63,22.87,22.52,22.25,22.28,22.66,23.07,23.21,23.01,22.55
71.413 | A-18F Light Blue | A-18F Azul Claro | GU 8.8,126,156,154,62.2,-10.62,-2.4,7.02BG,6.09,1.9,30.64,D65/10°,SCE,UV400,27.62,31.68,31.96,31.79,31.81,31.95,32.18,32.93,33.43,33.49,33.9,34.66,35.16,34.99,34.2,33.05,31.12,29.31,27.6,26.09,24.63,23.39,22.67,22.27,22.03,22.05,22.41,22.72,22.81,22.66,22.21
71.414 | AEH-9 Light Grey | AEH-9 Gris Claro | GU 2.7,184,189,187,76.46,-2.38,0.58,2.08RP,7.59,1.08,50.64,D65/10°,SCI,UV400,37.02,47.91,50.41,50.5,50.24,50.06,49.98,49.99,50.13,50.46,50.92,51.36,52,52.36,52.32,51.95,51.07,50.28,49.58,49.05,48.66,48.48,48.45,48.66,48.91,49.22,49.56,49.91,50.06,50.14,50.3
71.414 | AEH-9 Light Grey | AEH-9 Gris Claro | GU 2.7,184,189,186,76.2,-2.27,0.7,2.08RP,7.57,1.09,50.22,D65/10°,SCE,UV400,36.95,47.13,49.83,49.82,49.74,49.55,49.45,49.52,49.67,49.98,50.47,50.93,51.5,51.82,51.72,51.42,50.64,49.96,49.25,48.76,48.43,48.21,48.2,48.38,48.69,48.94,49.22,49.45,49.54,49.6,49.76
71.415 | A-21 Light Greyish Br. | A-21 Mr. Gris. Claro | GU 1.7,127,118,97,49.94,-0.2,12.89,2.05GY,4.95,1.31,18.37,D65/10°,SCI,UV400,9.7,10.62,10.88,11.49,12.39,12.95,13.26,13.5,13.8,14.15,14.86,15.91,17.11,18.24,19.11,19.59,19.83,20.24,20.42,20.3,20.02,19.68,19.43,19.24,19.07,18.9,18.85,18.93,19.01,19.02,19.03
71.415 | A-21 Light Greyish Br. | A-21 Mr. Gris. Claro | GU 1.7,127,118,97,49.94,0.03,12.5,2.05GY,4.95,1.31,18.37,D65/10°,SCE,UV400,10.36,10.95,11.11,11.74,12.55,13.13,13.37,13.59,13.85,14.18,14.93,15.94,17.13,18.23,19.01,19.41,19.83,20.24,20.44,20.36,20.11,19.75,19.45,19.29,19.11,18.98,18.95,18.92,18.96,18.97,18.94
71.416 | IJA Dark Beige | IJA Beige Oscuro | GU 1.3,139,98,72,45.42,13.58,21.33,6.15YR,4.55,3.91,14.85,D65/10°,SCI,UV400,6.26,6.77,6.83,7.01,7.31,7.53,7.77,7.86,7.97,8.13,8.52,9.21,10.39,11.71,12.6,13.13,14.24,16.9,20.07,22,22.69,22.8,22.78,22.79,22.74,22.72,22.74,22.72,22.65,22.55,22.51
71.416 | IJA Dark Beige | IJA Beige Oscuro | GU 1.3,140,98,74,45.56,13.63,20.27,6.17YR,4.56,3.87,14.95,D65/10°,SCE,UV400,7.07,7.26,7.23,7.42,7.71,7.88,8.09,8.19,8.24,8.4,8.81,9.46,10.55,11.79,12.58,13.02,14.33,16.96,20.11,22.09,22.79,22.89,22.86,22.85,22.84,22.8,22.79,22.68,22.57,22.48,22.49
"71.417 | ""Aotake"" Trans. Green | ""Aotake"" Verde Trans | GU 31.2 | Opacity 56.37%",0,101,59,37.26,-38.04,16.47,2.09G,3.63,7.33,9.68,D65/10°,SCI,UV400,4.44,4.51,4.51,4.58,4.61,4.63,4.74,4.98,5.63,7.88,14.62,21.54,21.81,18.19,13.83,9.95,6.17,4.76,4.22,4.08,4.03,4.04,4.02,4.02,4.05,4.09,4.14,4.16,4.22,4.23,4.23
"71.417 | ""Aotake"" Trans. Green | ""Aotake"" Verde Trans | GU 31.2 | Opacity 56.37%",0,93,44,33.2,-46.76,19.87,2.10G,3.22,10.08,7.63,D65/10°,SCE,UV400,2.71,2.66,2.59,2.65,2.7,2.7,2.82,3.06,3.73,5.95,12.53,19.4,19.64,16.04,11.66,7.81,4.24,2.8,2.22,2.04,2.04,2.01,1.98,2.01,2.01,2.01,2.08,2.08,2.13,2.14,2.1
71.418 | IJN Medium Brown | IJN Maroon Medio | GU 1.3,104,74,58,34.44,10.3,14.76,4.82YR,3.46,2.41,8.22,D65/10°,SCI,UV400,4.11,4.37,4.41,4.53,4.6,4.64,4.72,4.82,4.94,5.01,5.28,5.71,6.24,6.69,7.03,7.4,7.87,8.89,10.13,11.26,12.08,12.53,12.69,12.77,12.79,12.81,12.91,13.01,13.08,13.18,13.22
71.418 | IJN Medium Brown | IJN Maroon Medio | GU 1.3,104,75,60,34.8,10.18,13.86,4.65YR,3.49,2.62,8.4,D65/10°,SCE,UV400,4.72,4.77,4.7,4.83,4.94,4.95,5.02,5.1,5.2,5.27,5.54,5.98,6.49,6.86,7.13,7.4,8.1,9.1,10.29,11.41,12.23,12.65,12.83,12.91,12.96,12.96,13,13.01,13.11,13.18,13.25
"71.419 | ""Aotake"" Trans. Blue | ""Aotake"" Azul Trans. | GU 17.3 | Opacity 87.81%",45,69,63,27.43,-11,0.92,2.03BG,2.67,1.82,5.25,D65/10°,SCI,UV400,4.86,4.92,4.82,4.78,4.78,4.76,4.74,4.87,5.33,6.74,9.5,9.84,7.51,5.57,4.67,4.4,4.17,4.12,4.09,4.09,4.09,4.12,4.1,4.11,4.13,4.11,4.14,4.08,4.09,4.07,4.06
