saintsclaire Posted March 22, 2023 Share Posted March 22, 2023 Hi Does anyone know if there are any manufacturers of 1/35 25pdr shell cases, could do with a few for a diorama but all I've found are the Resicast stacks. Thanks Claire Link to comment Share on other sites More sharing options...
JackG Posted March 22, 2023 Share Posted March 22, 2023 Resicast product No. 35.2349 as pictured on Scalemates shows brass casings with resin shells. Your description of “stacks” am guessing means the set has more than you need and willing to spend on? Maybe scratch building them from appropriate hollow brass tubing, but punching out discs for the base and filing down the lip for a more scale thinness is a lot more work. There is also the problem of creating the slight taper towards the opening Then again, cannot confirm Resicast has incorporated this detail either. 1 Link to comment Share on other sites More sharing options...
Kingsman Posted March 22, 2023 Share Posted March 22, 2023 In 1/35 the slight taper of the cartridge case would not be noticeable. It's just slight enough to permit extraction without base separation and a stuck case. In my head I thought that RB Model did them but it seems not. But the 95mm howitzer shared a breech ring with the 25pdr, although slightly larger calibre at 95 vs 84mm. That's 0.3mm in 1/35: hardly noticeable. So I think you could get away with the cartridge cases for the 95mm, available from RB Models and AFV Club in brass and Accurate Armour in resin. The HE and smoke projectiles in the sets are also useable for 25pdr IMO, but not the HEAT rounds. Link to comment Share on other sites More sharing options...
saintsclaire Posted March 22, 2023 Author Share Posted March 22, 2023 1 hour ago, JackG said: Resicast product No. 35.2349 as pictured on Scalemates shows brass casings with resin shells. Your description of “stacks” am guessing means the set has more than you need and willing to spend on? Maybe scratch building them from appropriate hollow brass tubing, but punching out discs for the base and filing down the lip for a more scale thinness is a lot more work. There is also the problem of creating the slight taper towards the opening Then again, cannot confirm Resicast has incorporated this detail either. Thank you They wold be perfect, except they seem out of production 35.2349 is now 4.5mm Lenses 😪 Explains why 35.2433 was all i could find on their site 25 pdr shells Link to comment Share on other sites More sharing options...
saintsclaire Posted March 22, 2023 Author Share Posted March 22, 2023 20 minutes ago, Kingsman said: In 1/35 the slight taper of the cartridge case would not be noticeable. It's just slight enough to permit extraction without base separation and a stuck case. In my head I thought that RB Model did them but it seems not. But the 95mm howitzer shared a breech ring with the 25pdr, although slightly larger calibre at 95 vs 84mm. That's 0.3mm in 1/35: hardly noticeable. So I think you could get away with the cartridge cases for the 95mm, available from RB Models and AFV Club in brass and Accurate Armour in resin. The HE and smoke projectiles in the sets are also useable for 25pdr IMO, but not the HEAT rounds. Many thanks - That seems a good solution Link to comment Share on other sites More sharing options...
