WW2 Aircraft Exhaust Colour?
dr_gn
All,
Any suggestions for a good paint mix for WW2 aircraft exhausts?
It’s a kind of very dark copper / brownish black colour, over which I can apply some weathering powder to represent exhaust staining.
I’m not after a heavily weathered/corroded effect.
Thanks.
Try Tamiya XF-84 Burnt Iron
pic and caption by a @dogsbody
"Tamiya XF-84 Dark Iron and did a bit of weathering with Tamiya Pastels Burnt Red. They will need some lighter colours yet."
for worn in exhaust it's a good start, note the exhaust deposit on 2nd and 3rd exhaust here is pale, from running a lean mixture.
16804377395_ef98bef002_b.jpgSpitfire Mk. IIA, 1941. by Etienne du Plessis, on Flickr
from
https://www.flickr.com/search/?text=spitfire&user_id=8270787%40N07&view_all=1
Wartime period colour of Spitfires, a few you can see the exhaust colour well.
Exhaust start as bare steel, and then discolour, think F-100 rear fuselage.
 they will if left corrode and go more like the Spitfire.
For a fresher exhaust
I tried a mix of gunmetal and dark blue, which would make a nice party dress... then tried a Vallejo rust wash,  which made sparkly orange, so tried dulling it down with my grey wash and some hull red,  and then dabbed on some very thinned blue,  wiping off the excess each time.... which got me here,  you can add pastels to dull down and add exhaust deposits.
HTH
from
HTH
Thanks for that.
BTW I don’t think the visible parts of the exhausts would be “bare steel”, more like a type of inconel or nickel based alloy. Their heat discolouration would therefore be different from the chart.
Also remember that the fuel used, especially Allied fuel, was highly leaded, which would leave grey staining on anything to the rear of the exhaust outlets. Not black, but fairly dark grey.
Chris
Your suggestions seems good although I am not tied to any one exhaust colour because as others have said they all vary. I like to study any photos both period and current warbirds (with the usual caveats in terms of modern fuels and materials) to see what's going on and then try to replicate. I prefer working off an airbrushed black base and then use Gunze's Mr Metal Color various shades (iron, dark iron, stainless, brass, copper) airbrushed, some targeted brush painting with the same and then polish or not depending where and what I am trying to achieve. The variation you can achieve creates some nice effects quickly (but not cheaply). Then some exhaust staining depending on the subject and its environment. Here are some 1/48 examples:
Bf 109G-2 before exhaust
BG Bf-109 G2 Construction 40
PZL P.24B before exhaust
PZL P24B Construction 60
Bf-109G-14 after exhaust
BM BF-109G6 Construction 62
Spitfire Mk I before exhaust
SpitfireMkI_X4009_PatHughes_Construction_109
Spitfire Mk.VC after exhaust
Painting_Exhausts_2
Ray
Quite possibly.  It was suggestion as to ways an exhaust may appear.   You maybe able to find a more appropriate discoloration chart.
while looking for something else I spotted this in out Sea Hurricane walkround, which look to be a brand new set of exhaust pipes.
from
https://www.britmodeller.com/forums/index.php?/topic/76586-hawker-sea-hurricane/
from
Thanks. Yes it's a tricky subject  - so many variations, but if you get it wrong, it's immediately apparent!