"71.419 | ""Aotake"" Trans. Blue | ""Aotake"" Azul Trans. | GU 17.3 | Opacity 87.81%",30,61,55,23.54,-13.46,0.3,2.91BG,2.27,1.84,3.96,D65/10°,SCE,UV400,4.01,3.89,3.69,3.66,3.67,3.59,3.59,3.7,4.15,5.58,8.3,8.61,6.28,4.29,3.33,2.97,2.89,2.86,2.79,2.76,2.81,2.81,2.78,2.81,2.79,2.76,2.76,2.67,2.65,2.64,2.64
71.420 | N.17 Earth Yellow | N.17 Erdgelb | GU 0.8 3.1 18.3,175,139,78,60.24,6.32,37.54,2.20Y,6.05,6.06,28.39,D65/10°,SCI,UV400,7.18,7.72,8.06,8.64,9.62,10.35,10.77,11.18,11.68,12.33,13.7,16.07,19.41,23.58,28.06,31.86,35.69,38.75,40.35,39.22,36.56,34.22,32.77,32.09,31.6,31.43,32,33.2,34.69,35.98,37.11
71.420 | N.17 Earth Yellow | N.17 Erdgelb | GU 0.8 3.1 18.3,174,138,79,59.99,6.42,36.64,2.05Y,6.03,6.04,28.11,D65/10°,SCE,UV400,7.84,8.06,8.29,8.85,9.84,10.54,10.91,11.25,11.71,12.33,13.7,16.01,19.33,23.4,27.7,31.39,35.2,38.31,39.95,38.82,36.18,33.87,32.49,31.82,31.41,31.2,31.73,32.84,34.3,35.62,36.75
71.421 | Pinkish White | Blanco Rosado | FS36628 | GU 1.5 4.8 28.7,192,198,190,79.3,-3.61,3.31,5.07G,7.9,3.43,55.45,D65/10°,SCI,UV400,34.27,44.24,47.67,49.49,51.49,52.96,53.78,54.27,54.44,54.69,55,55.24,55.82,56.71,57.06,56.77,56.28,57.14,57.65,56.39,53.98,51.89,50.74,50.51,50.44,50.53,51.28,52.62,53.9,55,55.87
71.421 | Pinkish White | Blanco Rosado | FS36628 | GU 1.5 4.8 28.7,191,197,188,78.9,-3.5,3.37,5.07G,7.86,3.44,54.75,D65/10°,SCE,UV400,33.96,43.83,46.97,48.73,50.75,52.2,53.02,53.49,53.74,53.93,54.29,54.53,55.14,55.94,56.21,55.92,55.54,56.47,56.98,55.8,53.41,51.33,50.27,50.02,49.99,50.04,50.71,51.94,53.18,54.26,55.15
Edited by Casey
Marked the post as having raw data
12 minutes ago, Casey said:
Please do not use RGB for any paint color matching :) - this will not work as you hope - but if you are interested more about color matching and the rabbit hole of paint colors, pm me. I'll try to give you as much knowledge as you want.
I'll also try to get the raw data from my newest spectrophotometer somehow. I wonder how since this site do not allow attachments :)
Thank you, if you can get it into spreadsheet form i'll pm you my email address or maybe use dropbox?
Try copy&paste of the data I've put in hidden content above, and save it as .csv text file. Excel should open it.
Thanks, but i'm not having much luck copying the colour table, not even as an image .
Look at my first reply for you on this thread, there is a hidden section, click on it to expand.
I did and the hidden contents only give this
Paints were mixed on a vortex mixer for at least 3 minutes each, then prepared on drawdown cards using 10 mil wet film
Samples were left to dry and fully harden for at least 7 days
All samples were measured using the following devices:
Integrating sphere spectrophotometer using the following settings:
Measurement of reflected light wavelengths from 400 to 700nm (covering the visible spectrum from ultraviolet to infrared)
UV filter with 400nm cutoff to eliminate UV light fluorescence
Light source and observer: D65/10 deg
D65 is a daylight
10 deg represents modern human color perception model used to convert the color
Specular Component Included
It means the paint color is measured at all angles simultaneously, which eliminates the effect of paint finish (gloss/matte/satin) from color readouts - that allows measurement of true paint color.
Gloss meter
Measures paint finish independently from color
Measurement is done at a 60deg angle
I tried to copy the big colour chart to no avail
