I previously joined this GB with an Argentine representative from my "Sexy American Singles in South American Service" project, a F4U-5 Corsair:
Sadly, I'm not confident I can complete it in time, but I still want to build something for the GB, so now I am beginning a Hellcat from Uruguay! I am using this Eduard 1/72 kit:
y4m0PkC3c6WZYFGB-7bljQsA5yhq_14NYsNPkkgQ
It will be my first Eduard kit, and I am very impressed so far. I know there have been many of these built around here so I don't think I need to share sprue photos. This is the -5N (nightfighter) kit, but I am just building a -5 using these decals:
y4mi7qI64-ZmEhQiHYscKqQNYqibKovL9yRz9O1f
Here are photos of Uruguayan Hellcats which will be similar to what I'm attempting to model.
y4mWpCjDaWMUD2UV_tzIJugeqwGU9GaOCQHo2mih
y4mJPk9ZSZjIbneNN-2K3mXUkh9mUbMy_6L6JfC1
y4mFuM8r4bcXOGXdKXtF7ctYsT0-yBgvNg9VM2_k
I chopped up some sprue and cut off the parts that I want to spray black on.
y4mBb2bFku6If9h1YrV2tzw9O8Xod7hTPo_aJgpJ
I want to assemble some of that before spraying, and so that means getting into the PE. I've never worked with coloured PE before, and so far I haven't been a big fan of PE, but some of this looks workable and so I am giving it a bit of a go.
y4marXCi6u_kBJ_CEqMoLTDYmQLWMbtlo7h7fkEm
y4mjx-3-v-dbBryuXnClxwlmM6IF-6hhouS_I5JS
I don't really know what this PE piece in the seat is (lumbar support?), but here's the cockpit floor, back, seat with the PE stuck in, and pedals.
y4mXrqex5kAw5YIldKSUarYyMU7AujYfVtNmUehV
I want to spray the engines black, so snipped of the PE piece I need for that.
y4m-vtcdshFxWCLo4xcakcCcxEqqiRhgyWCcfBwJ
You can see I mangled it, but managed to mangle it onto the radials and I think it does what I want it to (i.e., just add to the "business"). Maybe one day I'll know what I'm doing when it comes to PE. 🤣
Everything ready for my rattle can black.
y4mdma2yWS4f2wujABO1qhu-JEMllBzjAgL8EuBT
After the black:
y4m-nnkK3Ad98KTy8gQy-nNV_tKoMVe-7s5DC16Y
I began painting MMP interior green on some of the cockpit pieces:
y4mN9IoUkAfSO9SD_LRtqk-OSCSl1Ja1_cDH0O-G
And working with more of the PE, for example on the instrument panel.
y4mM5_-JOZEM1EWh6-OXgFYIioScSE6li0ppJ5Tp
I didn't use all of the PE (there are a lot of pieces, including many tiny ones), but I'm happy with what I used and how it looks! Definitely the coolest IP I've assembled.
y4mmLJIF1S3s9JT5fsmZ26PbfLEmU9Zx4OhO5H1r
Here it's all assembled.
y4m2KGU6UNlZrZEO2h7ASS8QIIfWah8ASYCeJ4WP
y4m-zlwK7ol3RbbeSaXIJ0IazQUwDSmYzdppGgTb
That's all looking very nice.   I think you're right to be discerning.   It's all a balance in my view between   "need to know the detail is there  vs  life's too short for everything"  :rofl:  I haven't used PE yet, but feel the need to investigate.......
Good stuff ME
Rob
Nice start. This is a lovely kit and goes together well by all accounts so should make for a rewarding project.
Mostly I've been underwhelmed by it (I've never bought it specifically, just had some frets included in kits). But, I've enjoyed it to the extent I'm using it with this kit. Here's an example of a good "value add" PE piece, in my opinion:
y4mWDQmaYkZjqTV0tZB3rg7vhZD6zTfP05DuwapF
Big enough to work with comfortably, and some nice detail that couldn't be done effectively any other way.
11 hours ago, Tim R-T-C said:
Its nice to see the Uruguayan scheme. They also flew the Avenger for which LF do decals as well.
Good work so far
Thanks, @Tim R-T-C
This kit is incredible, has to be the nicest I've ever worked with. Prior to assembling the fuselage there's a bit of carving to do on the bottom to allow installation of the drop tank.
y4my--HVrifonJ8lA2MLcmrMJDrU5qk-BpEI3Uru
y4mb77d1ZAMEsjFhHj9TrNu85BFu-JIYggdHg4lJ
y4mqBLkfQl0REE78nPMEcpuF43MlbJ0RSkQJ-I4T
Speaking of the drop tank, it seems to me the Uruguayan Hellcats typically carried the drop tank and rocket mounts, but I haven't found pictures of any rockets. These are the Eduard rockets.
y4md1hfiKZbUTOsyQag5KlsJfc9qVBamojM9oGDo
They don't really have the mounts molded in a way that would work on their own, so I cut these off spare rockets from an Airfix F-51 kit.
y4mD-E0VbjPfFGrLLHwo99_dgSabrvNwBx7hHlbU
The other thing about the Uruguayan Hellcats is they were delivered unarmed, so that's how I will model this one. But, I installed the gun pieces before removing them so that I can easily fill these holes.
y4mhdZLPauO3TnBWDHarUYRL32MHLqiwke-ZsoZs
Wings all together, with guns removed.
y4m8DWZxprOqab2UxOkMIUklR5LyafQzwZMYme4g
Since the plan was to add guns later, I assume ejector ports would remain.
y4mz8BrxCmvsQFnVuYajI8zyWCrMGnXK8h-BOeJZ
And now with the rocket mounts installed.
y4mN7zHOQbt3IY1BNOGQgZvB0_dYcPo1sX3hWGLp
y4muGeTNMQhcoNOhb-xGhT2BF3YiKjCsMdnxqULr
Edited by ModelingEdmontonian
Very nice detail, those rocket mounts! In my opinion HVARs look better on the Hellcat than on either the Corsair or Mustang.
