First Gun Kill - Lt. Eugene Chancy VF-211 - 1/48 Hasegawa F-8E
Ray_W
Perfect timing for the STGB with Hasegawa doing the recent re-pop of their lovely 1/48 F-8E Crusader kit. I pre-ordered to ensure I snared one (wish I bought two).
F-8E WIP3
And the usual box of plastic.
F-8E WIP4
A lot of really nice decal options in the box. However, I had Furball's wonderful decal sheet MiG Masters 48-007 with markings for 26 aircraft. Printed by Cartograf. Who could resist?
F-8E WIP5
This gave me the problem of what scheme to choose. Adding the kit's 4 options gave me 30 aircraft and 1 kit. So many to choose from. I decided to go thematic rather than pretty and focus on the "Last of the Gunfighter's" only two gun kills achieved out of the total 18 (now sometimes increased to 19) kills credited during the Vietnam War . The last gun kill was an F-8C flown by LCDR Robert Kirkwood. I did not feel like back dating the E to a C so an E it must be. This leaves only one option, the first credited gun kill, LT Eugene Chancy VF-211 USS Hancock June 21, 1966.
F-8E WIP7
Just to make life interesting, I plan to throw a fair bit of resin at it. Whether I use it all will depend on how we go.
F-8E WIP9
Plus some Reskit wheels if this aircraft had the later hubs.
F-8E WIP8
The two aftermarket kits that would add to this build would be Wolfpack's Air Brake and Wing Folding kits. As rare as the original Hasegawa kit. Yes, can be tracked down, but expensive. I'll probably scratch-build these additions. The air brake is a must. Always seems to be cracked open when the aircraft is at rest.
Now, looking forward to the starting gun.
Ray
Have checked on how well the resin parts fit?  I'm just thinking about the usual fit of Aires resin parts and the amount of sanding and fettling that's usually involved. :unsure:
Bob, highly likely. I'll do some investigation this weekend. I plan to cut off the casting blocks and go through my usual dry-fit regime. We will see.
I've  got much of the same resin for mine ,sorry but  you'll  be my Guinea pig for the fit  of that if you dont mind ray🤗
No problem. Hopefully some learning from my trials and tribulations, and entertaining at least.
Ray
I was deciding how to fabricate the wing fold mechanism and then noticed a new entrant Mini Craft Collection offer it as an aftermarket solution.
The parts look excellent by these images:
F-8E WIP11
F-8E WIP10
The 48ers have them in stock. Promptly ordered. Hopefully they're OK. Irrespective, so long as they arrive in time, they will provide the raw material for a far better rendition than I could do.
Ray
58 minutes ago, modelling minion said:
Those wing fold parts do look very nice Ray, I shall have to look into getting hold of a set of them for myself.
Hi Craig,
I was really happy to be find this set. Not having a satisfactory solution to the wing fold was taking a little shine off the project. I am confident of scratchbuilding a reasonable air brake and interior. Not so much the wing fold due to its small size and complexity. Now I have a solution I'm raring to go.
Ray
They do indeed look very good, there is a problem with getting them from 48ers though.  They have a minimum order value of 160 Euros to send items to the UK now that we are no longer in the EU. :facepalm:
  • Sad 1
So far I have had a look at the Aires resin cockpit set, the resin replacement cockpit does not appear to be much larger than the kit part, though to fit it to the Hasegawa fuselage all the internal detail will have to be removed.  The resin ejection seat is a nicely detailed Martin Baker Mk.7.  The resin instrument panel is the early one with a rectangular angled radar screen, this was changed later to a normal round, vertical screen.
Thanks Bob for the input. As you point out, Aires provide a very nice Mk.7. Disappointingly this beautifully detailed ejection seat is incorrect for an F-8 prior to 1970. The Mk 5A being correct for my F-8E.  I have two options - detail the Hasegawa or try and source a Mk 5. A fall back option may be a Mk 4. The Mk.5 being a US navalised Mk 4. This is today's research subject.
F-8E WIP15
 The angled square radar screen is correct for my subject.
F-8E WIP16
I decided to clean up the resin parts and see what the fit was like in anticipation of next week's start.
Aires provide a replacement nose wheel well. This involves removing the moulded plastic version from the inlet trunking and attaching the resin replacement. Here I have already cut, filed and sanded off the plastic.
F-8E WIP13
Note the tiny clevis sticking up from the wheel well. One already broken off (which I found) and I have since removed this second one to re-attach later. I also discovered no fit issues with this assembly once placed in the fuselage.
F-8E WIP14
The replacement resin part for the variable incidence wing bay also slides in nicely. Full removal of the casting block is not necessary. I just wet sanded on a 240 grit sheet and kept testing until the part slipped in. A small amount of adjustment at the front will allow the fuselage to close up.
F-8E WIP17
A similar story with the main gear wells. Full removal of the casting block is not needed. Same wet sand and test process. No change to the kit parts were necessary for the resin part to drop in. Very pleasing.
F-8E WIP18
Typical Aires, once I came to the cockpit I was wondering how much to remove and where does it locate. No instructions are given. In the end I found I had to remove the lot. Simple I suppose.
F-8E WIP19
Once I did I found everything went into position.
