Hasegawa 1/48 F-4B
Inspired choice Stefan, especially in 1/48, my only worry is with the GB finishing in July, will you have enough time left to get all the decals on ? :whistle:
Good luck with this one
Cheers Pat
Built one of these when they were first release with Microscale decals for VF-102 with full stencil data!
USN/USMC F-4s are still one of my favourite jets/modelling subjects despite not having built one in years, having an Academy J and Tamiya B in the loft....
Edited by Threadbear
  • 3 months later...
Hi, Pat.
Thanks for asking.
The last couple of months, I have spent practically no time  modelling. Work, matters around the house that needed to be taken care of, etc...
It wasn't all gloom though, some were pre-planned fun outdoor activities.
I'm hoping to get back into it, but I must limit myself a bit in what I take on. I considered a 1/32 AH-1G for the large scale GB, but that's not going to happen.
The F-4B is actually  the best candidate to get built in time. Some work was done on it already, I sprayed a bit of white when I did the missiles for my Marineflieger F-104's. And I should have some time to work on it before the dead-line.
Cheers, Stefan.
Hi,
This build will be mostly out of the box.
The cockpit got some Furball decals.
I've also added a side panel on the starboard side of the rear cockpit. Hasegawa has such a panel in the F-4J kit, but at the time of the F-4B kit they apparantly didn't know about this.
There are two such panels in the Zoukei Moira F-4J and F-4S kits (one for each type), so I got one from there.
Cheers, Stefan.
Hi,
This morning, I noticed that "Part 2 Hardener" of my two-component white by Mr Paint had become goo inside its bottle. I thought I had closed it tightly enough, but...
I was able to get a couple of semi-fluid drops out of it and mixed them with "Part 1 Paint". It sprayed on beautifully, maybe it will take longer to harden.
Cheers, Stefan.
Hi,
As you probably expected, this is another one that will not be finished in time.
I can't blame the issue with the paint, even without that I would have run out of time.
The paint looks good, but I'm going to leave it a long time to harden. To use up the remainder my "Part 1 Paint" bottle, I think I'll use it on missiles and droptanks that I can set aside for a long time.
I like this old Hasegawa classic and hope to how it here in about a month or so.
Cheers, Stefan.