1 hour ago, Toryu said:
... HVARs look better on the Hellcat than on either the Corsair or Mustang.
The only possible comment is that anything would look good on the Hellcat.  A very effective fighter, but far from the best looking.
One disappointment is that the kit requires the rear wheel to be installed prior to fuselage assembly. I would prefer it be a later addition, but you can't get everything you want.
y4m4dhzp4D1qi74kwX_yHM5X8YJLl0UkKVJPSgpJ
The fuselage is also designed to accommodate either of the Hellcat's rear cockpit designs (with quarter window or without. The Uruguayan Hellcats were the later type (without the window), but the pieces to complete these are still clear (they can be just seen installed in the photo below).
y4m48-Akea5UMjU7blc6Gp1f8TeUAtTdJOCCkdaE
So with those and the rear wheel (and the cockpit tub) installed, and with the drop tank slot carved out, the fuselage is together!
y4msZidZ3wpglDGQKmYXJLIJZLfdOMbVJMWRWVRu
Wings and stabilizers more or less pop on (literally no glue on the wings).
y4m34ge4bUwi-0DH_HSzlaAq-Sgj0u3DKarO27Xi
Having studied your photo, and looked at the instructions online, I'm not sure why the tail wheel can't be installed later in the build. Unless I'm missing something crucial, it would seem to be nothing more than a 'plug-in from the underside' kind of deal, which can be done anytime that's convenient. Just because the instructions say to fit something now, doesn't mean that it has to be.
Irrelevant, I know, as you've already done it, but maybe something to remember for the next time?
The rear wheel piece has a bit of a ledge that would prevent it being added after. maybe more obvious in the instructions:
y4mzjD3VnXCTOfwhSkklPaYSFaCyHv0qFv147UpB
I suppose the ledge could be cut off and installed, then the remainder glued in after. But, honestly. now that it's altogether I'm not too bothered by it.
By the way, here is a photo of the two Hellcats I have decals for--450 and 405.
y4mfCIoSrNeefvRHizub39g4KHOZVEEE4D3FfBdN
You can see above that they have the "football" ADF underneath the rear fuselage. Eduard does not include this piece, but I have this AZ P-36 kit which I will use to model Peru for my Sexy American Singles in South American Service project.
y4m0ykuIaqUZlu38n1vZ2xg70zOTRhd8Qjq39Dlx
It has the football and I don't need it for the Peruvian version, so I have stolen it for Uruguay. I think the football is black, so I haven't installed it yet--I will do that after I finish the underside camo.
Meanwhile, cowling together beautifully . . .
y4mnqx7_WJafOZUUOHSCiBtHGchSh4sW_nooPR9E
. . . and the engine installed.
y4mFaFZgsjw-9rA9gOlPhV1bXgTrYKg_W8qusm1Q
Now here she is with cowling on (no glue needed, again).
y4mPY-cWkM-buK-Vx5JZO57yFlVG09e1Dmkav7Fb
UC doors and legs and drop tank are on next....
y4mioS1w1c4bex00bGGkG6lAR45qBfxk_FP-yI9w
So, she's on her legs, albeit no wheels up front.
y4mUlxaIbClUWIbl1LPYSUGG1I4KRKM0PnQ7Nqtr
I don't want to install the pitot tube at this stage, but I did need to work the hole larger to fit the part.
y4mm-4fu2wwESSqlEu-VXlffHx1UNy1A7Ut9BGRh
With that done, I was able to spray some grey primer!
y4mbJH29ATTyVAhNwE-3WZeKsejCBydz-1mY3rep
I can't get over how big the Hellcat is. I compared her here before priming to the MB 151 I'm building for the Marcel Bloch GB and you can see what a beast of a cat she is:
y4mM01AN019aB6qdajXJxmqW4V55oi56jpj0JCW_
We're not going to have a football war between Peru & Uruguay now are we, I thought that was further north. ;)
This is looking really good, I must pull some of my Eduard F6F kits from stock at some stage. :)
Steve.
  • Haha 3
Nice project and looking good 👍
You're right, it's a big plane.Stands shoulder to shoulder with the P47 Tbolt. I've just been finishing this plane's "Granddad" the F3F biplane, and I stood a mechanic beside it for a look. The mechanic can peer into the cockpit while standing on the ground - like a Sopwith Camel!
So in those few years there was quite a bit of upscaling with both airframes and engines
This is a good one, @stevehnz. Truly gave me a chuckle.
I have almost finished the upper camo now. Still have to get the blue down far enough on the cowling to match up with the fuselage.
y4mMpqIUhZngEjKeKFxyNRE_o7JjNKPJl14G0Hy3
With the camo complete, I brushed on some Pledge, and then it was on to the decals. The LF decals leave a lot to be desired, but I have managed to get them on. I used some of the Eduard stencils, too.
y4mrYm7DMWE4wxgqGtKd6w9YabfiiMKTPQsr0BVV
You can see the football is on, too.
y4mZuGipYzUhz2yycCZ3A5aw4WZ7z2tEHW8jfFc0
