Sturmpanzer II - Ark Model - 1/35
Hello everyone,
First of all, this vehicle was never called Sturmpanzer II. It was also never called Bison II either, as it is sometimes referred to by model kit producers. Its official name was: 15 cm sIG 33 auf Fahrgestell Panzerkampfwagen II (Sf).
It was developed as a response to the need to provide heavy artillery support in the environment of highly mobile warfare. Panzer II was selected to fit the 15cm sIG 33 heavy artillery gun. This proved to be a big challenge, never to be solved completely and adequately. The prototype was first tested at Kummersdorf on 13 June 1940. Panzer II chassis was modified, by lengthening and adding one more axel (which helped to absorb recoil forces better and reduce the chance of tipping over) and widened by 40cm, which made more space for the crew. It was still very crowded and hard to operate, and only 10 rounds could be stored inside. The engine was not adequate for the increased weight and engine cooling was not adjusted for desert conditions.
Alkett completed seven 15 cm sIG 33 auf Fahrgestell Panzerkampfwagen II (Sf) in December 1941 and five in January 1942. They were all sent to Africa and assigned to 707.schwere Infanteriegeschütze-Kompanien. and 708. schwere Infanteriegeschütze-Kompanien. Both of these regiments were part of Rommel’s 90. Leichte Afrika-Division and fought until the Axis surrender in Tunisia in May 1943. Vehicles were arriving in Libyia between February and April 1942 and were plagued by all kinds of problems. The engine could only run for very short periods of time without overheating, sand was thrown by the tracks into the engine air intake and the engine would constantly break. And there were no spare parts delivered. Basically, the vehicle was a disaster, they just added additional weight to the gun so it was hard to move it around. All 12 vehicles were present in the El Alamain battles, where half of them were lost, and the remaining 6 fought until the end of the war, surrendering in Tunisian in May 1943.
1
2
3
4
Ark Model kit is the same disaster as the vehicle itself :)
I will not grudge about it here... you can check my WIP thread if you are interested to see all the problems with the kit, but basically, it is really hard to build it into something decent without a fair amount of fixing, scratch-building, and AM parts. However, I must say that I enjoyed building it and fixing all the issues on some strange level :)
Accuracy-wise, I can not comment much, I didn't want to check the dimensions, because I couldn't do much about it anyway.
5
6
I used plenty of AM parts of this one. Friul tracks, Eduard PE set, Aber barrel and aerials, AFV Club ammo, and some additional Panzer Art, TMD, and Value Gear stuff. So basically I turned cheapest model I ever bought into the most expensive build :facepalm:
7
8
9
10
The model is painted with a combination of Gunze, MRP, Tamiya, and Vallejo paints and weathered with Mig's pigments. The Interior and sIG 33 gun are a bit better detailed compared to the rest of the vehicle. Here are some shots:
11
12
And here are some detailed shots, mostly of the stowage:
13
14
Thank you all for watching and for your support in my WIP thread.
Nenad
  • Like 45
  • Thanks 5
Nenad,
Very nicely done. The finish and weathering is spot on, neither too little nor too much.  And the tracks look good too with the right amount of sag.
Builds like this are often the most enjoyable, providing a great deal of satisfaction when complete. Building and making, not just assembling.
cheers, Graham
Nice job!  👌
It's an unusual AFV, finished to a high standard!
Keith 😁
The build of the model and the painting/weathering are superb, but that's what I expect from one of your builds Nenad. Brilliant work.
John.
Hi Nenad,
Top notch model, quite a winner!
I realize that the color is very different from what was seen in the WIP compared to what is now shown in the RFI. I personally like the latter more.
Cheers and TC
Francis,👍
It seems everyday, this Forum throws up yet another weird/wonderful German armour subject that I've yet to encounter. Thanks for this latest lesson.
It's wonderfully put together, your painting/weathering is superb, and it's very nicely photographed. Thanks for sharing.
Regards
Pete
Brilliant result! You’ve turned a terrible kit of a terrible tank into a wonderful model of a terrible tank-well done! Superb build, and great painting and weathering as usual.
Wow! Despite all the difficulties, that turned out exceptionally well! Very well done. :thumbsup:
Kind regards,
Stix
OMG that's an ugly beast!
Absolutely makes me want to build something like this myself.
The weathering and the finish is absolutely stunning.
And the overall feel it has in it.
Pure wow!
Kristjan
Thank you all for your kind words. You are so kind.  :thanks:
I toned it down quite a bit at the end by spraying the diluted pigments to simulate dust. It also helps a lot to blend everything together.
Also, I was taking photos for the WIP section with my phone, which produces photos with over-saturated colors. Which makes them look happier, but the colors are not realistic. Photos for RFI were taken with a DSLR camera, which produces much more realistic colors, with the white balance being corrected.