F-8E WIP20
And closed up. I will play with this some more to get as best fit as possible but, it's close.
F-8E WIP21
The IP coaming has no positive position so you scramble for your references to check on its location (it just touches up to the cockpit side panels). I started by leaving some of the Hasegawa moulded coaming in place but was unhappy with the transition so removed it completely. This left some gaps. The whole cockpit assembly needs to move forward about 1 mm. This will assist but the gaps will remain. I suspect Aires has the coaming correct. For example, this image shows the forward gap which will be largely hidden by the canopy and the IR sensor once is in place.
F-8E WIP12
More research needed and I will close the gaps as required.
All in all I did not need to spend too much time to tidy the parts and be ready for some serious building. Will I add the guns and refuelling probe detail? Still undecided. Time for more research and get ready for next weekend.
Ray
Eduard provided a very nice Mk 5 seat in their boxing of the Hasegawa seat, it might be available on their site.  I have no chance of finding a Vought early seat or an early spoked nose wheel for my F-8C conversion, I'm going to have to do it the old way. (Which is : Option A, ignore it.   Option B, Convert/scratch build)
I'll try Option B and if all fails, revert to Option A. :wicked:
Hi Bob, I think you will find the Eduard is also a Mk. F-7 ejection seat.
F-8E WIP22
Looks very much like a Mk. F-7 seat here:
http://www.ejectionsite.com/frame_sg.htm and select the Crusader Mk.F-7
Interestingly, Wolfpack, also use the above design and call it a Mk. 5. Looks like a Mk.7.
F-8E WIP25
And yet once you start looking into the Mk.5 you typically see a soft chute enclosed within the seat frame which continues down side of the seat.
F-8E WIP23
F-8E WIP24
Also see:
https://martin-baker.com/products/mk5-ejection-seat/
Squdron/Signal No.38 Walk Around F-8 Crusader pages 16 and 17 clearly shows the two different types. Well, three types as they show the Vought seat.
Now someone might have NAVAIR AFC-491 detailing when the Crusader changeover to the Mk. 7 occurred. Although, in my case, being 1966, I think the Mk 5 is a safer bet. And, I am still hunting for a suitable solution.
As to your 8C dilemma - aftermarket Vought ejection seat - tricky. Another option is to choose an F-8C subject after the retrofit of the Mk.5 or later Mk.7. As to the spoked nose wheel :think:  spares box? Something close? Modifiable?
Ray
The ejection seat conundrum, it was so much easier in the good old days when there was just an 'L' shaped piece of plastic.
I've had another look at my Detail & Scale book, there isn't much visual difference between the Mk.5 and the Mk.7, the main thing was the rocket pack under the seat pan which is on the Aires seat.  The other difference appears to be the parachute pack, on the Mk.5 it's in a 'soft' canvas pack, the Mk.7 has a 'hard' plastic pack with nylon cover over the top section.  Both of the seats have the parachute pack in a metal shroud, unlike on the F-4 seats where only the mk.5 seat had a metal shroud. these are the visual differences
You are similar to me in that you want to get the details correct.  You are correct, the Eduard one is a Mk.7, just better proportioned but missing the small canvas bag on the side for the seat pins.
So true.
I found just the seat I was hunting for from Sparkit and promptly ordered.
F-8E WIP26
Sparkit - a new 3D printing company. Some discussion on Britmodeller here:
They look exceptional. Hopefully receive them very soon.
Ray
26 minutes ago, modelling minion said:
Very nice work on the resin parts Ray, looks like you got a very good fit without having to resort to the use of C4, most unlike Aries.
Thanks Craig. I think one thing working in your favour is not having to try to fit a piece of resin into a thin wing. The usual resin battle. I just wish Aires gave some more detail on what to remove in the cockpit area and the required finished location so there was a little less trial and error.
That seat looks really good Ray, no such luck with my seat, I've only found a 1/32nd Vought seat, at least the photo will help me make one.
The photos of VF 84 with their flame effect F-8C's clearly show that they have the Vought seat fitted, finding out information on seat changes is difficult, Detail & Scale states that the Vought seat was fitted into early marks and was changed to the Martin Baker Mk.5 on the 144th F-8C built and re-fitted to the earlier aircraft, but no dates given.  The Mk.7 rocket equipped seat was fitted as as aircraft were updated, ie the F-8C to F-8K, F8-D to F-8H and the F-8E to F-8J.  Squadron/Signal F-8 Crusader in action states the F-8C having the Mk.5 seat from the start of that model, as the Vought seat with it's distinctive head box can be seen in photos of early F-8C aircraft we know this is incorrect.  Here is a photo showing the distinctive Vought seat head box.
Vought F8U Crusader chief production test pilot Howard Maby
34 minutes ago, Hewy said:
Good info for the resin fit ray, thanks
Glad it was of some value. Hopefully I can work out what is happening with the IP coaming before the weekend. I also tried the front canopy fit and this seems good, possibly a small amount to shave off the inside forward edge of the resin sidewalls.
I'll play with this some more and try and get everything fitting extremely well. My goal is to be able to glue everything in place in the time honoured right fuselage half and have the left fuselage side close up with no forcing and no gaps. We will see.
Ray
